I'm encountering a blocking issue when trying to create a new board using the NCS Board Wizard in VS Code with Nordic Connect SDK v3.0.0. After filling in valid inputs and clicking "Create Board", the wizard fails with the following error output:
The traceback points to the ncs_create_board.py
script attempting to parse a malformed JSON schema response. This happens consistently regardless of board name, vendor name formatting, or SoC choice.
I’ve verified that all inputs match the required schema constraints (e.g., vendor name without spaces, valid SoC, etc.), but the issue persists. It appears to be an internal bug in the wizard’s JSON generation or handling.
I am currently using:
Nordic SDK: v3.0.0
Toolchain: v3.0.0 (Windows)
VS Code Plugin: nRF Connect for VS Code
Board Root: Custom path (e.g.,
C:\my_boards
Please advise if there is a known workaround or patch, or if this issue has been resolved in a newer version of the SDK or tooling.
