Facing the issue while working on ST7789v with Nrf52840.
Hi , am developing the st7789v_minimal_sample application using Nrf52840. after creating minimal application am facing some unrecognisable issue. which am stuck can you please suggest me how to resolve it ? or where am going wrong? my nrf52840dk_nrf52840.overlay & proj.conf & Cmakelists.txt is as follows . and attaching the build issue for your reference.
 nrf52840dk_nrf52840.overlay:
    chosen {
        zephyr,display = &st7789v;
#include <zephyr/dt-bindings/mipi_dbi/mipi_dbi.h>
    mipi_dbi: mipi_dbi@0 {
        compatible = "zephyr,mipi-dbi-spi";
        dc-gpios = <&gpio0 20 GPIO_ACTIVE_HIGH>;
        reset-gpios = <&gpio0 18 GPIO_ACTIVE_LOW>;
        spi-dev = <&st7789v>;
        reg = <0 1>; //  Fix here
        spi-max-frequency = <8000000>;
        #address-cells = <1>;
        #size-cells = <0>;
        status = "okay";
        st7789v: st7789v@0 {
            compatible = "sitronix,st7789v";
            reg = <0>;
            status = "okay";
            width = <240>;
            height = <240>;
            pixel-format = "rgb565";
            x-offset = <0>;
            y-offset = <80>;
            mipi-mode = <2>; // 4-wire SPI
            gctrl = <0x35>;
            vcom = <0x19>;
            vrhs = <0x12>;
            vdvs = <0x20>;
            mdac = <0x00>;
            lcm = <0x2c>;
            colmod = <0x05>;
            gamma = <0x01>;
            porch-param = [0C 0C 00 33 33];
            cmd2en-param = [5A 69 02 01];
            pwctrl1-param = [A4 A1];
            pvgam-param = [D0 04 0D 11 13 2B 3F 54 4C 18 0D 0B 1F 23];
            nvgam-param = [D0 04 0C 11 13 2C 3F 44 51 2F 1F 1F 20 23];
            ram-param = [00 F0];
            rgb-param = [CD 08 14];
&spi2 {
    status = "okay";
    sck-pin = <15>;
    mosi-pin = <13>;
    cs-gpios = <&gpio0 17 GPIO_ACTIVE_LOW>;
Proj.conf:
# Logging
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
# Display framework
CONFIG_DISPLAY=y
CONFIG_DISPLAY_LOG_LEVEL_DBG=y
# ST7789V driver via MIPI-DBI SPI interface
CONFIG_MIPI_DBI=y
CONFIG_MIPI_DBI_SPI=y
#CONFIG_SITRONIX_ST7789V=y
#CONFIG_SITRONIX_ST789V_RGB565=y
CONFIG_ST7789V=y
CONFIG_ST7789V_RGB565=y
# SPI & GPIO drivers
CONFIG_SPI=y
CONFIG_SPI_NRFX=y
CONFIG_GPIO=y
Cmakelists.txt:
cmake_minimum_required(VERSION 3.20.0)
set(DTC_OVERLAY_FILE boards/nordic/nrf52840dk_nrf52840.overlay)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(st7789v_display_example)
target_sources(app PRIVATE src/main.c)
zephyr_library_include_directories(drivers/display)
