Hi all,
I've build a custom bord with an nRF9151, I try to connect to aws iot but it's seems it's doesn't work probably cause by bad cert, I got AWS_IOT_EVT_DISCONNECTED. Something strange if I list my cert with AT command:
AT%CMNG=1 %CMNG: 88,0,"XXXXXXX" %CMNG: 88,1,"XXXXXXX" %CMNG: 88,2,"XXXXXXX" %CMNG: 4294967292,11,"XXXXXXX" %CMNG: 4294967293,10,"XXXXXXX" %CMNG: 4294967294,6,"XXXXXXX" OK
I can see my certs, I want to use certs with secure tag 88. So if I understand well, my certs are ok but in my main if I try to check my certs with
modem_key_mgmt_exists(88, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, &exists); modem_key_mgmt_exists(88, MODEM_KEY_MGMT_CRED_TYPE_PUBLIC_CERT, &exists); modem_key_mgmt_exists(88, MODEM_KEY_MGMT_CRED_TYPE_PRIVATE_CERT, &exists);
exists is always false and I always got
<wrn> modem_key_mgmt: Failed to retrieve CMEE status, err -1
EDIT: ok I have my certs right now, but it's doesn't work, it's look like I'm never really connected to LTE. I'm using onomondo eSIM, but juste before trying coonecting to AWS I got:
+CSCON: 1 [00:14:05.313,873] <inf> GCG_DNV: RRC mode: Connected +CSCON: 0 [00:14:05.314,086] <inf> GCG_DNV: RRC mode: Idle [00:14:05.314,147] <inf> GCG_DNV: Connecting to AWS IoT [00:14:10.655,700] <inf> GCG_DNV: AWS_IOT_EVT_DISCONNECTED [00:14:10.655,792] <err> mqtt_helper: Cloud MQTT input error: -128
If I understand well, +CSCON :0 my modem is inactive, is it right ? As soon as I'm coonected I go to iIdle state 200ms between changing state
