nRF52832, SDK17.1, s132
I work with SPI and it works on the this project with SDK15.
But I have transferred this prj to the SDK17.1 and I can't make SPI work.
I don't get
spi_event_handler
where I set
spi_xfer_done
flag.
here are my code with SPI init
#include <lis3dh.h>
#include <nrf_gpio.h>
#include "nrf_drv_spi.h"
#include "nrf_log.h"
#include "nrf_delay.h"
#include "logic.h"
#define CTRL_REG1 0x20
#define CTRL_REG2 0x21
#define CTRL_REG3 0x22
#define CTRL_REG4 0x23
#define CTRL_REG5 0x24
#define CTRL_REG6 0x25
#define INT1_CFG 0x30
#define INT1_SRC 0x31
#define INT1_THS 0x32
#define INT1_DUR 0x33
#define LIS3DH_READ_MSK 128
#define LIS3DH_WRITE_MSK 0
#define SPI_INSTANCE 0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
static uint8_t m_tx_buf[2]; /**< TX buffer. */
static uint8_t m_rx_buf[2]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf); /**< Transfer length. */
uint8_t lis_spi_error;
* @brief SPI user event handler.
* @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
void * p_context)
spi_xfer_done = true;
// NRF_LOG_INFO("Transfer completed.");
if (m_rx_buf[0] != 0)
NRF_LOG_INFO(" Received:");
// NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
static __INLINE uint8_t lis3dh_spi_read_write(const uint8_t reg, const uint8_t data)
// uint8_t rx_buffer[2], tx_buffer[] = { reg, data };
m_tx_buf [0] = reg;
m_tx_buf [1] = data;
spi_xfer_done = false;
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
while (!spi_xfer_done)
__WFE();
return m_rx_buf[1];
uint8_t lis3dh_read(const uint8_t reg)
return lis3dh_spi_read_write(reg | LIS3DH_READ_MSK, 0xAA);
void lis3dh_write(const uint8_t reg, const uint8_t data)
lis3dh_spi_read_write(reg | LIS3DH_WRITE_MSK, data);
void lis3dh_init(void)
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = SPI_SS;
spi_config.miso_pin = SPI_MISO;
spi_config.mosi_pin = SPI_MOSI;
spi_config.sck_pin = SPI_SCK;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
lis3dh_write(CTRL_REG1, 0x2F); // low power mode, 1Hz (0x2F = 10 Hz)
lis3dh_write(CTRL_REG2, 0x01); // high pass filter enabled for AOI1
lis3dh_write(CTRL_REG3, 0x40); // AOI1 interrupt on INT1
lis3dh_write(CTRL_REG4, 0x80); // BDU, full scale = +-2g
lis3dh_write(CTRL_REG5, 0x00);
lis3dh_write(INT1_THS, 2); // threshold * 15.625 (mg)
lis3dh_write(INT1_DUR, 1); // duration * 1 (s)
lis3dh_write(INT1_CFG, 0x15); // X Or Y Or Z low events
if (lis3dh_read(CTRL_REG1) != 0x2F)
lis_spi_error = 10;
// nrf_drv_spi_uninit(&spi);
And sdk_config.h where I set for SPI
What possible reason?
Thanks.
