Automating merged.hex Patching After Build
Hello Nordic team,
I would like to automatically patch the merged.hex file each time I build my project. I’ve attempted to use extra_post_build in CMakeLists.txt, but my patching script still runs before the merged.hex file is generated.
From what I’ve read here https://devzone.nordicsemi.com/f/nordic-q-a/102010/adding-extra_post_build-step-from-out-of-tree-application, this behavior might be due to the CONFIG_BOOTLOADER_MCUBOOT macro.
Is there an alternative solution or recommended approach to ensure that my patching logic runs after merged.hex is fully created? i am using nrf 5340 and sdk 2.9.0
Thank you in advance!
kelk
  • Add a condition in your CMakeLists.txt using POST_BUILD for your execution something like below
    if (DEFINED CONFIG_BOOTLOADER_MCUBOOT)
      add_custom_command(
        TARGET mergehex
        POST_BUILD
        COMMAND ${CMAKE_COMMAND} -E env PYTHONPATH=${CMAKE_CURRENT_SOURCE_DIR}
                python ${CMAKE_CURRENT_SOURCE_DIR}/scripts/patch_hex.py
                ${CMAKE_BINARY_DIR}/merged.hex
    endif()
    I tested the provided code, but encountered the following error:
    CMake Error at CMakeLists.txt:119 (add_custom_command):
      No TARGET 'mergehex' has been created in this directory.
    To work around this, I manually added the target using:
    add_custom_target(mergehex
    --input ${CMAKE_BINARY_DIR}/../merged.hex
    However, after doing so, the Python script does not get executed.
  • Sorry for that experience.
    Can you please make sure that you have enabled the MCUBoot since this triggers the merged output via imgtool . I tested with this below
    my testing scripts/patch_hex.py contains (you might have different patch_hex.py)
    import sys
    print(f"Patching {sys.argv[1]} ...")
    with open(sys.argv[1], "a") as f:
        f.write("\n# Patched!\n")
    Adding below to the CMakeLists.txt
    # Run patching script after merged.hex is fully generated
    if(CONFIG_BOOTLOADER_MCUBOOT)
      add_custom_command(
        TARGET app
        POST_BUILD
        COMMAND ${CMAKE_COMMAND} -E echo "Running post-build patch on merged.hex..."
        COMMAND ${PYTHON_EXECUTABLE} ${CMAKE_CURRENT_SOURCE_DIR}/scripts/patch_hex.py
                ${CMAKE_BINARY_DIR}/zephyr/merged.hex
        COMMENT "Post-build: patch_hex.py running after merged.hex is created"
        VERBATIM
    endif()
    Make sure you do not have any typos. and make sure that CMAKE_CURRENT_SOURCE_DIR and  ${CMAKE_BINARY_DIR}/zephyr/merged.hex exists or replace them with the right directory.
    west build -b nrf5340dk/nrf5340/cpuapp -p
    should give something like
    Patching build/zephyr/merged.hex ...
    The commad  is still being executed before the merged files are generated.
    [0/24] Performing build step for 'ipc_radio'
    ninja: no work to do.
    [2/7] Linking C static library app\libapp.a
    [7/7] Linking C executable zephyr\zephyr.elf
    Memory region Used Size Region Size %age Used
    FLASH: 516152 B 916992 B 56.29%
    RAM: 243496 B 450544 B 54.04%
    IDT_LIST: 0 GB 32 KB 0.00%
    Generating files from C:/projects/sw_b/build/sw_b/zephyr/zephyr.elf for board: cpn0003
    image.py: sign the digest
    [5/20] Performing build step for 'mcuboot'
    [8/20] Performing build step for 'b0n'
    [18/18] Generating ../merged.hex
    * Terminal will be reused by tasks, press any key to close it.
  • You can copy path/to/ncs/version/zephyr/share/sysbuild/template/CMakeLists.txt to your project's sysbuild directory and then add your custom command and target there. For example:
    $ cp ~/ncs/v2.8.0/zephyr/share/sysbuild/template/CMakeLists.txt myapp/sysbuild/
    $ nvim myapp/sysbuild/CMakeLists.txt
    $ cat myapp/sysbuild/CMakeLists.txt
    find_package(Sysbuild REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(sysbuild LANGUAGES)
    add_custom_command(OUTPUT dummy.out COMMAND cmake -E touch dummy.out)
    add_custom_target(did-it-work ALL DEPENDS dummy.out merged_hex)
    [19/21] Generating ../dfu_application.zip
    [20/21] Generating ../merged.hex
    [21/21] Generating dummy.out
