Unknown device error 9 in nrf programmer
We designed our custom board using nrf54l05, and tried to flash it using segger J-lInk as well as using nrf54L15-DK Debuger out port using nrf connect Programmer utility. we checked and verified connections which are OK,
but facing issue of error code 9, UNKNOWN Device.
Please Help
Regards
Khodidas
  • Hi Khodidas,
    Thanks for the log. I've shared it with our developers and the error in the latest log is not the same as the one you've shared here
    Khodidas11 said:
    We tried response is as attached
    The error in the picture comes from the J-Link sw when we try to use J-link to connect to the chip.
    The error in the log indicates that the debug port is unavailable, which should normally work with a functional device.
    Question from our developers:
    1. Did you change anything about your setup between the two tries? Does it consistently error out with the second error or sometimes with the first?
    Both errors indicate that something might be wrong with the hw.
    Can you measure and report the following voltages, measure as close to the pad as possible, what voltage do you measure?:
    1. VDD
    2. RESET
    Can you also share the schematics and layout files for your custom board?
    Can you also specify how many boards you see this issue on, is it more than one?
    best regards
    Jared
    We changed to different system to work and getting same error as per log file. Please check attached waveforms for VDD and RESET. We checked on two different PCBs, and got same result.
    Regards
    Khodidas
    Ok, looks like both RESET and VDD is at around 1V8.
    Could you share your schematics and layout?
    Could you also probe the SWD signals and share a trace when you try to run recover command?
    regards
    Jared
    We tried with 1.8 as well as 3.3 both supply and results are same.
  • Can you share your email ID , so that we can share it
