FOTA update with external flash
I am trying to set up FOTA support with external flash for mcuboot secondary partition. I have gone through several tickets on the subject, but haven't been able to solve the issue.
The ncs version I am using is 2.9.1.
The problem seems to be (like in many other cases) secondary flash address etc. is not available:
26 | #define S_IMAGE_SECONDARY_PARTITION_OFFSET (PM_MCUBOOT_SECONDARY_ADDRESS)
/opt/nordic/ncs/v2.9.1/nrf/modules/trusted-firmware-m/tfm_boards/partition/region_defs.h:102:36: note: in expansion of macro 'S_IMAGE_SECONDARY_PARTITION_OFFSET'
102 | #define SECONDARY_PARTITION_START (S_IMAGE_SECONDARY_PARTITION_OFFSET)
/opt/nordic/ncs/v2.9.1/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c:763:33: note: in expansion of macro 'SECONDARY_PARTITION_START'
763 | .secondary_partition_base = SECONDARY_PARTITION_START,
I think the problem comes down to this:
warning: PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY (defined at
/opt/nordic/ncs/v2.9.1/nrf/subsys/partition_manager/Kconfig:214) was assigned the value 'y' but got
the value 'n'. Check these unsatisfied dependencies: (PM_EXTERNAL_FLASH_ENABLED || MCUBOOT) (=n).
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY
and/or look up PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY in the menuconfig/guiconfig interface. The
Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices
sections of the manual might be helpful too.
So, I may be missing some configuration parameters. Those two mentioned in the warning are not user settable. How would I be able to enable this?
