nRF5340: LC3 initialization causes a reboot due to error: LC3_RESULT_INSUFFICIENT_RESOURCES
I am trying to integrate the nRF5340 Audio application (CIS Unicast Server role with bidirectional streaming enabled) from NCS 2.9.0 into on my custom nRF5340 based hardware.
I am encountering an issue that LC3_API
LC3Initialize() always returns error code -5002: LC3_RESULT_INSUFFICIENT_RESOURCES,  that fianlly cause system to reboot in function audio_system_start():  "Failed to set up codec"
	void audio_system_start(void)
    	ret = sw_codec_init(sw_codec_cfg);
    	ERR_CHK_MSG(ret, "Failed to set up codec");
The UART logs before reboot are as below:
[00:02:21.715,393] <dbg> audio_system: audio_system_start: Initializes the FIFOs, codec, and starts           the I2S
[00:02:21.715,454] <dbg> audio_system: audio_headset_configure: sw_codec_cfg.encoder.num_ch: 1,  Mon          o
[00:02:21.715,515] <dbg> audio_system: audio_headset_configure: sw_codec_cfg.decoder.num_ch: 1,  Mon          o
sw_codec_lc3_init: enc_sample_rates:0x3f, dec_sample_rates:0x3f
sw_codec_lc3_init: framesize:0
LC3Initialize: ret = -5002
[00:06:42.279,998] <err> audio_system: Failed to set up codec
[00:06:42.279,998] <err> audio_system: ERR_CHK Err_code: [-5002] @ line: 406
[00:06:42.280,029] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000008  r2/a3:  0x00000007
[00:06:42.280,029] <err> os: r3/a4:  0x00000003 r12/ip:  0x200055d0 r14/lr:  0x0009ce41
[00:06:42.280,059] <err> os:  xpsr:  0x01100000
[00:06:42.280,059] <err> os: s[ 0]:  0x000bc11c  s[ 1]:  0x0009cefd  s[ 2]:  0xffffec76  s[ 3]:  0x0          0000004
[00:06:42.280,090] <err> os: s[ 4]:  0x2006c3c0  s[ 5]:  0x00000001  s[ 6]:  0xffffec76  s[ 7]:  0x2          006c3a0
[00:06:42.280,090] <err> os: s[ 8]:  0x2006c3c0  s[ 9]:  0x000bc11c  s[10]:  0x20057674  s[11]:  0x0          009cf41
[00:06:42.280,120] <err> os: s[12]:  0x2006c3c0  s[13]:  0x000bce14  s[14]:  0xffffec76  s[15]:  0x0          0000196
[00:06:42.280,120] <err> os: fpscr:  0x00000000
[00:06:42.280,120] <err> os: Faulting instruction address (r15/pc): 0x00016fa2
[00:06:42.280,151] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
[00:06:42.280,181] <err> os: Current thread: 0x20006d90 (CliHandler)
*** Booting MCUboot v2.1.0-dev-12e5ee106034 ***ystem error -- reason 3. Cold rebooting.
The out-of-box Audio application from NCS 2.9.0 can work fine on 5340 Audio DK but not on my custom board. And I did not change memory related configs against the nRF5340 Audio application. The system heap mem pool size was 4096 by default, and I increased it to 8192 but it still returned the same error "LC3_RESULT_INSUFFICIENT_RESOURCES"
Here are the configs regrading memory in my project:
     CONFIG_HEAP_MEM_POOL_SIZE=8192
     CONFIG_MAIN_STACK_SIZE=3072
     CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    CONFIG_SYS_HEAP_AUTO=y
    CONFIG_HEAP_MEM_POOL_ADD_SIZE_MQUEUE=1024
    CONFIG_KERNEL_MEM_POOL=y
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
Here is the build result:
           FLASH:      880324 B     974336 B     90.35%
             RAM:      279652 B       504 KB     54.19%
        IDT_LIST:          0 GB        32 KB      0.00%
Generating files from xxx/build/zephyr/zephyr.elf for board: nrf5340_cpuapp
As you know, in unicast server, LC3 codec will only be intialized when audio_system_start() is called after the remote Unicast client connects it and intrsucts it to start streaming. This is how I orignally met the issue.
To reproduce this issue easily, I added a shell command to call audio_system_start() even if it is not connected to unicast client yet. I can also produce this same issue.
Here is the sw_codec_lc3.c I used, I just added some logs.
 * Copyright (c) 2021 Nordic Semiconductor ASA
 * All rights reserved.
 * SPDX-License-Identifier: Nordic-5-Clause
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice,
 * this list of conditions and the following disclaimer.
 * 5. Any software provided in binary form under this license must not be
 * reverse engineered, decompiled, modified and/or disassembled.
 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
 * POSSIBILITY OF SUCH DAMAGE.
#include <zephyr/kernel.h>
#include "sw_codec_lc3.h"
#include "LC3API.h"
LOG_MODULE_REGISTER(sw_codec_lc3);
#define ENC_BITRATE_WRN_LVL_LOW 24000
#define ENC_BITRATE_WRN_LVL_HIGH 160000
static uint16_t enc_pcm_bytes_req;
static uint32_t m_enc_bitrate;
static LC3EncoderHandle_t enc_handle_ch[CONFIG_LC3_ENC_CHAN_MAX];
static LC3DecoderHandle_t dec_handle_ch[CONFIG_LC3_DEC_CHAN_MAX];
static uint8_t enc_num_instances;
static uint8_t dec_num_instances;
int sw_codec_lc3_enc_run(void const *const pcm_data, uint32_t pcm_data_size, uint32_t enc_bitrate,
			 uint8_t audio_ch, uint16_t lc3_data_buf_size, uint8_t *const lc3_data,
			 uint16_t *const lc3_data_wr_size)
	int ret;
	/* Number of PCM bytes read */
	uint16_t bytes_read = 0;
	if (pcm_data_size < enc_pcm_bytes_req) {
		LOG_ERR("Too few PCM samples to encode. Bytes required %d, input is %d",
			enc_pcm_bytes_req, pcm_data_size);
		return -EINVAL;
	if (audio_ch >= enc_num_instances) {
		LOG_ERR("Trying to use audio_ch outside of allowed range");
		return -EINVAL;
	LC3EncodeInput_t LC3EncodeInput = { .PCMData = (void *)pcm_data,
					    .PCMDataLength = pcm_data_size,
					    .bytesRead = bytes_read };
	if (enc_bitrate == LC3_USE_BITRATE_FROM_INIT) {
		LC3EncodeInput.encodeBitrate = m_enc_bitrate;
	} else {
		LC3EncodeInput.encodeBitrate = enc_bitrate;
	LC3EncodeOutput_t LC3EncodeOutput = { .outputData = lc3_data,
					      .outputDataLength = lc3_data_buf_size,
					      .bytesWritten = 0 };
	if (!enc_handle_ch[audio_ch]) {
		LOG_ERR("LC3 enc ch:%d is not initialized", audio_ch);
		return -EPERM;
	ret = LC3EncodeSessionData(enc_handle_ch[audio_ch], &LC3EncodeInput, &LC3EncodeOutput);
	if (ret) {
		return ret;
	*lc3_data_wr_size = LC3EncodeOutput.bytesWritten;
	return 0;
int sw_codec_lc3_dec_run(uint8_t const *const lc3_data, uint16_t lc3_data_size,
			 uint16_t pcm_data_buf_size, uint8_t audio_ch, void *const pcm_data,
			 uint16_t *const pcm_data_wr_size, bool bad_frame)
	int ret;
	LC3BFI_t frame_status;
	uint16_t plc_counter = 0;
	if (audio_ch >= dec_num_instances) {
		return -EINVAL;
	if (bad_frame) {
		frame_status = BadFrame;
	} else {
		frame_status = GoodFrame;
	LC3DecodeInput_t LC3DecodeInput = { .inputData = (uint8_t *)lc3_data,
					    .inputDataLength = lc3_data_size,
					    frame_status };
	LC3DecodeOutput_t LC3DecodeOutput = { .PCMData = pcm_data,
					      .PCMDataLength = pcm_data_buf_size,
					      .bytesWritten = 0,
					      .PLCCounter = plc_counter };
	if (!dec_handle_ch[audio_ch]) {
		LOG_ERR("LC3 dec ch:%d is not initialized", audio_ch);
		return -EPERM;
	ret = LC3DecodeSessionData(dec_handle_ch[audio_ch], &LC3DecodeInput, &LC3DecodeOutput);
	if (ret) {
		return ret;
	/* A non-zero PLCCounter indicates PLC has been applied to the current frame.
	 * Upon a successful decode, PLCCounter is reset.
	if (LC3DecodeOutput.PLCCounter > 0 && IS_ENABLED(CONFIG_LC3_PLC_DISABLED))
		/* Write a blank frame (all 0) into buffer. */
		memset(pcm_data, 0, pcm_data_buf_size);
	*pcm_data_wr_size = LC3DecodeOutput.bytesWritten;
	return 0;
int sw_codec_lc3_enc_uninit_all(void)
	for (uint8_t i = 0; i < enc_num_instances; i++) {
		if (enc_handle_ch[i] != NULL) {
			LC3EncodeSessionClose(enc_handle_ch[i]);
			enc_handle_ch[i] = NULL;
		} else {
			LOG_ERR("Encoder:%d already unitialized", i);
			return -EALREADY;
	return 0;
int sw_codec_lc3_dec_uninit_all(void)
	for (uint8_t i = 0; i < dec_num_instances; i++) {
		if (dec_handle_ch[i] != NULL) {
			LC3DecodeSessionClose(dec_handle_ch[i]);
			dec_handle_ch[i] = NULL;
		} else {
			LOG_ERR("Decoder:%d already unitialized", i);
			return -EALREADY;
	return 0;
int sw_codec_lc3_init(uint8_t *sw_codec_lc3_buffer, uint32_t *sw_codec_lc3_buffer_size,
		      uint16_t framesize_us)
	int ret;
	uint8_t enc_sample_rates = 0;
	uint8_t dec_sample_rates = 0;
	/* Set unique session to 0 for using the default sharing memory setting.
	 * This could lead to higher heap consumption, but is able to manipulate
	 * different sample rate setting between encoder/decoder.
	uint8_t unique_session = 0;
	/* Check supported sample rates for encoder */
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_8_KHZ;
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_16_KHZ;
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_24_KHZ;
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_32_KHZ;
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_441_KHZ;
	if (IS_ENABLED(CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT)) {
		enc_sample_rates |= LC3_SAMPLE_RATE_48_KHZ;
	/* Check supported sample rates for decoder */
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_8_KHZ;
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_16_KHZ;
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_24_KHZ;
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_32_KHZ;
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_441_KHZ;
	if (IS_ENABLED(CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT)) {
		dec_sample_rates |= LC3_SAMPLE_RATE_48_KHZ;
	printk("sw_codec_lc3_init: enc_sample_rates:0x%x, dec_sample_rates:0x%x\r\n", enc_sample_rates, dec_sample_rates);
	LC3FrameSize_t framesize;
	switch (framesize_us) {
	case 7500:
		framesize = LC3FrameSize7_5Ms;
	case 10000:
		framesize = LC3FrameSize10Ms;
		LOG_ERR("Unsupported framesize: %d", framesize_us);
		return -EINVAL;
	printk("sw_codec_lc3_init: framesize:%d\r\n", framesize);
	ret = LC3Initialize(enc_sample_rates, dec_sample_rates, framesize, unique_session,
			    sw_codec_lc3_buffer, sw_codec_lc3_buffer_size);
	printk("LC3Initialize: ret = %d\r\n", ret);
	return ret;
int sw_codec_lc3_enc_init(uint16_t pcm_sample_rate, uint8_t pcm_bit_depth, uint16_t framesize_us,
			  uint32_t enc_bitrate, uint8_t num_channels, uint16_t *const pcm_bytes_req)
	int ret;
	case 7500:
	case 10000:
		return -EINVAL;
	if (enc_bitrate == 0) {
		LOG_ERR("LC3 enc_bitrate is 0");
		return -EINVAL;
	} else if (enc_bitrate <= ENC_BITRATE_WRN_LVL_LOW) {
		LOG_WRN("LC3 enc_bitrate: %d : likely too low", enc_bitrate);
	} else if (enc_bitrate >= ENC_BITRATE_WRN_LVL_HIGH) {
		LOG_WRN("LC3 enc_bitrate: %d : likely too high", enc_bitrate);
	enc_pcm_bytes_req = LC3PCMBuffersize(pcm_sample_rate, pcm_bit_depth, framesize, &ret);
	*pcm_bytes_req = enc_pcm_bytes_req;
	if (enc_pcm_bytes_req == 0) {
		LOG_ERR("Required PCM bytes to encode LC3 is zero.");
		return -EPERM;
	for (uint8_t i = 0; i < num_channels; i++) {
		if (enc_handle_ch[i]) {
			LOG_ERR("LC3 enc ch: %d already initialized", i);
			return -EALREADY;
		enc_handle_ch[i] = LC3EncodeSessionOpen(pcm_sample_rate, pcm_bit_depth, framesize,
							NULL, NULL, &ret);
		if (ret) {
			return ret;
	m_enc_bitrate = enc_bitrate;
	enc_num_instances = num_channels;
	return ret;
int sw_codec_lc3_dec_init(uint16_t pcm_sample_rate, uint8_t pcm_bit_depth, uint16_t framesize_us,
			  uint8_t num_channels)
	int ret;
	case 7500:
	case 10000:
		return -EINVAL;
		if (dec_handle_ch[i]) {
			LOG_ERR("LC3 dec ch: %d already initialized", i);
			return -EALREADY;
		dec_handle_ch[i] = LC3DecodeSessionOpen(pcm_sample_rate, pcm_bit_depth, framesize,
							NULL, NULL, &ret);
		if (ret) {
			return ret;
	dec_num_instances = num_channels;
	return 0;
I do see a similar post here LC3 initialization causes a restart but it was finally not resolved. So I have some questions for you as below:
1. So can you tell if there is any special memory reuqirement for LC3 code? Is it different from system heap memory?
2. As you can see the first parmater(i.e. sw_codec_lc3_buffer) is passed in as NULL when calling sw_codec_lc3_init(NULL, NULL, CONFIG_AUDIO_FRAME_DURATION_US);
does that mean it will let LC3 lib allocate the memory dynamically on its own?
Why does it return -5002:LC3_RESULT_INSUFFICIENT_RESOURCES  as error code?
    I am not sure, but it would be interesting to see if there are any obvious differences for the same application built for your custom board and the nRF5340 Audio DK. Are you willing to build both versions and share the resulting .config for the application core and sysbuild with us?
    There could be configurations which are invoked for the Audio DK but not for your custom board.
    According to the function description, the needed memory should be allocated. (ref https://github.com/nrfconnect/sdk-nrfxlib/blame/v2.9.0/lc3/codec/inc/LC3API.h#L213)
    Since it is not succeeding to do so, it is interesting to find out which value *sw_codec_lc3_buffer points to after the initialization function fails.
    I am not sure if the value is updated when the input parameters are NULL, but it will be updated if the bufferSize value is too small. Since LC3_RESULT_INSUFFICIENT_RESOURCES is returned it does indicate that the initialization function is called with a *bufferSize < "required memory for codec" at some point.
    As another trial to see if the LC3 codec will run on your hardware is to look into the sw_code_lc3 test sample: https://github.com/nrfconnect/sdk-nrf/blob/v2.9.0/tests/nrf5340_audio/sw_codec_lc3/main.c
    Maria
  • As to my first question, I have figured out a way to know how much RAM is required by LC3 codec for 48KHz, 10ms duration time as below
     uint32_t bufferSize = 4096;
          NULL, &bufferSize);
     printk("LC3Initialize reurens bufferSize: %d\r\n", bufferSize);
    The result is
    LC3Initialize reurens bufferSize: 29584
    so it needs 29584  bytes.
    I guess the reason why sw_codec_lc3_init(NULL, NULL, CONFIG_AUDIO_FRAME_DURATION_US); returns success on 5340ADK is the nRF audio application is relatively simpler(waht I can see it only includes main thread, encoder thread, decoder threads, le-audio-rx thread) than my own project, so the 512KB RAM insider nRF5340 is enough to it. while in my project I have many other user threads, thus there is far less than 29KB RAM remining for heap.
    So my next question is: I see the stack size of the encoder and audio_datapath theads in NCS 2.9.0 5340 Audio application code are very big to me,  see the defualt values of CONFIG_ENCODER_STACK_SIZE and CONFIG_AUDIO_DATAPATH_STACK_SIZE below:
    menu "Stack sizes"
    config ENCODER_STACK_SIZE
    	int "Stack size for encoder thread"
    	default 11000 if AUDIO_BIT_DEPTH_16
    	default 21400 if AUDIO_BIT_DEPTH_32
    config AUDIO_DATAPATH_STACK_SIZE
    	int "Stack size for audio datapath thread"
    	default 7600 if AUDIO_BIT_DEPTH_16
    	default 14700 if AUDIO_BIT_DEPTH_32
    config LE_AUDIO_MSG_SUB_STACK_SIZE
    	int "Stack size for LE Audio subscriber"
    	default 2048
    config BT_MGMT_MSG_SUB_STACK_SIZE
    	int "Stack size for bt_mgmt subscriber"
    	default 2048
    config CONTENT_CONTROL_MSG_SUB_STACK_SIZE
    	int "Stack size for content control subscriber"
    	default 1024
    endmenu # Stack sizes
    Can you check with your audio team that if I can reduce these stack sizes safely?
    thanks
  • Well, after I tried my best to save RAM memory from my project, and then defined a static buffer of 32KB for  LC3Initialize(), it succeeded to inilalize LC3. see the code below:
    #define LC3_STATIC_BUFFER_SIZE   (32 * 1024) // 32K bytes
    static uint8_t lc3_codec_buf[LC3_STATIC_BUFFER_SIZE];
    	int ret;
    	case 7500:
    	case 10000:
    		return -EINVAL;
    	uint32_t required_size = 0;
    			   NULL, &required_size);
    	printk("First call of LC3Initialize: ret=%d, required buffer size=%d\r\n", ret, required_size);
    	if ( LC3_RESULT_INSUFFICIENT_RESOURCES == ret ) // failed to allocate memory dynamically, now Initialize LC3 again using static buffer
    		if ( required_size > LC3_STATIC_BUFFER_SIZE ) {
    			printk("Static LC3 buffer is too small!!\r\n");
    			return ret;
    		memset(lc3_codec_buf, 0, required_size);
    					lc3_codec_buf, &required_size);
    		printk("Second call of LC3Initialize with static buffer: ret=%d, actual buf_size=%d\r\n", ret, required_size);
    	return ret;
    However, the subsequent call to
    sw_codec_lc3_enc_init() failed and cause system reboot again.
    [00:00:05.131,072] <err> audio_system: Failed to set up codec
    [00:00:05.131,072] <err> audio_system: ERR_CHK Err_code: [-5002] @ line: 406
    [00:00:05.131,103] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000014  r2/a3:  0x00000013
    [00:00:05.131,103] <err> os: r3/a4:  0x00000003 r12/ip:  0x200052e8 r14/lr:  0x0009cdeb
    [00:00:05.131,103] <err> os:  xpsr:  0x21100000
    [00:00:05.131,134] <err> os: s[ 0]:  0x000b9d54  s[ 1]:  0x0009cea7  s[ 2]:  0xffffec76  s[ 3]:  0x00000004
    [00:00:05.131,134] <err> os: s[ 4]:  0x200340f0  s[ 5]:  0x00000001  s[ 6]:  0xffffec76  s[ 7]:  0x200340d0
    [00:00:05.007,751] <dbg> main: le_audio_msg_sub_thread: Received event = 2, current state = 1
    [00:00:05.131,164] <err> os: s[ 8]:  0x200340f0  s[ 9]:  0x000b9d54  s[10]:  0x00001900  s[11]:  0x0009ceeb
    [00:00:05.131,195] <err> os: s[12]:  0x200340f0  s[13]:  0x000baa44  s[14]:  0xffffec76  s[15]:  0x00000196
    [00:00:05.131,225] <err> os: fpscr:  0x00000000
    [00:00:05.131,225] <err> os: Faulting instruction address (r15/pc): 0x00017a4e
    [00:00:05.131,286] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    [00:00:05.131,317] <err> os: Current thread: 0x200043e8 (LE_AUDIO_MSG_SUB)
    I narrowed down the error position, it is LC3EncodeSessionOpen(pcm_sample_rate, pcm_bit_depth, framesize, NULL, NULL, &ret); rurturning -5002: LC3_RESULT_INSUFFICIENT_RESOURCES  again!
    so it is obvious that not only LC3 lib needs to allocate a very big buffer, but also lc3 encoder session!
    	int ret;
    	case 7500:
    	case 10000:
    		return -EINVAL;
    		return -EINVAL;
    		return -EPERM;
    			return -EALREADY;
    							NULL, NULL, &ret);
    		if (ret) {
    			return ret;
    	return ret;
    Thank you for your updates.
    These values were increased some time ago (february 2024) when the resampling feature was introduced. The increase accounts for higher stack usage when the feature is in use. The resampling feature can be disabled with CONFIG_SAMPLE_RATE_CONVERTER=y. When the feature is disabled, you should be able to safely reduce the stack sizes for the encoder and audio datapath.
    You can see what the values for the stacks were before the resampling addition here: https://github.com/nrfconnect/sdk-nrf/commit/0a2ef78ea8a82aa84539037d17eaff9a39b8c248#diff-47659bfa917ed5f5bf471b2e405f09d84c304281115895f9915ea784c6e30a68L344 (lines 344/343-352/351).
    lincoln-lu said:
    However, the subsequent call to sw_codec_lc3_enc_init() failed and cause system reboot again.
    The stack which seems to be too small here is the CONFIG_LE_AUDIO_MSG_SUB_STACK_SIZE. The log above is lines 13 and 14 in your latest device log.
    Maria
  • The stack which seems to be too small here is the CONFIG_LE_AUDIO_MSG_SUB_STACK_SIZE. The log above is lines 13 and 14 in your latest device log.
    Hi
    No, I do not think the error was caused by the stack size of CONFIG_LE_AUDIO_MSG_SUB_STACK_SIZE. In fact I did not change this config, its value is 2048,  the same as out-of-box 5340 Audio application.
    The real problem is: in
    le_audio_msg_sub_thread, it is initializing lc3 encoder by callingsw_codec_lc3_enc_init(), which treis to dynamically allocate 3740Bytes from heap but failed.
    see the call stack below:
    le_audio_msg_sub_thread -> audio_system_start ->  sw_codec_init -> sw_codec_lc3_enc_init
    I fianlly fixed this issue again using static array as the buffer passed to LC3 API
    LC3EncodeSessionOpen() , like below
    #define LC3_ENCODER_BUFFER_SIZE   (4 * 1024)  // 4K bytes
    static uint8_t lc3_encoder_buf[2][LC3_ENCODER_BUFFER_SIZE];
    uint16_t required_size = 0;
    int sw_codec_lc3_enc_init()
    			return -EALREADY;
    							NULL, &required_size, &ret);
    		printk("chan %d, first call of LC3EncodeSessionOpen: ret=%d, required buffer size=%d\r\n", i, ret, required_size);
    		if ( LC3_RESULT_INSUFFICIENT_RESOURCES == ret ) // failed to allocate memory dynamically, now open LC3 encoder again using static buffer
    			if ( required_size > LC3_ENCODER_BUFFER_SIZE ) {
    				printk("LC3 encoder static buffer is too small!!\r\n");
    				return ret;
    			memset(lc3_encoder_buf[i], 0, LC3_ENCODER_BUFFER_SIZE);
    													lc3_encoder_buf[i], &required_size, &ret);
    			printk("chan %d, second call of LC3EncodeSessionOpen with static buffer: ret=%d, actual buf_size=%d\r\n", i, ret, required_size);
    		if (ret) {
    			return ret;
