FOTA - BLE: Custom Keys issue on compilation
I've recently upgraded my pre-production application on nrf52832 from NCS v2.6.2 to Ncs v3.0.1 also upgraded to HWv2(on interim ncs 2.9.0 as adding custom board for me didn't work on NCS v3.0.1 - Will explain this issue on This thread : Here
Setup:
custom HArdware Nrf52832 Raytac Module.
Ncs v3.0.1SDK with 3.0.1 Toolchain
Note ncs v3.0.1: I've just tried the default LBS example on nrf52dk with FOTA & it works well.
I want to add my custom-generated key for FOTA security. followed "Dev academy tutorial" as well as this page: https://docs.nordicsemi.com/bundle/ncs-3.0.0/page/nrf/app_dev/bootloaders_dfu/mcuboot_nsib/bootloader_adding_sysbuild.html
I followed this link, OPENSS,L to generate the custom key as mentioned : https://docs.nordicsemi.com/bundle/ncs-2.9.0/page/nrf/app_dev/bootloaders_dfu/mcuboot_nsib/bootloader_signature_keys.html
But I'm getting this issue on the terminal while compiling, and my custom keys seem to be getting rejected.
My objective:
1) Would like to use an Upgradable Bootloader, but when I enabled the sysbuild configs, I'm just getting errors (refer screen shoot - hence I've only attached the fully compiling configuration & it's logs here in this thread)
2) I would like to implement the custom private key solution.
My Issues:
1)  secure_boot = n (warning on terminal) -( MCUBoot bootloader key file: C:/ncs/v3.0.1/bootloader/mcuboot/root-rsa-2048.pem
CMake Warning at CMakeLists.txt:393 (message):
WARNING: Using default MCUboot signing key file, this file is for debug use
only and is not secure!)
2) warning: Deprecated symbol DEPRECATED_UART_NRFX_UARTE_LEGACY_SHIM is enabled. (How to solve this?)
3) warning: Deprecated symbol BT_CTLR is enabled (how to solve this?)
4) When I run west update (technically I'm not using the wested workspace though) on ncsv3.0.1, I'm getting issues on old SDK v2.6.2, not found error on the terminal. (see screenshot attached.)
Need Assistance here. Thanks in advance for your help.
  • Hello
    In this case, can you try to set the MCUboot key instead: SB_CONFIG_BOOT_SIGNATURE_KEY_FILE.
    yes this fails as well. tried it on both my personal project & the 52DK LBS project as well.
    logs:
     *  Executing task: nRF Connect: Build [pristine]: BLE/build (active)
    Building BLE
    C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/Nordic/Software/BLE/build c:/Nordic/Software/BLE --pristine --board p1br2/nrf52832 --sysbuild -- -DCONF_FILE=prj.conf -DCONFIG_SIZE_OPTIMIZATIONS=y -DBOARD_ROOT=c:/nordic/software/ble"
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.0.1/zephyr/.cache
    -- Board: p1br2, qualifiers: nrf52832
    Parsing c:/Nordic/Software/BLE/Kconfig.sysbuild
    Loaded configuration 'C:/Nordic/Software/BLE/build/_sysbuild/empty.conf'
    Merged configuration 'c:/Nordic/Software/BLE/sysbuild.conf'
    Configuration saved to 'C:/Nordic/Software/BLE/build/zephyr/.config'
    Kconfig header saved to 'C:/Nordic/Software/BLE/build/_sysbuild/autoconf.h'
       * Running CMake for mcuboot *
    -- Application: C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr
    -- CMake version: 3.21.0
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.1/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/0b393f9e1b/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/Nordic/Software/BLE/boards/p1br2/p1br2.dts
    -- Found devicetree overlay: C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr/app.overlay
    -- Generated zephyr.dts: C:/Nordic/Software/BLE/build/mcuboot/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Nordic/Software/BLE/build/mcuboot/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Nordic/Software/BLE/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Nordic/Software/BLE/build/mcuboot/zephyr/dts.cmake
    Parsing C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/Nordic/Software/BLE/boards/p1br2/p1br2_defconfig'
    Merged configuration 'C:/ncs/v3.0.1/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'C:/Nordic/Software/BLE/sysbuild/mcuboot.conf'
    Merged configuration 'C:/Nordic/Software/BLE/build/mcuboot/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Nordic/Software/BLE/build/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/Nordic/Software/BLE/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    MCUBoot bootloader key file: C:NordicSoftwareBLEFOTA-KeysPrivateECDSA256.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Nordic/Software/BLE/build/mcuboot
       * Running CMake for BLE *
    -- Application: C:/Nordic/Software/BLE
    -- Generated zephyr.dts: C:/Nordic/Software/BLE/build/BLE/zephyr/zephyr.dts
    -- Generated pickled edt: C:/Nordic/Software/BLE/build/BLE/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/Nordic/Software/BLE/build/BLE/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Nordic/Software/BLE/build/BLE/zephyr/dts.cmake
    Parsing C:/Nordic/Software/BLE/Kconfig
    Merged configuration 'C:/Nordic/Software/BLE/prj.conf'
    Merged configuration 'C:/Nordic/Software/BLE/build/BLE/zephyr/misc/generated/extra_kconfig_options.conf'
    Merged configuration 'C:/Nordic/Software/BLE/build/BLE/zephyr/.config.sysbuild'
    Configuration saved to 'C:/Nordic/Software/BLE/build/BLE/zephyr/.config'
    Kconfig header saved to 'C:/Nordic/Software/BLE/build/BLE/zephyr/include/generated/zephyr/autoconf.h'
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    -- Including signing script: C:/ncs/v3.0.1/nrf/cmake/sysbuild/image_signing.cmake
    CMake Error at C:/ncs/v3.0.1/nrf/cmake/sysbuild/image_signing.cmake:45 (message):
      west sign can't find file C:NordicSoftwareBLEFOTA-KeysPrivateECDSA256.pem
      (Note: Relative paths are relative to the west workspace topdir
      "C:/ncs/v3.0.1")
      C:/ncs/v3.0.1/nrf/cmake/sysbuild/image_signing.cmake:239 (zephyr_mcuboot_tasks)
      C:/ncs/v3.0.1/zephyr/CMakeLists.txt:2040 (include)
    See also "C:/Nordic/Software/BLE/build/BLE/CMakeFiles/CMakeOutput.log".
    See also "C:/Nordic/Software/BLE/build/BLE/CMakeFiles/CMakeError.log".
    CMake Error at cmake/modules/sysbuild_extensions.cmake:514 (message):
      CMake configure failed for Zephyr project: BLE
      cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
      cmake/modules/sysbuild_default.cmake:21 (include)
      C:/ncs/v3.0.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
      C:/ncs/v3.0.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      C:/ncs/v3.0.1/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
      template/CMakeLists.txt:10 (find_package)
    See also "C:/Nordic/Software/BLE/build/CMakeFiles/CMakeOutput.log".
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\0b393f9e1b\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe '-Bc:\Nordic\Software\BLE\build' -GNinja -DBOARD=p1br2/nrf52832 -DCONF_FILE=prj.conf -DCONFIG_SIZE_OPTIMIZATIONS=y -DBOARD_ROOT=c:/nordic/software/ble '-SC:\ncs\v3.0.1\zephyr\share\sysbuild' '-DAPP_DIR:PATH=c:\Nordic\Software\BLE'
     *  The terminal process terminated with exit code: 1.
  • Try to escape all the "\"s:
    "C:\\Nordic\\Software\\BLE\\FOTA-Keys\\FOTA-Private-Key-ECDSA-P256.pem"
    No success ..
    Done this.
    But a new development:
    I've did it like this....
    But I still see in logs that the default key is getting used.
    Another Development 2:
    I did it like this ...
    Tested this & it works correctly.
