Error message using nRF Connect DFU Programmer
I have used the Programmer previously with success. I am attempting to program the Dongle (10059) with a slightly modified version of ble_nusc_usb_dongle. Although it claims to have completed successfully in 14 seconds, it halts with an error message in red in the log. Also I note that the memory map shown in the Programmer does not change.
0:09:18.298
Hash is generated by SHA256
10:09:18.303
Performing DFU. This may take a few seconds
10:09:29.455
Getting serial port options from the persistent store for C5946A55E568.pc-nrfconnect-programmer
10:09:29.456
Wait For Device was successful
10:09:29.851
10:09:32.407
All dfu images have been written to the target device
10:09:33.136
10:09:33.136
10:09:33.550
10:09:34.053
Error when fetching device versions: Error: Failed with exit code 1. One or more set mcu state tasks failed: * C5946A55E568: No matching plugin found for operations to execute, code: UnsupportedDevice. Message: Failed to set mcu state on C5946A55E568, No matching plugin found for operations to execute.
  • I'm probably not asking the question correctly. For now I jsut need to be able to run the USB CDC demo without getting an error message every time I download new firmware, and with some confirmation that it loaded correctly.
  • Sorry, I think I must have mistaken this error for another (in previous versions of the programmer app you would get a similar sounding error if the updated application did not include the DFU Trigger Library (USB). However, I did not get any error when I tried to reproduce this now with the Programmer v4.5.0 app and the nRF5_SDK_17.1.0_ddde560/examples/peripheral/cli/hex/cli_pca10059_mbr.hex. Could you try with the same hex file?
  • I have what is apparently the same file from 17.0.2. It loads correctly, no error messages, and the memory map of the target is correctly updated. For whatever reason, my target hex file still generates the same error when I attempt to program. Here's a screenshot after an unsuccessful load, just prior to attempting to program again. Note that the Application area has only partially loaded, and the bootloader area does not appear to be exactly the same size either. Thus I deduce that the programming failed partway thru, but it did overwrite what was loaded previously from the file you suggested.
  • I note that when I change the Manufacturer and Product strings, USBView correctly shows the new strings. So at least part of the hex file is getting loaded correctly. It enumerates correctly as a USB serial port, but no data comes thru.
  • It's not possible to boot a partially updated application. In other words, if the app is now using a different manufacturer and product string, it means the update was successfully completed. Does it work again if you revert your modifications of the FW?
    The programmer app is only able to read back the memory content when you have a debugger attached, not when using SDFU. Thus, the representation shown in the UI may not be correct.
