SDK 3.0.0 custom board definition
I'm having trouble porting my project from the older SDK (2.6.0) to the new SDK.
I thought the most straightforward way to do that would be to start with a sample project similar to what I want to do. So I took the Matter Window Cover Sample. I have the nRF54L15-DK so I compiled the project for that board and it seems to work.
Now I use the VSCode button to create a new board. After closing VSCode and opening it again I can select my new custom board as the target for the build. It fails as my custom board is pretty much just boilerplate empty board definitions. So I start copying the contents of the nRF54L15-DK board definitions to my own custom board folder. The aim being to get the project to compile for the same dev kit with my custom board as the target. Ideally I would make no changes to the files but due to custom name I still have to do that. This also means I have to make another partition manager static definition file. I just copy the one used for the DK build and rename it for my custom board.
After fighting with some very hard to fix devicetree errors I get compilation process to reach the partition manager stage and there is something weird happening there. I have the exact same contents for the static definition file as the DK but for my board the build fails complaining about too many gaps in the partitions. I'm attaching the actual file I use for this.
pm_static_blindy_v3_nrf54l15_cpuapp.zip
The error I get from partition manager is this:
-- Found partition manager static configuration : /home/tiit/code/nordic/blindy_matter/pm_static_blindy_v3_nrf54l15_cpuapp.yml
Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
Partition manager failed: Incorrect amount of gaps found in static configuration. There must be exactly one gap in the static configuration to support placing the dynamic partitions (such as 'app'). Gaps found (2):0xd800-0x165000 0x17d000-0x172000 The most common solution to this problem is to fill the smallest of these gaps with statically defined partition(s) until there is only one gap left. Alternatively re-order the already defined static partitions so that only one gap remains.
Failed to partition region flash_primary, size of region: 1462272
Partition Configuration:
app:
factory_data:
mcuboot:
mcuboot_pad:
mcuboot_primary:
mcuboot_primary_app:
settings_storage:
Can you please check what I'm doing wrong here to cause this. This is somehow caused by using the custom board definition. I'm also attaching the whole custom board folder here just in case you can see something weird in there. This is just the folder that has to be extracted into the boards folder and after a VSCode restart it appears as a target for the build.
soma.zip
Hoping to hear back from you after the Easter Holidays,
Tiit
    I will try to describe step by step what I did and I will also attach the whole result here so you can try that.
    1. I create a new project in VSCode using the nRF Connect tab. There I select copy sample and copy the sample Matter Window Cover from SDK 3.0.1.
    2. I make copies of the files nrf54l15dk_nrf54l15_cpuapp.conf and nrf54l15dk_nrf54l15_cpuapp.overlay and rename them for the new blindy_v4 board (blindy_v4_nrf54l15_cpuapp.conf and blindy_v4_nrf54l15_cpuapp.overlay). I add CONFIG_ZMS=y to my new blindy_v4_nrf54l15_cpuapp.conf.
    3. I make renamed copies the same way in the sysbuild/mcuboot/boards folder
    4. I make a copy of the pm_static_nrf54l15dk_nrf54l15_cpuapp.yml file and name the copy pm_static_blindy_v4_nrf54l15_cpuapp.yml
    5. I close VSCode and open it again (so the new boards become available in the IDE)
    6. I add new configuration, select SDK and toolchain 3.0.1, board target blindy_v4/nrf54l15/cpuapp
    7. Build and flash the code the the DK
    8. Cry in desperation as nothing happens. No leds blink, nothing is printed to RTT or the serial ports. Debugging still fails in this project as well for some reason.
    window_covering_1.zip
    I have attached a project with everything I did here.
    Looking forward to your feedback on this.
    Tiit
  • Hi
    I can confirm I've reproduced this now, and I see what you mean. I don't see a reason why all of a sudden absolutely nothing happens. I've now reported it to the developers to see if they have a good reason as to why this happens. I'm sorry it took so long to get to this point.
    Simon
  • An initial question from one of our developers, to narrow down where the issue here lies. Are you also able to see this if you add the custom boards and build it from the directory in-tree of the window covering sample?
    Note that this is not a proposed fix, but will allow the devs to narrow down what's wrong. I can try it myself as well, but due to the staff shortage at the moment I won't have time this week I think.
    Simon
  • Hi Simon,
    It's good that you could at least confirm that the issue exists. I tried the in-tree build and that seems to have the same issue for me. I hope the devs will have time to look at this next week. I'm working on multiple projects with this SOC and so far at least one has already reverted back to nRF52840 as their schedule did not allow for a delay as long as this.
    Tiit
  • Hi Tiit
    Can you check if adding the -DSB_CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y and  -DCONFIG_CHIP_SPI_NOR=y to the build command helps? Our suspicion is that we enable some options based on the DK and not SoC in the Matter projects (see this). That is because we don't know what customers are going to do with the SoC, so it seemed to be a good idea to set this to the DK and not the SoC selection.
    Simon
