NRF9161 based LTE-M tracker data drops while moving – can it be optimized?
Hi everyone,
I’m using a custom board (a tracker) that can travel at speeds up to 65 km/h and transmits data regularly every 200 ms. I expect, therefore, that the inactivity timer should not be activated. While the device is in motion, I’m seeing intermittent data gaps ranging up to several seconds, which is unacceptable for our application.
Could this be caused by non-optimal cell-handover settings? I’ve attached a few logs below for reference.
Any suggestions would be greatly appreciated.
Martin
Three log fragments examples, related to data send drops:
17:31:57.179 +CSCON: 0
17:31:57.230 <inf> main: RRC mode: Idle
17:31:57.276 +CEREG: 1,"04D3","0DBC2351",7,,,"11100000","11100000"
17:31:57.298 <inf> main: Cell update, cell tac: 1235, cell id: 230433617
17:31:57.371 +CSCON: 1
17:31:57.429 <inf> main: RRC mode: Connected
17:31:57.539 +CSCON: 0
17:31:57.568 <inf> main: RRC mode: Idle
17:31:57.907 +CSCON: 1
17:31:57.926 <inf> main: RRC mode: Connected
17:37:54.095 +CEREG: 1,"04D3","0DC18750",7,,,"11100000","11100000"
17:37:54.154 [00:54:10.770,263] <inf> main: Cell update, cell tac: 1235, cell id: 230786896
17:38:05.373 +CEREG: 1,"04D3","0DDD4350",7,,,"11100000","11100000"
17:38:05.434 <inf> main: Cell update, cell tac: 1235, cell id: 232604496
Modem firmware: mfw_nrf91x1_2.0.2
Current 9161 modem initiation sequence is:
AT+CFUN=0
AT%XSYSTEMMODE=1,0,0,0
AT+CPSMS=0
AT+CEDRXS=0
AT%RAI=0
AT+CSCON=1
AT+CEREG=5
AT+CFUN=1
  • Hi Martin,
    marsal said:
    In general, my question would be if the described settings are OK and/or what could be done more.
    Connection re-establishment is triggered due to sync loss to serving cell (T310 expiry). This is normal operation for moving UE. Data paths are suspended for time of connection re-establishment. Parameters which control re-establishment are given by the network. There is nothing which could be done from UE side to avoid this interruption. You could contact the carrier regarding network support for LTE-M handover.
    Dejan
