I've tried the following with the Quick Start app v1.2.0, v1.1.0 and v1.0.1.
The log below is from v1.1.0, if I recall correctly. All logs are about same.
Programmed the Asset Tracker v2 without problems but next step, Verification, is failing.
LOG:
2025-05-06T07:06:16.562Z INFO Initialising the bundled nrfutil device
2025-05-06T07:06:16.582Z DEBUG Started watching devices
2025-05-06T07:06:17.051Z INFO Using the bundled core version for nrfutil device: 8.0.0
2025-05-06T07:06:17.242Z INFO Using nrfutil-device version: 2.7.5
2025-05-06T07:06:17.243Z INFO Using nrf-device-lib version: 0.17.41
2025-05-06T07:06:17.243Z INFO Using nrfjprog DLL version: 10.24.2
2025-05-06T07:06:17.243Z INFO Using JLink version: JLink_V8.18
2025-05-06T07:06:17.245Z INFO Your version of SEGGER J-Link (8.18) is newer than the one this app was tested with (7.94i). The tested version is not required, and your J-Link version will most likely work fine. If you get issues related to J-Link with your devices, use the tested version.
2025-05-06T07:06:19.571Z DEBUG Selected device: nRF9160 DK
2025-05-06T07:06:19.651Z DEBUG Changed step: Info
2025-05-06T07:06:21.447Z DEBUG Changed step: Rename
2025-05-06T07:06:23.652Z DEBUG Changed step: Program
2025-05-06T07:07:09.207Z DEBUG Changed step: Verify
2025-05-06T07:07:12.213Z INFO Opened port with options: {"path":"/dev/ttyACM0","baudRate":115200}
2025-05-06T07:07:14.216Z ERROR Error: Received ERROR as return value from AT command
2025-05-06T07:07:14.228Z INFO Closed port: /dev/ttyACM0
When I open the serial terminal on /dev/ttyACM0 and reset the DK, the following log is printed out:
*** Booting nRF Connect SDK v2.8.0-a2386bfc8401 ***
*** Using Zephyr OS v3.7.99-0bc3393fb112 ***
Attempting to boot slot 0.
Attempting to boot from address 0x8200.
I: Verifying signature against key 0.
I: Hash: 0x2e...07
I: Firmware signature verified.
Firmware version 1
*** Booting My Application v2.1.0-dev-4594a8693738 ***
*** Using nRF Connect SDK v2.8.0-a2386bfc8401 ***
I: Starting bootloader
E: Failed to open flash area ID 2 (image 0 slot 1): -19, cannot continue
Any explanation for this?
Something I could do to avoid this problem?
