west zap-gui fails in SDK 3.0.1
We have a fresh install of SDK 3.0.1 (from within VS Code), toolchain 3.0.0. We try to follow the Matter adding cluster tutorial (https://docs.nordicsemi.com/bundle/ncs-3.0.1/page/nrf/protocols/matter/getting_started/adding_clusters.html). When trying to start zap-gui, we get the following error:
PS C:\Users\iteedi\template> west zap-gui
Using ZAP file: C:\Users\iteedi\template\src\default_zap\template.zap
Using ZCL file: c:\ncs\v3.0.0\modules\lib\matter\src\app\zap-templates\zcl\zcl.json
Using app templates: c:\ncs\v3.0.0\modules\lib\matter\src\app\zap-templates\app-templates.json
ZAP installation directory: c:\ncs\v3.0.0\modules\lib\matter\.zap-install
Found ZAP 2024.8.14 (up to date)
­ƒöº Using temporary state directory: C:\Users\iteedi\AppData\Local\Temp\zap.MA9Fmg
TypeError: Cannot read properties of undefined (reading '0')
    at prepareDeviceType (c:\ncs\v3.0.0\modules\lib\matter\.zap-install\resources\app.asar\dist\src-electron\zcl\zcl-loader-silabs.js:1343:43)
    at c:\ncs\v3.0.0\modules\lib\matter\.zap-install\resources\app.asar\dist\src-electron\zcl\zcl-loader-silabs.js:1418:39
    at Array.map (<anonymous>)
    at processDeviceTypes (c:\ncs\v3.0.0\modules\lib\matter\.zap-install\resources\app.asar\dist\src-electron\zcl\zcl-loader-silabs.js:1418:28)
    at processParsedZclData (c:\ncs\v3.0.0\modules\lib\matter\.zap-install\resources\app.asar\dist\src-electron\zcl\zcl-loader-silabs.js:1478:25)
FATAL ERROR: Error::ThrowAsJavaScriptException napi_throw
 1: 00007FF7B2EFB786 node::SetTracingController+82646
 2: 00007FF7B2EFB8CE node::OnFatalError+286
 3: 00007FF7B36F0B60 napi_fatal_error+144
 4: 00007FFC3B6919D7
 5: 00007FFC3B691DA6
 6: 00007FFC3B6AADC9
 7: 00007FF7B36F3713 node_api_get_module_file_name+2019
 8: 00007FF7B360441C uv_dlerror+71580
 9: 00007FF7B3604273 uv_dlerror+71155
10: 00007FF7B3718D57 uv_fs_poll_getpath+1447
11: 00007FF7B2F76503 uv_run+1987
12: 00007FF7B2F75F3E uv_run+510
13: 00007FF7B2F41A4B node::Stop+157323
14: 00007FF7B2F4238A node::Stop+159690
15: 00007FF7B2F6E5CA node::FreeEnvironment+186
16: 00007FF7B1128295 node::FreeArrayBufferAllocator+21413
17: 00007FF7B10808D2 std::__Cr::vector<v8::CpuProfileDeoptInfo,std::__Cr::allocator<v8::CpuProfileDeoptInfo> >::__alloc+71314
18: 00007FF7B2046964 uv_fs_get_path+91668
19: 00007FF7B204859E uv_fs_get_path+98894
20: 00007FF7B2043817 uv_fs_get_path+79047
21: 00007FF7B1236601 v8::ScriptCompiler::ScriptStreamingTask::ScriptStreamingTask+558609
22: 00007FF7B1237C48 v8::ScriptCompiler::ScriptStreamingTask::ScriptStreamingTask+564312
23: 00007FF7B1237667 v8::ScriptCompiler::ScriptStreamingTask::ScriptStreamingTask+562807
24: 00007FF7B1233AB4 v8::ScriptCompiler::ScriptStreamingTask::ScriptStreamingTask+547524
25: 00007FF7B1233C2D v8::ScriptCompiler::ScriptStreamingTask::ScriptStreamingTask+547901
26: 00007FF7B0F7AEF7 std::__Cr::vector<v8::CpuProfileDeoptInfo,std::__Cr::allocator<v8::CpuProfileDeoptInfo> >::vector<v8::CpuProfileDeoptInfo,std::__Cr::allocator<v8::CpuProfileDeoptInfo> >+62711
27: 00007FF7B541DA92 Cr_z_adler32+4519682
28: 00007FFC904D259D BaseThreadInitThunk+29
29: 00007FFC907EAF38 RtlUserThreadStart+40
FATAL ERROR: command exited with status 134: 'c:\ncs\v3.0.0\modules\lib\matter\.zap-install\zap.exe' 'C:\Users\iteedi\template\src\default_zap\template.zap' --zcl 'c:\ncs\v3.0.0\modules\lib\matter\src\app\zap-templates\zcl\zcl.json' --gen 'c:\ncs\v3.0.0\modules\lib\matter\src\app\zap-templates\app-templates.json' --tempState
Any ideas what's wrong?
Thanks, Edi
