Hi
I'm trying to load a custom board with nrf9160 with the Serial LTE Modem, and route the AT commands to the UART from a coprocessor (ESP32C3)
I have followed the guide on using an external MCU: https://docs.nordicsemi.com/bundle/ncs-2.9.0/page/nrf/applications/serial_lte_modem/doc/slm_description.html
But its not clear as to whether I need the 52840 chip on my custom board for this to work.
The closest I have got to this working after several nights of modifying overlays is access to the shell over my HW Serial port, but none of the AT commands are available.
Here's a rough breakdown of the steps I've taken:
Background:
I’m using the Nordic nRF9160 DK with the Serial LTE Modem (SLM) sample from NCS v3.0.1. My goal is to route the AT-command interface (UART1?) to Arduino header pins P0.05 (RX) and P0.06 (TX), then get the SLM shell working over that serial port.
1. Pin-mux & Overlay
By default, UART1 was mapped to P0.14/P0.15. I created a custom DTS overlay (
nrf9160dk_nrf9160_ns.overlay) to remapuart1_defaultto pins 5/6. -
Confirmed via the graphical devicetree viewer that the pins changed and, after rebuilding, saw “UART test: Hello from P0.05/P0.06!” on the serial console.
2. Shell vs. Console Confusion
I tried driving AT commands and shell commands directly over UART1, but:
In “console” mode I got
AT: command not found. -
In “shell” mode I got a Zephyr shell prompt but none of the SLM AT commands (e.g.
AT+CFUN?) were recognized.
Turns out SLM uses its own AT parser/backend, not the stock Zephyr shell, so I needed to disable the Zephyr shell and enable the AT console backend.
3. prj.conf Tweaks & Kconfig Errors
I modified prj.conf heavily, enabling/disabling for:
CONFIG_SHELL,CONFIG_SHELL_BACKEND_SERIAL -
CONFIG_UART_CONSOLEvs.CONFIG_RTT_CONSOLE -
CONFIG_AT_CMD_CUSTOM,CONFIG_NRFX_TIMER2, etc. -
Enabled downloader, FOTA, MQTT, TF-M lazy stacking, etc.
But that introduced a flood of build errors:
Undefined symbols:
AT_CMD,AT_HOST,TFM_ENABLE_FP,TFM_LAZY_STACKING -
Missing
nrf_cloud_agnss_schema_v1.h,cJSON.h -
Missing downloader sizes:
CONFIG_DOWNLOADER_MAX_HOSTNAME_SIZE, etc. -
MQTT config undefined (
CONFIG_MQTT_CLEAN_SESSION) -
Dependency loops in TF-M config: “INVALID CONFIG… AND CONFIG_TFM_LAZY_STACKING”
Errors in
slm_at_nrfcloud.c,slm_at_fota.c,slm_at_gnss.c,main.c, etc., due to missing headers and undefined Kconfig symbols.
4. Root Cause & Recovery Plan
I’d (re)discover that:
SLM has its own AT backends—you don’t use
CONFIG_SHELLbut rather the AT console (CONFIG_AT_CMD_CUSTOM,CONFIG_LOG_BACKEND_UART, etc.). -
Only pull in the exact downloader/MQTT/Kconfig symbols you need—don’t blanket-enable unsupported features.
Revert to a known-good commit and then incrementally re-apply each config line, rebuilding after each to catch exactly which setting breaks the build.
Next Steps:
Forum Request: Anyone who’s successfully routed UART1 → P0.05/P0.06 for SLM, could you share your minimal
prj.confand overlay snippets? -
DT Overlay Example: What exact lines did you use in
boards/nrf9160dk_nrf9160_ns.overlayto get Zephyr’suart1working on Arduino pins 5/6? -
Kconfig Tips: Best practices for including downloader/FOTA/MQTT symbols in SLM without pulling in every network feature and blowing up TF-M?
Many thanks in advance for reading this query and any insightful responses!
Tom
