nrf52840: RTT shell on the custom board not working
We want to enable zephyr shell over RTT on our custom board based on nrf52840. I tried the 'shell_module' sample with prj_minimal_rtt.conf and it works fine on nrf52840 devkit with nrf5340 (version command return the zephyr version in RTT viewer ).
When I tried the same sample on our custom board, the prompt is not visible and typing command does not return the zephyr version.
We already have another working firmware with custom dts file with ncs v2.6 with RTT logging working. The shell_module sample also does not run on our custom board (as described above)
For this specific firmware, we will later integrate the 'radio_test' application and we will not need other hardware peripherals. At beginning, we are only aiming to run the zephyr shell sample. So bare minimum board dts will be OK.
For our custom board, we connect to it using jlink-base to a pin header and 'SWO' pin is not connected to nrf chip. Is SWO pin a must for running RTT shell ? What else can we check ?
Amir
