[MQTT sample] Assertion failed unlock mutex in mqtt_os
Hello Nordic team,
I'v found a bug on mqtt sample (using both ncs 3.0.0 and 2.6.1).
Description
Settings CONFIG_MQTT_SAMPLE_TRANSPORT_CLIENT_ID and trying to connect to an "off" broker will get this error after a certain time:
[00:30:16.784,271] <err> mqtt_helper: Cloud MQTT input error: -128
[00:30:16.935,668] <err> mqtt_helper: Cloud MQTT input error: -128
ASSERTION FAIL [ret == 0] @ WEST_TOPDIR/zephyr/subsys/net/lib/mqtt/mqtt_os.h:61
       sys_mutex_unlock failed with -22
[00:30:17.104,614] <err> os: r0/a1:  0x00000004  r1/a2:  0x0000003d  r2/a3:  0x00000005
[00:30:17.104,614] <err> os: r3/a4:  0x20011448 r12/ip:  0x0000000c r14/lr:  0x0002605f
[00:30:17.104,644] <err> os: xpsr:  0x41000000
[00:30:17.104,644] <err> os: Faulting instruction address (r15/pc): 0x00035a7e
[00:30:17.104,675] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
[00:30:17.104,736] <err> os: Current thread: 0x20011d88 (unknown)
This is due to the  mqtt_os mutex unlock being used despite the fact that is already unlocked.
Workaroud
You can either:
  • set CONFIG_ASSERT to n
  • in transport.c set a delay (tested with 10ms works)
/* Function executed when the module enters the disconnected state. */
static void disconnected_entry(void *o)
	struct s_object *user_object = o;
	/* Reschedule a connection attempt if we are connected to network and we enter the
	 * disconnected state.
	if (user_object->status == NETWORK_CONNECTED) {
		k_work_reschedule_for_queue(&transport_queue, &connect_work, K_MSEC(100));
Conclusion
This doesn't seems to be a critical bug, but it can show weakness in mqtt_helper that may introduce some bugs later on.
I don't have time to look further now, but I've found relevant to report this.
