Trigger mode on LSM6DSO
I've been working on a project involving an IMU and bluetooth for a while, and had been using the IMU (LSM6DSO) on polling mode. Unfortunately, I found out that I will need to use trigger mode for this application, so I've been trying to figure out how to do that. I've made what feels like a hundred changes to my config and devicetree overlay files to try and get this working and have had no success so far. It seems like many of the trigger mode config options don't work, or say that they weren't able to set the value to y. I did find one combination that at least let me successfully build my code, and I will share both of those files here. I've been starting with the lsm6dso sample and trying to add code that sends an interrupt when the IMU records >2g acceleration and turns an LED on the nrf52 dk, but currently nothing occurs after the line 'Failed to set acceleration threshold' is printed in the terminal. Lastly, I have verified that my physical wiring and connections are as they should be, and uploaded the working code (using polling mode) to confirm. I would really appreciate any help or information that you can share regarding this. Thank you!
 * Copyright (c) 2020 Yestin Sun
#include <stdio.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/sensor.h>
static inline float out_ev(struct sensor_value *val)
	return (val->val1 + (float)val->val2 / 1000000);
#define LED0_NODE DT_ALIAS(led0)
static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
static void fetch_and_display(const struct device *dev)
	struct sensor_value x, y, z;
	static int trig_cnt;
	trig_cnt++;
	/* lsm6dso accel */
	sensor_sample_fetch_chan(dev, SENSOR_CHAN_ACCEL_XYZ);
	sensor_channel_get(dev, SENSOR_CHAN_ACCEL_X, &x);
	sensor_channel_get(dev, SENSOR_CHAN_ACCEL_Y, &y);
	sensor_channel_get(dev, SENSOR_CHAN_ACCEL_Z, &z);
	printf("accel x:%f ms/2 y:%f ms/2 z:%f ms/2\n",
			(double)out_ev(&x), (double)out_ev(&y), (double)out_ev(&z));
	/* lsm6dso gyro */
	sensor_sample_fetch_chan(dev, SENSOR_CHAN_GYRO_XYZ);
	sensor_channel_get(dev, SENSOR_CHAN_GYRO_X, &x);
	sensor_channel_get(dev, SENSOR_CHAN_GYRO_Y, &y);
	sensor_channel_get(dev, SENSOR_CHAN_GYRO_Z, &z);
	printf("gyro x:%f rad/s y:%f rad/s z:%f rad/s\n",
	printf("trig_cnt:%d\n\n", trig_cnt);
static int set_sampling_freq(const struct device *dev)
	int ret = 0;
	struct sensor_value odr_attr;
	/* set accel/gyro sampling frequency to 12.5 Hz */
	odr_attr.val1 = 12.5;
	odr_attr.val2 = 0;
	ret = sensor_attr_set(dev, SENSOR_CHAN_ACCEL_XYZ,
			SENSOR_ATTR_SAMPLING_FREQUENCY, &odr_attr);
	if (ret != 0) {
		printf("Cannot set sampling frequency for accelerometer.\n");
		return ret;
	ret = sensor_attr_set(dev, SENSOR_CHAN_GYRO_XYZ,
	if (ret != 0) {
		printf("Cannot set sampling frequency for gyro.\n");
		return ret;
	return 0;
#ifdef CONFIG_LSM6DSO_TRIGGER
static void trigger_handler(const struct device *dev,
	const struct sensor_trigger *trig)
static bool led_on = false;
printf("Triggered.\n");
// Toggle LED
led_on = !led_on;
gpio_pin_set_dt(&led, led_on);
// Optional: also display sensor data
fetch_and_display(dev);
static void test_trigger_mode(const struct device *dev)
	struct sensor_trigger trig;
	struct sensor_value threshold;
	if (set_sampling_freq(dev) != 0)
		return;
	// Set 2g threshold (approx. 19.6 m/s²)
	threshold.val1 = 19;
	threshold.val2 = 600000;
	if (sensor_attr_set(dev, SENSOR_CHAN_ACCEL_XYZ, SENSOR_ATTR_SLOPE_TH, &threshold) != 0) {
		printf("Failed to set acceleration threshold\n");
		return;
	// Set trigger type to threshold
	trig.type = SENSOR_TRIG_THRESHOLD;
	trig.chan = SENSOR_CHAN_ACCEL_XYZ;
	if (sensor_trigger_set(dev, &trig, trigger_handler) != 0) {
		printf("Could not set threshold trigger\n");
		return;
#else
static void test_polling_mode(const struct device *dev)
	if (set_sampling_freq(dev) != 0) {
		return;
	while (1) {
		k_sleep(K_MSEC(1000));
	const struct device *const dev = DEVICE_DT_GET_ONE(st_lsm6dso);
	if (!device_is_ready(dev)) {
		printk("%s: device not ready.\n", dev->name);
		return 0;
	printf("Testing LSM6DSO sensor in trigger mode.\n\n");
	if (!gpio_is_ready_dt(&led)) {
		printk("LED device not ready\n");
		return 0;
	if (gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE) != 0) {
		printk("Failed to configure LED\n");
		return 0;
	test_trigger_mode(dev);
#else
	printf("Testing LSM6DSO sensor in polling mode.\n\n");
	test_polling_mode(dev);
	return 0;
Config file:
CONFIG_STDOUT_CONSOLE=y
CONFIG_I2C=y
CONFIG_GPIO=y
CONFIG_SENSOR=y
CONFIG_LSM6DSO=y
CONFIG_LSM6DSO_TRIGGER_GLOBAL_THREAD=y  # or OWN_THREAD if you prefer
CONFIG_CBPRINTF_FP_SUPPORT=y
Devicetree overlay:
&i2c0 {
    lsm6dso@6b {
        compatible = "st,lsm6dso";
        reg = <0x6b>;
        label = "LSM6DSO";
        irq-gpios = <&gpio0 12 GPIO_ACTIVE_HIGH>;
        int-pin = <1>;
        status = "okay";
  • I believe the sensor itself should support this mode, but when I looked through the lsm6dso.c trigger driver file and it appears that the only supported trigger mode is data ready, no threshold based interrupts. Unless I'm reading that wrong, I'll need to configure the registers manually. I've been having some issues with that but will give it some more attempts and can share my code/outputs when I've done so.
  • Okay, I've been putting a lot of time into this and have made some progress, which I will share here. My code compiles and runs, and I have been able to get trigger mode working (somewhat) without using the trigger modes in the drivers. I manually change register values and have a different interrupt handler function that does successfully trigger. Now, I'm running into a bunch of odd behavior that I could use help figuring out.
    1. Register values don't seem to correspond to trigger sensitivity. For instance, I've been trying to lower the trigger threshold register value in my code (from 4g to 2g, or 2g to 1g) and if anything that makes it harder to trigger. Also, the wake up duration being set to 0 makes it so I can't trigger it at all (I have no clue why this would be the case, if anything this should make triggering more sensitive/frequent.
    2. I print the state of my gpio pin after the interrupt. Sometimes it is 0 (which it should be since its cleared), but other times it is 1. I have no clue why, it seems random.
    3. Occasionally, LED 3 and 4 on on my DK both turn on. This is not something that I do in my code at all, and I have no clue why this happens.
    4. After triggering, sometimes it does not let me trigger again. This seems to correspond to either the behavior I mentioned in (2) or (3) occurring.
    I'll share my current code, devicetree overlay, config file, and some sample output. Any advice would be appreciated!
    #include <stdio.h>
    #include <zephyr/drivers/i2c.h>
    #define INT1_NODE DT_ALIAS(lsm6dso_int1)
    #if DT_NODE_HAS_STATUS(INT1_NODE, okay)
    static const struct gpio_dt_spec int1_gpio = GPIO_DT_SPEC_GET(INT1_NODE, irq_gpios);
    #else
    #error "INT1_NODE is not defined or not okay in the device tree"
    static struct gpio_callback int1_cb_data;
    // Replace with correct label from your board's devicetree if needed
    #define I2C_BUS DT_NODELABEL(i2c0)
    #define LSM6DSO_I2C_ADDR 0x6B
    static const struct device *i2c_dev = DEVICE_DT_GET(I2C_BUS);
    static int lsm6dso_write_reg(uint8_t reg, uint8_t val) {
    	return i2c_reg_write_byte(i2c_dev, LSM6DSO_I2C_ADDR, reg, val);
    static int lsm6dso_read_reg(uint8_t reg, uint8_t *val) {
    	return i2c_reg_read_byte(i2c_dev, LSM6DSO_I2C_ADDR, reg, val);
    	trig_cnt++;
    	/* lsm6dso accel */
    	/* lsm6dso gyro */
    	int ret = 0;
    	odr_attr.val2 = 0;
    	if (ret != 0) {
    		return ret;
    	if (ret != 0) {
    		return ret;
    	return 0;
    static struct k_work lsm6dso_work;
    // This function is safe to run outside ISR context
    static void lsm6dso_work_handler(struct k_work *work)
            printk("LSM6DSO device not ready\n");
            return;
        uint8_t wake_src;
        lsm6dso_read_reg(0x1B, &wake_src);  // Safe here
        printk("Wake-up SRC: 0x%02X\n", wake_src);
        printk("callback triggered.\n");
        fetch_and_display(dev);  // Whatever your normal logic is
    static void lsm6dso_int1_callback(const struct device *port, struct gpio_callback *cb, uint32_t pins)
    	uint8_t wake_src;
        lsm6dso_read_reg(0x1B, &wake_src);  // Read to clear the interrupt flag
        printk("Wake-up SRC: 0x%02X\n", wake_src);  // Optional: debug info
    	// printk("callback triggered.\n");
    	//k_sleep(K_MSEC(500));
        // const struct device *const dev = DEVICE_DT_GET_ONE(st_lsm6dso);
        // fetch_and_display(dev);  // Or whatever handler logic you want
    	k_work_submit(&lsm6dso_work);
    	int gpio_state = gpio_pin_get(port, 12);
        printk("GPIO pin state after interrupt: %d\n", gpio_state);  // Should print 0 (low) if cleared properly
    static void setup_int1_gpio(void)
        //gpio_pin_configure_dt(&int1_gpio, GPIO_INPUT);
    	gpio_pin_configure_dt(&int1_gpio, GPIO_INPUT | GPIO_PULL_UP);
        gpio_pin_interrupt_configure_dt(&int1_gpio, GPIO_INT_EDGE_TO_ACTIVE);
        gpio_init_callback(&int1_cb_data, lsm6dso_int1_callback, BIT(int1_gpio.pin));
        gpio_add_callback(int1_gpio.port, &int1_cb_data);
    // Function to read 6 bytes of accelerometer data (X, Y, Z)
    void read_accel_data(void) {
        uint8_t accel_xl[6];  // Buffer to store 6 bytes of accelerometer data
        int ret;
        // Read 6 consecutive bytes starting from register 0x28
        for (int i = 0; i < 6; i++) {
            ret = lsm6dso_read_reg(0x28 + i, &accel_xl[i]);
            if (ret != 0) {
                printk("Failed to read register 0x%02X\n", 0x28 + i);
                return;
        // Convert the raw data to meaningful values
        int16_t accel_x = (int16_t)((accel_xl[1] << 8) | accel_xl[0]);  // X-axis
        int16_t accel_y = (int16_t)((accel_xl[3] << 8) | accel_xl[2]);  // Y-axis
        int16_t accel_z = (int16_t)((accel_xl[5] << 8) | accel_xl[4]);  // Z-axis
        // Print the raw accelerometer values
        printk("Accel X: %d, Y: %d, Z: %d\n", accel_x, accel_y, accel_z);
    static void lsm6dso_config_motion_interrupt(void)
    	// 1. Enable BDU and auto-increment
    	lsm6dso_write_reg(0x12, 0x44);  // CTRL3_C
    	// 2. Enable accelerometer: ODR = 104 Hz, FS = ±4g (0x50)
    	lsm6dso_write_reg(0x10, 0x50);  // CTRL1_XL
    	lsm6dso_write_reg(0x19, 0x01);  // FUNC_CFG_ACCESS = 1 → Enable embedded register access
    	lsm6dso_write_reg(0x04, 0x01);  // EMB_FUNC_EN_A: Enable embedded functions
    	// 3. Enable embedded function interrupt
    	lsm6dso_write_reg(0x58, 0x80);  // TAP_CFG0: INT_EN = 1
    	// 4. Set wake-up threshold to 2g → 0x10 (FS=4g, 0.125g/LSB)
    	lsm6dso_write_reg(0x5B, 0x20);  // WAKE_UP_THS
    	// 5. Set no additional duration for interrupt
    	lsm6dso_write_reg(0x5C, 0x01);  // WAKE_UP_DUR
    	// 6. Route wake-up interrupt to INT1
    	lsm6dso_write_reg(0x5E, 0x20);  // MD1_CFG: Wake-up INT on INT1
    	printk("LSM6DSO motion interrupt configured for 2g threshold.\n");
    		return;
    	lsm6dso_config_motion_interrupt();  // <--- manually configure 2g motion INT
    	k_msleep(100);
    	setup_int1_gpio();
    	// struct sensor_trigger trig;
    	// trig.type = SENSOR_TRIG_DELTA;  // Could be SENSOR_TRIG_DATA_READY, both should work
    	// trig.chan = SENSOR_CHAN_ACCEL_XYZ;
    	// if (sensor_trigger_set(dev, &trig, trigger_handler) != 0) {
    	// 	printf("Could not set sensor trigger.\n");
    	// 	return;
    	uint8_t wake_src;
    	for (;;){
    		// lsm6dso_read_reg(0x1B, &wake_src);  // Clear the interrupt
        	// printk("Wake-up SRC: 0x%02X\n", wake_src);  // Optional: debug info
    		// read_accel_data();
    		// k_sleep(K_MSEC(3000));
    #else
    		return;
    	while (1) {
    		return 0;
    	k_work_init(&lsm6dso_work, lsm6dso_work_handler);
    #else
    	return 0;
    Devicetree overlay:
    &i2c0 {
        lsm6dso: lsm6dso@6b {
            reg = <0x6b>;
            label = "LSM6DSO";
            int-pin = <1>;
            status = "okay";
    &{/aliases} {
        lsm6dso-int1 = &lsm6dso;
    Config file:
    CONFIG_I2C=y
    CONFIG_GPIO=y
    CONFIG_SENSOR=y
    CONFIG_LSM6DSO=y
    Sample Output:
    Wake-up SRC: 0x00
    GPIO pin state after interrupt: 0
    Wake-up SRC: 0x10
    callback triggered.
    accel x:-3.107080 ms/2 y:2.021935 ms/2 z:10.009775 ms/2
    gyro x:-0.037110 rad/s y:-0.007788 rad/s z:3.345860 rad/s
    trig_cnt:1
    Wake-up SRC: 0x00
    GPIO pin state after interrupt: 1
    Wake-up SRC: 0x00
    callback triggered.
    accel x:-18.340984 ms/2 y:0.000000 ms/2 z:0.629312 ms/2
    gyro x:-4.682281 rad/s y:0.000000 rad/s z:0.162490 rad/s
    trig_cnt:2
  • I've been testing it more, and I'm starting to think that the triggering may not be based directly on the interrupt signal and the acceleration values that the LSM6DSO records. When I manually unplug and plug in gpio 12 (which I am using as my INT1 pin), it triggers the value. I think that this behavior matches what I was seeing before, and makes me think that may be why I'm getting odd behavior and inconsistent triggering. It may have been that the reason it required a very aggressive shake to trigger before was that the shaking was physically disconnecting and reconnecting the wire, or something similar. I'm pretty stumped still and am not sure what to look into next.
  • Okay, new update. Things are working better now. I went through a lot of work changing the register values to get to a configuration that would work. I switched to INT2 but it was constantly being held low, so I ended up going back to INT1 and it is functional now. My callback function in my main code does work, and triggers corresponding to a small tap on the IMU (which is close enough to my desired behavior).
    The current issue that I am having is that the triggering doesn't always work on the NRF side. What I mean by this is that my logic analyzer shows a pulse in int1, but my callback function doesn't work. I would say that it works most of the time, but it is odd that it isn't fully consistent. Additionally, when this function gets called, it sometimes turns on LED 3 and 4, which I believe indicates a fault of some sort. I am still able to trigger this function again afterwards, but it required a larger acceleration magnitude (I have no clue why). Some insight into why the LEDs are turning on would be helpful if that is something anyone knows about.
    My next step is to implement the nrf low power mode, and use this interrupt signal to turn on the chip fully and send data over bluetooth, before putting it to sleep again and reenabling trigger mode. I'll likely work on this early next week, but in the meantime if anyone can help explain the LED behavior it would be appreciated. Thank you for the help! I will share my current code below so you can reference it.
    #include <stdio.h>
    #else
    	trig_cnt++;
    	/* lsm6dso accel */
    	/* lsm6dso gyro */
    	int ret = 0;
    	odr_attr.val2 = 0;
    	if (ret != 0) {
    		return ret;
    	if (ret != 0) {
    		return ret;
    	return 0;
    	gpio_pin_interrupt_configure_dt(&int1_gpio, GPIO_INT_DISABLE);
        // if (!device_is_ready(dev)) {
        //     printk("LSM6DSO device not ready\n");
        //     return;
    	uint8_t wake_src, tap_src, status;
    	lsm6dso_read_reg(0x1C, &tap_src);
    	lsm6dso_read_reg(0x1E, &status);
        //fetch_and_display(dev);  // Whatever your normal logic is
    static void reset_registers(void){
    	// 1. Reset device (optional but good practice)
    	lsm6dso_write_reg(0x12, 0x01);  // CTRL3_C: SW_RESET
    	k_sleep(K_MSEC(100));            // Delay to allow reset
    	// 2. Disable all interrupts on INT1 and INT2
    	lsm6dso_write_reg(0x5E, 0x00);  // MD1_CFG: no interrupt routed
    	lsm6dso_write_reg(0x5F, 0x00);  // MD2_CFG: no interrupt routed
    	// 3. Disable embedded functions, just basic accelerometer on 104 Hz, ±2g
    	lsm6dso_write_reg(0x10, 0x40);  // CTRL1_XL: 104 Hz, ±2g
    	lsm6dso_write_reg(0x11, 0x00);  // CTRL2_G: gyroscope off
    	lsm6dso_write_reg(0x12, 0x44);  // CTRL3_C: BDU + auto-increment enabled
    	// 4. Disable embedded functions access
    	lsm6dso_write_reg(0x19, 0x00);  // FUNC_CFG_ACCESS: disable
    	// 5. Read INT1 pin voltage level with logic analyzer or voltmeter
        int ret;
            if (ret != 0) {
                return;
    static void read_all_registers(void)
    	uint8_t reg;
    	lsm6dso_read_reg(0x1A, &reg); printk("ALL_INT_SRC: 0x%02X\n", reg);
    	lsm6dso_read_reg(0x1B, &reg); printk("WAKE_UP_SRC: 0x%02X\n", reg);
    	lsm6dso_read_reg(0x1C, &reg); printk("TAP_SRC: 0x%02X\n", reg);
    	lsm6dso_read_reg(0x1D, &reg); printk("D6D_SRC: 0x%02X\n", reg);
    	lsm6dso_read_reg(0x53, &reg); printk("FUNC_SRC1: 0x%02X\n", reg);
    	lsm6dso_read_reg(0x54, &reg); printk("FUNC_SRC2: 0x%02X\n", reg);
    	lsm6dso_read_reg(0x12, &reg); printk("CTRL3_C: 0x%02X\n", reg);
    	lsm6dso_read_reg(0x5E, &reg); printk("MD1_CFG: 0x%02X\n", reg);
    	reset_registers();
    	// 3. Enable access to embedded functions
    	lsm6dso_write_reg(0x01A, 0x80); // FUNC_CFG_ACCESS = enable embedded reg access
    	// 4. Enable embedded functions
    	lsm6dso_write_reg(0x04, 0x01);  // EMB_FUNC_EN_A = enable wake-up
    	lsm6dso_write_reg(0x05, 0x00);  // EMB_FUNC_EN_B = (optional)
    	// 5. Enable embedded function interrupt
    	lsm6dso_write_reg(0x58, 0x80);  // TAP_CFG0: enable interrupts
    	lsm6dso_write_reg(0x59, 0x0C);  // TAP_CFG2: route wake-up to INTs
    	// 6. Set wake-up threshold and duration
    	lsm6dso_write_reg(0x5B, 0x02);  // WAKE_UP_THS = ~2g
    	lsm6dso_write_reg(0x5C, 0x00);  // WAKE_UP_DUR = min duration
    	// 7. Route wake-up interrupt to INT2
    	lsm6dso_write_reg(0x5F, 0x20);  // MD2_CFG: bit 5 = wake-up INT2
    	// 7b. Route core wake-up interrupt to INT2 (not just embedded wake-up)
    	//lsm6dso_write_reg(0x5E, 0x20);
    	//lsm6dso_write_reg(0x0F, 0x20);  // INT2_CTRL: Wake-up to INT2
    	// 8. (Optional) Enable HPF for reliable wake-up
    	lsm6dso_write_reg(0x17, 0x09);  // CTRL8_XL: no HPF
    	// 9. Exit embedded access mode
    	lsm6dso_write_reg(0x1A, 0x00);  // FUNC_CFG_ACCESS = user bank
    	// 10. Enable Wake-Up in CTRL10_C
    	lsm6dso_write_reg(0x19, 0x24);  // CTRL10_C: FUNC_EN | WAKE_EN
    	// 11. Configure INT2: push-pull, active high
    	lsm6dso_write_reg(0x13, 0x00);  // CTRL4_C: default push-pull
    	// 12. Enable interrupt latch
    	lsm6dso_write_reg(0x0B, 0x40);  // CTRL6_C: LIR = 1
    	// Explicitly disable wake-up on INT1
    	lsm6dso_write_reg(0x5E, 0x00);  // MD1_CFG: clear wake-up routing on INT1
    	// Route wake-up interrupt to INT2
    	lsm6dso_write_reg(0x5F, 0x20);  // MD2_CFG: wake-up INT2
    	// Explicitly route wake-up interrupt on INT2 control register
    	lsm6dso_write_reg(0x0F, 0x20);  // INT2_CTRL: wake-up interrupt to INT2
    	// Disable wake-up on INT1 control register
    	lsm6dso_write_reg(0x0E, 0x00);  // INT1_CTRL
    	// Optional: configure INT2 pin type
    	lsm6dso_write_reg(0x13, 0x00);  // or try 0x02 for open-drain
    	//enable int1 code below
    	// Disable INT2
    	lsm6dso_write_reg(0x0F, 0x00);  // INT2_CTRL
    	// Enable INT1 for wake-up
    	lsm6dso_write_reg(0x5E, 0x20);  // MD1_CFG: route wake-up to INT1
    	lsm6dso_write_reg(0x0E, 0x20);  // INT1_CTRL: route core wake-up to INT1
    		return;
    	k_msleep(100);
    	setup_int1_gpio();
    	//reset_registers();
    	while (1) {
    		return 0;
    	return 0;
  • Final update is that seems to be working for the most part with the exception of some glitches where the IMU doesn't initialize upon powerup occasionally. My questions have transitioned from the IMU and trigger mode to lower power stuff, so I made a new post that summarizes where I'm at, which can be found here.
