nrf52840 RCT2 configuration and usage
I'm trying to enable RTC2 for nrf52840 DK to use as a date time clock and set/get over SMP protocol. RTC0 is used for MPSL, RTC1 is used by the system.
I configured MCU MGR option:
CONFIG_MCUMGR_GRP_OS_DATETIME=y
I configured RTC:
CONFIG_COUNTER=y
CONFIG_NRFX_RTC2=y
CONFIG_RTC=y
DTS for RTC2:
aliases {
		rtc = &rtc2;
&rtc2 {
    status = "okay";
The command to set date-time works and return empty result. But when try to get date-time I see strange result. For instance:
  "datetime": "39997-165-36T05:168:00"
And now matter how many times I get it I see the same.
For me it looks like the RTC2 is not initialized. But i check it readiness in main:
if (!device_is_ready(rtc)) {
		printk("Device RTC is not ready\n");
		return 0;
Anything I forget to do to use RTC2 as a date-time source?
  • Hi
    I'm able to set/get epoch time on nRF52840 via RTC2. Can you share more information on your rtc set/get implementation. Are you directly using nrfx library?
    Best Regards,
    Mayank
  • Hi
    Just to check, are you using the os_mgmt_datetime sample in <ncs version>\zephyr\tests\subsys\mgmt\mcumgr\os_mgmt_datetime for this? Where does this strange output print from exactly? Are you sure you have set the date time as reference somewhere in your project so the RTC has a reference point?
    Can you show me the full log of your application running so we can get a better understanding of what exactly is returning this value?
    Simon
  • Hi Simonr,
    In my original project I don't use this example. But I adopted the test you mentioned to reproduce this issue. I attached my project. I did a build for nrf52840dk board with RTC0 used and SDK 3.0.0 version. To test date-time set/get functionality I use AuTerm tool and analyzed the terminal traffic to see what is inside the packets.
    I did next command sequence:
    1. Get current time
    2. Set current time
    3. Get current time
    The traffic looks like the next:
    \06	AAsIAAABAAANBKBXIA==
    \06	ACkJAAAfAAANBL9oZGF0ZXRpbWVzMjk0OC0wMS0wMFQwMDo0NTowMP88ig==
    \06	AC8KAAAlAAAOBKFoZGF0ZXRpbWV4GTIwMjUtMDUtMjBUMTQ6NTU6MTYrMDI6MDDQUw==
    \06	AAwLAAACAAAOBL//9T4=
    \06	AAsIAAABAAAPBKA5QA==
    \06	ACkJAAAfAAAPBL9oZGF0ZXRpbWVzMjk0OC0wMS0wMFQwMDo0NTowMP83Ew==
    This is a Base64 packets and I decrypted them based on the SPM protocol specification and UART transport specification:
    Get
    000b 0800000100000d04 a0 5720
    0029 0900001f00000d04 bf686461746574696d6573323934382d30312d30305430303a34353a3030ff 3c8a
    { "datetime": "2948-01-00T00:45:00"}
    Set
    002f 0a00002500000e04 a1686461746574696d657819323032352d30352d32305431343a35353a31362b30323a3030 d053
    {"datetime": "2025-05-20T14:55:16+02:00"}
    000c 0b00000200000e04 bfff f53e
    Get
    000b 0800000100000f04 a0 3940
    0029 0900001f00000f04 bf686461746574696d6573323934382d30312d30305430303a34353a3030ff 3713
    {_ "datetime": "2948-01-00T00:45:00"}
    As you can see even if I set the proper date-time in the second command with positive response to this command
    I can't get the proper date-time on the following read. What interesting this output is the same as a first read and doesn't change
    os_mgmt_datetime.zip
  • Hi Egor,
    I wanted to try to pitch in my 2 cents here.
    I am suspecting that this is because you have not enabled the counter API
    Enable this in your prj,conf using RTC2 just to be sure since rtc0 is used by RTOS.
    CONFIG_COUNTER=y
    CONFIG_RTC=y
    CONFIG_NRFX_RTC2=y
    also set this your overlay instead of rtc0
    aliases {
        rtc = &rtc2;
    &rtc2 {
        status = "okay";
    I have not tried your sample but if this does not work, then i will try to debug your app on why you have simple date and time feature not working.
