NVS is erased after OTA
We have a product which is based on nrf52840 and nrf connect sdk 2.8.0
After OTA sometimes, I find that the NVS is erased, which could lead to some issues on client side.
Here is the content of pm_static file
app:
  address: 0xc200
  end_address: 0x85000
  region: flash_primary
mcuboot:
  address: 0x0
  end_address: 0xc000
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0xc000
  end_address: 0xc200
  placement:
    align:
      start: 0x1000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0xc000
  orig_span: &id001
  - app
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0xc200
  orig_span: &id002
  - app
  span: *id002
mcuboot_secondary:
  address: 0x85000
  end_address: 0xfe000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
  share_size:
  - mcuboot_primary
settings_storage:
  address: 0xfe000
  end_address: 0x100000
  placement:
    align:
      start: 0x1000
    before:
    - end
sram_primary:
  address: 0x20000000
  end_address: 0x20040000
  region: sram_primary
and on the overlay file we have
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x000000000 0x0000C000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000C000 0x00067000>;
		slot1_partition: partition@73000 {
			label = "image-1";
			reg = <0x00073000 0x00067000>;
		scratch_partition: partition@da000 {
			label = "image-scratch";
			reg = <0x000da000 0x0001e000>;
		 * The flash starting at 0x000f8000 and ending at
		 * 0x000fffff is reserved for use by the application.
		 * Storage partition will be used by FCB/LittleFS/NVS
		 * if enabled.
		storage_partition: partition@f8000 {
			label = "storage";
			reg = <0x000f8000 0x00008000>;
on proj.conf
# Enable mcumgr.
CONFIG_MCUMGR=y
# Ensure an MCUboot-compatible binary is generated.
CONFIG_BOOTLOADER_MCUBOOT=y
# Enable FOTA over BLE
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
CONFIG_SECURE_BOOT=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# This is enabled only in prodcution, but will limit debugging and breakpoints
# CONFIG_DISABLE_FLASH_PATCH=y # already defined in mcuboot.conf
# Enable the Bluetooth (unauthenticated) and shell mcumgr transports.
CONFIG_BT_SMP=y
CONFIG_ZCBOR=y
CONFIG_STREAM_FLASH=y
CONFIG_MCUMGR_TRANSPORT_BT=y
CONFIG_MCUMGR_TRANSPORT_BT_PERM_RW=n
CONFIG_MCUMGR_TRANSPORT_BT_CONN_PARAM_CONTROL=y
CONFIG_MCUMGR_GRP_IMG=y
CONFIG_MCUMGR_GRP_OS=y
# Enable MCUmgr Packet Reassembly feature over Bluetooth and its
# configuration dependencies. MCUmgr buffer size is optimized to fit one SMP
# packet divided into five Bluetooth Write Commands, transmitted with the
# maximum possible MTU value: 498 bytes.
CONFIG_MCUMGR_TRANSPORT_BT_REASSEMBLY=y
CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=2475
CONFIG_MCUMGR_GRP_OS_MCUMGR_PARAMS=y
# Enable custom SMP request to erase settings partition.
CONFIG_MCUMGR_GRP_ZBASIC=n
CONFIG_MCUMGR_GRP_ZBASIC_STORAGE_ERASE=y
CONFIG_MCUMGR_GRP_OS_ECHO=y
CONFIG_MCUMGR_GRP_OS_INFO=y
