NCS 2.9.1
NRF52840
Sysbuild but with only a single image (no bootloader)
I've been trying to figure out how to change the merged.hex output and how to perform additional steps after the merged.hex is generated.
I was finally able to track down the generation of merged.hex to the partition_manager function in nrf/cmake/sysbulid/partition_manager.cmake I'm able to change the name of the merged.hex file by modifying the variable ${merged} in this code:
set(merged zephyr-merged${merged_suffix})
set(MERGED ZEPHYR-MERGED${MERGED_SUFFIX})
Within the cmake function partition_manager, this command is added:
add_custom_command(
OUTPUT ${CMAKE_BINARY_DIR}/${container}.hex
COMMAND
${PYTHON_EXECUTABLE}
${ZEPHYR_BASE}/scripts/build/mergehex.py
-o ${CMAKE_BINARY_DIR}/${container}.hex
${${container}overlap_arg}
${${container}hex_files}
DEPENDS
${${container}targets}
Which has a corresponding custom target
add_custom_target(
${container}_hex
ALL DEPENDS
However I'm still confused by how these partition_manager targets are not usable from my project's CMakeLists.txt. For example how can I make an additional custom target that depends on merged_hex. Is this a different cmake run after the POST_BUILD that doesn't include the app CMakeLists.txt?
As well, there is this code which may be unrelated, but I'm not sure what it does:
if ("${container}" STREQUAL "merged")
update_runner(IMAGE ${DEFAULT_IMAGE} HEX ${CMAKE_BINARY_DIR}/${container}.hex)
endif()
