I installed NRF connect
I successfully built project
when I flash I get success, but actually I can see project is not flashed
what and how can I debug that ?
What sample are you programming to the board? Have you tried a simple sample such as blinky, are you able to flash that sucessfully?
You should also specify if you are using a development kit or custom board,
regards
Jared
yes, I tried even with blinky, same result. I am using the Nordic EVB
What board are you building for? Can you share the exact name?
Can you share a screenshot of VS code that shows your build configuration and that the board is flashed successfully?
regards
Jared
