nRF5340 1-wire EEPROM
I have nrf5340dk and AT21CS01-STUM10-T module. This is EEPROM module. I want to communicate with it by 1-wire.
The problem is that I don't know how to do it. I looked through examples in SDK and DevZone but didn't find anything helpful for me. I found an example with 1-wire in the SDK (v2.8.0), but there is very short code in it and there is no overlay for Nordic board. I see that this example uses the w1 driver. When I looked at the w1.h file, I saw functions for writing and reading, but I didn't try them because I don't know how .overlay file for 1-wire should look like.
Can you help me with it ?
Best Regards
    Zephyr has a 1-wire scanner sample available here:
    https://docs.zephyrproject.org/latest/samples/drivers/w1/scanner/README.html#w1-scanner
    You can setup a overlay for your board similar to this:
    &uart1 {
    	status = "okay";
    	current-speed = <115200>;
    	pinctrl-0 = <&uart1_default>;
    	pinctrl-1 = <&uart1_sleep>;
    	w1: w1 {
    		compatible = "zephyr,w1-serial";
    &pinctrl {
    	uart1_default: uart1_default {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 1, 9)>;
    		group2 {
    			psels = <NRF_PSEL(UART_RX, 1, 8)>;
    			bias-pull-up;
    	uart1_sleep: uart1_sleep {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 1, 9)>,
    			low-power-enable;
    Feel free to change the pinout to your liking.
    Håkon
    Thanks for your reply.
    I tried to use 1w library with my module, but it didn't work.
    Then i found this site
    AT21CS01 | Microchip Technology
    and I downloaded this code:
    https://ww1.microchip.com/downloads/aemDocuments/documents/MPD/ApplicationNotes/AppnoteSourceCode/AN3304_Source_Code_V1.0.0.X.zip
    I ported this code (only low-level.h, low-level.c, operations.h, operations.c files) to ESP32 and it works.
    Then I ported this code to nordic (for now nRF52840dk). But I have problem - my code read only "0xFF" value when EEPROM is connected (or 0x00 when pin is connected to GND). I was checking with Logic Analyzer how single wire signal looks and it is similar to the one generated by ESP (times are also similar).
    I think this problem is caused by pin configuration.
    This is my .overlay file
    	m_pin {
    		compatible = "gpio-leds";
    		m_pin0: m_pin_0 {
    			gpios = <&gpio0 29 (GPIO_OPEN_DRAIN | GPIO_PULL_UP)>;
    			label = "M_PIN";
    	aliases {
    		mpin = &m_pin0;
    and I have this lines in my code:
    int ret;
    if (!gpio_is_ready_dt(&mypin)) {
    	return -1;
    ret = gpio_pin_configure_dt(&mypin, GPIO_INPUT | GPIO_OUTPUT | GPIO_OPEN_DRAIN | GPIO_PULL_UP);
    if (ret < 0) {
    	return -1;
    I also tried to switching pin_configure_dt depending on writing and reading from module but it didn't help.
    // before writing to module
    //ret = gpio_pin_configure_dt(&mypin, GPIO_INPUT | GPIO_OPEN_DRAIN | GPIO_PULL_UP); // I had an error with this line
    ret = gpio_pin_configure_dt(&mypin, GPIO_OUTPUT | GPIO_INPUT | GPIO_OPEN_DRAIN | GPIO_PULL_UP);
    //ret = gpio_pin_configure_dt(&mypin, GPIO_INPUT); // I also tried this - but then in .overlay file was this line: 'gpios = <&gpio0 29 (GPIO_PULL_UP)>;'
    if (ret < 0) {
        printk("\n\tERROR: configure INPUT\n");
    // before reading from module
    ret = gpio_pin_configure_dt(&mypin, GPIO_OUTPUT | GPIO_OPEN_DRAIN | GPIO_PULL_UP);
    if (ret < 0) {
        printk("\n\tERROR: configure OUTPUT\n");
    Best Regards
    Reading a pin is either '0' or '1'. You will not get a serialized data output without fully bit-banging your chosen protocol. I would recommend that you look into the former w1-scanner and try to get that running instead of just reading a gpio input.
    Håkon
    But problem is that w1-scanner doesn't work with my module.
    With the configuration you wrote above I have this output (when my module is connected):
    [00:00:00.251,220] <inf> main: Number of devices found on bus: 0
    and this when nothng is connected to port P1.08:
    [00:00:00.254,791] <err> w1_serial: tx_rx_error reset_present
    [00:00:00.254,791] <inf> main: Number of devices found on bus: -5
    Second thing is that I want to read and write data, and this functionality is not presented in this sample.
    I have the above code which I tested with ESP and it works with my EEPROM module, so I would like to implement this code on nrf but I have problem that nrf is not reading data from EEPROM.
    Best Regards
