I’m using the Zephyr nordic,npm1300-charger driver on an nRF52840 to control the nPM1300 PMIC charger. At runtime I need to be able to turn charging on and off—on command, while the application is running—rather than via a build-time Devicetree flag.
Specifically, I need to invoke a function (or Zephyr API call) from my application code that:
Disables the charger so the battery stops charging immediately.
Re-enables the charger when desired.
I’m looking for the recommended Zephyr/NCS API or example code snippet to perform these operations at runtime. Are there particular sensor attributes or PMIC driver functions I should call? Any guidance on register sequences, required delays, or best practices would be greatly appreciated.
Thank you!
