aws_iot_connect with policie and client_id
Hi all,
I have a custom board with an 9151, I want to use mqtt with aws, it's works I'm able to connect aws, but I have a question about
aws_iot_connect()
If I want to be able to connect on AWS, I have to use a very simple policie like that:
  "Version": "2012-10-17",
  "Statement": [
      "Effect": "Allow",
      "Action": "iot:*",
      "Resource": "*"
But If I try to use something like that
  "Statement": [
      "Effect": "Allow",
      "Action": [
        "iot:Connect",
        "iot:Publish",
        "iot:Receive",
        "iot:Subscribe"
      "Resource": [
        "arn:aws:iot:*******:client/TryIt",
        "arn:aws:iot:*******:topic/ABC/359404230602222/*",
        "arn:aws:iot:*******:topicfilter/ABC/359404230602222/*"
AWS reject me as soon as I try to connect, so if I understand well TryIt is my client_id so here is what I've done in my main
	LOG_INF("Connecting to AWS IoT");
	struct aws_iot_config config = {
		.client_id = "TryIt"
	err = aws_iot_connect(&config);
	if (err) {
		LOG_ERR("aws_iot_connect, error: %d", err);
Why I've missed ?
    Is your application based on any of our samples?
    Can you provide complete log which shows the rejection from AWS?
    Dejan
    Yes my source code is base on https://devzone.nordicsemi.com/guides/cellular-iot-guides/b/software-and-protocols/posts/connecting-to-aws-cloud-services-using-the-nrf9160
    So here is the log outuput after calling aws_iot_connect()
    AWS_IOT_EVT_DISCONNECTED
    [00:04:59.030,700] <err> mqtt_helper: Cloud MQTT input error: -128
    [00:05:26.609,771] <err> aws_iot: Timed out waiting for subscription acknowledgments
    [00:05:26.609,863] <err> mqtt_helper: Library is in the wrong state (MQTT_STATE_DISCONNECTED), MQTT_STATE_CONNECTED required
    [00:05:26.609,863] <err> aws_iot: mqtt_helper_disconnect, error: -95
    [00:05:26.609,893] <err> aws_iot_connect, error: -11
    And my policiy for the test ( can publish, subscrid in all topics in datas/top/*) I use ${iot:Connection.Thing.ThingName} for connect rules, so in my config I set
    		.client_id = "XXXX"
    	if (err) {
    Where XXXX is equal at my object name in aws iot core.
    My JSON polocy
      "Statement": [
          "Effect": "Allow",
          "Action": [
            "iot:Connect"
          "Resource": [
            "arn:aws:iot:eu-west-3:876997124557:client/${iot:Connection.Thing.ThingName}"
          "Condition": {
            "Bool": {
              "iot:Connection.Thing.IsAttached": "true"
          "Effect": "Allow",
          "Action": [
            "iot:Publish"
          "Resource": [
            "arn:aws:iot:eu-west-3:XXXX:topic/datas/top/*"
          "Effect": "Allow",
          "Action": [
            "iot:Subscribe"
          "Resource": [
            "arn:aws:iot:eu-west-3:XXXX:topicfilter/datas/top/*"
          "Effect": "Allow",
          "Action": [
            "iot:Receive"
          "Resource": [
    I don't know if the problem is coming from JSON policy or certs ? The only way for me to log in is to put a permissive policy with
      "Statement": [
          "Effect": "Allow",
          "Action": "iot:*",
          "Resource": "*"
    You could first double-check that your policy matches subscribe/publish requests. Afterwards you should subscribe to AWS IoT lifecycle events to find out disconnection cause.
    Dejan
