NRF 5340DK CONFIG_BT_MAX_CONN cannot go above 5
Project based on NUS Central example.
Application is to connect to multiple peripherals concurrently running a custom service and subscribe to Notifications on a characteristic.
This i have working.
This is for an environmental measuring application, and ideally, the Central could support more than 40 concurrent connections.
No Pairing is required. connection is completed against a list of MAC Addresses
I have an issue where if i set CONFIG_BT_MAX_CONN to > 5 then there is a compiliation error
C:/ncs/v2.8.0/zephyr/include/zephyr/toolchain/gcc.h:87:36: error: static assertion failed: ""
   87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert((EXPR), "" MSG)
C:/ncs/v2.8.0/zephyr/subsys/bluetooth/common/dummy.c:75:1: note: in expansion of macro 'BUILD_ASSERT'
   75 | BUILD_ASSERT(CONFIG_BT_BUF_ACL_RX_COUNT > CONFIG_BT_MAX_CONN);
How can i Increase the number of connections?
I have tried to search for CONFIG_BT_BUF_ACL_RX_COUNT in the prj.conf
if I try to set CONFIG_BT_BUF_ACL_RX_COUNT it shows up as undefined.
using SDK vers 2.8.0
