[Direct Test Mode] The failed compiled result for nRF54L15 via SDK v3.0.0
Hi Support team:
I am new for using the Nordic Design kit of nRF54L15-DK.
And I would like to use the app "Direct Test Mode" v2.4.2 built-in the "nRF Connect for Desktop" v5.1.0 on my Windows OS.
But I followed up the instruction to install the SDK with v3.0.0 and find the application under the default dictionary.
C:\ncs\toolchains\v3.0.0\nrf\samples\bluetooth\direct_test_mode
Use the nRFutil with tool "West" to build the hex.
But I encountered the issue and don`t know which setting is not matched and lead the failure.
Can team help to guide me to fix the issue?
------------------------- Console log of the during the compilation -------------------------
(v3.0.0) C:\ncs\toolchains\v3.0.0\nrf\samples\bluetooth\direct_test_mode> west build -b nrf54l15dk/nrf54l15/cpuapp
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: C:/ncs/toolchains/v3.0.0/zephyr/.cache
-- Board: nrf54l15dk, qualifiers: nrf54l15/cpuapp
Parsing C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/Kconfig.sysbuild
Loaded configuration 'C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/build/_sysbuild/empty.conf'
Merged configuration 'C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/sysbuild.conf'
Configuration saved to 'C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/build/zephyr/.config'
Kconfig header saved to 'C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/build/_sysbuild/autoconf.h'
* Running CMake for direct_test_mode *
-- Application: C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode
-- CMake version: 3.21.0
-- Zephyr version: 4.0.99 (C:/ncs/toolchains/v3.0.0/zephyr)
-- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/0b393f9e1b/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/toolchains/v3.0.0/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts
-- Found devicetree overlay: C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/boards/nrf54l15dk_nrf54l15_cpuapp.overlay
-- Generated zephyr.dts: C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/build/direct_test_mode/zephyr/zephyr.dts
-- Generated pickled edt: C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/build/direct_test_mode/zephyr/edt.pickle
-- Generated devicetree_generated.h: C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/build/direct_test_mode/zephyr/include/generated/zephyr/devicetree_generated.h
-- Including generated dts.cmake file: C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/build/direct_test_mode/zephyr/dts.cmake
Loaded configuration 'C:/ncs/toolchains/v3.0.0/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp_defconfig'
Merged configuration 'C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/prj.conf'
Merged configuration 'C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/boards/nrf54l15dk_nrf54l15_cpuapp.conf'
Merged configuration 'C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/build/direct_test_mode/zephyr/.config.sysbuild'
Configuration saved to 'C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/build/direct_test_mode/zephyr/.config'
Kconfig header saved to 'C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/build/direct_test_mode/zephyr/include/generated/zephyr/autoconf.h'
CMake Error at C:/ncs/toolchains/v3.0.0/zephyr/cmake/modules/extensions.cmake:2645 (message):
No such file or directory: LIBGCC_FILE_NAME: ''
C:/ncs/toolchains/v3.0.0/zephyr/cmake/compiler/gcc/target.cmake:106 (assert_exists)
C:/ncs/toolchains/v3.0.0/zephyr/cmake/modules/FindTargetTools.cmake:103 (include)
C:/ncs/toolchains/v3.0.0/zephyr/cmake/modules/kernel.cmake:25 (find_package)
C:/ncs/toolchains/v3.0.0/zephyr/cmake/modules/zephyr_default.cmake:142 (include)
C:/ncs/toolchains/v3.0.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/toolchains/v3.0.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:8 (find_package)
CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
CMake configure failed for Zephyr project: direct_test_mode
Location: C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode
cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
cmake/modules/sysbuild_default.cmake:21 (include)
C:/ncs/toolchains/v3.0.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
C:/ncs/toolchains/v3.0.0/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
template/CMakeLists.txt:10 (find_package)
See also "C:/ncs/toolchains/v3.0.0/nrf/samples/bluetooth/direct_test_mode/build/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe '-BC:\ncs\toolchains\v3.0.0\nrf\samples\bluetooth\direct_test_mode\build' -GNinja -DBOARD=nrf54l15dk/nrf54l15/cpuapp '-SC:\ncs\toolchains\v3.0.0\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\ncs\toolchains\v3.0.0\nrf\samples\bluetooth\direct_test_mode'
Best Regards.
Paul Lin
