nRF7002 and CONFIG_MBEDTLS_ENABLE_HEAP
I am trying to integrate nRF7002 into my application firmware, by using the "wifi/sta" example in NCS3.0.1.
My application has CONFIG_NRF_SECURITY=y and PSA enabled and also uses BT_SMP, otherwise nothing special. With that CONFIG_MBEDTLS_ENABLE_HEAP is set automatically but then the WIFI code fails with "<err> wpa_supp: Error in pbkdf2_sha1()". I can make it work by explicitly setting CONFIG_MBEDTLS_ENABLE_HEAP=n. I noted that the "wifi/sta" example does not generate a MBEDTLS config.
It would be good if the wifi code would work with other common security configurations.
What are the implications of CONFIG_MBEDTLS_ENABLE_HEAP=n?
    It should be possible to use CONFIG_MBEDTLS_ENABLE_HEAP=n, and you can see some examples of that (for instance here). Which nRF5 device are you using with the nRF7002? Also, can you share your generated prj.conf?
  • At the moment I use the nRF7002DK. Yes so far CONFIG_MBEDTLS_ENABLE_HEAP=n works and is no problem. Do you mean I should share my .config? And which case, failure or working?
    I was thinking about comparing them, and then take it from there to narrow down why you had it enabled in the first place. CONFIG_MBEDTLS_ENABLE_HEAP should not be enabled, and is not enabled if you build whe wifi/sta sample from an unmodified SDK for the DK.
  • Yes I have noted that the sample doesn't activate that config. Somehow with my config MBEDTLS_LEGACY_CRYPTO_C is getting activated. Below is the whole .config for my project:
    CONFIG_SPI=y
    CONFIG_GPIO=y
    # CONFIG_DW3000 is not set
    CONFIG_UWB_SLEEP_ENABLED=y
    # CONFIG_INPUT is not set
    CONFIG_WIFI=y
    CONFIG_NET_L2_ETHERNET=y
    CONFIG_ADC_INIT_PRIORITY=50
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    CONFIG_NET_IPV6=y
    # CONFIG_NET_CONFIG_NEED_IPV6 is not set
    CONFIG_BT_HCI_ACL_FLOW_CONTROL=y
    CONFIG_BT_HCI_VS=y
    CONFIG_FLASH_LOAD_SIZE=0x40000
    CONFIG_SRAM_SIZE=448
    CONFIG_FLASH_LOAD_OFFSET=0x10000
    CONFIG_NUM_IRQS=69
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_SOC_RESET_HOOK=y
    CONFIG_MAIN_STACK_SIZE=5200
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_CLOCK_CONTROL=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_ROM_START_OFFSET=0
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_XIP=y
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_CPU_HAS_ARM_MPU=y
    # CONFIG_COUNTER is not set
    # CONFIG_SHARED_INTERRUPTS is not set
    CONFIG_PM_DEVICE=y
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_BT_AUTO_PHY_UPDATE=y
    CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
    CONFIG_FPU=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2560
    # CONFIG_BT_USER_PHY_UPDATE is not set
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_PHY_INIT_PRIORITY=70
    CONFIG_USE_DT_CODE_PARTITION=y
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_GEN_ISR_TABLES=y
    CONFIG_INIT_STACKS=y
    CONFIG_TIMESLICE_SIZE=0
    # CONFIG_REGULATOR is not set
    CONFIG_PM_DEVICE_SYSTEM_MANAGED=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    # CONFIG_BUILD_OUTPUT_S19 is not set
    CONFIG_FLASH_FILL_BUFFER_SIZE=32
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_HW_STACK_PROTECTION=y
    CONFIG_NET_TCP_CHECKSUM=y
    CONFIG_NET_UDP_CHECKSUM=y
    # CONFIG_HCI_NXP_ENABLE_AUTO_SLEEP is not set
    # CONFIG_HCI_NXP_SET_CAL_DATA is not set
    # CONFIG_MFD is not set
    # CONFIG_HCI_NXP_RX_THREAD is not set
    CONFIG_SERIAL=y
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_NET_L2_IEEE802154 is not set
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    # CONFIG_MEMC is not set
    # CONFIG_CACHE is not set
    CONFIG_LOG=y
    CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_ROMSTART_RELOCATION_ROM is not set
    CONFIG_DCACHE_LINE_SIZE=32
    # CONFIG_RESET is not set
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET=y
    CONFIG_LOG_DOMAIN_NAME=""
    # CONFIG_ASSERT is not set
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_PM_DEVICE_POWER_DOMAIN=y
    # CONFIG_PM_DEVICE_RUNTIME is not set
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    # CONFIG_SYSCON is not set
    CONFIG_SERIAL_INIT_PRIORITY=50
    CONFIG_ENTROPY_INIT_PRIORITY=50
    # CONFIG_INTC_MTK_ADSP is not set
    # CONFIG_MTK_ADSP_TIMER is not set
    CONFIG_CONSOLE=y
    # CONFIG_WINSTREAM is not set
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_SOC_TOOLCHAIN_NAME="amd_acp_6_0_adsp"
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_REBOOT=y
    CONFIG_FLASH_INIT_PRIORITY=50
    CONFIG_GEN_IRQ_START_VECTOR=0
    CONFIG_SRAM_OFFSET=0
    # CONFIG_POWER_DOMAIN is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_SPI_NOR=y
    # CONFIG_MCUBOOT_GENERATE_UNSIGNED_IMAGE is not set
    # CONFIG_MCUBOOT_GENERATE_CONFIRMED_IMAGE is not set
    CONFIG_BOOTLOADER_MCUBOOT=y
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_WATCHDOG=y
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_BT_BUF_ACL_TX_COUNT=3
    CONFIG_BT_BUF_CMD_TX_SIZE=255
    CONFIG_BT_BUF_EVT_RX_SIZE=255
    CONFIG_BT_BUF_ACL_TX_SIZE=251
    CONFIG_BT_BUF_ACL_RX_SIZE=251
    CONFIG_BT_L2CAP_TX_MTU=247
    # Devicetree Info
    CONFIG_DT_HAS_ARDUINO_UNO_ADC_ENABLED=y
    CONFIG_DT_HAS_ARDUINO_HEADER_R3_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_FORWARDER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_QSPI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_HFXO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_LFXO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_OSCILLATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53X_REGULATOR_HV_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53X_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF7002_COEX_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF7002_QSPI_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_IPC_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
    # end of Devicetree Info
    # Modules
    # CONFIG_BUILD_ONLY_NO_BLOBS is not set
    # Available modules.
    # nrf (/home/br1/dev/nordic/ncs/v3.0.1/nrf)
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_LOG_BUFFER_SIZE=2048
    CONFIG_NET_IPV6_NBR_CACHE=y
    CONFIG_NET_IPV6_MLD=y
    CONFIG_NET_PKT_RX_COUNT=16
    CONFIG_NET_PKT_TX_COUNT=16
    # CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
    # CONFIG_MBEDTLS_SSL_MAX_FRAGMENT_LENGTH is not set
    CONFIG_MBEDTLS_ENTROPY_C=y
    CONFIG_MBEDTLS_CIPHER_MODE_CBC=y
    CONFIG_MBEDTLS_CIPHER_MODE_CTR=y
    CONFIG_MBEDTLS_CHACHA20_C=y
    CONFIG_MBEDTLS_POLY1305_C=y
    CONFIG_MBEDTLS_CHACHAPOLY_C=y
    CONFIG_MBEDTLS_DHM_C=y
    # CONFIG_MBEDTLS_RSA_C is not set
    CONFIG_MBEDTLS_SHA512_C=y
    CONFIG_MBEDTLS_GCM_C=y
    CONFIG_MBEDTLS_SSL_SRV_C=y
    CONFIG_MBEDTLS_SSL_COOKIE_C=y
    CONFIG_MBEDTLS_SSL_CLI_C=y
    CONFIG_MBEDTLS_SSL_TLS_C=y
    CONFIG_MBEDTLS_HEAP_SIZE=512
    # CONFIG_NET_PKT_TXTIME is not set
    # CONFIG_NET_PKT_TIMESTAMP is not set
    CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT=32
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_NET_RX_STACK_SIZE=4096
    CONFIG_NET_TX_STACK_SIZE=4096
    CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=16384
    CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384
    CONFIG_MBEDTLS_KEY_EXCHANGE_PSK_ENABLED=y
    CONFIG_ZMS=y
    # CONFIG_NVS is not set
    CONFIG_MBEDTLS_SHA1_C=y
    CONFIG_MBEDTLS=y
    # CONFIG_MBEDTLS_TLS_VERSION_1_2 is not set
    CONFIG_MBEDTLS_MAC_SHA256_ENABLED=y
    # CONFIG_MBEDTLS_CTR_DRBG_ENABLED is not set
    CONFIG_MBEDTLS_MD_C=y
    CONFIG_MBEDTLS_TLS_LIBRARY=y
    CONFIG_MBEDTLS_X509_LIBRARY=y
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_ECP_C=y
    CONFIG_MBEDTLS_CTR_DRBG_C=y
    CONFIG_MBEDTLS_CMAC_C=y
    CONFIG_MBEDTLS_CCM_C=y
    # CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C is not set
    CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    CONFIG_NRF_SECURITY_ENABLER=y
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU is not set
    # CONFIG_IMG_ERASE_PROGRESSIVELY is not set
    CONFIG_UPDATEABLE_IMAGE_NUMBER=1
    CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
    # CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP is not set
    # Subsystems
    # Bootloader
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # CONFIG_NRF53_ENFORCE_IMAGE_VERSION_EQUALITY is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y
    CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_COMPANY_ID_NORDIC=0x0059
    CONFIG_BT_COMPANY_ID=0x0059
    CONFIG_BT_MAX_CONN=3
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_LONG_WQ_STACK_SIZE=1800
    CONFIG_BT_HCI_TX_STACK_SIZE=1024
    CONFIG_BT_RX_STACK_SIZE=4096
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_SCAN is not set
    # CONFIG_BT_CONN_CTX is not set
    CONFIG_BT_EXT_ADV_MAX_ADV_SET=6
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    CONFIG_BT_GATT_AUTO_SEC_REQ=y
    # end of Bluetooth Services
    # BLE over nRF RPC
    # CONFIG_BT_RPC is not set
    CONFIG_HEAP_MEM_POOL_SIZE=37000
    # CONFIG_BT_SHELL is not set
    # CONFIG_BT_RPC_STACK is not set
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_OBSERVER=y
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    CONFIG_BT_EXT_ADV=y
    # CONFIG_BT_EXT_ADV_LEGACY_SUPPORT is not set
    # CONFIG_BT_PER_ADV is not set
    # CONFIG_BT_PER_ADV_SYNC is not set
    # CONFIG_BT_PER_ADV_SYNC_RSP is not set
    # CONFIG_BT_EXT_ADV_CODING_SELECTION is not set
    CONFIG_BT_LOG=y
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_LOG_LEVEL_INF is not set
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    CONFIG_BT_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_LOG_LEVEL=3
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL=3
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
    CONFIG_BT_RPA_LOG_LEVEL=3
    # CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RPA_LOG_LEVEL_INF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CRYPTO_LOG_LEVEL=3
    # CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_ATT_LOG_LEVEL=3
    # CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
    CONFIG_BT_GATT_LOG_LEVEL=3
    # CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_GATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
    CONFIG_BT_L2CAP_LOG_LEVEL=3
    # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_HCI_CORE_LOG_LEVEL=3
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CONN_LOG_LEVEL=3
    # CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONN_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y
    CONFIG_BT_KEYS_LOG_LEVEL=3
    # CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SMP_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SMP_LOG_LEVEL=3
    # CONFIG_BT_SMP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SMP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SMP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
    CONFIG_BT_SERVICE_LOG_LEVEL=3
    # CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_DIS is not set
    # CONFIG_BT_CTS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_ZEPHYR_NUS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_BAS_BLS is not set
    CONFIG_BT_BUF_ACL_RX_COUNT_EXTRA=0
    CONFIG_BT_BUF_ACL_RX_COUNT=0
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=58
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
    CONFIG_BT_HAS_HCI_VS=y
    # CONFIG_BT_HCI_VS_FATAL_ERROR is not set
    # CONFIG_BT_HCI_VS_EXT_DETECT is not set
    # CONFIG_BT_HCI_MESH_EXT is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_RPA=y
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    # CONFIG_BT_HCI_ERR_TO_STR is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    # CONFIG_BT_DEBUG_MONITOR_RTT is not set
    CONFIG_BT_LONG_WQ=y
    CONFIG_BT_LONG_WQ_PRIO=10
    CONFIG_BT_LONG_WQ_INIT_PRIO=50
    CONFIG_BT_HCI_HOST=y
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_CONN_TX_NOTIFY_WQ is not set
    # CONFIG_BT_MESH is not set
    # CONFIG_BT_AUDIO is not set
    CONFIG_BT_HOST_CRYPTO=y
    CONFIG_BT_HOST_CRYPTO_PRNG=y
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_LIM_ADV_TIMEOUT=30
    CONFIG_BT_CONN_TX_USER_DATA_SIZE=16
    CONFIG_BT_CONN_FRAG_COUNT=3
    CONFIG_BT_CONN_TX_MAX=3
    # CONFIG_BT_CONN_PARAM_ANY is not set
    # CONFIG_BT_CONN_CHECK_NULL_BEFORE_CREATE is not set
    # CONFIG_BT_USER_DATA_LEN_UPDATE is not set
    # CONFIG_BT_REMOTE_INFO is not set
    CONFIG_BT_SMP=y
    # CONFIG_BT_SECURITY_ERR_TO_STR is not set
    # CONFIG_BT_SMP_ERR_TO_STR is not set
    # CONFIG_BT_PASSKEY_KEYPRESS is not set
    # CONFIG_BT_PRIVACY is not set
    # CONFIG_BT_SIGNING is not set
    # CONFIG_BT_SMP_APP_PAIRING_ACCEPT is not set
    CONFIG_BT_SMP_SC_PAIR_ONLY=y
    CONFIG_BT_SMP_SC_ONLY=y
    # CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE is not set
    # CONFIG_BT_ID_UNPAIR_MATCHING_BONDS is not set
    # CONFIG_BT_ID_ALLOW_UNAUTH_OVERWRITE is not set
    CONFIG_BT_FIXED_PASSKEY=y
    # CONFIG_BT_USE_DEBUG_KEYS is not set
    # CONFIG_BT_BONDABLE is not set
    # CONFIG_BT_BONDABLE_PER_CONNECTION is not set
    # CONFIG_BT_STORE_DEBUG_KEYS is not set
    CONFIG_BT_SMP_ENFORCE_MITM=y
    # CONFIG_BT_KEYS_OVERWRITE_OLDEST is not set
    CONFIG_BT_SMP_MIN_ENC_KEY_SIZE=16
    CONFIG_BT_L2CAP_TX_BUF_COUNT=3
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    # CONFIG_BT_L2CAP_DYNAMIC_CHANNEL is not set
    # CONFIG_BT_L2CAP_SEG_RECV is not set
    # CONFIG_BT_L2CAP_RECONFIGURE_EXPLICIT is not set
    # CONFIG_BT_ATT_ERR_TO_STR is not set
    CONFIG_BT_ATT_TX_COUNT=3
    CONFIG_BT_ATT_PREPARE_COUNT=0
    CONFIG_BT_ATT_RETRY_ON_SEC_ERR=y
    # CONFIG_BT_ATT_SENT_CB_AFTER_TX is not set
    CONFIG_BT_GATT_AUTO_RESUBSCRIBE=y
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    # CONFIG_BT_GATT_DYNAMIC_DB is not set
    CONFIG_BT_GATT_CACHING=y
    # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
    # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    CONFIG_BT_GATT_CLIENT=y
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    # CONFIG_BT_GATT_AUTO_DISCOVER_CCC is not set
    # CONFIG_BT_GATT_AUTO_UPDATE_MTU is not set
    # CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS is not set
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=24
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=40
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=42
    CONFIG_BT_DEVICE_NAME_GATT_WRITABLE=y
    # CONFIG_DEVICE_NAME_GATT_WRITABLE_NONE is not set
    CONFIG_DEVICE_NAME_GATT_WRITABLE_ENCRYPT=y
    # CONFIG_DEVICE_NAME_GATT_WRITABLE_AUTHEN is not set
    # CONFIG_BT_GATT_AUTHORIZATION_CUSTOM is not set
    CONFIG_BT_MAX_PAIRED=2
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    CONFIG_BT_BACKGROUND_SCAN_INTERVAL=2048
    CONFIG_BT_BACKGROUND_SCAN_WINDOW=18
    CONFIG_BT_EXT_SCAN_BUF_SIZE=229
    # CONFIG_BT_SCAN_WITH_IDENTITY is not set
    # CONFIG_BT_SCAN_AND_INITIATE_IN_PARALLEL is not set
    CONFIG_BT_DEVICE_NAME_DYNAMIC=y
    CONFIG_BT_DEVICE_NAME_MAX=28
    CONFIG_BT_DEVICE_NAME="Zephyr"
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_DEVICE_APPEARANCE=0
    CONFIG_BT_ID_MAX=2
    # CONFIG_BT_DF is not set
    CONFIG_BT_ECC=y
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_CLASSIC is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    CONFIG_BT_CRYPTO=y
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    CONFIG_DFU_TARGET=y
    CONFIG_DFU_TARGET_MCUBOOT=y
    CONFIG_DFU_TARGET_STREAM=y
    # CONFIG_DFU_TARGET_MCUBOOT_SAVE_PROGRESS is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_OFF is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_ERR is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_WRN is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_INF is not set
    # CONFIG_DFU_TARGET_LOG_LEVEL_DBG is not set
    CONFIG_DFU_TARGET_LOG_LEVEL_DEFAULT=y
    CONFIG_DFU_TARGET_LOG_LEVEL=3
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_EMDS is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # CONFIG_NRF_CLOUD is not set
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_DOWNLOADER is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    CONFIG_WIFI_READY_LIB=y
    # CONFIG_WIFI_READY_LIB_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_READY_LIB_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_READY_LIB_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_READY_LIB_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_READY_LIB_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_READY_LIB_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_READY_LIB_LOG_LEVEL=3
    CONFIG_WIFI_READY_MAX_CALLBACKS=2
    CONFIG_WIFI_READY_INIT_PRIORITY=90
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    CONFIG_NRF_WIFI_PATCHES_EXT_FLASH_DISABLED=y
    # CONFIG_NRF_WIFI_PATCHES_EXT_FLASH_XIP is not set
    # CONFIG_NRF_WIFI_PATCHES_EXT_FLASH_STORE is not set
    CONFIG_CUSTOM_LINKER_SCRIPT="/home/br1/dev/nordic/ncs/v3.0.1/zephyr/../nrf/subsys/net/lib/nrf70_fw_ext/rpu_fw_patche
    s.ld"
    CONFIG_HOSTAP_CRYPTO_ALT_LEGACY_PSA=y
    # CONFIG_HOSTAP_CRYPTO_ALT_PSA is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_WPA3=y
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_CRYPTO_ENTERPRISE is not set
    # end of Application protocols
    # CONFIG_OPENTHREAD_RPC is not set
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # CONFIG_NFC_RPC is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # CONFIG_SHELL_IPC is not set
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_CX_ANY_SUPPORT=y
    CONFIG_MPSL_CX_NRF70_SUPPORT=y
    # CONFIG_MPSL_CX is not set
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=26
    CONFIG_MPSL_HFCLK_LATENCY=1400
    CONFIG_MPSL_INIT_PRIORITY=40
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0x4000
    CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0x2000
    # Zephyr subsystem configurations
    CONFIG_RPMSG_NRF53_SRAM_SIZE=0x10000
    CONFIG_PM_PARTITION_SIZE_ZMS_STORAGE=0x6000
    # CONFIG_PM_PARTITION_REGION_ZMS_STORAGE_EXTERNAL is not set
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_ENABLED=y
    CONFIG_PM_EXTERNAL_FLASH_PATH="/soc/peripheral@50000000/spi@a000/mx25r6435f@0"
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=67108864
    CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
    CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x80000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # Full Modem Firmware Update Management(FMFU)
    # end of Full Modem Firmware Update Management(FMFU)
    # Additional MCUmgr configuration
    # Additional MCUmgr group configuration
    # Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr group configuration
    # end of Additional MCUmgr configuration
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # Nordic-added meta types
    CONFIG_PSA_HAS_AEAD_SUPPORT=y
    CONFIG_PSA_HAS_ASYM_SIGN_SUPPORT=y
    CONFIG_PSA_HAS_CIPHER_SUPPORT=y
    CONFIG_PSA_HAS_HASH_SUPPORT=y
    CONFIG_PSA_HAS_KEY_AGREEMENT=y
    CONFIG_PSA_HAS_KEY_DERIVATION=y
    CONFIG_PSA_HAS_KEY_SUPPORT=y
    CONFIG_PSA_HAS_MAC_SUPPORT=y
    # Nordic added alg types
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y
    CONFIG_PSA_WANT_ALG_CHACHA20=y
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_AES_KW is not set
    # CONFIG_PSA_WANT_ALG_AES_KWP is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE_PT is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE is not set
    # Nordic added ECC curve types
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    # Nordic addded RNG configuration
    CONFIG_PSA_WANT_GENERATE_RANDOM=y
    # Nordic added key types
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set
    CONFIG_MBEDTLS_CFG_FILE="nrf-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-user-config.h"
    CONFIG_MBEDTLS_X509_USE_C=y
    # CONFIG_MBEDTLS_X509_CREATE_C is not set
    CONFIG_MBEDTLS_X509_CHECK_KEY_USAGE=y
    CONFIG_MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE=y
    CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
    CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
    CONFIG_MBEDTLS_X509_CRT_PARSE_C=y
    # CONFIG_MBEDTLS_X509_CSR_WRITE_C is not set
    CONFIG_MBEDTLS_X509_REMOVE_INFO=y
    CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
    CONFIG_MBEDTLS_SSL_ENCRYPT_THEN_MAC=y
    CONFIG_MBEDTLS_SSL_EXTENDED_MASTER_SECRET=y
    # CONFIG_MBEDTLS_TLS_VERSION_1_3 is not set
    # CONFIG_MBEDTLS_DEBUG_C is not set
    # CONFIG_MBEDTLS_MEMORY_DEBUG is not set
    CONFIG_MBEDTLS_SSL_ALL_ALERT_MESSAGES=y
    CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION=y
    # CONFIG_MBEDTLS_SSL_DEBUG_ALL is not set
    CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE=y
    # CONFIG_MBEDTLS_SSL_RENEGOTIATION is not set
    # CONFIG_MBEDTLS_SSL_SESSION_TICKETS is not set
    # CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION is not set
    # CONFIG_MBEDTLS_SSL_CACHE_C is not set
    # CONFIG_MBEDTLS_SSL_TICKET_C is not set
    CONFIG_MBEDTLS_SSL_EXPORT_KEYS=y
    CONFIG_MBEDTLS_SSL_CIPHERSUITES=""
    # TLS/DTL Cipher Suites
    CONFIG_MBEDTLS_HAS_CBC_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_GCM_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_CCM_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_CHACHAPOLY_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_CIPHER_MODE_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_ECDH_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_ECDSA_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_HAS_ECJPAKE_CIPHERSUITE_REQUIREMENTS=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED=y
    CONFIG_MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED=y
    # end of TLS/DTL Cipher Suites
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_PSA_CORE_OBERON=y
    # PSA Driver Support
    CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y
    CONFIG_PSA_CRYPTO_DRIVER_OBERON=y
    # CONFIG_PSA_CRYPTO_DRIVER_CC3XX is not set
    # Choose DRBG algorithm
    CONFIG_PSA_WANT_ALG_CTR_DRBG=y
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    CONFIG_PSA_USE_CTR_DRBG_DRIVER=y
    # end of Choose DRBG algorithm
    # CryptoCell PSA Driver Configuration
    CONFIG_PSA_USE_CC3XX_CTR_DRBG_DRIVER=y
    # end of CryptoCell PSA Driver Configuration
    # CRACEN PSA Driver Configuration
    # end of CRACEN PSA Driver Configuration
    # AES key size configuration
    CONFIG_PSA_WANT_AES_KEY_SIZE_128=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_192=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_256=y
    # end of AES key size configuration
    # RSA key size configuration
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_2048 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set
    CONFIG_PSA_MAX_RSA_KEY_BITS=0
    # end of RSA key size configuration
    CONFIG_PSA_ACCEL_GENERATE_RANDOM=y
    CONFIG_PSA_NEED_CC3XX_CTR_DRBG_DRIVER=y
    # CONFIG_CRACEN_LOG_LEVEL_OFF is not set
    # CONFIG_CRACEN_LOG_LEVEL_ERR is not set
    # CONFIG_CRACEN_LOG_LEVEL_WRN is not set
    # CONFIG_CRACEN_LOG_LEVEL_INF is not set
    # CONFIG_CRACEN_LOG_LEVEL_DBG is not set
    CONFIG_CRACEN_LOG_LEVEL_DEFAULT=y
    CONFIG_CRACEN_LOG_LEVEL=3
    CONFIG_PSA_NEED_OBERON_CCM_AES=y
    CONFIG_PSA_NEED_OBERON_GCM_AES=y
    CONFIG_PSA_NEED_OBERON_CHACHA20_POLY1305=y
    CONFIG_PSA_NEED_OBERON_AEAD_DRIVER=y
    CONFIG_PSA_NEED_OBERON_CTR_AES=y
    CONFIG_PSA_NEED_OBERON_CBC_NO_PADDING_AES=y
    CONFIG_PSA_NEED_OBERON_CBC_PKCS7_AES=y
    CONFIG_PSA_NEED_OBERON_ECB_NO_PADDING_AES=y
    CONFIG_PSA_NEED_OBERON_STREAM_CIPHER_CHACHA20=y
    CONFIG_PSA_NEED_OBERON_CIPHER_DRIVER=y
    CONFIG_PSA_NEED_OBERON_ECDH_SECP_R1_256=y
    CONFIG_PSA_NEED_OBERON_ECDH=y
    CONFIG_PSA_NEED_OBERON_KEY_AGREEMENT_DRIVER=y
    CONFIG_PSA_NEED_OBERON_ECDSA_SECP_R1_256=y
    CONFIG_PSA_NEED_OBERON_ECDSA_VERIFY=y
    CONFIG_PSA_NEED_OBERON_ECDSA_SIGN=y
    CONFIG_PSA_NEED_OBERON_ECDSA_DETERMINISTIC=y
    CONFIG_PSA_NEED_OBERON_ECDSA_RANDOMIZED=y
    CONFIG_PSA_NEED_OBERON_SHA_1=y
    CONFIG_PSA_NEED_OBERON_SHA_224=y
    CONFIG_PSA_NEED_OBERON_SHA_256=y
    CONFIG_PSA_NEED_OBERON_SHA_384=y
    CONFIG_PSA_NEED_OBERON_SHA_512=y
    CONFIG_PSA_NEED_OBERON_HASH_DRIVER=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_PUBLIC_KEY_SECP_R1_256=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_IMPORT_SECP_R1_256=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_EXPORT_SECP_R1_256=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_GENERATE_SECP_R1_256=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_DERIVE_SECP_R1_256=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_PUBLIC_KEY_SECP_R1_256=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT_SECP_R1_256=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT_SECP_R1_256=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE_SECP_R1_256=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_PUBLIC_KEY_SECP=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_IMPORT_SECP=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_EXPORT_SECP=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_GENERATE_SECP=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_DERIVE_SECP=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_PUBLIC_KEY_SECP=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT_SECP=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT_SECP=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE_SECP=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_PUBLIC_KEY=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_ECC_KEY_PAIR_DERIVE=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_PUBLIC_KEY=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT=y
    CONFIG_PSA_NEED_OBERON_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE=y
    CONFIG_PSA_NEED_OBERON_KEY_MANAGEMENT_DRIVER=y
    CONFIG_PSA_NEED_OBERON_HMAC=y
    CONFIG_PSA_NEED_OBERON_CMAC=y
    CONFIG_PSA_NEED_OBERON_MAC_DRIVER=y
    CONFIG_PSA_NEED_OBERON_HKDF=y
    CONFIG_PSA_NEED_OBERON_TLS12_PRF=y
    CONFIG_PSA_NEED_OBERON_TLS12_PSK_TO_MS=y
    CONFIG_PSA_NEED_OBERON_PBKDF2_AES_CMAC_PRF_128=y
    CONFIG_PSA_NEED_OBERON_TLS12_ECJPAKE_TO_PMS=y
    CONFIG_PSA_NEED_OBERON_KEY_DERIVATION_DRIVER=y
    CONFIG_PSA_NEED_OBERON_ASYMMETRIC_SIGNATURE_DRIVER=y
    # PSA API support
    # CONFIG_MBEDTLS_USE_PSA_CRYPTO is not set
    # CONFIG_MBEDTLS_PSA_STATIC_KEY_SLOTS is not set
    # end of PSA API support
    CONFIG_MBEDTLS_PLATFORM_MEMORY=y
    CONFIG_MBEDTLS_PLATFORM_C=y
    CONFIG_MBEDTLS_MEMORY_C=y
    CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y
    CONFIG_MBEDTLS_THREADING_C=y
    CONFIG_MBEDTLS_BASE64_C=y
    CONFIG_MBEDTLS_OID_C=y
    CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y
    CONFIG_MBEDTLS_THREADING_ALT=y
    CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT=y
    CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT=y
    CONFIG_MBEDTLS_AES_ENCRYPT_ALT=y
    CONFIG_MBEDTLS_AES_DECRYPT_ALT=y
    CONFIG_MBEDTLS_CHACHA20_ALT=y
    CONFIG_MBEDTLS_POLY1305_ALT=y
    CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT=y
    CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT=y
    CONFIG_MBEDTLS_ECDSA_GENKEY_ALT=y
    CONFIG_MBEDTLS_ECDSA_SIGN_ALT=y
    CONFIG_MBEDTLS_ECDSA_VERIFY_ALT=y
    CONFIG_MBEDTLS_ECJPAKE_ALT=y
    CONFIG_MBEDTLS_SHA1_ALT=y
    CONFIG_MBEDTLS_SHA224_ALT=y
    CONFIG_MBEDTLS_SHA256_ALT=y
    CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y
    CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1
    CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y
    # CONFIG_NRF_SECURITY_ADVANCED is not set
    CONFIG_OBERON_ONLY_PSA_ENABLED=y
    CONFIG_OBERON_ONLY_ENABLED=y
    # Legacy mbed TLS crypto APIs
    CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6
    CONFIG_MBEDTLS_MPI_MAX_SIZE=256
    # CONFIG_CC3XX_BACKEND is not set
    # CONFIG_OBERON_BACKEND is not set
    CONFIG_MBEDTLS_HMAC_DRBG_C=y
    CONFIG_MBEDTLS_AES_C=y
    # Cipher Selection
    # CBC cipher padding modes
    CONFIG_MBEDTLS_CIPHER_PADDING_PKCS7=y
    CONFIG_MBEDTLS_CIPHER_PADDING_ONE_AND_ZEROS=y
    CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS_AND_LEN=y
    CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS=y
    # CONFIG_MBEDTLS_AES_FEWER_TABLES is not set
    CONFIG_MBEDTLS_AES_ROM_TABLES=y
    # end of CBC cipher padding modes
    # CONFIG_MBEDTLS_AES_ONLY_128_BIT_KEY_LENGTH is not set
    # AEAD  - Authenticated Encryption with Associated Data
    # end of AEAD  - Authenticated Encryption with Associated Data
    CONFIG_MBEDTLS_ECDH_C=y
    CONFIG_MBEDTLS_ECDSA_C=y
    CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=y
    CONFIG_MBEDTLS_ECJPAKE_C=y
    # ECC curves
    # CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED is not set
    CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
    # CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_DP_CURVE448_ENABLED is not set
    # end of ECC curves
    CONFIG_MBEDTLS_HKDF_C=y
    # SHA - Secure Hash Algorithm
    CONFIG_MBEDTLS_MD5_C=y
    CONFIG_MBEDTLS_SHA224_C=y
    CONFIG_MBEDTLS_SHA256_C=y
    # CONFIG_MBEDTLS_SHA256_SMALLER is not set
    CONFIG_MBEDTLS_SHA384_C=y
    # CONFIG_MBEDTLS_512_SMALLER is not set
    # end of SHA - Secure Hash Algorithm
    # CONFIG_MBEDTLS_FORCE_LEGACY_MD is not set
    # CONFIG_MBEDTLS_FORCE_LEGACY_CIPHER is not set
    CONFIG_MBEDTLS_CIPHER_C=y
    CONFIG_MBEDTLS_PK_C=y
    CONFIG_MBEDTLS_PKCS5_C=y
    CONFIG_MBEDTLS_PK_WRITE_C=y
    CONFIG_MBEDTLS_PK_PARSE_C=y
    CONFIG_MBEDTLS_PK_PARSE_EC_EXTENDED=y
    # CONFIG_MBEDTLS_PEM_PARSE_C is not set
    # CONFIG_MBEDTLS_PEM_WRITE_C is not set
    # end of Legacy mbed TLS crypto APIs
    # Zephyr legacy configurations
    # CONFIG_MBEDTLS_DTLS is not set
    CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED=y
    # CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_MD5_ENABLED is not set
    # CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER is not set
    # CONFIG_MBEDTLS_MD is not set
    # CONFIG_MBEDTLS_ENTROPY_ENABLED is not set
    # CONFIG_MBEDTLS_GENPRIME_ENABLED is not set
    # end of Zephyr legacy configurations
    CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
    # end of nRF Security
    # CONFIG_NET_CORE_MONITOR is not set
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEST is not set
    # Log levels
    # end of Log levels
    # end of Audio Modules
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEMPLATE is not set
    # CONFIG_UART_ASYNC_ADAPTER is not set
    # CONFIG_TRUSTED_STORAGE is not set
    # Logging over RPC
    # CONFIG_LOG_FORWARDER_RPC is not set
    # CONFIG_LOG_BACKEND_RPC is not set
    # end of Logging over RPC
    # CONFIG_SUIT is not set
    # CONFIG_DULT is not set
    # CONFIG_NRF_COMPRESS is not set
    # MCUboot IDs (informative only, do not change)
    CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=0
    CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
    # end of MCUboot IDs (informative only, do not change)
    # end of Subsystems
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # CONFIG_APP_JWT is not set
    # Binary libraries
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
    CONFIG_FPROTECT_BLOCK_SIZE=0x4000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_AT_PARSER is not set
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    # CONFIG_SMS is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    # CONFIG_HW_UNIQUE_KEY is not set
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_IDENTITY_KEY is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    CONFIG_NCS_BOOT_BANNER=y
    CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="My Application"
    CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
    CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_ENTROPY_CC3XX=y
    # CONFIG_FLASH_RPC is not set
    CONFIG_HW_CC3XX=y
    # CONFIG_SOC_FLASH_NRF_RADIO_SYNC_RPC is not set
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # CONFIG_IPC_UART is not set
    # end of Device Drivers
    # External libraries
    # CONFIG_GETOPT_LIB is not set
    # end of External libraries
    # Test
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # CONFIG_MOCK_NRF_RPC is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/home/br1/dev/nordic/ncs/v3.0.1/nrf)
    # hostap (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/hostap)
    CONFIG_WIFI_NM_WPA_SUPPLICANT=y
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_HOSTAP=30000
    CONFIG_WIFI_NM_WPA_SUPPLICANT_THREAD_STACK_SIZE=5800
    CONFIG_WIFI_NM_WPA_SUPPLICANT_WQ_STACK_SIZE=4400
    CONFIG_WIFI_NM_WPA_SUPPLICANT_WQ_PRIO=7
    CONFIG_WIFI_NM_WPA_SUPPLICANT_PRIO=0
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NM_WPA_SUPPLICANT_LOG_LEVEL=3
    CONFIG_WIFI_NM_WPA_SUPPLICANT_DEBUG_LEVEL=5
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_ADVANCED_FEATURES is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_WEP is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_CRYPTO_ALT is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_CRYPTO_NONE is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_CRYPTO_EXT=y
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_CRYPTO_MBEDTLS_PSA is not set
    # CONFIG_EAP_TLS is not set
    # CONFIG_EAP_TTLS is not set
    # CONFIG_EAP_PEAP is not set
    # CONFIG_EAP_MD5 is not set
    # CONFIG_EAP_GTC is not set
    # CONFIG_EAP_MSCHAPV2 is not set
    # CONFIG_EAP_LEAP is not set
    # CONFIG_EAP_PSK is not set
    # CONFIG_EAP_PAX is not set
    # CONFIG_EAP_SAKE is not set
    # CONFIG_EAP_GPSK is not set
    # CONFIG_EAP_PWD is not set
    # CONFIG_EAP_EKE is not set
    # CONFIG_EAP_IKEV2 is not set
    # CONFIG_EAP_SIM is not set
    # CONFIG_EAP_AKA is not set
    # CONFIG_EAP_FAST is not set
    # CONFIG_EAP_ALL is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_AP is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_WPS is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_P2P is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_EAPOL is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_CLI is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_INF_MON=y
    # CONFIG_WIFI_NM_HOSTAPD_CRYPTO_ENTERPRISE is not set
    # CONFIG_EAP_SERVER_TLS is not set
    # CONFIG_EAP_SERVER_IDENTITY is not set
    # CONFIG_EAP_SERVER_MD5 is not set
    # CONFIG_EAP_SERVER_MSCHAPV2 is not set
    # CONFIG_EAP_SERVER_PEAP is not set
    # CONFIG_EAP_SERVER_GTC is not set
    # CONFIG_EAP_SERVER_TTLS is not set
    # CONFIG_EAP_SERVER_ALL is not set
    CONFIG_WIFI_NM_WPA_SUPPLICANT_BSS_MAX_IDLE_TIME=300
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_NO_DEBUG is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_DPP is not set
    # CONFIG_WPA_CLI is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_ROAMING is not set
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_SKIP_DHCP_ON_ROAMING is not set
    CONFIG_SME=y
    CONFIG_NO_CONFIG_WRITE=y
    CONFIG_NO_CONFIG_BLOBS=y
    CONFIG_CTRL_IFACE=y
    CONFIG_CTRL_IFACE_ZEPHYR=y
    CONFIG_NO_RANDOM_POOL=y
    CONFIG_WIFI_NM_WPA_SUPPLICANT_NW_SEL_THROUGHPUT=y
    # CONFIG_WIFI_NM_WPA_SUPPLICANT_NW_SEL_RELIABILITY is not set
    # CONFIG_SAE_PWE_EARLY_EXIT is not set
    CONFIG_WIFI_NM_WPA_CTRL_RESP_TIMEOUT_S=15
    CONFIG_ZEPHYR_HOSTAP_MODULE=y
    # end of hostap (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/hostap)
    # mcuboot (/home/br1/dev/nordic/ncs/v3.0.1/bootloader/mcuboot)
    # MCUboot
    # CONFIG_MCUBOOT_HARDWARE_DOWNGRADE_PREVENTION is not set
    CONFIG_MCUBOOT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
    # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (/home/br1/dev/nordic/ncs/v3.0.1/bootloader/mcuboot)
    # mbedtls (/home/br1/dev/nordic/ncs/v3.0.1/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_PSA_CRYPTO_CLIENT=y
    # CONFIG_PSA_CRYPTO_ENABLE_ALL is not set
    CONFIG_PSA_WANT_ALG_CBC_NO_PADDING=y
    CONFIG_PSA_WANT_ALG_CBC_PKCS7=y
    CONFIG_PSA_WANT_ALG_CCM=y
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    CONFIG_PSA_WANT_ALG_CMAC=y
    CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305=y
    CONFIG_PSA_WANT_ALG_CTR=y
    CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA=y
    CONFIG_PSA_WANT_ALG_ECDH=y
    CONFIG_PSA_WANT_ALG_ECDSA=y
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    CONFIG_PSA_WANT_ALG_GCM=y
    CONFIG_PSA_WANT_ALG_HKDF=y
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    CONFIG_PSA_WANT_ALG_HMAC=y
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_PBKDF2_HMAC is not set
    # CONFIG_PSA_WANT_ALG_PBKDF2_AES_CMAC_PRF_128 is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    CONFIG_PSA_WANT_ALG_SHA_1=y
    CONFIG_PSA_WANT_ALG_SHA_224=y
    CONFIG_PSA_WANT_ALG_SHA_256=y
    CONFIG_PSA_WANT_ALG_SHA_384=y
    CONFIG_PSA_WANT_ALG_SHA_512=y
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    CONFIG_PSA_WANT_ALG_STREAM_CIPHER=y
    CONFIG_PSA_WANT_ALG_TLS12_PRF=y
    CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS=y
    CONFIG_PSA_WANT_ALG_TLS12_ECJPAKE_TO_PMS=y
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    CONFIG_PSA_WANT_ECC_SECP_R1_256=y
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    CONFIG_PSA_WANT_KEY_TYPE_HMAC=y
    CONFIG_PSA_WANT_KEY_TYPE_AES=y
    CONFIG_PSA_WANT_KEY_TYPE_CHACHA20=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY=y
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE=y
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE=y
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_DERIVE is not set
    CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_BASIC=y
    # CONFIG_MBEDTLS_LIBRARY is not set
    CONFIG_DISABLE_MBEDTLS_BUILTIN=y
    # CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_OFF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_ERR is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_WRN is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_INF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_DBG is not set
    CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT=y
    CONFIG_MBEDTLS_LOG_LEVEL=3
    # CONFIG_MBEDTLS_DEBUG is not set
    # CONFIG_MBEDTLS_HEAP_CUSTOM_SECTION is not set
    CONFIG_MBEDTLS_INIT=y
    # CONFIG_MBEDTLS_ZEROIZE_ALT is not set
    CONFIG_APP_LINK_WITH_MBEDTLS=y
    # end of mbedtls (/home/br1/dev/nordic/ncs/v3.0.1/modules/crypto/mbedtls)
    # oberon-psa-crypto (/home/br1/dev/nordic/ncs/v3.0.1/modules/crypto/oberon-psa-crypto)
    CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    # end of oberon-psa-crypto (/home/br1/dev/nordic/ncs/v3.0.1/modules/crypto/oberon-psa-crypto)
    # trusted-firmware-m (/home/br1/dev/nordic/ncs/v3.0.1/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_TFM_BOARD="/home/br1/dev/nordic/ncs/v3.0.1/zephyr/modules/trusted-firmware-m/nordic/nrf5340_cpuapp"
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (/home/br1/dev/nordic/ncs/v3.0.1/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    # cjson (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/cjson)
    # azure-sdk-for-c (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/azure-sdk-for-c)
    # cirrus-logic (/home/br1/dev/nordic/ncs/v3.0.1/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (/home/br1/dev/nordic/ncs/v3.0.1/modules/hal/cirrus-logic)
    # openthread (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/openthread)
    # suit-generator (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/suit-generator)
    CONFIG_SUIT_ENVELOPE_TEMPLATE_FILENAME=""
    CONFIG_SUIT_ENVELOPE_TARGET=""
    CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
    # CONFIG_SUIT_RECOVERY is not set
    # CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
    # CONFIG_SUIT_DFU_CACHE_EXTRACT_IMAGE is not set
    # CONFIG_SUIT_ENVELOPE_TARGET_ENCRYPT is not set
    # CONFIG_SUIT_ENVELOPE_TARGET_SIGN is not set
    CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
    # end of suit-generator (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/suit-generator)
    # suit-processor (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/suit-processor)
    # CONFIG_SUIT_PROCESSOR is not set
    CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
    CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
    # end of suit-processor (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/suit-processor)
    # memfault-firmware-sdk (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/memfault-firmware-sdk)
    # coremark (/home/br1/dev/nordic/ncs/v3.0.1/modules/benchmark/coremark)
    # CONFIG_COREMARK is not set
    CONFIG_ZEPHYR_COREMARK_MODULE=y
    # end of coremark (/home/br1/dev/nordic/ncs/v3.0.1/modules/benchmark/coremark)
    # canopennode (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/canopennode)
    # chre (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/chre)
    # lz4 (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/lz4)
    # nanopb (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/nanopb)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/zscilib)
    # cmsis (/home/br1/dev/nordic/ncs/v3.0.1/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis (/home/br1/dev/nordic/ncs/v3.0.1/modules/hal/cmsis)
    # cmsis-dsp (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/cmsis-dsp)
    # cmsis-nn (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/cmsis-nn)
    # fatfs (/home/br1/dev/nordic/ncs/v3.0.1/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (/home/br1/dev/nordic/ncs/v3.0.1/modules/fs/fatfs)
    # hal_nordic (/home/br1/dev/nordic/ncs/v3.0.1/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_SER_HOST is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_DPPI_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_IPC_LOG is not set
    # CONFIG_NRFX_NVMC_LOG is not set
    # CONFIG_NRFX_QSPI_LOG is not set
    # CONFIG_NRFX_SPIM_LOG is not set
    # CONFIG_NRFX_WDT_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    CONFIG_NRFX_DPPI=y
    CONFIG_NRFX_DPPI0=y
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE0=y
    # CONFIG_NRFX_GPIOTE1 is not set
    CONFIG_NRFX_GPPI=y
    # CONFIG_NRFX_I2S0 is not set
    CONFIG_NRFX_IPC=y
    # CONFIG_NRFX_LPCOMP is not set
    # CONFIG_NRFX_NFCT is not set
    CONFIG_NRFX_NVMC=y
    # CONFIG_NRFX_PDM0 is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PWM0 is not set
    # CONFIG_NRFX_PWM1 is not set
    # CONFIG_NRFX_PWM2 is not set
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC0 is not set
    # CONFIG_NRFX_QDEC1 is not set
    CONFIG_NRFX_QSPI=y
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SAADC is not set
    CONFIG_NRFX_SPIM=y
    # CONFIG_NRFX_SPIM0 is not set
    # CONFIG_NRFX_SPIM1 is not set
    # CONFIG_NRFX_SPIM2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    CONFIG_NRFX_SPIM4=y
    # CONFIG_NRFX_SPIS0 is not set
    # CONFIG_NRFX_SPIS1 is not set
    # CONFIG_NRFX_SPIS2 is not set
    # CONFIG_NRFX_SPIS3 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER1 is not set
    # CONFIG_NRFX_TIMER2 is not set
    # CONFIG_NRFX_TWIM0 is not set
    # CONFIG_NRFX_TWIM1 is not set
    # CONFIG_NRFX_TWIM2 is not set
    # CONFIG_NRFX_TWIM3 is not set
    # CONFIG_NRFX_TWIS0 is not set
    # CONFIG_NRFX_TWIS1 is not set
    # CONFIG_NRFX_TWIS2 is not set
    # CONFIG_NRFX_TWIS3 is not set
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    # CONFIG_NRFX_UARTE2 is not set
    # CONFIG_NRFX_UARTE3 is not set
    # CONFIG_NRFX_USBREG is not set
    CONFIG_NRFX_WDT=y
    CONFIG_NRFX_WDT0=y
    # CONFIG_NRFX_WDT1 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_config_reserved_resources_ncs.h"
    # end of hal_nordic (/home/br1/dev/nordic/ncs/v3.0.1/modules/hal/nordic)
    # hal_st (/home/br1/dev/nordic/ncs/v3.0.1/modules/hal/st)
    CONFIG_ZEPHYR_HAL_ST_MODULE=y
    # end of hal_st (/home/br1/dev/nordic/ncs/v3.0.1/modules/hal/st)
    # hal_tdk (/home/br1/dev/nordic/ncs/v3.0.1/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_TDK_MODULE=y
    # TDK drivers
    # CONFIG_TDK_HAL is not set
    # end of TDK drivers
    # end of hal_tdk (/home/br1/dev/nordic/ncs/v3.0.1/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    # liblc3 (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # CONFIG_LIBLC3 is not set
    # end of liblc3 (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # littlefs (/home/br1/dev/nordic/ncs/v3.0.1/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (/home/br1/dev/nordic/ncs/v3.0.1/modules/fs/littlefs)
    # loramac-node (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/loramac-node)
    # lvgl (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    # nrf_wifi (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/nrf_wifi)
    CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
    CONFIG_NRF70_BUSLIB=y
    CONFIG_NRF70_ON_QSPI=y
    # CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NRF70_BUSLIB_LOG_LEVEL=3
    CONFIG_NRF70_LOG_VERBOSE=y
    # end of nrf_wifi (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/nrf_wifi)
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # percepio (/home/br1/dev/nordic/ncs/v3.0.1/modules/debug/percepio)
    # Percepio Tracealyzer support can be enabled from the tracing subsystem
    # CONFIG_PERCEPIO_DFM is not set
    CONFIG_ZEPHYR_PERCEPIO_MODULE=y
    # end of percepio (/home/br1/dev/nordic/ncs/v3.0.1/modules/debug/percepio)
    # picolibc (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/picolibc)
    # segger (/home/br1/dev/nordic/ncs/v3.0.1/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    # CONFIG_SEGGER_RTT_SECTION_NONE is not set
    # CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    # CONFIG_SEGGER_RTT_SECTION_CCM is not set
    CONFIG_SEGGER_RTT_SECTION_CUSTOM=y
    # CONFIG_SEGGER_RTT_SECTION_CUSTOM_DTS_REGION is not set
    CONFIG_SEGGER_RTT_SECTION_CUSTOM_NAME=".rtt_buff_data"
    # CONFIG_SEGGER_RTT_INIT_MODE_ALWAYS is not set
    CONFIG_SEGGER_RTT_INIT_MODE_STRONG_CHECK=y
    # CONFIG_SEGGER_RTT_INIT_MODE_WEAK_CHECK is not set
    # end of segger (/home/br1/dev/nordic/ncs/v3.0.1/modules/debug/segger)
    CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    # uoscore-uedhoc (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/uoscore-uedhoc)
    # zcbor (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/zcbor)
    # decadriver (/home/br1/dev/locbeacon4/src/app/../lib/decadriver)
    # CONFIG_DW3000_LOG_LEVEL_OFF is not set
    # CONFIG_DW3000_LOG_LEVEL_ERR is not set
    # CONFIG_DW3000_LOG_LEVEL_WRN is not set
    # CONFIG_DW3000_LOG_LEVEL_INF is not set
    # CONFIG_DW3000_LOG_LEVEL_DBG is not set
    CONFIG_DW3000_LOG_LEVEL_DEFAULT=y
    CONFIG_DW3000_LOG_LEVEL=3
    CONFIG_ZEPHYR_DECADRIVER_MODULE=y
    # end of decadriver (/home/br1/dev/locbeacon4/src/app/../lib/decadriver)
    # nrfxlib (/home/br1/dev/nordic/ncs/v3.0.1/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # end of nrf_modem (Modem library)
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_HAS_HW_NRF_CC3XX=y
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # CONFIG_CC3XX_HW_MUTEX_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # CONFIG_SW_CODEC_LC3_T2_SOFTWARE is not set
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (/home/br1/dev/nordic/ncs/v3.0.1/nrfxlib)
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    CONFIG_ZEPHYR_LIBDECA_MODULE=y
    # connectedhomeip (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (/home/br1/dev/nordic/ncs/v3.0.1/modules/lib/matter)
    CONFIG_LIBMETAL=y
    CONFIG_LIBMETAL_SRC_PATH="libmetal"
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_HAS_MEC5_HAL is not set
    CONFIG_OPENAMP=y
    CONFIG_OPENAMP_SRC_PATH="open-amp"
    CONFIG_OPENAMP_MASTER=y
    CONFIG_OPENAMP_SLAVE=y
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_TINYCRYPT is not set
    CONFIG_MCUBOOT_SIGNATURE_KEY_FILE="/home/br1/dev/infsoft/private-key/infsoft-locbeacon4-sign-key.pem"
    CONFIG_MCUBOOT_ENCRYPTION_KEY_FILE=""
    CONFIG_MCUBOOT_IMGTOOL_SIGN_VERSION="4.0.126+0"
    # CONFIG_MCUBOOT_IMGTOOL_OVERWRITE_ONLY is not set
    CONFIG_MCUBOOT_EXTRA_IMGTOOL_ARGS=""
    # On board MCUboot operation mode
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SINGLE_APP is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_WITHOUT_SCRATCH=y
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_SWAP_SCRATCH is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_OVERWRITE_ONLY is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_RAM_LOAD is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_DIRECT_XIP_WITH_REVERT is not set
    # CONFIG_MCUBOOT_BOOTLOADER_MODE_FIRMWARE_UPDATER is not set
    CONFIG_MCUBOOT_BOOTLOADER_MODE_HAS_NO_DOWNGRADE=y
    # CONFIG_MCUBOOT_BOOTLOADER_NO_DOWNGRADE is not set
    # CONFIG_MCUBOOT_BOOTLOADER_USES_SHA512 is not set
    # end of On board MCUboot operation mode
    CONFIG_MCUBOOT_BOOTUTIL_LIB=y
    CONFIG_MCUBOOT_BOOTUTIL_LIB_OWN_LOG=y
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_OFF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_ERR is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_INF is not set
    # CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DBG is not set
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL_DEFAULT=y
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL=3
    # CONFIG_BOOT_IMAGE_ACCESS_HOOKS is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD="nrf7002dk"
    CONFIG_BOARD_REVISION=""
    CONFIG_BOARD_TARGET="nrf7002dk/nrf5340/cpuapp"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF7002DK=y
    CONFIG_BOARD_NRF7002DK_NRF5340_CPUAPP=y
    CONFIG_BOARD_QUALIFIERS="nrf5340/cpuapp"
    # Board Options
    CONFIG_MBOX_NRFX_IPC=y
    CONFIG_BT_HCI_IPC=y
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_BOARD=4096
    CONFIG_DOMAIN_CPUNET_BOARD="nrf7002dk/nrf5340/cpunet"
    # end of Board Options
    # Hardware Configuration
    CONFIG_SOC="nrf5340"
    CONFIG_SOC_SERIES="nrf53"
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NORDIC_NRF=y
    CONFIG_SOC_SERIES_NRF53X=y
    CONFIG_SOC_NRF5340_CPUAPP=y
    CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    CONFIG_HAS_HW_NRF_CC312=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_CTRLAP=y
    CONFIG_HAS_HW_NRF_DCNF=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE0=y
    CONFIG_HAS_HW_NRF_KMU=y
    CONFIG_HAS_HW_NRF_MUTEX=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_QSPI=y
    CONFIG_HAS_HW_NRF_RESET=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM4=y
    CONFIG_HAS_HW_NRF_SPU=y
    CONFIG_HAS_HW_NRF_TWIM1=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_USBREG=y
    CONFIG_HAS_HW_NRF_VMC=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_HAS_NORDIC_RAM_CTRL=y
    # CONFIG_NRF_FORCE_RAM_ON_REBOOT is not set
    # CONFIG_NRF_SYS_EVENT is not set
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
    CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
    # CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND_FOR_EXECUTION_FROM_RAM is not set
    CONFIG_SOC_NRF53_RTC_PRETICK=y
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_SOC_NRF_GPIO_FORWARDER_FOR_NRF5340=y
    CONFIG_SOC_NRF53_CPUNET_MGMT=y
    # CONFIG_SOC_NRF53_CPUNET_ENABLE is not set
    # CONFIG_BOARD_ENABLE_CPUNET is not set
    # CONFIG_SOC_ENABLE_LFXO is not set
    CONFIG_SOC_HFXO_CAP_DEFAULT=y
    # CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_HFXO_CAP_INTERNAL is not set
    CONFIG_NRF_ENABLE_CACHE=y
    # CONFIG_NRF53_SYNC_RTC is not set
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
    # CONFIG_SOC_NRF54H20_GPD is not set
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    CONFIG_GPIO_INIT_PRIORITY=40
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF53X=y
    CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y
    CONFIG_ARCH="arm"
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_CPU_CORTEX=y
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    # ARM Options
    CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
    CONFIG_ARM_ON_EXIT_CPU_IDLE=y
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    # CONFIG_PLATFORM_SPECIFIC_INIT is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_ARM_STORE_EXC_RETURN=y
    CONFIG_FP_HARDABI=y
    # CONFIG_FP_SOFTABI is not set
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_ARM_TRUSTZONE_M=y
    # CONFIG_MPU_STACK_GUARD is not set
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    CONFIG_CPU_HAS_NRF_IDAU=y
    CONFIG_HAS_SWO=y
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    # CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # CONFIG_FRAME_POINTER is not set
    # Interrupt Configuration
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_EXCEPTION_DEBUG=y
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # DSP Options
    # end of DSP Options
    # Floating Point Options
    CONFIG_FPU_SHARING=y
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    # CONFIG_SCHED_DUMB is not set
    CONFIG_SCHED_SIMPLE=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_DUMB is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_SIMPLE=y
    # Misc Kernel related options
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_CURRENT_THREAD_USE_TLS=y
    # end of Misc Kernel related options
    # Kernel Debugging and Metrics
    CONFIG_BOOT_DELAY=0
    # CONFIG_BOOT_CLEAR_SCREEN is not set
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # System Work Queue Options
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of System Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # end of Timer API Options
    # Other Kernel Object Options
    CONFIG_POLL=y
    # CONFIG_MEM_SLAB_POINTER_VALIDATE is not set
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    CONFIG_PIPES=y
    CONFIG_KERNEL_MEM_POOL=y
    CONFIG_HEAP_MEM_POOL_IGNORE_MIN=y
    # end of Other Kernel Object Options
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    # Security Options
    CONFIG_STACK_POINTER_RANDOM=0
    # end of Security Options
    # Memory Domains
    CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
    CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
    # end of Memory Domains
    # SMP Options
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
    # CONFIG_STATIC_INIT_GNU is not set
    # CONFIG_BOOTARGS is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # CONFIG_DEVICE_MUTABLE is not set
    # CONFIG_DEVICE_DT_METADATA is not set
    # end of Device Options
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Virtual Memory Support
    # end of Virtual Memory Support
    # SoC and Board Hooks
    # CONFIG_SOC_PREP_HOOK is not set
    # CONFIG_SOC_EARLY_INIT_HOOK is not set
    # CONFIG_SOC_LATE_INIT_HOOK is not set
    # CONFIG_SOC_PER_CORE_INIT_HOOK is not set
    # CONFIG_BOARD_EARLY_INIT_HOOK is not set
    # CONFIG_BOARD_LATE_INIT_HOOK is not set
    # end of SoC and Board Hooks
    # Device Drivers
    CONFIG_ADC=y
    CONFIG_ADC_CONFIGURABLE_INPUTS=y
    # CONFIG_ADC_ASYNC is not set
    # CONFIG_ADC_LOG_LEVEL_OFF is not set
    # CONFIG_ADC_LOG_LEVEL_ERR is not set
    # CONFIG_ADC_LOG_LEVEL_WRN is not set
    # CONFIG_ADC_LOG_LEVEL_INF is not set
    # CONFIG_ADC_LOG_LEVEL_DBG is not set
    CONFIG_ADC_LOG_LEVEL_DEFAULT=y
    CONFIG_ADC_LOG_LEVEL=3
    CONFIG_ADC_NRFX_SAADC=y
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    CONFIG_BT_DRIVERS=y
    # Bluetooth HCI Driver Options
    CONFIG_BT_HCI_IPC_SEND_RETRY_COUNT=3
    CONFIG_BT_HCI_IPC_SEND_RETRY_DELAY_US=75
    CONFIG_BT_HCI_IPC_ENDPOINT_BOUND_TIMEOUT_MS=2000
    CONFIG_BT_HCI_INIT_PRIORITY=50
    # CONFIG_HCI_NXP_SET_CAL_DATA_ANNEX100 is not set
    CONFIG_FLASH=y
    CONFIG_BT_DRV_TX_STACK_SIZE=256
    CONFIG_BT_DRV_RX_STACK_SIZE=256
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    # CONFIG_CLOCK_CONTROL_RTS5912_SCCON is not set
    # CONFIG_COMPARATOR is not set
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    CONFIG_CONSOLE_INIT_PRIORITY=40
    # CONFIG_UART_CONSOLE is not set
    # CONFIG_RAM_CONSOLE is not set
    CONFIG_RTT_CONSOLE=y
    CONFIG_RTT_TX_RETRY_CNT=2
    CONFIG_RTT_TX_RETRY_DELAY_MS=2
    # CONFIG_RTT_TX_RETRY_IN_INTERRUPT is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_EFI_CONSOLE is not set
    CONFIG_WINSTREAM_CONSOLE_STATIC=y
    CONFIG_WINSTREAM_CONSOLE_STATIC_SIZE=32768
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_DP_DRIVER is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    CONFIG_ENTROPY_GENERATOR=y
    # CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
    # CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
    # CONFIG_ENTROPY_LOG_LEVEL_INF is not set
    # CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
    CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y
    CONFIG_ENTROPY_LOG_LEVEL=3
    CONFIG_ENTROPY_BT_HCI=y
    CONFIG_ENTROPY_HAS_DRIVER=y
    # CONFIG_ESPI is not set
    CONFIG_ETH_DRIVER=y
    # CONFIG_ETHERNET_LOG_LEVEL_OFF is not set
    # CONFIG_ETHERNET_LOG_LEVEL_ERR is not set
    # CONFIG_ETHERNET_LOG_LEVEL_WRN is not set
    # CONFIG_ETHERNET_LOG_LEVEL_INF is not set
    # CONFIG_ETHERNET_LOG_LEVEL_DBG is not set
    CONFIG_ETHERNET_LOG_LEVEL_DEFAULT=y
    CONFIG_ETHERNET_LOG_LEVEL=3
    # CONFIG_ETH_IVSHMEM is not set
    # DWC XGMAC configuration
    # end of DWC XGMAC configuration
    CONFIG_ETH_PHY_DRIVER=y
    # CONFIG_PHY_LOG_LEVEL_OFF is not set
    # CONFIG_PHY_LOG_LEVEL_ERR is not set
    # CONFIG_PHY_LOG_LEVEL_WRN is not set
    # CONFIG_PHY_LOG_LEVEL_INF is not set
    # CONFIG_PHY_LOG_LEVEL_DBG is not set
    CONFIG_PHY_LOG_LEVEL_DEFAULT=y
    CONFIG_PHY_LOG_LEVEL=3
    CONFIG_PHY_AUTONEG_TIMEOUT_MS=4000
    CONFIG_PHY_MONITOR_PERIOD=500
    # NXP ENET
    # end of NXP ENET
    CONFIG_ETH_INIT_PRIORITY=80
    # Firmware drivers
    # CONFIG_ARM_SCMI is not set
    # end of Firmware drivers
    CONFIG_FLASH_HAS_DRIVER_ENABLED=y
    CONFIG_FLASH_HAS_EX_OP=y
    CONFIG_FLASH_HAS_EXPLICIT_ERASE=y
    CONFIG_FLASH_HAS_PAGE_LAYOUT=y
    CONFIG_FLASH_JESD216=y
    # CONFIG_FLASH_JESD216_API is not set
    CONFIG_FLASH_PAGE_LAYOUT=y
    # CONFIG_FLASH_EX_OP_ENABLED is not set
    # MSPI flash device driver
    # end of MSPI flash device driver
    CONFIG_SPI_NOR_SFDP_MINIMAL=y
    # CONFIG_SPI_NOR_SFDP_DEVICETREE is not set
    # CONFIG_SPI_NOR_SFDP_RUNTIME is not set
    CONFIG_SPI_NOR_INIT_PRIORITY=80
    CONFIG_SPI_NOR_CS_WAIT_DELAY=0
    CONFIG_SPI_NOR_SLEEP_WHILE_WAITING_UNTIL_READY=y
    CONFIG_SPI_NOR_FLASH_LAYOUT_PAGE_SIZE=65536
    CONFIG_SOC_FLASH_NRF=y
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
    # CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
    # CONFIG_SOC_FLASH_NRF_UICR is not set
    # CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
    # CONFIG_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_FLASH_LOG_LEVEL=3
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_GPIO_RTS5912 is not set
    # CONFIG_HAPTICS is not set
    # CONFIG_HWINFO is not set
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # CONFIG_IEEE802154 is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    CONFIG_MBOX=y
    # CONFIG_MBOX_NRF_VEVIF_EVENT_USE_54L_ERRATA_16 is not set
    CONFIG_MBOX_INIT_PRIORITY=40
    # CONFIG_MBOX_LOG_LEVEL_OFF is not set
    # CONFIG_MBOX_LOG_LEVEL_ERR is not set
    # CONFIG_MBOX_LOG_LEVEL_WRN is not set
    # CONFIG_MBOX_LOG_LEVEL_INF is not set
    # CONFIG_MBOX_LOG_LEVEL_DBG is not set
    CONFIG_MBOX_LOG_LEVEL_DEFAULT=y
    CONFIG_MBOX_LOG_LEVEL=3
    # CONFIG_MDIO is not set
    # CONFIG_MIPI_DBI is not set
    # Miscellaneous Drivers
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_MSPI is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    CONFIG_PINCTRL=y
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PINCTRL_REALTEK_RTS5912 is not set
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    # CONFIG_UART_RTS5912 is not set
    # CONFIG_SMBUS is not set
    # CONFIG_SPI_ASYNC is not set
    # CONFIG_SPI_RTIO is not set
    # CONFIG_SPI_SLAVE is not set
    # CONFIG_SPI_EXTENDED_MODES is not set
    CONFIG_SPI_INIT_PRIORITY=50
    CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    # CONFIG_SPI_LOG_LEVEL_OFF is not set
    # CONFIG_SPI_LOG_LEVEL_ERR is not set
    # CONFIG_SPI_LOG_LEVEL_WRN is not set
    # CONFIG_SPI_LOG_LEVEL_INF is not set
    # CONFIG_SPI_LOG_LEVEL_DBG is not set
    CONFIG_SPI_LOG_LEVEL_DEFAULT=y
    CONFIG_SPI_LOG_LEVEL=3
    CONFIG_SPI_NRFX=y
    CONFIG_SPI_NRFX_SPIM=y
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
    CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200
    # CONFIG_STEPPER is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # CONFIG_REALTEK_RTS5912_RTMR is not set
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
    # CONFIG_NRF_USBD_COMMON is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_USBC_PPC_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_WDT_LOG_LEVEL_OFF is not set
    # CONFIG_WDT_LOG_LEVEL_ERR is not set
    # CONFIG_WDT_LOG_LEVEL_WRN is not set
    # CONFIG_WDT_LOG_LEVEL_INF is not set
    # CONFIG_WDT_LOG_LEVEL_DBG is not set
    CONFIG_WDT_LOG_LEVEL_DEFAULT=y
    CONFIG_WDT_LOG_LEVEL=3
    CONFIG_WDT_NRFX=y
    # CONFIG_WDT_NRFX_NO_IRQ is not set
    # CONFIG_WIFI_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_LOG_LEVEL=3
    CONFIG_WIFI_INIT_PRIORITY=80
    # CONFIG_WIFI_OFFLOAD is not set
    CONFIG_WIFI_USE_NATIVE_NETWORKING=y
    # CONFIG_WIFI_SIMPLELINK is not set
    CONFIG_NET_TCP_WORKQ_STACK_SIZE=1024
    CONFIG_NET_MGMT_EVENT_STACK_SIZE=4600
    CONFIG_WIFI_MGMT_SCAN_CHAN_MAX_MANUAL=3
    CONFIG_WIFI_NRF70=y
    CONFIG_WIFI_NRF7002=y
    CONFIG_NRF70_QSPI_LOW_POWER=y
    # CONFIG_NRF70_SCAN_ONLY is not set
    CONFIG_NRF70_SYSTEM_MODE=y
    # CONFIG_NRF70_RADIO_TEST is not set
    # CONFIG_NRF70_OFFLOADED_RAW_TX is not set
    CONFIG_NRF70_STA_MODE=y
    # CONFIG_NRF70_P2P_MODE is not set
    CONFIG_NRF70_SYSTEM_WITH_RAW_MODES=y
    # CONFIG_NRF70_RAW_DATA_TX is not set
    CONFIG_NRF70_RAW_DATA_RX=y
    # CONFIG_NRF70_PROMISC_DATA_RX is not set
    CONFIG_NRF70_DATA_TX=y
    CONFIG_NRF_WIFI_IF_AUTO_START=y
    # CONFIG_NRF_WIFI_PATCHES_BUILTIN is not set
    CONFIG_NRF_WIFI_PATCHES_EXTERNAL=y
    CONFIG_NRF_WIFI_LOW_POWER=y
    CONFIG_NRF70_TCP_IP_CHECKSUM_OFFLOAD=y
    CONFIG_NRF70_REG_DOMAIN="00"
    # CONFIG_WIFI_NRF70_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NRF70_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NRF70_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NRF70_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NRF70_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NRF70_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NRF70_LOG_LEVEL=3
    # CONFIG_NRF70_SR_COEX is not set
    CONFIG_NRF70_SR_COEX_SLEEP_CTRL_GPIO_CTRL=y
    CONFIG_NRF70_SR_COEX_SWCTRL1_OUTPUT=0
    CONFIG_NRF70_SR_COEX_BT_GRANT_ACTIVE_LOW=1
    CONFIG_NRF70_WORKQ_STACK_SIZE=4096
    CONFIG_NRF70_WORKQ_MAX_ITEMS=100
    CONFIG_NRF70_MAX_TX_PENDING_QLEN=18
    CONFIG_NRF70_PCB_LOSS_2G=0
    CONFIG_NRF70_PCB_LOSS_5G_BAND1=0
    CONFIG_NRF70_PCB_LOSS_5G_BAND2=0
    CONFIG_NRF70_PCB_LOSS_5G_BAND3=0
    CONFIG_NRF70_ANT_GAIN_2G=0
    CONFIG_NRF70_ANT_GAIN_5G_BAND1=0
    CONFIG_NRF70_ANT_GAIN_5G_BAND2=0
    CONFIG_NRF70_ANT_GAIN_5G_BAND3=0
    CONFIG_NRF70_BAND_2G_LOWER_EDGE_BACKOFF_DSSS=0
    CONFIG_NRF70_BAND_2G_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_2G_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_BAND_2G_UPPER_EDGE_BACKOFF_DSSS=0
    CONFIG_NRF70_BAND_2G_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_2G_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_BAND_UNII_1_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_UNII_1_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_BAND_UNII_1_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_UNII_1_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_UNII_2A_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_UNII_2A_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_UNII_2C_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_UNII_2C_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_BAND_UNII_3_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_UNII_3_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_BAND_UNII_3_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_UNII_3_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_BAND_UNII_4_LOWER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_UNII_4_LOWER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_BAND_UNII_4_UPPER_EDGE_BACKOFF_HT=0
    CONFIG_NRF70_BAND_UNII_4_UPPER_EDGE_BACKOFF_HE=0
    CONFIG_NRF70_RX_NUM_BUFS=16
    CONFIG_NRF70_MAX_TX_AGGREGATION=12
    CONFIG_NRF70_MAX_TX_TOKENS=10
    CONFIG_NRF70_TX_MAX_DATA_SIZE=1600
    CONFIG_NRF70_RX_MAX_DATA_SIZE=1600
    # CONFIG_NRF70_TX_DONE_WQ_ENABLED is not set
    # CONFIG_NRF70_RX_WQ_ENABLED is not set
    CONFIG_NRF70_IRQ_WQ_PRIORITY=-15
    CONFIG_NRF70_BH_WQ_PRIORITY=0
    CONFIG_NRF70_IRQ_WQ_STACK_SIZE=2048
    CONFIG_NRF70_BH_WQ_STACK_SIZE=2048
    CONFIG_NRF70_RPU_PS_IDLE_TIMEOUT_MS=10
    # CONFIG_NRF70_RPU_EXTEND_TWT_SP is not set
    CONFIG_WIFI_FIXED_MAC_ADDRESS=""
    CONFIG_WIFI_OTP_MAC_ADDRESS=y
    # CONFIG_WIFI_FIXED_MAC_ADDRESS_ENABLED is not set
    # CONFIG_WIFI_RANDOM_MAC_ADDRESS is not set
    CONFIG_NRF70_RSSI_STALE_TIMEOUT_MS=1000
    CONFIG_NRF_WIFI_CTRL_HEAP_SIZE=20000
    CONFIG_NRF_WIFI_DATA_HEAP_SIZE=40000
    CONFIG_NET_TC_TX_COUNT=1
    CONFIG_SHELL_STACK_SIZE=4096
    CONFIG_WIFI_MGMT_SCAN_SSID_FILT_MAX=2
    CONFIG_NRF_WIFI_SCAN_MAX_BSS_CNT=0
    CONFIG_NRF_WIFI_BEAMFORMING=y
    CONFIG_WIFI_NRF70_SCAN_TIMEOUT_S=30
    # nRF Wi-Fi operation band(s)
    # CONFIG_NRF_WIFI_2G_BAND is not set
    # CONFIG_NRF_WIFI_5G_BAND is not set
    CONFIG_NRF_WIFI_OP_BAND=3
    # end of nRF Wi-Fi operation band(s)
    CONFIG_NRF_WIFI_IFACE_MTU=1500
    # CONFIG_WIFI_NRF70_SKIP_LOCAL_ADMIN_MAC is not set
    # CONFIG_WIFI_NRF70_SCAN_DISABLE_DFS_CHANNELS is not set
    CONFIG_NET_INTERFACE_NAME_LEN=15
    CONFIG_NRF_WIFI_AP_DEAD_DETECT_TIMEOUT=20
    CONFIG_NRF_WIFI_RPU_RECOVERY=y
    CONFIG_NRF_WIFI_RPU_RECOVERY_PROPAGATION_DELAY_MS=2000
    CONFIG_NET_MGMT_EVENT_QUEUE_SIZE=16
    CONFIG_NRF_WIFI_RPU_RECOVERY_PS_ACTIVE_TIMEOUT_MS=50000
    CONFIG_NRF_WIFI_RPU_MIN_TIME_TO_ENTER_SLEEP_MS=1000
    # CONFIG_NRF_WIFI_RPU_RECOVERY_DEBUG is not set
    CONFIG_NRF_WIFI_RPU_RECOVERY_QUIET_PERIOD_MS=5000
    CONFIG_NRF_WIFI_RPU_RECOVERY_MAX_RETRIES=0
    CONFIG_NRF_WIFI_RPU_RECOVERY_RETRY_WINDOW_S=900
    # CONFIG_NRF_WIFI_RPU_RECOVERY_PS_STATE_DEBUG is not set
    CONFIG_NRF_WIFI_FEAT_WMM=y
    CONFIG_NRF_WIFI_PS_POLL_BASED_RETRIEVAL=y
    # CONFIG_NRF_WIFI_QOS_NULL_BASED_RETRIEVAL is not set
    CONFIG_NRF_WIFI_MGMT_BUFF_OFFLOAD=y
    # CONFIG_NRF_WIFI_FEAT_KEEPALIVE is not set
    # CONFIG_NRF_WIFI_PS_EXIT_EVERY_TIM is not set
    CONFIG_NRF_WIFI_PS_INT_PS=y
    CONFIG_NRF_WIFI_DISPLAY_SCAN_BSS_LIMIT=150
    # CONFIG_NRF_WIFI_COEX_DISABLE_PRIORITY_WINDOW_FOR_SCAN is not set
    # CONFIG_NRF_WIFI_ZERO_COPY_TX is not set
    CONFIG_NRF_WIFI_MAX_PS_POLL_FAIL_CNT=10
    CONFIG_NRF_WIFI_RX_STBC_HT=y
    # CONFIG_TEE is not set
    CONFIG_REQUIRES_FULL_LIBC=y
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    CONFIG_NATIVE_LIBC_INCOMPATIBLE=y
    # C Library
    CONFIG_PICOLIBC=y
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_ASCTIME_R is not set
    # CONFIG_COMMON_LIBC_CTIME_R is not set
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    CONFIG_COMMON_LIBC_REMOVE=y
    # CONFIG_PICOLIBC_USE_MODULE is not set
    CONFIG_PICOLIBC_USE_TOOLCHAIN=y
    CONFIG_PICOLIBC_IO_FLOAT=y
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # end of C++ Language Support
    CONFIG_CRC=y
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_STRESS is not set
    # CONFIG_SYS_HEAP_INFO is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_MULTI_HEAP is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # end of Heap and Memory Allocation
    # Memory Blocks
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Memory Blocks
    CONFIG_NET_BUF=y
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_BUF_LOG_LEVEL_INF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    CONFIG_NET_BUF_ALIGNMENT=0
    # OS Support Library
    CONFIG_FDTABLE=y
    CONFIG_ZVFS_OPEN_MAX=16
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    CONFIG_CBPRINTF_FP_SUPPORT=y
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    CONFIG_ZVFS=y
    CONFIG_ZVFS_EVENTFD=y
    CONFIG_ZVFS_EVENTFD_MAX=1
    CONFIG_ZVFS_POLL=y
    CONFIG_ZVFS_POLL_MAX=10
    CONFIG_ZVFS_SELECT=y
    # end of OS Support Library
    # POSIX API Support
    # POSIX Options
    CONFIG_POSIX_API=y
    CONFIG_POSIX_AEP_CHOICE_NONE=y
    # CONFIG_POSIX_AEP_CHOICE_BASE is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
    CONFIG_POSIX_BASE_DEFINITIONS=y
    CONFIG_POSIX_AEP_REALTIME_MINIMAL=y
    CONFIG_POSIX_ASYNCHRONOUS_IO=y
    CONFIG_POSIX_BARRIERS=y
    CONFIG_MAX_PTHREAD_BARRIER_COUNT=5
    # CONFIG_PTHREAD_CREATE_BARRIER is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_BARRIER_LOG_LEVEL=3
    CONFIG_POSIX_C_LANG_SUPPORT_R=y
    # CONFIG_POSIX_C_LIB_EXT is not set
    # POSIX device I/O
    CONFIG_POSIX_DEVICE_IO=y
    CONFIG_POSIX_OPEN_MAX=16
    # end of POSIX device I/O
    CONFIG_POSIX_FD_MGMT=y
    CONFIG_POSIX_FILE_SYSTEM_R=y
    CONFIG_POSIX_FILE_SYSTEM=y
    # POSIX memory
    CONFIG_POSIX_PAGE_SIZE=0x40
    # CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
    # CONFIG_POSIX_MAPPED_FILES is not set
    # CONFIG_POSIX_MEMORY_PROTECTION is not set
    # end of POSIX memory
    CONFIG_POSIX_MESSAGE_PASSING=y
    CONFIG_POSIX_MQ_OPEN_MAX=16
    CONFIG_POSIX_MQ_PRIO_MAX=32
    CONFIG_MSG_SIZE_MAX=16
    CONFIG_MQUEUE_NAMELEN_MAX=16
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_MQUEUE=1024
    CONFIG_POSIX_NETWORKING=y
    CONFIG_POSIX_HOST_NAME_MAX=63
    # CONFIG_POSIX_IPV6 is not set
    # CONFIG_POSIX_RAW_SOCKETS is not set
    CONFIG_POSIX_SINGLE_PROCESS=y
    CONFIG_POSIX_SYSCONF_IMPL_MACRO=y
    # CONFIG_POSIX_SYSCONF_IMPL_FULL is not set
    CONFIG_POSIX_UNAME_VERSION_LEN=70
    CONFIG_POSIX_UNAME_NODENAME_LEN=6
    # CONFIG_POSIX_ENV_LOG_LEVEL_OFF is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_ERR is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_WRN is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_INF is not set
    # CONFIG_POSIX_ENV_LOG_LEVEL_DBG is not set
    CONFIG_POSIX_ENV_LOG_LEVEL_DEFAULT=y
    CONFIG_POSIX_ENV_LOG_LEVEL=3
    CONFIG_POSIX_MULTI_PROCESS=y
    CONFIG_POSIX_MULTI_PROCESS_ALIAS_GETPID=y
    CONFIG_POSIX_THREADS=y
    CONFIG_POSIX_THREAD_THREADS_MAX=5
    CONFIG_MAX_PTHREAD_MUTEX_COUNT=5
    CONFIG_MAX_PTHREAD_COND_COUNT=5
    CONFIG_POSIX_THREAD_KEYS_MAX=5
    CONFIG_PTHREAD_RECYCLER_DELAY_MS=100
    CONFIG_POSIX_THREAD_ATTR_STACKADDR=y
    CONFIG_POSIX_THREAD_ATTR_STACKSIZE=y
    # CONFIG_POSIX_THREADS_EXT is not set
    CONFIG_POSIX_THREAD_PRIORITY_SCHEDULING=y
    CONFIG_POSIX_PTHREAD_ATTR_STACKSIZE_BITS=23
    CONFIG_POSIX_PTHREAD_ATTR_GUARDSIZE_BITS=9
    CONFIG_POSIX_PTHREAD_ATTR_GUARDSIZE_DEFAULT=0
    CONFIG_POSIX_THREAD_PRIO_INHERIT=y
    CONFIG_POSIX_THREAD_PRIO_PROTECT=y
    CONFIG_POSIX_THREAD_SAFE_FUNCTIONS=y
    # CONFIG_PTHREAD_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_LOG_LEVEL=3
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_MUTEX_LOG_LEVEL=3
    # CONFIG_PTHREAD_COND_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_COND_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_COND_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_COND_LOG_LEVEL=3
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_KEY_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_KEY_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_KEY_LOG_LEVEL=3
    CONFIG_POSIX_READER_WRITER_LOCKS=y
    CONFIG_MAX_PTHREAD_RWLOCK_COUNT=5
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_RWLOCK_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_RWLOCK_LOG_LEVEL=3
    # POSIX scheduler options
    # CONFIG_POSIX_PRIORITY_SCHEDULING is not set
    # end of POSIX scheduler options
    CONFIG_POSIX_SEMAPHORES=y
    CONFIG_POSIX_SEM_VALUE_MAX=32767
    CONFIG_POSIX_SEM_NSEMS_MAX=256
    CONFIG_POSIX_SEM_NAMELEN_MAX=16
    # POSIX signals
    CONFIG_POSIX_REALTIME_SIGNALS=y
    CONFIG_POSIX_RTSIG_MAX=8
    CONFIG_POSIX_SIGNALS=y
    CONFIG_POSIX_SIGNAL_STRING_DESC=y
    # end of POSIX signals
    CONFIG_POSIX_SPIN_LOCKS=y
    CONFIG_MAX_PTHREAD_SPINLOCK_COUNT=5
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_OFF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_ERR is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_WRN is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_INF is not set
    # CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DBG is not set
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL_DEFAULT=y
    CONFIG_PTHREAD_SPINLOCK_LOG_LEVEL=3
    # POSIX synchronized I/O
    CONFIG_POSIX_FSYNC=y
    CONFIG_POSIX_SYNCHRONIZED_IO=y
    # end of POSIX synchronized I/O
    CONFIG_POSIX_TIMERS=y
    CONFIG_POSIX_THREAD_CPUTIME=y
    CONFIG_POSIX_MONOTONIC_CLOCK=y
    CONFIG_POSIX_CPUTIME=y
    CONFIG_POSIX_CLOCK_SELECTION=y
    CONFIG_POSIX_DELAYTIMER_MAX=32
    CONFIG_POSIX_TIMER_MAX=32
    CONFIG_POSIX_TIMEOUTS=y
    CONFIG_TIMER_CREATE_WAIT=100
    # CONFIG_TIMER_LOG_LEVEL_OFF is not set
    # CONFIG_TIMER_LOG_LEVEL_ERR is not set
    # CONFIG_TIMER_LOG_LEVEL_WRN is not set
    # CONFIG_TIMER_LOG_LEVEL_INF is not set
    # CONFIG_TIMER_LOG_LEVEL_DBG is not set
    CONFIG_TIMER_LOG_LEVEL_DEFAULT=y
    CONFIG_TIMER_LOG_LEVEL=3
    # X/Open system interfaces
    # CONFIG_XSI_SINGLE_PROCESS is not set
    # CONFIG_XOPEN_STREAMS is not set
    # CONFIG_XSI_SYSTEM_LOGGING is not set
    CONFIG_XSI_THREADS_EXT=y
    # end of X/Open system interfaces
    # Miscellaneous POSIX-related options
    CONFIG_EVENTFD=y
    # end of Miscellaneous POSIX-related options
    # Deprecated POSIX options
    CONFIG_EVENTFD_MAX=1
    # CONFIG_FNMATCH is not set
    CONFIG_MAX_PTHREAD_COUNT=5
    CONFIG_MAX_PTHREAD_KEY_COUNT=5
    CONFIG_MAX_TIMER_COUNT=32
    CONFIG_MSG_COUNT_MAX=16
    CONFIG_POSIX_CLOCK=y
    # CONFIG_POSIX_FS is not set
    CONFIG_POSIX_LIMITS_RTSIG_MAX=8
    CONFIG_POSIX_MAX_FDS=16
    CONFIG_POSIX_MAX_OPEN_FILES=16
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_POSIX_PUTMSG is not set
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_POSIX_SYSCONF is not set
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_PTHREAD is not set
    # CONFIG_PTHREAD_BARRIER is not set
    # CONFIG_PTHREAD_COND is not set
    # CONFIG_PTHREAD_IPC is not set
    # CONFIG_PTHREAD_KEY is not set
    # CONFIG_PTHREAD_MUTEX is not set
    # CONFIG_PTHREAD_RWLOCK is not set
    # CONFIG_PTHREAD_SPINLOCK is not set
    # CONFIG_TIMER is not set
    CONFIG_TIMER_DELAYTIMER_MAX=32
    CONFIG_SEM_NAMELEN_MAX=16
    CONFIG_SEM_VALUE_MAX=32767
    # end of Deprecated POSIX options
    CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
    # end of POSIX Options
    # POSIX Shell Utilities
    # end of POSIX Shell Utilities
    # end of POSIX API Support
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_LIBGCC_RTLIB=y
    # Utility Library
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    CONFIG_ONOFF=y
    # CONFIG_UTF8 is not set
    # end of Utility Library
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    CONFIG_BT=y
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_SCA_UPDATE is not set
    # CONFIG_BT_TRANSMIT_POWER_CONTROL is not set
    # CONFIG_BT_PATH_LOSS_MONITORING is not set
    # CONFIG_BT_SUBRATING is not set
    # CONFIG_BT_CHANNEL_SOUNDING is not set
    # CONFIG_BT_ISO_PERIPHERAL is not set
    # CONFIG_BT_ISO_CENTRAL is not set
    # CONFIG_BT_ISO_BROADCASTER is not set
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # Bluetooth Classic Options
    # end of Bluetooth Classic Options
    # end of Bluetooth Host
    # CONFIG_BT_CTLR is not set
    # CONFIG_BT_EAD is not set
    # Bluetooth logging
    # Common
    # end of Common
    # Libraries
    # end of Libraries
    # Host
    # end of Host
    # Services
    # end of Services
    # end of Bluetooth logging
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_DAP is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    CONFIG_STACK_SENTINEL=y
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    CONFIG_DEBUG_COREDUMP=y
    CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
    # CONFIG_DEBUG_COREDUMP_BACKEND_FLASH_PARTITION is not set
    # CONFIG_DEBUG_COREDUMP_BACKEND_OTHER is not set
    CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
    # CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_THREADS is not set
    # CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_LINKER_RAM is not set
    # CONFIG_DEBUG_COREDUMP_THREADS_METADATA is not set
    # CONFIG_SYMTAB is not set
    # end of Debugging Options
    # CONFIG_MIPI_STP_DECODER is not set
    # CONFIG_CS_TRACE_DEFMT is not set
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    CONFIG_MCUBOOT_TRAILER_SWAP_TYPE=y
    CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE=0x3000
    CONFIG_IMG_BLOCK_BUF_SIZE=512
    # CONFIG_IMG_ENABLE_IMAGE_CHECK is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_OFF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_ERR is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_WRN is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_INF is not set
    # CONFIG_IMG_MANAGER_LOG_LEVEL_DBG is not set
    CONFIG_IMG_MANAGER_LOG_LEVEL_DEFAULT=y
    CONFIG_IMG_MANAGER_LOG_LEVEL=3
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    CONFIG_FILE_SYSTEM_LIB_LINK=y
    CONFIG_FILE_SYSTEM=y
    # CONFIG_FS_LOG_LEVEL_OFF is not set
    # CONFIG_FS_LOG_LEVEL_ERR is not set
    # CONFIG_FS_LOG_LEVEL_WRN is not set
    # CONFIG_FS_LOG_LEVEL_INF is not set
    # CONFIG_FS_LOG_LEVEL_DBG is not set
    CONFIG_FS_LOG_LEVEL_DEFAULT=y
    CONFIG_FS_LOG_LEVEL=3
    CONFIG_APP_LINK_WITH_FS=y
    CONFIG_FILE_SYSTEM_MAX_TYPES=2
    CONFIG_FILE_SYSTEM_MAX_FILE_NAME=-1
    CONFIG_FILE_SYSTEM_INIT_PRIORITY=99
    # CONFIG_FILE_SYSTEM_MKFS is not set
    # CONFIG_FAT_FILESYSTEM_ELM is not set
    # CONFIG_FILE_SYSTEM_LITTLEFS is not set
    # CONFIG_FILE_SYSTEM_EXT2 is not set
    # CONFIG_EXT2_LOG_LEVEL_OFF is not set
    # CONFIG_EXT2_LOG_LEVEL_ERR is not set
    # CONFIG_EXT2_LOG_LEVEL_WRN is not set
    # CONFIG_EXT2_LOG_LEVEL_INF is not set
    # CONFIG_EXT2_LOG_LEVEL_DBG is not set
    CONFIG_EXT2_LOG_LEVEL_DEFAULT=y
    CONFIG_EXT2_LOG_LEVEL=3
    # CONFIG_FCB is not set
    # CONFIG_ZMS_LOOKUP_CACHE is not set
    # CONFIG_ZMS_DATA_CRC is not set
    # CONFIG_ZMS_CUSTOMIZE_BLOCK_SIZE is not set
    # CONFIG_ZMS_NO_DOUBLE_WRITE is not set
    # CONFIG_ZMS_LOG_LEVEL_OFF is not set
    # CONFIG_ZMS_LOG_LEVEL_ERR is not set
    # CONFIG_ZMS_LOG_LEVEL_WRN is not set
    # CONFIG_ZMS_LOG_LEVEL_INF is not set
    # CONFIG_ZMS_LOG_LEVEL_DBG is not set
    CONFIG_ZMS_LOG_LEVEL_DEFAULT=y
    CONFIG_ZMS_LOG_LEVEL=3
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    CONFIG_IPC_SERVICE=y
    CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46
    CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2
    CONFIG_IPC_SERVICE_RPMSG=y
    CONFIG_IPC_SERVICE_STATIC_VRINGS=y
    CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT=4
    # CONFIG_IPC_SERVICE_ICMSG is not set
    # CONFIG_IPC_SERVICE_ICMSG_ME is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_DBG is not set
    CONFIG_IPC_SERVICE_LOG_LEVEL_DEFAULT=y
    CONFIG_IPC_SERVICE_LOG_LEVEL=3
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # Linkable loadable Extension Development Kit (EDK)
    CONFIG_LLEXT_EDK_NAME="llext-edk"
    # CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
    # end of Linkable loadable Extension Development Kit (EDK)
    # Logging
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    CONFIG_LOG_BLOCK_IN_THREAD=y
    CONFIG_LOG_BLOCK_IN_THREAD_TIMEOUT_MS=1000
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # CONFIG_LOG_TIMESTAMP_USE_REALTIME is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    # CONFIG_LOG_DBG_COLOR_BLUE is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP=y
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    CONFIG_LOG_OUTPUT_FORMAT_TIME_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_DATE_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_ISO8601_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    # CONFIG_LOG_BACKEND_FS is not set
    # CONFIG_LOG_BACKEND_NET is not set
    CONFIG_LOG_BACKEND_RTT=y
    # CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
    CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
    # CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
    CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
    CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
    CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
    CONFIG_LOG_BACKEND_RTT_BUFFER=0
    CONFIG_LOG_BACKEND_RTT_FORCE_PRINTK=y
    # CONFIG_LOG_BACKEND_SWO is not set
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_FMT_STRING_VALIDATE is not set
    # CONFIG_LOG_MEM_UTILIZATION is not set
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    CONFIG_MEM_ATTR=y
    # CONFIG_MEM_ATTR_HEAP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_HOSTNAME_ENABLE=y
    CONFIG_NET_HOSTNAME="zephyr"
    CONFIG_NET_HOSTNAME_DYNAMIC=y
    CONFIG_NET_HOSTNAME_MAX_LEN=63
    # CONFIG_NET_HOSTNAME_UNIQUE is not set
    # CONFIG_NET_HOSTNAME_LOG_LEVEL_OFF is not set
    # CONFIG_NET_HOSTNAME_LOG_LEVEL_ERR is not set
    # CONFIG_NET_HOSTNAME_LOG_LEVEL_WRN is not set
    # CONFIG_NET_HOSTNAME_LOG_LEVEL_INF is not set
    # CONFIG_NET_HOSTNAME_LOG_LEVEL_DBG is not set
    CONFIG_NET_HOSTNAME_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_HOSTNAME_LOG_LEVEL=3
    # Link layer options
    # CONFIG_NET_L2_DUMMY is not set
    # CONFIG_NET_L2_VIRTUAL is not set
    # CONFIG_NET_L2_ETHERNET_LOG_LEVEL_OFF is not set
    # CONFIG_NET_L2_ETHERNET_LOG_LEVEL_ERR is not set
    # CONFIG_NET_L2_ETHERNET_LOG_LEVEL_WRN is not set
    # CONFIG_NET_L2_ETHERNET_LOG_LEVEL_INF is not set
    # CONFIG_NET_L2_ETHERNET_LOG_LEVEL_DBG is not set
    CONFIG_NET_L2_ETHERNET_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_L2_ETHERNET_LOG_LEVEL=3
    # CONFIG_NET_L2_ETHERNET_RESERVE_HEADER is not set
    CONFIG_NET_L2_ETHERNET_MGMT=y
    # CONFIG_NET_L2_ETHERNET_ACCEPT_MISMATCH_L3_L2_ADDR is not set
    # CONFIG_NET_VLAN is not set
    CONFIG_NET_ARP=y
    CONFIG_NET_ARP_TABLE_SIZE=2
    CONFIG_NET_ARP_GRATUITOUS=y
    # CONFIG_NET_ARP_GRATUITOUS_TRANSMISSION is not set
    # CONFIG_NET_ARP_LOG_LEVEL_OFF is not set
    # CONFIG_NET_ARP_LOG_LEVEL_ERR is not set
    # CONFIG_NET_ARP_LOG_LEVEL_WRN is not set
    # CONFIG_NET_ARP_LOG_LEVEL_INF is not set
    # CONFIG_NET_ARP_LOG_LEVEL_DBG is not set
    CONFIG_NET_ARP_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_ARP_LOG_LEVEL=3
    # CONFIG_NET_GPTP is not set
    # CONFIG_NET_LLDP is not set
    # CONFIG_NET_ETHERNET_BRIDGE is not set
    CONFIG_NET_ETHERNET_FORWARD_UNRECOGNISED_ETHERTYPE=y
    # CONFIG_NET_L2_PPP is not set
    # CONFIG_NET_L2_OPENTHREAD is not set
    # CONFIG_NET_L2_CUSTOM_IEEE802154 is not set
    # CONFIG_NET_L2_CANBUS_RAW is not set
    CONFIG_NET_L2_WIFI_UTILS=y
    CONFIG_NET_L2_WIFI_MGMT=y
    # CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_OFF is not set
    # CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_ERR is not set
    # CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_WRN is not set
    # CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_INF is not set
    # CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_DBG is not set
    CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_L2_WIFI_MGMT_LOG_LEVEL=3
    # CONFIG_WIFI_MGMT_RAW_SCAN_RESULTS is not set
    CONFIG_WIFI_MGMT_TWT_CHECK_IP=y
    # CONFIG_WIFI_MGMT_FORCED_PASSIVE_SCAN is not set
    CONFIG_WIFI_SHELL_MAX_AP_STA=1
    CONFIG_WIFI_NM=y
    CONFIG_WIFI_NM_MAX_MANAGED_INTERFACES=1
    # CONFIG_WIFI_NM_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_NM_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_NM_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_NM_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_NM_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_NM_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_NM_LOG_LEVEL=3
    CONFIG_WIFI_MGMT_AP_STA_INACTIVITY_TIMEOUT=300
    # CONFIG_WIFI_MGMT_AP_STA_SKIP_INACTIVITY_POLL is not set
    CONFIG_WIFI_MGMT_AP_MAX_NUM_STA=4
    CONFIG_WIFI_ENT_IDENTITY_MAX_USERS=8
    # CONFIG_NET_L2_WIFI_SHELL is not set
    # CONFIG_NET_L2_PTP is not set
    # end of Link layer options
    # IP stack
    CONFIG_NET_IP=y
    CONFIG_NET_CONNECTION_SOCKETS=y
    CONFIG_NET_NATIVE=y
    CONFIG_NET_NATIVE_IP=y
    CONFIG_NET_NATIVE_IPV6=y
    CONFIG_NET_NATIVE_IPV4=y
    CONFIG_NET_NATIVE_TCP=y
    CONFIG_NET_NATIVE_UDP=y
    # CONFIG_NET_OFFLOAD is not set
    CONFIG_NET_INIT_PRIO=90
    CONFIG_NET_IP_DSCP_ECN=y
    CONFIG_NET_IF_MAX_IPV6_COUNT=1
    CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=2
    CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=3
    CONFIG_NET_IF_IPV6_PREFIX_COUNT=2
    CONFIG_NET_IPV6_MTU=1280
    # CONFIG_NET_IPV6_PMTU is not set
    CONFIG_NET_INITIAL_HOP_LIMIT=64
    CONFIG_NET_INITIAL_MCAST_HOP_LIMIT=1
    CONFIG_NET_IPV6_MAX_NEIGHBORS=8
    # CONFIG_NET_IPV6_FRAGMENT is not set
    CONFIG_NET_IPV6_ND=y
    CONFIG_NET_IPV6_DAD=y
    CONFIG_NET_IPV6_RS_TIMEOUT=1
    CONFIG_NET_IPV6_IID_EUI_64=y
    # CONFIG_NET_IPV6_IID_STABLE is not set
    # CONFIG_NET_IPV6_PE is not set
    # CONFIG_NET_6LO is not set
    # CONFIG_NET_IPV6_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IPV6_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IPV6_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IPV6_LOG_LEVEL_INF is not set
    # CONFIG_NET_IPV6_LOG_LEVEL_DBG is not set
    CONFIG_NET_IPV6_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IPV6_LOG_LEVEL=3
    # CONFIG_NET_IPV6_ND_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IPV6_ND_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IPV6_ND_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IPV6_ND_LOG_LEVEL_INF is not set
    # CONFIG_NET_IPV6_ND_LOG_LEVEL_DBG is not set
    CONFIG_NET_IPV6_ND_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IPV6_ND_LOG_LEVEL=3
    # CONFIG_NET_IPV6_PE_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IPV6_PE_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IPV6_PE_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IPV6_PE_LOG_LEVEL_INF is not set
    # CONFIG_NET_IPV6_PE_LOG_LEVEL_DBG is not set
    CONFIG_NET_IPV6_PE_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IPV6_PE_LOG_LEVEL=3
    # CONFIG_NET_ICMPV6_LOG_LEVEL_OFF is not set
    # CONFIG_NET_ICMPV6_LOG_LEVEL_ERR is not set
    # CONFIG_NET_ICMPV6_LOG_LEVEL_WRN is not set
    # CONFIG_NET_ICMPV6_LOG_LEVEL_INF is not set
    # CONFIG_NET_ICMPV6_LOG_LEVEL_DBG is not set
    CONFIG_NET_ICMPV6_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_ICMPV6_LOG_LEVEL=3
    # CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_INF is not set
    # CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_DBG is not set
    CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IPV6_NBR_CACHE_LOG_LEVEL=3
    CONFIG_NET_IPV4=y
    CONFIG_NET_IF_MAX_IPV4_COUNT=1
    CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1
    CONFIG_NET_IF_MCAST_IPV4_ADDR_COUNT=1
    CONFIG_NET_IPV4_DEFAULT_NETMASK=24
    CONFIG_NET_INITIAL_TTL=64
    CONFIG_NET_INITIAL_MCAST_TTL=1
    CONFIG_NET_IF_MCAST_IPV4_SOURCE_COUNT=1
    # CONFIG_NET_ICMPV4_ACCEPT_BROADCAST is not set
    # CONFIG_NET_IPV4_ACCEPT_ZERO_BROADCAST is not set
    # CONFIG_NET_IPV4_IGMP is not set
    # CONFIG_NET_IPV4_ACD is not set
    # CONFIG_NET_IPV4_AUTO is not set
    # CONFIG_NET_IPV4_HDR_OPTIONS is not set
    # CONFIG_NET_IPV4_FRAGMENT is not set
    # CONFIG_NET_IPV4_PMTU is not set
    # CONFIG_NET_IPV4_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IPV4_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IPV4_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IPV4_LOG_LEVEL_INF is not set
    # CONFIG_NET_IPV4_LOG_LEVEL_DBG is not set
    CONFIG_NET_IPV4_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IPV4_LOG_LEVEL=3
    # CONFIG_NET_ICMPV4_LOG_LEVEL_OFF is not set
    # CONFIG_NET_ICMPV4_LOG_LEVEL_ERR is not set
    # CONFIG_NET_ICMPV4_LOG_LEVEL_WRN is not set
    # CONFIG_NET_ICMPV4_LOG_LEVEL_INF is not set
    # CONFIG_NET_ICMPV4_LOG_LEVEL_DBG is not set
    CONFIG_NET_ICMPV4_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_ICMPV4_LOG_LEVEL=3
    # CONFIG_NET_IPV4_ACD_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IPV4_ACD_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IPV4_ACD_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IPV4_ACD_LOG_LEVEL_INF is not set
    # CONFIG_NET_IPV4_ACD_LOG_LEVEL_DBG is not set
    CONFIG_NET_IPV4_ACD_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IPV4_ACD_LOG_LEVEL=3
    # CONFIG_NET_IPV4_MAPPING_TO_IPV6 is not set
    # CONFIG_NET_SHELL is not set
    CONFIG_NET_TC_RX_COUNT=1
    # CONFIG_NET_TC_SKIP_FOR_HIGH_PRIO is not set
    CONFIG_NET_TC_THREAD_COOPERATIVE=y
    # CONFIG_NET_TC_THREAD_PREEMPTIVE is not set
    CONFIG_NET_TC_NUM_PRIORITIES=16
    # CONFIG_NET_TC_THREAD_PRIO_CUSTOM is not set
    CONFIG_NET_TC_MAPPING_STRICT=y
    CONFIG_NET_TX_DEFAULT_PRIORITY=1
    CONFIG_NET_RX_DEFAULT_PRIORITY=0
    # CONFIG_NET_ALLOW_ANY_PRIORITY is not set
    CONFIG_NET_IP_ADDR_CHECK=y
    CONFIG_NET_MAX_ROUTERS=2
    CONFIG_NET_ROUTE=y
    CONFIG_NET_MAX_ROUTES=8
    CONFIG_NET_MAX_NEXTHOPS=8
    # CONFIG_NET_ROUTE_MCAST is not set
    CONFIG_NET_TCP=y
    # CONFIG_NET_TCP_LOG_LEVEL_OFF is not set
    # CONFIG_NET_TCP_LOG_LEVEL_ERR is not set
    # CONFIG_NET_TCP_LOG_LEVEL_WRN is not set
    # CONFIG_NET_TCP_LOG_LEVEL_INF is not set
    # CONFIG_NET_TCP_LOG_LEVEL_DBG is not set
    CONFIG_NET_TCP_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_TCP_LOG_LEVEL=3
    CONFIG_NET_TCP_WORKER_PRIO=2
    CONFIG_NET_TCP_TIME_WAIT_DELAY=1500
    CONFIG_NET_TCP_INIT_RETRANSMISSION_TIMEOUT=200
    CONFIG_NET_TCP_RANDOMIZED_RTO=y
    CONFIG_NET_TCP_RETRY_COUNT=9
    CONFIG_NET_TCP_MAX_SEND_WINDOW_SIZE=0
    CONFIG_NET_TCP_MAX_RECV_WINDOW_SIZE=0
    CONFIG_NET_TCP_RECV_QUEUE_TIMEOUT=2000
    CONFIG_NET_TCP_PKT_ALLOC_TIMEOUT=100
    CONFIG_NET_TCP_FAST_RETRANSMIT=y
    CONFIG_NET_TCP_CONGESTION_AVOIDANCE=y
    # CONFIG_NET_TCP_KEEPALIVE is not set
    # CONFIG_NET_TCP_ISN_RFC6528 is not set
    CONFIG_NET_TCP_REJECT_CONN_WITH_RST=y
    # CONFIG_NET_TCP_IPV6_ND_REACHABILITY_HINT is not set
    # CONFIG_NET_TEST_PROTOCOL is not set
    CONFIG_NET_UDP=y
    CONFIG_NET_UDP_MISSING_CHECKSUM=y
    # CONFIG_NET_UDP_LOG_LEVEL_OFF is not set
    # CONFIG_NET_UDP_LOG_LEVEL_ERR is not set
    # CONFIG_NET_UDP_LOG_LEVEL_WRN is not set
    # CONFIG_NET_UDP_LOG_LEVEL_INF is not set
    # CONFIG_NET_UDP_LOG_LEVEL_DBG is not set
    CONFIG_NET_UDP_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_UDP_LOG_LEVEL=3
    CONFIG_NET_MAX_CONN=8
    CONFIG_NET_MAX_CONTEXTS=5
    # CONFIG_NET_CONTEXT_NET_PKT_POOL is not set
    CONFIG_NET_CONTEXT_SYNC_RECV=y
    CONFIG_NET_CONTEXT_CHECK=y
    # CONFIG_NET_CONTEXT_PRIORITY is not set
    # CONFIG_NET_CONTEXT_TXTIME is not set
    CONFIG_NET_CONTEXT_RCVTIMEO=y
    # CONFIG_NET_CONTEXT_SNDTIMEO is not set
    # CONFIG_NET_CONTEXT_RCVBUF is not set
    # CONFIG_NET_CONTEXT_SNDBUF is not set
    CONFIG_NET_CONTEXT_DSCP_ECN=y
    CONFIG_NET_CONTEXT_REUSEADDR=y
    CONFIG_NET_CONTEXT_REUSEPORT=y
    # CONFIG_NET_CONTEXT_RECV_PKTINFO is not set
    # CONFIG_NET_CONTEXT_TIMESTAMPING is not set
    # CONFIG_NET_CONTEXT_CLAMP_PORT_RANGE is not set
    # CONFIG_NET_TEST is not set
    CONFIG_NET_BUF_RX_COUNT=16
    CONFIG_NET_BUF_TX_COUNT=32
    # CONFIG_NET_BUF_FIXED_DATA_SIZE is not set
    CONFIG_NET_BUF_VARIABLE_DATA_SIZE=y
    CONFIG_NET_PKT_BUF_RX_DATA_POOL_SIZE=4096
    CONFIG_NET_PKT_BUF_TX_DATA_POOL_SIZE=4096
    CONFIG_NET_PKT_BUF_USER_DATA_SIZE=4
    CONFIG_NET_DEFAULT_IF_FIRST=y
    # CONFIG_NET_DEFAULT_IF_UP is not set
    # CONFIG_NET_DEFAULT_IF_ETHERNET is not set
    # CONFIG_NET_DEFAULT_IF_WIFI is not set
    CONFIG_NET_INTERFACE_NAME=y
    # CONFIG_NET_PKT_RXTIME_STATS is not set
    # CONFIG_NET_PKT_TXTIME_STATS is not set
    # CONFIG_NET_PKT_ALLOC_STATS is not set
    # CONFIG_NET_PROMISCUOUS_MODE is not set
    # CONFIG_NET_DISABLE_ICMP_DESTINATION_UNREACHABLE is not set
    # Stack usage
    # end of Stack usage
    CONFIG_NET_MGMT=y
    CONFIG_NET_MGMT_EVENT=y
    CONFIG_NET_MGMT_EVENT_THREAD=y
    # CONFIG_NET_MGMT_EVENT_SYSTEM_WORKQUEUE is not set
    # CONFIG_NET_MGMT_EVENT_DIRECT is not set
    CONFIG_NET_MGMT_EVENT_QUEUE=y
    CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT=5000
    CONFIG_NET_MGMT_EVENT_INFO=y
    # CONFIG_NET_MGMT_EVENT_LOG_LEVEL_OFF is not set
    # CONFIG_NET_MGMT_EVENT_LOG_LEVEL_ERR is not set
    # CONFIG_NET_MGMT_EVENT_LOG_LEVEL_WRN is not set
    # CONFIG_NET_MGMT_EVENT_LOG_LEVEL_INF is not set
    # CONFIG_NET_MGMT_EVENT_LOG_LEVEL_DBG is not set
    CONFIG_NET_MGMT_EVENT_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_MGMT_EVENT_LOG_LEVEL=3
    # CONFIG_NET_DEBUG_MGMT_EVENT_STACK is not set
    # CONFIG_NET_MGMT_THREAD_PRIO_CUSTOM is not set
    # CONFIG_NET_STATISTICS is not set
    CONFIG_NET_LOG=y
    # CONFIG_NET_PKT_LOG_LEVEL_OFF is not set
    # CONFIG_NET_PKT_LOG_LEVEL_ERR is not set
    # CONFIG_NET_PKT_LOG_LEVEL_WRN is not set
    # CONFIG_NET_PKT_LOG_LEVEL_INF is not set
    # CONFIG_NET_PKT_LOG_LEVEL_DBG is not set
    CONFIG_NET_PKT_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_PKT_LOG_LEVEL=3
    # CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set
    CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0
    # CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set
    # CONFIG_NET_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_NET_CORE_LOG_LEVEL_ERR is not set
    # CONFIG_NET_CORE_LOG_LEVEL_WRN is not set
    # CONFIG_NET_CORE_LOG_LEVEL_INF is not set
    # CONFIG_NET_CORE_LOG_LEVEL_DBG is not set
    CONFIG_NET_CORE_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_CORE_LOG_LEVEL=3
    # CONFIG_NET_IF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_IF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_IF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_IF_LOG_LEVEL_INF is not set
    # CONFIG_NET_IF_LOG_LEVEL_DBG is not set
    CONFIG_NET_IF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_IF_LOG_LEVEL=3
    # CONFIG_NET_TC_LOG_LEVEL_OFF is not set
    # CONFIG_NET_TC_LOG_LEVEL_ERR is not set
    # CONFIG_NET_TC_LOG_LEVEL_WRN is not set
    # CONFIG_NET_TC_LOG_LEVEL_INF is not set
    # CONFIG_NET_TC_LOG_LEVEL_DBG is not set
    CONFIG_NET_TC_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_TC_LOG_LEVEL=3
    # CONFIG_NET_UTILS_LOG_LEVEL_OFF is not set
    # CONFIG_NET_UTILS_LOG_LEVEL_ERR is not set
    # CONFIG_NET_UTILS_LOG_LEVEL_WRN is not set
    # CONFIG_NET_UTILS_LOG_LEVEL_INF is not set
    # CONFIG_NET_UTILS_LOG_LEVEL_DBG is not set
    CONFIG_NET_UTILS_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_UTILS_LOG_LEVEL=3
    # CONFIG_NET_CONTEXT_LOG_LEVEL_OFF is not set
    # CONFIG_NET_CONTEXT_LOG_LEVEL_ERR is not set
    # CONFIG_NET_CONTEXT_LOG_LEVEL_WRN is not set
    # CONFIG_NET_CONTEXT_LOG_LEVEL_INF is not set
    # CONFIG_NET_CONTEXT_LOG_LEVEL_DBG is not set
    CONFIG_NET_CONTEXT_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_CONTEXT_LOG_LEVEL=3
    # CONFIG_NET_CONN_LOG_LEVEL_OFF is not set
    # CONFIG_NET_CONN_LOG_LEVEL_ERR is not set
    # CONFIG_NET_CONN_LOG_LEVEL_WRN is not set
    # CONFIG_NET_CONN_LOG_LEVEL_INF is not set
    # CONFIG_NET_CONN_LOG_LEVEL_DBG is not set
    CONFIG_NET_CONN_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_CONN_LOG_LEVEL=3
    # CONFIG_NET_ROUTE_LOG_LEVEL_OFF is not set
    # CONFIG_NET_ROUTE_LOG_LEVEL_ERR is not set
    # CONFIG_NET_ROUTE_LOG_LEVEL_WRN is not set
    # CONFIG_NET_ROUTE_LOG_LEVEL_INF is not set
    # CONFIG_NET_ROUTE_LOG_LEVEL_DBG is not set
    CONFIG_NET_ROUTE_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_ROUTE_LOG_LEVEL=3
    # end of IP stack
    # Network Packet Filtering
    # CONFIG_NET_PKT_FILTER is not set
    # end of Network Packet Filtering
    # Network Protocols
    # CONFIG_COAP is not set
    # CONFIG_DNS_RESOLVER is not set
    # CONFIG_MDNS_RESPONDER is not set
    # CONFIG_LLMNR_RESPONDER is not set
    # CONFIG_DNS_SD is not set
    # CONFIG_MQTT_LIB is not set
    # CONFIG_MQTT_SN_LIB is not set
    # CONFIG_PTP is not set
    # CONFIG_TFTP_LIB is not set
    # CONFIG_HTTP_PARSER is not set
    # CONFIG_HTTP_PARSER_URL is not set
    # CONFIG_HTTP_CLIENT is not set
    # CONFIG_HTTP_SERVER is not set
    # CONFIG_NET_HTTP_LOG_LEVEL_OFF is not set
    # CONFIG_NET_HTTP_LOG_LEVEL_ERR is not set
    # CONFIG_NET_HTTP_LOG_LEVEL_WRN is not set
    # CONFIG_NET_HTTP_LOG_LEVEL_INF is not set
    # CONFIG_NET_HTTP_LOG_LEVEL_DBG is not set
    CONFIG_NET_HTTP_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_HTTP_LOG_LEVEL=3
    # CONFIG_NET_HTTP_SERVER_LOG_LEVEL_OFF is not set
    # CONFIG_NET_HTTP_SERVER_LOG_LEVEL_ERR is not set
    # CONFIG_NET_HTTP_SERVER_LOG_LEVEL_WRN is not set
    # CONFIG_NET_HTTP_SERVER_LOG_LEVEL_INF is not set
    # CONFIG_NET_HTTP_SERVER_LOG_LEVEL_DBG is not set
    CONFIG_NET_HTTP_SERVER_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_HTTP_SERVER_LOG_LEVEL=3
    # CONFIG_WEBSOCKET_CLIENT is not set
    # CONFIG_LWM2M is not set
    # CONFIG_SOCKS is not set
    # CONFIG_SNTP is not set
    # end of Network Protocols
    # Network Libraries
    # CONFIG_NET_CONFIG_LOG_LEVEL_OFF is not set
    # CONFIG_NET_CONFIG_LOG_LEVEL_ERR is not set
    # CONFIG_NET_CONFIG_LOG_LEVEL_WRN is not set
    # CONFIG_NET_CONFIG_LOG_LEVEL_INF is not set
    # CONFIG_NET_CONFIG_LOG_LEVEL_DBG is not set
    CONFIG_NET_CONFIG_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_CONFIG_LOG_LEVEL=3
    CONFIG_NET_CONFIG_SETTINGS=y
    CONFIG_NET_CONFIG_AUTO_INIT=y
    CONFIG_NET_CONFIG_INIT_PRIO=95
    # CONFIG_NET_CONFIG_NEED_IPV6_ROUTER is not set
    # CONFIG_NET_CONFIG_NEED_IPV4 is not set
    CONFIG_NET_CONFIG_INIT_TIMEOUT=0
    CONFIG_NET_CONFIG_MY_IPV6_ADDR=""
    CONFIG_NET_CONFIG_PEER_IPV6_ADDR=""
    CONFIG_NET_CONFIG_MY_IPV4_ADDR="192.168.1.99"
    CONFIG_NET_CONFIG_MY_IPV4_NETMASK="255.255.255.0"
    CONFIG_NET_CONFIG_MY_IPV4_GW="192.168.1.1"
    CONFIG_NET_CONFIG_PEER_IPV4_ADDR=""
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_PRIORITY_DEFAULT=50
    CONFIG_NET_SOCKETS_POLL_MAX=10
    CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000
    CONFIG_NET_SOCKET_MAX_SEND_WAIT=10000
    # CONFIG_NET_SOCKETS_SERVICE is not set
    # CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set
    CONFIG_NET_SOCKETS_TLS_PRIORITY=45
    CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y
    # CONFIG_NET_SOCKETS_OFFLOAD is not set
    CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY=40
    CONFIG_NET_SOCKETS_PACKET=y
    CONFIG_NET_SOCKETS_PACKET_DGRAM=y
    # CONFIG_NET_SOCKETS_CAN is not set
    CONFIG_NET_SOCKETPAIR=y
    CONFIG_NET_SOCKETPAIR_BUFFER_SIZE=1024
    # CONFIG_NET_SOCKETPAIR_STATIC is not set
    CONFIG_NET_SOCKETPAIR_HEAP=y
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_SOCKETPAIR=9120
    # CONFIG_NET_SOCKETS_NET_MGMT is not set
    # CONFIG_NET_SOCKETS_LOG_LEVEL_OFF is not set
    # CONFIG_NET_SOCKETS_LOG_LEVEL_ERR is not set
    # CONFIG_NET_SOCKETS_LOG_LEVEL_WRN is not set
    # CONFIG_NET_SOCKETS_LOG_LEVEL_INF is not set
    # CONFIG_NET_SOCKETS_LOG_LEVEL_DBG is not set
    CONFIG_NET_SOCKETS_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_SOCKETS_LOG_LEVEL=3
    # CONFIG_TLS_CREDENTIALS is not set
    # end of Network Libraries
    # Network additional services
    # CONFIG_NET_CAPTURE is not set
    CONFIG_NET_DHCPV4=y
    # CONFIG_NET_DHCPV4_LOG_LEVEL_OFF is not set
    # CONFIG_NET_DHCPV4_LOG_LEVEL_ERR is not set
    # CONFIG_NET_DHCPV4_LOG_LEVEL_WRN is not set
    # CONFIG_NET_DHCPV4_LOG_LEVEL_INF is not set
    # CONFIG_NET_DHCPV4_LOG_LEVEL_DBG is not set
    CONFIG_NET_DHCPV4_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_DHCPV4_LOG_LEVEL=3
    CONFIG_NET_DHCPV4_INITIAL_DELAY_MAX=10
    # CONFIG_NET_DHCPV4_OPTION_CALLBACKS is not set
    # CONFIG_NET_DHCPV4_OPTION_CALLBACKS_VENDOR_SPECIFIC is not set
    CONFIG_NET_DHCPV4_ACCEPT_UNICAST=y
    # CONFIG_NET_DHCPV4_VENDOR_CLASS_IDENTIFIER is not set
    # CONFIG_NET_DHCPV4_SERVER is not set
    # CONFIG_NET_DHCPV6 is not set
    CONFIG_NET_DHCPV6_DUID_MAX_LEN=22
    # CONFIG_NET_TRICKLE is not set
    # CONFIG_NET_ZPERF is not set
    CONFIG_WIFI_CREDENTIALS=y
    # CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_OFF is not set
    # CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_ERR is not set
    # CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_WRN is not set
    # CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_INF is not set
    # CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_DBG is not set
    CONFIG_WIFI_CREDENTIALS_LOG_LEVEL_DEFAULT=y
    CONFIG_WIFI_CREDENTIALS_LOG_LEVEL=3
    CONFIG_WIFI_CREDENTIALS_BACKEND_NONE=y
    CONFIG_WIFI_CREDENTIALS_MAX_ENTRIES=2
    CONFIG_WIFI_CREDENTIALS_SAE_PASSWORD_LENGTH=128
    CONFIG_WIFI_CREDENTIALS_CONNECT_STORED=y
    CONFIG_WIFI_CREDENTIALS_CONNECT_STORED_CONNECTION_TIMEOUT=30
    CONFIG_WIFI_CREDENTIALS_STATIC=y
    CONFIG_WIFI_CREDENTIALS_STATIC_SSID="Spiral"
    CONFIG_WIFI_CREDENTIALS_STATIC_PASSWORD="spiraloasis"
    # CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_OPEN is not set
    CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_PSK=y
    # CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_PSK_SHA256 is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_SAE is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC_TYPE_WPA_PSK is not set
    # end of Network additional services
    # CONFIG_NET_CONNECTION_MANAGER is not set
    # end of Networking
    # Power Management
    # CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_OFF is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_ERR is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_WRN is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_INF is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_DBG is not set
    CONFIG_PM_DEVICE_LOG_LEVEL_DEFAULT=y
    CONFIG_PM_DEVICE_LOG_LEVEL=3
    # end of Power Management
    # Portability
    # end of Portability
    # CONFIG_PROFILING is not set
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    # CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR is not set
    CONFIG_XOSHIRO_RANDOM_GENERATOR=y
    CONFIG_CSPRNG_AVAILABLE=y
    CONFIG_CSPRNG_ENABLED=y
    CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
    # CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SECURE_STORAGE is not set
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    CONFIG_FLASH_MAP=y
    # CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
    # CONFIG_FLASH_MAP_LABELS is not set
    CONFIG_STREAM_FLASH=y
    CONFIG_STREAM_FLASH_INSPECT=y
    CONFIG_STREAM_FLASH_POST_WRITE_CALLBACK=y
    CONFIG_STREAM_FLASH_ERASE=y
    # CONFIG_STREAM_FLASH_LOG_LEVEL_OFF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_ERR is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_WRN is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_INF is not set
    # CONFIG_STREAM_FLASH_LOG_LEVEL_DBG is not set
    CONFIG_STREAM_FLASH_LOG_LEVEL_DEFAULT=y
    CONFIG_STREAM_FLASH_LOG_LEVEL=3
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # CONFIG_MODULES is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_ROM_END_OFFSET=0x3000
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_ITERABLE_SUBALIGN=4
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_STD_C90 is not set
    CONFIG_STD_C99=y
    # CONFIG_STD_C11 is not set
    # CONFIG_STD_C17 is not set
    # CONFIG_STD_C23 is not set
    CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
    # CONFIG_GNU_C_EXTENSIONS is not set
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    CONFIG_BUILD_GAP_FILL_PATTERN=0xFF
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_DEPRECATED=y
    CONFIG_WARN_DEPRECATED=y
    CONFIG_EXPERIMENTAL=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
    # end of Compatibility
    I see. CONFIG_MBEDTLS_LEGACY_CRYPTO_C is needeed by CONFIG_HOSTAP_CRYPTO_ALT_LEGACY_PSA, which in turn is needed for wpa_supplicant. I am not able to see why you get the CONFIG_MBEDTLS_ENABLE_HEAP enabled, and seeing as it should not be needed, I do not se a problem by setting it to =n. You could back track and look at board and project configuration files to try to narrow down where it is set (either directly or something else is set that selects it).
