No target "run" in since nrf sdk 2.9.0
I used to be working with the nrf sdk 2.7.0. For running unit tests for my project I build and run the unit test application for qemu_cortex_m3 like this:
west build --build-dir ./tests/fusa_api/build ./tests/fusa_api -b qemu_cortex_m3 -t run
For some reason, since I updated to nrf sdk 2.9.0 the build output tells me that no "run" target has been created.
Can anyone tell me what I need to do here?
Log output:
Setting ZEPHYR_BASE to "C:/ncs/v2.9.0/zephyr"
Setting ZEPHYR_TOOLCHAIN_VARIANT to "zephyr"
Setting CMAKE_PREFIX_PATH to "C:/ncs/toolchains/b620d30767/opt"
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/Brose/hecketo/EE/git/project/.venv/Scripts/python.exe (found suitable version "3.12.9", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.9.0/zephyr/.cache
-- Found west (found suitable version "1.3.0", minimum required is "0.14.0")
-- Board: qemu_cortex_m3, qualifiers: ti_lm3s6965
Parsing C:/ncs/v2.9.0/zephyr/share/sysbuild/Kconfig
Loaded configuration 'C:/user/hecketo/EE/git/project/tests/fusa_api/build/_sysbuild/empty.conf'
Merged configuration 'C:/user/hecketo/EE/git/project/tests/fusa_api/build/_sysbuild/empty.conf'
Configuration saved to 'C:/user/hecketo/EE/git/project/tests/fusa_api/build/zephyr/.config'
Kconfig header saved to 'C:/user/hecketo/EE/git/project/tests/fusa_api/build/_sysbuild/autoconf.h'
* Running CMake for fusa_api *
-- Application: C:/user/hecketo/EE/git/project/tests/fusa_api
-- CMake version: 3.24.2
-- Using NCS Toolchain 2.8.20241119.782234748775 for building. (C:/ncs/toolchains/b620d30767/cmake)
-- Found Python3: C:/ncs/toolchains/b620d30767/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.8") found components: Interpreter
-- Zephyr version: 3.7.99 (C:/ncs/v2.9.0/zephyr)
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/b620d30767/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/b620d30767/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.9.0/zephyr/boards/qemu/cortex_m3/qemu_cortex_m3.dts
-- Generated zephyr.dts: C:/user/hecketo/EE/git/project/tests/fusa_api/build/fusa_api/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/user/hecketo/EE/git/project/tests/fusa_api/build/fusa_api/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: C:/user/hecketo/EE/git/project/tests/fusa_api/build/fusa_api/zephyr/dts.cmake
Parsing C:/user/hecketo/EE/git/project/tests/fusa_api/Kconfig
Loaded configuration 'C:/ncs/v2.9.0/zephyr/boards/qemu/cortex_m3/qemu_cortex_m3_defconfig'
Merged configuration 'C:/user/hecketo/EE/git/project/tests/fusa_api/prj.conf'
Merged configuration 'C:/user/hecketo/EE/git/project/tests/fusa_api/build/fusa_api/zephyr/.config.sysbuild'
Configuration saved to 'C:/user/hecketo/EE/git/project/tests/fusa_api/build/fusa_api/zephyr/.config'
Kconfig header saved to 'C:/user/hecketo/EE/git/project/tests/fusa_api/build/fusa_api/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Setting build type to 'MinSizeRel' as none was specified.
-- Generating test runner C:/user/hecketo/EE/git/project/tests/fusa_api/build/fusa_api/runner/runner_main.c
-- Configuring done
-- Generating done
-- Build files have been written to: C:/user/hecketo/EE/git/project/tests/fusa_api/build/fusa_api
-- Configuring done
-- Generating done
←[92m-- west build: running target run
←[0mninja: error: unknown target 'run', did you mean 'all'?
FATAL ERROR: command exited with status 1: 'C:\Program Files\T_cygwin~VRR1\T_cygwin\opt\cmake\bin\cmake.EXE' --build C:/user/hecketo/EE/git/project/tests/fusa_api/build --target run
BR, Tom
