nRF5340: LC3 initialization causes a reboot due to error: LC3_RESULT_INSUFFICIENT_RESOURCES
I am trying to integrate the nRF5340 Audio application (CIS Unicast Server role with bidirectional streaming enabled) from NCS 2.9.0 into on my custom nRF5340 based hardware.
I am encountering an issue that LC3_API
LC3Initialize() always returns error code -5002: LC3_RESULT_INSUFFICIENT_RESOURCES,  that fianlly cause system to reboot in function audio_system_start():  "Failed to set up codec"
	void audio_system_start(void)
    	ret = sw_codec_init(sw_codec_cfg);
    	ERR_CHK_MSG(ret, "Failed to set up codec");
The UART logs before reboot are as below:
[00:02:21.715,393] <dbg> audio_system: audio_system_start: Initializes the FIFOs, codec, and starts           the I2S
[00:02:21.715,454] <dbg> audio_system: audio_headset_configure: sw_codec_cfg.encoder.num_ch: 1,  Mon          o
[00:02:21.715,515] <dbg> audio_system: audio_headset_configure: sw_codec_cfg.decoder.num_ch: 1,  Mon          o
sw_codec_lc3_init: enc_sample_rates:0x3f, dec_sample_rates:0x3f
sw_codec_lc3_init: framesize:0
LC3Initialize: ret = -5002
[00:06:42.279,998] <err> audio_system: Failed to set up codec
[00:06:42.279,998] <err> audio_system: ERR_CHK Err_code: [-5002] @ line: 406
[00:06:42.280,029] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000008  r2/a3:  0x00000007
[00:06:42.280,029] <err> os: r3/a4:  0x00000003 r12/ip:  0x200055d0 r14/lr:  0x0009ce41
[00:06:42.280,059] <err> os:  xpsr:  0x01100000
[00:06:42.280,059] <err> os: s[ 0]:  0x000bc11c  s[ 1]:  0x0009cefd  s[ 2]:  0xffffec76  s[ 3]:  0x0          0000004
[00:06:42.280,090] <err> os: s[ 4]:  0x2006c3c0  s[ 5]:  0x00000001  s[ 6]:  0xffffec76  s[ 7]:  0x2          006c3a0
[00:06:42.280,090] <err> os: s[ 8]:  0x2006c3c0  s[ 9]:  0x000bc11c  s[10]:  0x20057674  s[11]:  0x0          009cf41
[00:06:42.280,120] <err> os: s[12]:  0x2006c3c0  s[13]:  0x000bce14  s[14]:  0xffffec76  s[15]:  0x0          0000196
[00:06:42.280,120] <err> os: fpscr:  0x00000000
[00:06:42.280,120] <err> os: Faulting instruction address (r15/pc): 0x00016fa2
[00:06:42.280,151] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:06:42.280,181] <err> os: Current thread: 0x20006d90 (CliHandler)
*** Booting MCUboot v2.1.0-dev-12e5ee106034 ***ystem error -- reason 3. Cold rebooting.
The out-of-box Audio application from NCS 2.9.0 can work fine on 5340 Audio DK but not on my custom board. And I did not change memory related configs against the nRF5340 Audio application. The system heap mem pool size was 4096 by default, and I increased it to 8192 but it still returned the same error "LC3_RESULT_INSUFFICIENT_RESOURCES"
Here are the configs regrading memory in my project:
     CONFIG_HEAP_MEM_POOL_SIZE=8192
     CONFIG_MAIN_STACK_SIZE=3072
     CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    CONFIG_SYS_HEAP_AUTO=y
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_MQUEUE=1024
    CONFIG_KERNEL_MEM_POOL=y
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
Here is the build result:
           FLASH:      880324 B     974336 B     90.35%
             RAM:      279652 B       504 KB     54.19%
        IDT_LIST:          0 GB        32 KB      0.00%
Generating files from xxx/build/zephyr/zephyr.elf for board: nrf5340_cpuapp
As you know, in unicast server, LC3 codec will only be intialized when audio_system_start() is called after the remote Unicast client connects it and intrsucts it to start streaming. This is how I orignally met the issue.
To reproduce this issue easily, I added a shell command to call audio_system_start() even if it is not connected to unicast client yet. I can also produce this same issue.
Here is the sw_codec_lc3.c I used, I just added some logs.
 * Copyright (c) 2021 Nordic Semiconductor ASA
 * All rights reserved.
 * SPDX-License-Identifier: Nordic-5-Clause
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice,
 * this list of conditions and the following disclaimer.
 * 5. Any software provided in binary form under this license must not be
 * reverse engineered, decompiled, modified and/or disassembled.
 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
 * POSSIBILITY OF SUCH DAMAGE.
#include <zephyr/kernel.h>
#include "sw_codec_lc3.h"
#include "LC3API.h"
LOG_MODULE_REGISTER(sw_codec_lc3);
#define ENC_BITRATE_WRN_LVL_LOW 24000
#define ENC_BITRATE_WRN_LVL_HIGH 160000
static uint16_t enc_pcm_bytes_req;
static uint32_t m_enc_bitrate;
static LC3EncoderHandle_t enc_handle_ch[CONFIG_LC3_ENC_CHAN_MAX];
static LC3DecoderHandle_t dec_handle_ch[CONFIG_LC3_DEC_CHAN_MAX];
static uint8_t enc_num_instances;
static uint8_t dec_num_instances;
int sw_codec_lc3_enc_run(void const *const pcm_data, uint32_t pcm_data_size, uint32_t enc_bitrate,
			 uint8_t audio_ch, uint16_t lc3_data_buf_size, uint8_t *const lc3_data,
			 uint16_t *const lc3_data_wr_size)
	int ret;
	/* Number of PCM bytes read */
	uint16_t bytes_read = 0;
	if (pcm_data_size < enc_pcm_bytes_req) {
		LOG_ERR("Too few PCM samples to encode. Bytes required %d, input is %d",
			enc_pcm_bytes_req, pcm_data_size);
		return -EINVAL;
	if (audio_ch >= enc_num_instances) {
		LOG_ERR("Trying to use audio_ch outside of allowed range");
		return -EINVAL;
	LC3EncodeInput_t LC3EncodeInput = { .PCMData = (void *)pcm_data,
					    .PCMDataLength = pcm_data_size,
					    .bytesRead = bytes_read };
	if (enc_bitrate == LC3_USE_BITRATE_FROM_INIT) {
		LC3EncodeInput.encodeBitrate = m_enc_bitrate;
	} else {
		LC3EncodeInput.encodeBitrate = enc_bitrate;
	LC3EncodeOutput_t LC3EncodeOutput = { .outputData = lc3_data,
					      .outputDataLength = lc3_data_buf_size,
					      .bytesWritten = 0 };
	if (!enc_handle_ch[audio_ch]) {
		LOG_ERR("LC3 enc ch:%d is not initialized", audio_ch);
		return -EPERM;
	ret = LC3EncodeSessionData(enc_handle_ch[audio_ch], &LC3EncodeInput, &LC3EncodeOutput);
	if (ret) {
		return ret;
	*lc3_data_wr_size = LC3EncodeOutput.bytesWritten;
	return 0;
int sw_codec_lc3_dec_run(uint8_t const *const lc3_data, uint16_t lc3_data_size,
			 uint16_t pcm_data_buf_size, uint8_t audio_ch, void *const pcm_data,
			 uint16_t *const pcm_data_wr_size, bool bad_frame)
	int ret;
	LC3BFI_t frame_status;
	uint16_t plc_counter = 0;
	if (audio_ch >= dec_num_instances) {
		return -EINVAL;
	if (bad_frame) {
		frame_status = BadFrame;
	} else {
		frame_status = GoodFrame;
	LC3DecodeInput_t LC3DecodeInput = { .inputData = (uint8_t *)lc3_data,
					    .inputDataLength = lc3_data_size,
					    frame_status };
	LC3DecodeOutput_t LC3DecodeOutput = { .PCMData = pcm_data,
					      .PCMDataLength = pcm_data_buf_size,
					      .bytesWritten = 0,
					      .PLCCounter = plc_counter };
	if (!dec_handle_ch[audio_ch]) {
		LOG_ERR("LC3 dec ch:%d is not initialized", audio_ch);
		return -EPERM;
	ret = LC3DecodeSessionData(dec_handle_ch[audio_ch], &LC3DecodeInput, &LC3DecodeOutput);
	if (ret) {
		return ret;
	/* A non-zero PLCCounter indicates PLC has been applied to the current frame.
	 * Upon a successful decode, PLCCounter is reset.
	if (LC3DecodeOutput.PLCCounter > 0 && IS_ENABLED(CONFIG_LC3_PLC_DISABLED))
		/* Write a blank frame (all 0) into buffer. */
		memset(pcm_data, 0, pcm_data_buf_size);
	*pcm_data_wr_size = LC3DecodeOutput.bytesWritten;
	return 0;
int sw_codec_lc3_enc_uninit_all(void)
	for (uint8_t i = 0; i < enc_num_instances; i++) {
		if (enc_handle_ch[i] != NULL) {
			LC3EncodeSessionClose(enc_handle_ch[i]);
			enc_handle_ch[i] = NULL;
		} else {
			LOG_ERR("Encoder:%d already unitialized", i);
			return -EALREADY;
	return 0;
int sw_codec_lc3_dec_uninit_all(void)
	for (uint8_t i = 0; i < dec_num_instances; i++) {
		if (dec_handle_ch[i] != NULL) {
			LC3DecodeSessionClose(dec_handle_ch[i]);
			dec_handle_ch[i] = NULL;
		} else {
			LOG_ERR("Decoder:%d already unitialized", i);
			return -EALREADY;
	return 0;
int sw_codec_lc3_init(uint8_t *sw_codec_lc3_buffer, uint32_t *sw_codec_lc3_buffer_size,
		      uint16_t framesize_us)
	int ret;
	uint8_t enc_sample_rates = 0;
	uint8_t dec_sample_rates = 0;
	/* Set unique session to 0 for using the default sharing memory setting.
	 * This could lead to higher heap consumption, but is able to manipulate
	 * different sample rate setting between encoder/decoder.
	uint8_t unique_session = 0;
	/* Check supported sample rates for encoder */
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_8_KHZ;
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_16_KHZ;
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_24_KHZ;
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_32_KHZ;
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_441_KHZ;
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_48_KHZ;
	/* Check supported sample rates for decoder */
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_8_KHZ;
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_16_KHZ;
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_24_KHZ;
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_32_KHZ;
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_441_KHZ;
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_48_KHZ;
	printk("sw_codec_lc3_init: enc_sample_rates:0x%x, dec_sample_rates:0x%x\r\n", enc_sample_rates, dec_sample_rates);
	LC3FrameSize_t framesize;
	switch (framesize_us) {
	case 7500:
		framesize = LC3FrameSize7_5Ms;
	case 10000:
		framesize = LC3FrameSize10Ms;
		LOG_ERR("Unsupported framesize: %d", framesize_us);
		return -EINVAL;
	printk("sw_codec_lc3_init: framesize:%d\r\n", framesize);
	ret = LC3Initialize(enc_sample_rates, dec_sample_rates, framesize, unique_session,
			    sw_codec_lc3_buffer, sw_codec_lc3_buffer_size);
	printk("LC3Initialize: ret = %d\r\n", ret);
	return ret;
int sw_codec_lc3_enc_init(uint16_t pcm_sample_rate, uint8_t pcm_bit_depth, uint16_t framesize_us,
			  uint32_t enc_bitrate, uint8_t num_channels, uint16_t *const pcm_bytes_req)
	int ret;
	case 7500:
	case 10000:
		return -EINVAL;
	if (enc_bitrate == 0) {
		LOG_ERR("LC3 enc_bitrate is 0");
		return -EINVAL;
	} else if (enc_bitrate <= ENC_BITRATE_WRN_LVL_LOW) {
		LOG_WRN("LC3 enc_bitrate: %d : likely too low", enc_bitrate);
	} else if (enc_bitrate >= ENC_BITRATE_WRN_LVL_HIGH) {
		LOG_WRN("LC3 enc_bitrate: %d : likely too high", enc_bitrate);
	enc_pcm_bytes_req = LC3PCMBuffersize(pcm_sample_rate, pcm_bit_depth, framesize, &ret);
	*pcm_bytes_req = enc_pcm_bytes_req;
	if (enc_pcm_bytes_req == 0) {
		LOG_ERR("Required PCM bytes to encode LC3 is zero.");
		return -EPERM;
	for (uint8_t i = 0; i < num_channels; i++) {
		if (enc_handle_ch[i]) {
			LOG_ERR("LC3 enc ch: %d already initialized", i);
			return -EALREADY;
		enc_handle_ch[i] = LC3EncodeSessionOpen(pcm_sample_rate, pcm_bit_depth, framesize,
							NULL, NULL, &ret);
		if (ret) {
			return ret;
	m_enc_bitrate = enc_bitrate;
	enc_num_instances = num_channels;
	return ret;
int sw_codec_lc3_dec_init(uint16_t pcm_sample_rate, uint8_t pcm_bit_depth, uint16_t framesize_us,
			  uint8_t num_channels)
	int ret;
	case 7500:
	case 10000:
		return -EINVAL;
		if (dec_handle_ch[i]) {
			LOG_ERR("LC3 dec ch: %d already initialized", i);
			return -EALREADY;
		dec_handle_ch[i] = LC3DecodeSessionOpen(pcm_sample_rate, pcm_bit_depth, framesize,
							NULL, NULL, &ret);
		if (ret) {
			return ret;
	dec_num_instances = num_channels;
	return 0;
I do see a similar post here LC3 initialization causes a restart but it was finally not resolved. So I have some questions for you as below:
1. So can you tell if there is any special memory reuqirement for LC3 code? Is it different from system heap memory?
2. As you can see the first parmater(i.e. sw_codec_lc3_buffer) is passed in as NULL when calling sw_codec_lc3_init(NULL, NULL, CONFIG_AUDIO_FRAME_DURATION_US);
does that mean it will let LC3 lib allocate the memory dynamically on its own?
Why does it return -5002:LC3_RESULT_INSUFFICIENT_RESOURCES  as error code?
    lincoln-lu said:
    No, I do not think the error was caused by the stack size of CONFIG_LE_AUDIO_MSG_SUB_STACK_SIZE. In fact I did not change this config, its value is 2048,  the same as out-of-box 5340 Audio application.
    The real problem is: in
    le_audio_msg_sub_thread, it is initializing lc3 encoder by callingsw_codec_lc3_enc_init(), which treis to dynamically allocate 3740Bytes from heap but failed.
    Thank you for correcting my misunderstanding.
    lincoln-lu said:
    I fianlly fixed this issue again using static array as the buffer passed to LC3 API
    LC3EncodeSessionOpen() , like below
    Great! Thank you for sharing your solution.
    Did you also have a chance to look into disabling the resampling feature?
    Maria
  • Did you also have a chance to look into disabling the resampling feature?
    what is impact if I disable resampling feature in headset(unicast server) when it works in bidirection streaming mode, i.e sending mic data to gatewat via LE audio?
    Thank you for your patience.
    I asked for some feedback regarding the resampling feature, and this is what I was told:
    You can only disable the resampling if you only plan on using 48kHz sampling. However this means that 16kHz and 24kHz is not supported, which will make your solution non-compliant with the LE Audio standard.
    I was also informed that the stack sizes used in the application have some room for reduction, and are meant to be experimented with to reduce to a suitable size.
    Maria
