Bootloader dfu
HI, I have to implement buttonless bootloader.I am having simple doubt.I am programming softdevice,application(Hrs example with bootloader),bootloader hex file using nrfgostudio one by one in the following sequence.I am having doubt whether it should be in application or bootloader mode.But my device is in bootloader mode and advertising as DfuTarg.But i want to be in application mode.After enabling the dfu service it should go to Bootloader mode and after that i can do DFU.I am compiling the program using eclipse gcc. My sdk version 9.0.0 sd s130.
Parents Reply
  • Another approach is to set the flag using nrfjprog after programming SD+BL+APP:
    nrfjprog --memwr 0x3FC00 --val 1
    nrfjprog -r
    You can use read the memory afterwards to confirm that the flag is set:
    nrfjprog --memrd 0x3FC00 // should return 1 for both mentioned methods
