Hello everyone,
I'm facing a strange issue and would appreciate your input.
Background
This is an electrical sensor device that reads the main AC line and load data, performs local processing, and publishes the results to the cloud via LoRaWAN.
Note: The SoftDevice is not in use.
System Setup
MCU: nRF52832
ADC: 7 channels enabled, acquisition time = 3µs
Sampling: Triggered via TIMER0 through PPI
Samples per channel: 840
Timer period: 40µs → total ADC conversion takes ~33.6ms
Sampling frequency: Every 2 seconds
LoRaWAN uplink: Once every 60 seconds
Problem Statement
ADC Channel 0 intermittently fails to sample its input signal.
The behavior is inconsistent — it may work after a power cycle or it may not.
Troubleshooting Observations
If NVM access is disabled or writes are kept under 128 bytes, channel 0 behaves correctly.
The issue occurs even though NVM writes only happen during boot, right after system initialization and before ADC sampling.
Temporary Workaround
As a quick fix, I deferred the ADC initialization until after the NVM write operations. This seems to solve the issue, but it's clearly a workaround.
I'd like to understand the root cause and find a proper solution.
Any Suggestions?
Has anyone experienced similar behavior with the nRF52 ADC or internal flash/NVM writes?
Could this be related to SAADC hardware limitations, flash controller interaction, or analog pin instability?
Any insights would be greatly appreciated!
