Matter RCP with SDK v3.0.0 on nrf54l-dk using Docker openthread/otbr image?
I have built and flashed the openthread/coprocessor sample using VS Code specifying "nrf54l15dk/nrf54l15/cpuapp".
I then tried to run it (on Ubuntu 24.04.2 LTS, x86_64) using:
sudo docker run -it --rm --privileged --name otbr --network otbr -p 8080:80 \
--sysctl "net.ipv6.conf.all.disable_ipv6=0 net.ipv4.conf.all.forwarding=1 net.ipv6.conf.all.forwarding=1" \
--volume /dev/ttyACM0:/dev/radio openthread/otbr --radio-url spinel+hdlc+uart:///dev/radio?uart-baudrate=1000000
However, it doesn't appear to be working. When I click on "Join" in the web interface it reports:
Information
There is no available Thread network currently, please wait a moment and retry it.
Would this be expected to work?
A similar attempt with "nrf52840dongle/nrf52840" was able to see two entries under Available Thread Networks.
I'm new to Matter/Thread so I apologise if I'm asking a rather clumsy question ...
    You're using the openthread/otbr Docker image. I would recommend using the Nordic-specific image nrfconnect/otbr. See the Running OTBR using Docker documentation to download the compatible version of the OpenThread Border Router Docker image.
    Amanda H.
  • Thanks for the reply.
    Tried your suggestion replacing "openthread/otbr" with "nrfconnect/otbr:fbde28a" using the nrf54l15-dk with broadly similar results.
    Switched the nrf54l15-dk for the nrf52840dongle and that was able to see two entries under Available Thread Networks as with "openthread/otbr".
    Looks like the problem is most likely related to nrf54l15-dk support.
    Note that I used the v3.0.0 toolchain and SDK to build the RCP firmware.
  • Just tried and works as expected. I think used /dev/ttyACM0 while the serial port to the application processor is /dev/ttyACM1.
    What I did:
    west build -p always -b nrf54l15dk/nrf54l15/cpuapp nrf/samples/openthread/coprocessor/
    west flash --erase
    sudo docker run -it --rm --privileged --name otbr --network otbr -p 8080:80 --sysctl "net.ipv6.conf.all.disable_ipv6=0 net.ipv4.conf.all.forwarding=1 net.ipv6.conf.all.forwarding=1" --volume /dev/ttyACM1:/dev/radio nrfconnect/otbr:fbde28a --radio-url spinel+hdlc+uart:///dev/radio?uart-baudrate=1000000
