AES CBC (or EBC) on nRF52832 & nRF54L05
So I need to decrypt a single 16 byte block of data using AES128 and a pre-shared key on the above SoCs. But PSA doesn't seem to work (I'm currently working using the nRF52DK). Even the AES CBC example application fails with an error when I run it
Booting nRF Connect SDK v2.9.0-7787b2649840 ***
*** Using Zephyr OS v3.7.99-1f8f3dc29142 ***
[00:00:00.265,533] <inf> aes_cbc: Starting AES-CBC-NO-PADDING example...
[00:00:00.265,594] <inf> aes_cbc: Generating random AES key...
[00:00:00.265,625] <inf> aes_cbc: psa_generate_key failed! (Error: -141)
[00:00:00.265,625] <inf> aes_cbc: Example exited with error!
I notice there is a config option CONFIG_MBEDTLS_LEGACY_CRYPTO_C, but the description suggests it's not a great option
Enable support for legacy mbed TLS APIs.
Note that this is a configuration that may be removed at some point.
It is only provided during a transition period while PSA Crypto APIs become
the defacto front-end. Enabling this will enable nrf_oberon for all features that
are supported and builtin for the remaining functionality.
Any advice on the way forward?
  • No I haven't commented out anything! That is exactly how the sample project was delivered (apart of course from the lines appended as you suggested).
    Edit: Here is the prj.conf after deleting the old folders and creating another new application from the sample (no build, nothing)
    # Copyright (c) 2024 Nordic Semiconductor ASA
    # The Zephyr CMSIS emulation assumes that ticks are ms, currently
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=1000
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_HEAP_MEM_POOL_SIZE=4096
    # Enable logging
    CONFIG_CONSOLE=y
    CONFIG_LOG=y
    # Enable nordic security backend and PSA APIs
    #CONFIG_NRF_SECURITY=y
    #CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    #CONFIG_PSA_WANT_GENERATE_RANDOM=y
    #CONFIG_PSA_WANT_KEY_TYPE_AES=y
    #CONFIG_PSA_WANT_ALG_CBC_NO_PADDING=y
    CONFIG_NORDIC_SECURITY_BACKEND=y
  • You have commented out configs that are needed and that are used in the sample here. The configs you have commented your last post should be uncommented. Specifically, these:
  • OK so I have no idea how this happened - but I checked my ncs folder from where the samples are copied and the lines were commented. So I re-downloaded ncs 2.9.0 and replaced the aes-cbc folder entirely from Github and it's as it should be. Weird, as I've only used the "copy a sample" method from within VCS?
    So anyway now it runs :) Apologies for the hassle.
    For a pre-shared key do I generate a key using psa_import_key() ?
    I am glad to hear you got it working. Yes, you import an existing key using psa_import_key(). You can see an example of importing an AES key here (generally, you specify key type and uses as astributs you provide to the call together with the raw key).
