ERROR 1813 [Unknown error code] at KGJ`hóˆ@h:536871936 PC at: 0x0001505C
I am using the nRF52840 with nRF-SDK version 16.0.
At random intervals, I encounter the following error:
"[00:02:51.009,460] <error> app: ERROR 1813 [Unknown error code] at KGJ`hh:536871936 PC at: 0x0001505C".
This issue appears to be the same as one previously reported-here, but that ticket did not provide any helpful details.
Could you please explain under what conditions this error occurs? It would help me narrow down the source of the problem in my code.
Thank you,
Shreya
    The issue is still getting reproduced even after setting the SPI interrupt priorities to 6. We have configured the interrupt priorities to 6 in sdk_config.h and are no longer setting them explicitly. However, when I logged the IRQ priorities using NVIC_GetPriority(irq), I noticed that many IRQs still have different priorities. Am I checking this incorrectly?
    I’ve attached the logged IRQ priorities for your reference.
    00> [00:04:26.582,336] <info> app: Logging all IRQ priorities:
    00> [00:04:26.582,458] <info> app: IRQ 0 (POWER_CLOCK_IRQn): priority 4
    00> [00:04:26.582,580] <info> app: IRQ 1 (RADIO_IRQn): priority 0
    00> [00:04:26.582,702] <info> app: IRQ 2 (UARTE0_UART0_IRQn): priority 0
    00> [00:04:26.582,885] <info> app: IRQ 3 (SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQn): priority 0
    00> [00:04:26.583,007] <info> app: IRQ 4 (SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQn): priority 6
    00> [00:04:26.583,190] <info> app: IRQ 5 (NFCT_IRQn): priority 0
    00> [00:04:26.583,312] <info> app: IRQ 6 (GPIOTE_IRQn): priority 6
    00> [00:04:26.584,411] <info> app: IRQ 7 (SAADC_IRQn): priority 6
    00> [00:04:26.584,594] <info> app: IRQ 8 (TIMER0_IRQn): priority 0
    00> [00:04:26.586,730] <info> app: IRQ 9 (TIMER1_IRQn): priority 0
    00> [00:04:26.586,853] <info> app: IRQ 10 (TIMER2_IRQn): priority 0
    00> [00:04:26.586,975] <info> app: IRQ 11 (RTC0_IRQn): priority 0
    00> [00:04:26.587,097] <info> app: IRQ 12 (TEMP_IRQn): priority 0
    00> [00:04:26.587,219] <info> app: IRQ 13 (RNG_IRQn): priority 4
    00> [00:04:26.587,402] <info> app: IRQ 14 (ECB_IRQn): priority 4
    00> [00:04:26.588,500] <info> app: IRQ 15 (CCM_AAR_IRQn): priority 4
    00> [00:04:26.588,623] <info> app: IRQ 16 (WDT_IRQn): priority 0
    00> [00:04:26.590,759] <info> app: IRQ 17 (RTC1_IRQn): priority 6
    00> [00:04:26.590,942] <info> app: IRQ 18 (QDEC_IRQn): priority 0
    00> [00:04:26.591,064] <info> app: IRQ 19 (COMP_LPCOMP_IRQn): priority 0
    00> [00:04:26.591,186] <info> app: IRQ 20 (SWI0_EGU0_IRQn): priority 0
    00> [00:04:26.591,308] <info> app: IRQ 21 (SWI1_EGU1_IRQn): priority 6
    00> [00:04:26.592,468] <info> app: IRQ 22 (SWI2_EGU2_IRQn): priority 6
    00> [00:04:26.592,590] <info> app: IRQ 23 (SWI3_EGU3_IRQn): priority 0
    00> [00:04:26.594,726] <info> app: IRQ 24 (SWI4_EGU4_IRQn): priority 0
    00> [00:04:26.594,909] <info> app: IRQ 25 (SWI5_EGU5_IRQn): priority 4
    00> [00:04:26.595,031] <info> app: IRQ 26 (TIMER3_IRQn): priority 0
    00> [00:04:26.595,153] <info> app: IRQ 27 (TIMER4_IRQn): priority 0
    00> [00:04:26.595,275] <info> app: IRQ 28 (PWM0_IRQn): priority 0
    00> [00:04:26.596,435] <info> app: IRQ 29 (PDM_IRQn): priority 0
    00> [00:04:26.596,557] <info> app: IRQ 30 (Reserved (30)): priority 0
    00> [00:04:26.599,853] <info> app: IRQ 32 (MWU_IRQn): priority 1
    00> [00:04:26.599,975] <info> app: IRQ 33 (PWM1_IRQn): priority 0
    00> [00:04:26.600,097] <info> app: IRQ 34 (PWM2_IRQn): priority 0
    00> [00:04:26.600,219] <info> app: IRQ 35 (SPIM2_SPIS2_SPI2_IRQn): priority 0
    00> [00:04:26.600,402] <info> app: IRQ 36 (RTC2_IRQn): priority 6
    00> [00:04:26.600,524] <info> app: IRQ 37 (I2S_IRQn): priority 0
    00> [00:04:26.600,646] <info> app: IRQ 38 (FPU_IRQn): priority 0
    00> [00:04:26.600,769] <info> app: IRQ 39 (USBD_IRQn): priority 0
    00> [00:04:26.602,905] <info> app: IRQ 40 (UARTE1_IRQn): priority 0
    00> [00:04:26.603,027] <info> app: IRQ 41 (QSPI_IRQn): priority 0
    00> [00:04:26.603,210] <info> app: IRQ 42 (CRYPTOCELL_IRQn): priority 0
    00> [00:04:26.603,332] <info> app: IRQ 43 (Reserved (43)): priority 0
    00> [00:04:26.604,492] <info> app: IRQ 44 (Reserved (44)): priority 0
    00> [00:04:26.604,614] <info> app: IRQ 45 (PWM3_IRQn): priority 0
    00> [00:04:26.604,736] <info> app: IRQ 46 (Reserved (46)): priority 0
    00> [00:04:26.606,872] <info> app: IRQ 47 (SPIM3_IRQn): priority 0
    This list looks sensible. Some are set to 1 and 4, and those are used by the SoftDevice. Regarding thouse with priority 0 it is difficult to say. To be sure, you could also check with NVIC_GetEnableIRQ() to see if interrupts are enabled? (or do you see any with priority 0 that you use dierectly, and not via the SoftDevice)?
    If this is all good, maybe we need to look elsewhere. I see interested in configurations that affect scheduling, such as NRF_SDH_BLE_GAP_EVENT_LENGTH.
    Thanks for your input. I checked the enabled IRQs using NVIC_GetEnableIRQ(), and all enabled interrupts appear correctly configured for our application. So, from the IRQ priority perspective, everything seems fine.
    Could you please help me debug further? Regarding NRF_SDH_BLE_GAP_EVENT_LENGTH Currently, it is set to 7.5 ms.
     Our connection parameters are as follows:
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(30, UNIT_1_25_MS)
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(40, UNIT_1_25_MS)
    #define SLAVE_LATENCY                   5
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(10000, UNIT_10_MS)
    What should I check or adjust related to NRF_SDH_BLE_GAP_EVENT_LENGTH or other BLE scheduling parameters?
    I see.
    Can you try increasing NRF_SDH_BLE_GAP_EVENT_LENGTH (for instance doubling it) as an experiment? Also, what is the LF clock source configuration? Does configuring a lower accuracy (higher ppm) value make a difference?
  • Can you try increasing NRF_SDH_BLE_GAP_EVENT_LENGTH (for instance doubling it) as an experiment?
    Sure, I will try.
    We are currently using:
    NRF_SDH_CLOCK_LF_ACCURACY          NRF_CLOCK_LF_ACCURACY_20_PPM
    NRF_SDH_CLOCK_LF_SRC               NRF_CLOCK_LF_SRC_XTAL
    NRF_SDH_CLOCK_LF_RC_CTIV           0
    NRF_SDH_CLOCK_LF_RC_TEMP_CTIV      0
    As an experiment, I’ll change the accuracy to NRF_CLOCK_LF_ACCURACY_100_PPM and observe if it makes any difference.
    I’ll share the results once I’ve tested this.
