Hey,
I have been using the FOTA download client library with bg95 module for HTTP dfu for a while and works perfectly fine.
Now that I have added a few additions to my project, which have made its size bigger. And now almost 98% of both my RAM and FLASH are full.
Memory region Used Size Region Size %age Used
FLASH: 477780 B 491008 B 97.31%
RAM: 253448 B 256 KB 96.68%
IDT_LIST: 0 GB 32 KB 0.00%
Now when I start fota, everything works good till downloading and setting the swap type and resetting device, but immediately the old(same) firmware boots up.
I could able to see another image in slot 1 when read via device manager apk(couldn't select the confirm option there too, error:bad state), also tried ble dfu via device manager apk, same happens here too, image uploads, new image in slot 1 when read, and when I send reset command old firmware boots immediately.(same in nrf connect apk too).
But when I reduce some libraries from my project, which results in following memory usage, fota works fine and image gets swapped.
FLASH: 468192 B 491008 B 95.35%
RAM: 251364 B 256 KB 95.89%
What could be the possible reason?
and also, is the IDT_LIST necessary?? mostly the project doesn't require debug requirements. can i able to disable them so I can extend the flash size ??
