Hi Support Team
What types of antenna is recommended for nRF9151 NTN. Many thanks.
Hi Support Team
I will ask internally. Do you have more information on use-case, type of application, and if this is an external or embedded antenna?
Øyvind
Hello again,
We recommend reaching out to our antenna solution partners as a first step. They are best equipped to provide detailed guidance on the most suitable antenna for your specific application.
Non-Terrestrial Networks (NTNs) require optimal link conditions, and the choice of antenna depends on several factors, including whether the application supports both LTE and NTN or NTN alone, as well as the physical constraints of the product—such as size and materials that may impact signal strength.
For applications targeting both LTE and NTN, it is essential to select a wideband antenna that can meet the performance and form factor requirements of both technologies. The antenna must support a broad frequency range to satisfy the performance criteria of LTE networks and the relevant satellite operators.
Let me know how that works for you.
Øyvind
Hello Oyvind
Thank you. By the way, how is the frequency range for NTN.
You can find the frequency bands here:
