How to make the Intermittent application with GRTC and LFXO while asleep.
Hi.
I have been investigating how to use GRTC and LFXO for LFCLK with nRF54L15DK.
In my goal, I would like to make the Intermittent application with sleep and GRTC that works with LFXO even if the MCU stay asleep.
I found the library(nrfx_grtc.h), but I couldn't find the sample named 'GRTC' with the library from ncs 3.0.0.
Do you know how to manipulate the API of GRTC, and properly to write the prj.cof ?
Best regards.
  • Hi.
    Thank you for replying.
    I'll put them.
    with 'nrf54l15dk/nrf54l15/cpuapp'
    # CONFIG_APP_USE_RETAINED_MEM is not set
    # CONFIG_GPIO_WAKEUP_ENABLE is not set
    CONFIG_GRTC_WAKEUP_ENABLE=y
    # CONFIG_LPCOMP_WAKEUP_ENABLE is not set
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    CONFIG_ROM_START_OFFSET=0
    CONFIG_NUM_IRQS=271
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=1000000
    CONFIG_FLASH_SIZE=500
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_SOC_RESET_HOOK=y
    CONFIG_MAIN_STACK_SIZE=1024
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_CLOCK_CONTROL=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=31250
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_XIP=y
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_CPU_HAS_ARM_MPU=y
    # CONFIG_COUNTER is not set
    # CONFIG_SHARED_INTERRUPTS is not set
    CONFIG_PM_DEVICE=y
    CONFIG_TICKLESS_KERNEL=y
    # CONFIG_FPU is not set
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    # CONFIG_USE_DT_CODE_PARTITION is not set
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_CACHE_MANAGEMENT=y
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_INIT_STACKS is not set
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_FLASH_LOAD_OFFSET=0
    # CONFIG_REGULATOR is not set
    CONFIG_PM_DEVICE_SYSTEM_MANAGED=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    # CONFIG_BUILD_OUTPUT_S19 is not set
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_MFD is not set
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_SPI is not set
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    # CONFIG_MEMC is not set
    CONFIG_CACHE=y
    CONFIG_LOG=y
    CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_ROMSTART_RELOCATION_ROM is not set
    CONFIG_DCACHE_LINE_SIZE=32
    # CONFIG_RESET is not set
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    # CONFIG_NRF_RTC_TIMER is not set
    CONFIG_LOG_DOMAIN_NAME=""
    # CONFIG_ASSERT is not set
    CONFIG_CACHE_NRF_CACHE=y
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_PM_DEVICE_POWER_DOMAIN=y
    # CONFIG_PM_DEVICE_RUNTIME is not set
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    # CONFIG_SYSCON is not set
    CONFIG_SERIAL_INIT_PRIORITY=50
    # CONFIG_INTC_MTK_ADSP is not set
    # CONFIG_MTK_ADSP_TIMER is not set
    CONFIG_CONSOLE=y
    # CONFIG_WINSTREAM is not set
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_SOC_TOOLCHAIN_NAME="amd_acp_6_0_adsp"
    CONFIG_GEN_SW_ISR_TABLE=y
    # CONFIG_REBOOT is not set
    CONFIG_GEN_IRQ_START_VECTOR=0
    CONFIG_SRAM_OFFSET=0
    # CONFIG_POWER_DOMAIN is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    # CONFIG_SCHED_CPU_MASK is not set
    # CONFIG_WATCHDOG is not set
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_CLOCK_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_BT_HCI_SDC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GRTC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_HFXO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_LFXO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PPIB_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF54L_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_RRAM_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_MEMORY_REGION_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_PSA_CRYPTO_RNG_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_RETAINED_RAM_ENABLED=y
    # end of Devicetree Info
    # Modules
    # CONFIG_BUILD_ONLY_NO_BLOBS is not set
    # Available modules.
    # nrf (C:/ncs/v3.0.0/nrf)
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_LOG_BUFFER_SIZE=1024
    CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT=32
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    # CONFIG_ZMS is not set
    # CONFIG_MBEDTLS is not set
    # CONFIG_MBEDTLS_MD_C is not set
    # CONFIG_MBEDTLS_TLS_LIBRARY is not set
    # CONFIG_MBEDTLS_X509_LIBRARY is not set
    # CONFIG_MBEDTLS_ENABLE_HEAP is not set
    # CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C is not set
    # CONFIG_MBEDTLS_LEGACY_CRYPTO_C is not set
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    CONFIG_NRF_SECURITY_ENABLER=y
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # Subsystems
    # Bootloader
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7000
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y
    CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # BLE over nRF RPC
    CONFIG_HEAP_MEM_POOL_SIZE=0
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # CONFIG_NRF_CLOUD is not set
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_DOWNLOADER is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # CONFIG_OPENTHREAD_RPC is not set
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # CONFIG_NFC_RPC is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=28
    CONFIG_MPSL_HFCLK_LATENCY=854
    CONFIG_MPSL_INIT_PRIORITY=40
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # CONFIG_MPSL_PIN_DEBUG is not set
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_SIZE=92
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0
    CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0
    # Zephyr subsystem configurations
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_PATH=""
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x17000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # Full Modem Firmware Update Management(FMFU)
    # end of Full Modem Firmware Update Management(FMFU)
    # Additional MCUmgr configuration
    # Additional MCUmgr group configuration
    # Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr group configuration
    # end of Additional MCUmgr configuration
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    CONFIG_NRF_SECURITY=y
    # Nordic-added meta types
    # Nordic added alg types
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_AES_KW is not set
    # CONFIG_PSA_WANT_ALG_AES_KWP is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE_PT is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE is not set
    # Nordic added ECC curve types
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    # Nordic addded RNG configuration
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # Nordic added key types
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set
    CONFIG_MBEDTLS_PSA_CRYPTO_BUILTIN_KEYS=y
    CONFIG_MBEDTLS_CFG_FILE="nrf-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-user-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_PSA_CORE_OBERON=y
    # CONFIG_PSA_CORE_LITE is not set
    # PSA Driver Support
    CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y
    # CONFIG_PSA_CRYPTO_DRIVER_OBERON is not set
    CONFIG_PSA_CRYPTO_DRIVER_CRACEN=y
    # Choose DRBG algorithm
    # end of Choose DRBG algorithm
    # CryptoCell PSA Driver Configuration
    # end of CryptoCell PSA Driver Configuration
    # CRACEN PSA Driver Configuration
    CONFIG_PSA_USE_CRACEN_CIPHER_DRIVER=y
    CONFIG_PSA_USE_CRACEN_AEAD_DRIVER=y
    CONFIG_PSA_USE_CRACEN_HASH_DRIVER=y
    CONFIG_PSA_USE_CRACEN_MAC_DRIVER=y
    CONFIG_PSA_USE_CRACEN_KEY_AGREEMENT_DRIVER=y
    CONFIG_PSA_USE_CRACEN_ASYMMETRIC_DRIVER=y
    CONFIG_PSA_USE_CRACEN_KEY_MANAGEMENT_DRIVER=y
    CONFIG_PSA_USE_CRACEN_KEY_DERIVATION_DRIVER=y
    CONFIG_PSA_USE_CRACEN_PAKE_DRIVER=y
    CONFIG_PSA_USE_CRACEN_ASYMMETRIC_SIGNATURE_DRIVER=y
    CONFIG_PSA_USE_CRACEN_CTR_DRBG_DRIVER=y
    # end of CRACEN PSA Driver Configuration
    # AES key size configuration
    CONFIG_PSA_WANT_AES_KEY_SIZE_128=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_192=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_256=y
    # end of AES key size configuration
    # RSA key size configuration
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_2048 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set
    CONFIG_PSA_MAX_RSA_KEY_BITS=0
    # end of RSA key size configuration
    CONFIG_CRACEN_HW_PRESENT=y
    CONFIG_CRACEN_HW_VERSION_BASE=y
    # CONFIG_CRACEN_LOG_LEVEL_OFF is not set
    # CONFIG_CRACEN_LOG_LEVEL_ERR is not set
    # CONFIG_CRACEN_LOG_LEVEL_WRN is not set
    # CONFIG_CRACEN_LOG_LEVEL_INF is not set
    # CONFIG_CRACEN_LOG_LEVEL_DBG is not set
    CONFIG_CRACEN_LOG_LEVEL_DEFAULT=y
    CONFIG_CRACEN_LOG_LEVEL=3
    CONFIG_CRACEN_LOAD_MICROCODE=y
    CONFIG_CRACEN_LIB_KMU=y
    CONFIG_CRACEN_IKG_SEED_LOAD=y
    CONFIG_CRACEN_IKG_SEED_KMU_SLOT=183
    CONFIG_PSA_NEED_CRACEN_KMU_DRIVER=y
    # PSA API support
    CONFIG_MBEDTLS_USE_PSA_CRYPTO=y
    # CONFIG_MBEDTLS_PSA_STATIC_KEY_SLOTS is not set
    # end of PSA API support
    CONFIG_MBEDTLS_PLATFORM_MEMORY=y
    CONFIG_MBEDTLS_PLATFORM_C=y
    CONFIG_MBEDTLS_MEMORY_C=y
    CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y
    CONFIG_MBEDTLS_THREADING_C=y
    CONFIG_MBEDTLS_BASE64_C=y
    CONFIG_MBEDTLS_OID_C=y
    CONFIG_MBEDTLS_ASN1_WRITE_C=y
    CONFIG_MBEDTLS_ASN1_PARSE_C=y
    CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y
    CONFIG_MBEDTLS_THREADING_ALT=y
    CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y
    CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1
    CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y
    # CONFIG_NRF_SECURITY_ADVANCED is not set
    # Legacy mbed TLS crypto APIs
    CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6
    CONFIG_MBEDTLS_MPI_MAX_SIZE=256
    # CONFIG_MBEDTLS_CIPHER_C is not set
    # CONFIG_MBEDTLS_PK_C is not set
    # CONFIG_MBEDTLS_PEM_PARSE_C is not set
    # CONFIG_MBEDTLS_PEM_WRITE_C is not set
    # end of Legacy mbed TLS crypto APIs
    # end of nRF Security
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEST is not set
    # Log levels
    # end of Log levels
    # end of Audio Modules
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEMPLATE is not set
    # CONFIG_UART_ASYNC_ADAPTER is not set
    # CONFIG_TRUSTED_STORAGE is not set
    # Logging over RPC
    # CONFIG_LOG_FORWARDER_RPC is not set
    # CONFIG_LOG_BACKEND_RPC is not set
    # end of Logging over RPC
    # CONFIG_SUIT is not set
    # CONFIG_NRF_COMPRESS is not set
    # MCUboot IDs (informative only, do not change)
    CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
    # end of MCUboot IDs (informative only, do not change)
    # end of Subsystems
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # CONFIG_APP_JWT is not set
    # Binary libraries
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_FPROTECT_BLOCK_SIZE=0x1000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_AT_PARSER is not set
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    # CONFIG_SMS is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    # CONFIG_HW_UNIQUE_KEY is not set
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    CONFIG_NCS_BOOT_BANNER=y
    CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
    CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    # CONFIG_FLASH_RPC is not set
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # CONFIG_MOCK_NRF_RPC is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (C:/ncs/v3.0.0/nrf)
    # hostap (C:/ncs/v3.0.0/modules/lib/hostap)
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    CONFIG_ZEPHYR_HOSTAP_MODULE=y
    # end of hostap (C:/ncs/v3.0.0/modules/lib/hostap)
    # mcuboot (C:/ncs/v3.0.0/bootloader/mcuboot)
    # MCUboot
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=16
    # CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (C:/ncs/v3.0.0/bootloader/mcuboot)
    # mbedtls (C:/ncs/v3.0.0/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_PSA_CRYPTO_CLIENT=y
    # CONFIG_PSA_CRYPTO_ENABLE_ALL is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    # CONFIG_PSA_WANT_ALG_CMAC is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    # CONFIG_PSA_WANT_ALG_GCM is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    # CONFIG_PSA_WANT_ALG_HMAC is not set
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    # CONFIG_PSA_WANT_ALG_SHA_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    # CONFIG_PSA_WANT_KEY_TYPE_AES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_DERIVE is not set
    # end of mbedtls (C:/ncs/v3.0.0/modules/crypto/mbedtls)
    # oberon-psa-crypto (C:/ncs/v3.0.0/modules/crypto/oberon-psa-crypto)
    CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    # end of oberon-psa-crypto (C:/ncs/v3.0.0/modules/crypto/oberon-psa-crypto)
    # trusted-firmware-m (C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    # cjson (C:/ncs/v3.0.0/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (C:/ncs/v3.0.0/modules/lib/cjson)
    # azure-sdk-for-c (C:/ncs/v3.0.0/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (C:/ncs/v3.0.0/modules/lib/azure-sdk-for-c)
    # cirrus-logic (C:/ncs/v3.0.0/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (C:/ncs/v3.0.0/modules/hal/cirrus-logic)
    # openthread (C:/ncs/v3.0.0/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (C:/ncs/v3.0.0/modules/lib/openthread)
    # suit-generator (C:/ncs/v3.0.0/modules/lib/suit-generator)
    CONFIG_SUIT_ENVELOPE_TEMPLATE_FILENAME=""
    CONFIG_SUIT_ENVELOPE_TARGET=""
    CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
    # CONFIG_SUIT_RECOVERY is not set
    # CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
    # CONFIG_SUIT_DFU_CACHE_EXTRACT_IMAGE is not set
    # CONFIG_SUIT_ENVELOPE_TARGET_ENCRYPT is not set
    # CONFIG_SUIT_ENVELOPE_TARGET_SIGN is not set
    CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
    # end of suit-generator (C:/ncs/v3.0.0/modules/lib/suit-generator)
    # suit-processor (C:/ncs/v3.0.0/modules/lib/suit-processor)
    # CONFIG_SUIT_PROCESSOR is not set
    CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
    CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
    # end of suit-processor (C:/ncs/v3.0.0/modules/lib/suit-processor)
    # memfault-firmware-sdk (C:/ncs/v3.0.0/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (C:/ncs/v3.0.0/modules/lib/memfault-firmware-sdk)
    # coremark (C:/ncs/v3.0.0/modules/benchmark/coremark)
    # CONFIG_COREMARK is not set
    CONFIG_ZEPHYR_COREMARK_MODULE=y
    # end of coremark (C:/ncs/v3.0.0/modules/benchmark/coremark)
    # canopennode (C:/ncs/v3.0.0/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (C:/ncs/v3.0.0/modules/lib/canopennode)
    # chre (C:/ncs/v3.0.0/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (C:/ncs/v3.0.0/modules/lib/chre)
    # lz4 (C:/ncs/v3.0.0/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (C:/ncs/v3.0.0/modules/lib/lz4)
    # nanopb (C:/ncs/v3.0.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (C:/ncs/v3.0.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (C:/ncs/v3.0.0/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (C:/ncs/v3.0.0/modules/lib/zscilib)
    # cmsis (C:/ncs/v3.0.0/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis (C:/ncs/v3.0.0/modules/hal/cmsis)
    # cmsis-dsp (C:/ncs/v3.0.0/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (C:/ncs/v3.0.0/modules/lib/cmsis-dsp)
    # cmsis-nn (C:/ncs/v3.0.0/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (C:/ncs/v3.0.0/modules/lib/cmsis-nn)
    # fatfs (C:/ncs/v3.0.0/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (C:/ncs/v3.0.0/modules/fs/fatfs)
    # hal_nordic (C:/ncs/v3.0.0/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_RADIO_DRIVER is not set
    # CONFIG_NRF_802154_SER_RADIO is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_GRTC_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    # CONFIG_NRFX_DPPI00 is not set
    # CONFIG_NRFX_DPPI10 is not set
    # CONFIG_NRFX_DPPI20 is not set
    # CONFIG_NRFX_DPPI30 is not set
    # CONFIG_NRFX_EGU10 is not set
    # CONFIG_NRFX_EGU20 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE20=y
    CONFIG_NRFX_GPIOTE30=y
    # CONFIG_NRFX_GPPI is not set
    CONFIG_NRFX_GRTC=y
    # CONFIG_NRFX_I2S20 is not set
    # CONFIG_NRFX_LPCOMP is not set
    # CONFIG_NRFX_NFCT is not set
    # CONFIG_NRFX_PDM20 is not set
    # CONFIG_NRFX_PDM21 is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PPIB00 is not set
    # CONFIG_NRFX_PPIB01 is not set
    # CONFIG_NRFX_PPIB10 is not set
    # CONFIG_NRFX_PPIB11 is not set
    # CONFIG_NRFX_PPIB20 is not set
    # CONFIG_NRFX_PPIB21 is not set
    # CONFIG_NRFX_PPIB22 is not set
    # CONFIG_NRFX_PPIB30 is not set
    # CONFIG_NRFX_PWM20 is not set
    # CONFIG_NRFX_PWM21 is not set
    # CONFIG_NRFX_PWM22 is not set
    # CONFIG_NRFX_QDEC20 is not set
    # CONFIG_NRFX_QDEC21 is not set
    CONFIG_NRFX_RRAMC=y
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPIM00 is not set
    # CONFIG_NRFX_SPIM20 is not set
    # CONFIG_NRFX_SPIM21 is not set
    # CONFIG_NRFX_SPIM22 is not set
    # CONFIG_NRFX_SPIM30 is not set
    # CONFIG_NRFX_SPIS00 is not set
    # CONFIG_NRFX_SPIS20 is not set
    # CONFIG_NRFX_SPIS21 is not set
    # CONFIG_NRFX_SPIS22 is not set
    # CONFIG_NRFX_SPIS30 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TEMP is not set
    # CONFIG_NRFX_TIMER00 is not set
    # CONFIG_NRFX_TIMER10 is not set
    # CONFIG_NRFX_TIMER20 is not set
    # CONFIG_NRFX_TIMER21 is not set
    # CONFIG_NRFX_TIMER22 is not set
    # CONFIG_NRFX_TIMER23 is not set
    # CONFIG_NRFX_TIMER24 is not set
    # CONFIG_NRFX_TWIM20 is not set
    # CONFIG_NRFX_TWIM21 is not set
    # CONFIG_NRFX_TWIM22 is not set
    # CONFIG_NRFX_TWIM30 is not set
    # CONFIG_NRFX_TWIS20 is not set
    # CONFIG_NRFX_TWIS21 is not set
    # CONFIG_NRFX_TWIS22 is not set
    # CONFIG_NRFX_TWIS30 is not set
    # CONFIG_NRFX_UARTE00 is not set
    # CONFIG_NRFX_UARTE20 is not set
    # CONFIG_NRFX_UARTE21 is not set
    # CONFIG_NRFX_UARTE22 is not set
    # CONFIG_NRFX_UARTE30 is not set
    # CONFIG_NRFX_WDT30 is not set
    # CONFIG_NRFX_WDT31 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_config_reserved_resources_ncs.h"
    # end of hal_nordic (C:/ncs/v3.0.0/modules/hal/nordic)
    # hal_st (C:/ncs/v3.0.0/modules/hal/st)
    CONFIG_ZEPHYR_HAL_ST_MODULE=y
    # end of hal_st (C:/ncs/v3.0.0/modules/hal/st)
    # hal_tdk (C:/ncs/v3.0.0/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_TDK_MODULE=y
    # TDK drivers
    # CONFIG_TDK_HAL is not set
    # end of TDK drivers
    # end of hal_tdk (C:/ncs/v3.0.0/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    # liblc3 (C:/ncs/v3.0.0/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (C:/ncs/v3.0.0/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # littlefs (C:/ncs/v3.0.0/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (C:/ncs/v3.0.0/modules/fs/littlefs)
    # loramac-node (C:/ncs/v3.0.0/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (C:/ncs/v3.0.0/modules/lib/loramac-node)
    # lvgl (C:/ncs/v3.0.0/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (C:/ncs/v3.0.0/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    # nrf_wifi (C:/ncs/v3.0.0/modules/lib/nrf_wifi)
    CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
    # CONFIG_NRF70_BUSLIB is not set
    # end of nrf_wifi (C:/ncs/v3.0.0/modules/lib/nrf_wifi)
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # percepio (C:/ncs/v3.0.0/modules/debug/percepio)
    # Percepio Tracealyzer support can be enabled from the tracing subsystem
    # CONFIG_PERCEPIO_DFM is not set
    CONFIG_ZEPHYR_PERCEPIO_MODULE=y
    # end of percepio (C:/ncs/v3.0.0/modules/debug/percepio)
    # picolibc (C:/ncs/v3.0.0/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (C:/ncs/v3.0.0/modules/lib/picolibc)
    # segger (C:/ncs/v3.0.0/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    # CONFIG_SEGGER_RTT_SECTION_NONE is not set
    # CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    # CONFIG_SEGGER_RTT_SECTION_CCM is not set
    CONFIG_SEGGER_RTT_SECTION_CUSTOM=y
    # CONFIG_SEGGER_RTT_SECTION_CUSTOM_DTS_REGION is not set
    CONFIG_SEGGER_RTT_SECTION_CUSTOM_NAME=".rtt_buff_data"
    # CONFIG_SEGGER_RTT_INIT_MODE_ALWAYS is not set
    CONFIG_SEGGER_RTT_INIT_MODE_STRONG_CHECK=y
    # CONFIG_SEGGER_RTT_INIT_MODE_WEAK_CHECK is not set
    # end of segger (C:/ncs/v3.0.0/modules/debug/segger)
    CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    # uoscore-uedhoc (C:/ncs/v3.0.0/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (C:/ncs/v3.0.0/modules/lib/uoscore-uedhoc)
    # zcbor (C:/ncs/v3.0.0/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (C:/ncs/v3.0.0/modules/lib/zcbor)
    # nrfxlib (C:/ncs/v3.0.0/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # end of nrf_modem (Modem library)
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # CONFIG_MPSL is not set
    # Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_NRF_DM is not set
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (C:/ncs/v3.0.0/nrfxlib)
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    # connectedhomeip (C:/ncs/v3.0.0/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (C:/ncs/v3.0.0/modules/lib/matter)
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_HAS_MEC5_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_TINYCRYPT is not set
    # CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD="nrf54l15dk"
    CONFIG_BOARD_REVISION=""
    CONFIG_BOARD_TARGET="nrf54l15dk/nrf54l05/cpuapp"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF54L15DK=y
    CONFIG_BOARD_NRF54L15DK_NRF54L05_CPUAPP=y
    CONFIG_BOARD_QUALIFIERS="nrf54l05/cpuapp"
    # Board Options
    # end of Board Options
    # Hardware Configuration
    CONFIG_SOC="nrf54l05"
    CONFIG_SOC_SERIES="nrf54l"
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NORDIC_NRF=y
    CONFIG_SOC_SERIES_NRF54LX=y
    CONFIG_SOC_NRF54L05=y
    CONFIG_SOC_NRF54L05_CPUAPP=y
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIO2=y
    CONFIG_HAS_HW_NRF_GPIOTE20=y
    CONFIG_HAS_HW_NRF_GPIOTE30=y
    CONFIG_HAS_HW_NRF_GRTC=y
    CONFIG_HAS_HW_NRF_PWM20=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
    CONFIG_HAS_HW_NRF_RADIO_CS=y
    CONFIG_HAS_HW_NRF_RADIO_DFE=y
    CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM00=y
    CONFIG_HAS_HW_NRF_TEMP=y
    CONFIG_HAS_HW_NRF_UARTE20=y
    CONFIG_HAS_NORDIC_RAM_CTRL=y
    # CONFIG_NRF_FORCE_RAM_ON_REBOOT is not set
    # CONFIG_NRF_SYS_EVENT is not set
    # CONFIG_SOC_NRF54H20_GPD is not set
    CONFIG_SOC_NRF54L_CPUAPP_COMMON=y
    # CONFIG_SOC_NRF54LX_DISABLE_FICR_TRIMCNF is not set
    # CONFIG_SOC_NRF54LX_SKIP_GLITCHDETECTOR_DISABLE is not set
    # CONFIG_SOC_NRF_FORCE_CONSTLAT is not set
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_DISABLE=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_DISABLE=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    CONFIG_GPIO_INIT_PRIORITY=40
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF54LX=y
    CONFIG_ARCH="arm"
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_CPU_CORTEX=y
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_ALLOW_FLASH_WRITE is not set
    # ARM Options
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    # CONFIG_PLATFORM_SPECIFIC_INIT is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    # CONFIG_ARM_TRUSTZONE_M is not set
    # CONFIG_MPU_STACK_GUARD is not set
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    CONFIG_CPU_HAS_ARM_SAU=y
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # CONFIG_FRAME_POINTER is not set
    # Interrupt Configuration
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_EXCEPTION_DEBUG=y
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_CPU_HAS_ICACHE=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # DSP Options
    # end of DSP Options
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    CONFIG_ICACHE=y
    # CONFIG_ICACHE_LINE_SIZE_DETECT is not set
    # CONFIG_ARCH_CACHE is not set
    CONFIG_EXTERNAL_CACHE=y
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    # CONFIG_SCHED_DUMB is not set
    CONFIG_SCHED_SIMPLE=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_DUMB is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_SIMPLE=y
    # Misc Kernel related options
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_CURRENT_THREAD_USE_TLS=y
    # end of Misc Kernel related options
    # Kernel Debugging and Metrics
    CONFIG_BOOT_DELAY=0
    # CONFIG_BOOT_CLEAR_SCREEN is not set
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # System Work Queue Options
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of System Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_POLL is not set
    # CONFIG_MEM_SLAB_POINTER_VALIDATE is not set
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    CONFIG_EVENTS=y
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
    # end of Other Kernel Object Options
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    # Security Options
    # end of Security Options
    # Memory Domains
    CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
    CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
    # end of Memory Domains
    # SMP Options
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
    # CONFIG_STATIC_INIT_GNU is not set
    # CONFIG_BOOTARGS is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # CONFIG_DEVICE_MUTABLE is not set
    # CONFIG_DEVICE_DT_METADATA is not set
    # end of Device Options
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Virtual Memory Support
    # end of Virtual Memory Support
    # SoC and Board Hooks
    # CONFIG_SOC_PREP_HOOK is not set
    # CONFIG_SOC_EARLY_INIT_HOOK is not set
    # CONFIG_SOC_LATE_INIT_HOOK is not set
    # CONFIG_SOC_PER_CORE_INIT_HOOK is not set
    # CONFIG_BOARD_EARLY_INIT_HOOK is not set
    # CONFIG_BOARD_LATE_INIT_HOOK is not set
    # end of SoC and Board Hooks
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    # CONFIG_FLASH is not set
    CONFIG_CACHE_HAS_DRIVER=y
    # CONFIG_CACHE_LOG_LEVEL_OFF is not set
    # CONFIG_CACHE_LOG_LEVEL_ERR is not set
    # CONFIG_CACHE_LOG_LEVEL_WRN is not set
    # CONFIG_CACHE_LOG_LEVEL_INF is not set
    # CONFIG_CACHE_LOG_LEVEL_DBG is not set
    CONFIG_CACHE_LOG_LEVEL_DEFAULT=y
    CONFIG_CACHE_LOG_LEVEL=3
    # Device Drivers
    # CONFIG_CACHE_NRF_PATCH_LINEADDR is not set
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_HFINT_CALIBRATION is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    # CONFIG_CLOCK_CONTROL_RTS5912_SCCON is not set
    # CONFIG_COMPARATOR is not set
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    CONFIG_CONSOLE_INIT_PRIORITY=40
    # CONFIG_UART_CONSOLE is not set
    # CONFIG_RAM_CONSOLE is not set
    CONFIG_RTT_CONSOLE=y
    CONFIG_RTT_TX_RETRY_CNT=2
    CONFIG_RTT_TX_RETRY_DELAY_MS=2
    # CONFIG_RTT_TX_RETRY_IN_INTERRUPT is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_EFI_CONSOLE is not set
    CONFIG_WINSTREAM_CONSOLE_STATIC=y
    CONFIG_WINSTREAM_CONSOLE_STATIC_SIZE=32768
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_DP_DRIVER is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    # CONFIG_ENTROPY_GENERATOR is not set
    # CONFIG_ESPI is not set
    # Firmware drivers
    # CONFIG_ARM_SCMI is not set
    # end of Firmware drivers
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_GPIO_RTS5912 is not set
    # CONFIG_HAPTICS is not set
    CONFIG_HWINFO=y
    # CONFIG_HWINFO_LOG_LEVEL_OFF is not set
    # CONFIG_HWINFO_LOG_LEVEL_ERR is not set
    # CONFIG_HWINFO_LOG_LEVEL_WRN is not set
    # CONFIG_HWINFO_LOG_LEVEL_INF is not set
    # CONFIG_HWINFO_LOG_LEVEL_DBG is not set
    CONFIG_HWINFO_LOG_LEVEL_DEFAULT=y
    CONFIG_HWINFO_LOG_LEVEL=3
    CONFIG_HWINFO_HAS_DRIVER=y
    CONFIG_HWINFO_NRF=y
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MBOX is not set
    # CONFIG_MDIO is not set
    # CONFIG_MIPI_DBI is not set
    # Miscellaneous Drivers
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_MSPI is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    CONFIG_PINCTRL=y
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PINCTRL_REALTEK_RTS5912 is not set
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    # CONFIG_UART_20_NRF_PARITY_BIT is not set
    CONFIG_UART_20_NRF_TX_BUFFER_SIZE=32
    # CONFIG_UART_RTS5912 is not set
    # CONFIG_SMBUS is not set
    # CONFIG_STEPPER is not set
    # Timer drivers
    CONFIG_TIMER_HAS_64BIT_CYCLE_COUNTER=y
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_NRF_GRTC_TIMER=y
    # CONFIG_NRF_GRTC_TIMER_APP_DEFINED_INIT is not set
    CONFIG_NRF_GRTC_START_SYSCOUNTER=y
    CONFIG_NRF_GRTC_TIMER_CLOCK_MANAGEMENT=y
    CONFIG_NRF_GRTC_SYSCOUNTER_SLEEP_MINIMUM_LATENCY=1000
    CONFIG_NRF_GRTC_TIMER_AUTO_KEEP_ALIVE=y
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # CONFIG_REALTEK_RTS5912_RTMR is not set
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_USBC_PPC_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_TEE is not set
    # CONFIG_REQUIRES_FULL_LIBC is not set
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    # CONFIG_MINIMAL_LIBC is not set
    CONFIG_PICOLIBC=y
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_ASCTIME_R is not set
    # CONFIG_COMMON_LIBC_CTIME_R is not set
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    # CONFIG_COMMON_LIBC_REMOVE is not set
    # CONFIG_PICOLIBC_USE_MODULE is not set
    CONFIG_PICOLIBC_USE_TOOLCHAIN=y
    # CONFIG_PICOLIBC_IO_FLOAT is not set
    CONFIG_PICOLIBC_IO_LONG_LONG=y
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # end of C++ Language Support
    CONFIG_CRC=y
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_STRESS is not set
    # CONFIG_SYS_HEAP_INFO is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_MULTI_HEAP is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # end of Heap and Memory Allocation
    # Memory Blocks
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Memory Blocks
    # CONFIG_NET_BUF is not set
    # OS Support Library
    # CONFIG_FDTABLE is not set
    CONFIG_ZVFS_OPEN_MAX=4
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_HAS_POWEROFF=y
    CONFIG_POWEROFF=y
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    # CONFIG_ZVFS is not set
    # end of OS Support Library
    # POSIX API Support
    # POSIX Options
    # CONFIG_POSIX_API is not set
    CONFIG_POSIX_AEP_CHOICE_NONE=y
    # CONFIG_POSIX_AEP_CHOICE_BASE is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
    # CONFIG_POSIX_ASYNCHRONOUS_IO is not set
    # CONFIG_POSIX_BARRIERS is not set
    # CONFIG_POSIX_C_LANG_SUPPORT_R is not set
    # CONFIG_POSIX_C_LIB_EXT is not set
    # POSIX device I/O
    # CONFIG_POSIX_DEVICE_IO is not set
    CONFIG_POSIX_OPEN_MAX=4
    # end of POSIX device I/O
    # CONFIG_POSIX_FD_MGMT is not set
    # CONFIG_POSIX_FILE_SYSTEM_R is not set
    # CONFIG_POSIX_FILE_SYSTEM is not set
    # POSIX memory
    CONFIG_POSIX_PAGE_SIZE=0x40
    # CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
    # CONFIG_POSIX_MAPPED_FILES is not set
    # CONFIG_POSIX_MEMORY_PROTECTION is not set
    # end of POSIX memory
    # CONFIG_POSIX_MESSAGE_PASSING is not set
    # CONFIG_POSIX_SINGLE_PROCESS is not set
    # CONFIG_POSIX_MULTI_PROCESS is not set
    # CONFIG_POSIX_THREADS is not set
    # CONFIG_POSIX_READER_WRITER_LOCKS is not set
    # POSIX scheduler options
    # CONFIG_POSIX_PRIORITY_SCHEDULING is not set
    # end of POSIX scheduler options
    # CONFIG_POSIX_SEMAPHORES is not set
    # POSIX signals
    # CONFIG_POSIX_REALTIME_SIGNALS is not set
    # CONFIG_POSIX_SIGNALS is not set
    # end of POSIX signals
    # CONFIG_POSIX_SPIN_LOCKS is not set
    # POSIX synchronized I/O
    # CONFIG_POSIX_FSYNC is not set
    # CONFIG_POSIX_SYNCHRONIZED_IO is not set
    # end of POSIX synchronized I/O
    # CONFIG_POSIX_TIMERS is not set
    # X/Open system interfaces
    # CONFIG_XOPEN_STREAMS is not set
    # CONFIG_XSI_SYSTEM_LOGGING is not set
    # CONFIG_XSI_THREADS_EXT is not set
    # end of X/Open system interfaces
    # Miscellaneous POSIX-related options
    # CONFIG_EVENTFD is not set
    # end of Miscellaneous POSIX-related options
    # Deprecated POSIX options
    CONFIG_EVENTFD_MAX=0
    # CONFIG_FNMATCH is not set
    CONFIG_MAX_PTHREAD_COUNT=0
    CONFIG_MAX_PTHREAD_KEY_COUNT=0
    CONFIG_MAX_TIMER_COUNT=0
    CONFIG_MSG_COUNT_MAX=0
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_POSIX_FS is not set
    CONFIG_POSIX_LIMITS_RTSIG_MAX=0
    CONFIG_POSIX_MAX_FDS=4
    CONFIG_POSIX_MAX_OPEN_FILES=4
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_POSIX_PUTMSG is not set
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_POSIX_SYSCONF is not set
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_PTHREAD is not set
    # CONFIG_PTHREAD_BARRIER is not set
    # CONFIG_PTHREAD_COND is not set
    # CONFIG_PTHREAD_IPC is not set
    # CONFIG_PTHREAD_KEY is not set
    # CONFIG_PTHREAD_MUTEX is not set
    # CONFIG_PTHREAD_RWLOCK is not set
    # CONFIG_PTHREAD_SPINLOCK is not set
    # CONFIG_TIMER is not set
    CONFIG_TIMER_DELAYTIMER_MAX=0
    CONFIG_SEM_NAMELEN_MAX=0
    CONFIG_SEM_VALUE_MAX=0
    # end of Deprecated POSIX options
    CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
    # end of POSIX Options
    # POSIX Shell Utilities
    # end of POSIX Shell Utilities
    # end of POSIX API Support
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_LIBGCC_RTLIB=y
    # Utility Library
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    CONFIG_ONOFF=y
    # CONFIG_UTF8 is not set
    # end of Utility Library
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    # CONFIG_BT is not set
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_DAP is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # CONFIG_SYMTAB is not set
    # end of Debugging Options
    # CONFIG_MIPI_STP_DECODER is not set
    # CONFIG_CS_TRACE_DEFMT is not set
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM_LIB_LINK is not set
    # CONFIG_FILE_SYSTEM is not set
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # Linkable loadable Extension Development Kit (EDK)
    CONFIG_LLEXT_EDK_NAME="llext-edk"
    # CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
    # end of Linkable loadable Extension Development Kit (EDK)
    # Logging
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    # CONFIG_LOG_DBG_COLOR_BLUE is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP=y
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    CONFIG_LOG_OUTPUT_FORMAT_TIME_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    CONFIG_LOG_BACKEND_RTT=y
    # CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
    CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
    # CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
    CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
    CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
    CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
    CONFIG_LOG_BACKEND_RTT_BUFFER=0
    CONFIG_LOG_BACKEND_RTT_FORCE_PRINTK=y
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_FMT_STRING_VALIDATE is not set
    # CONFIG_LOG_MEM_UTILIZATION is not set
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    CONFIG_MEM_ATTR=y
    # CONFIG_MEM_ATTR_HEAP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_OFF is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_ERR is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_WRN is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_INF is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_DBG is not set
    CONFIG_PM_DEVICE_LOG_LEVEL_DEFAULT=y
    CONFIG_PM_DEVICE_LOG_LEVEL=3
    # end of Power Management
    # Portability
    # end of Portability
    # CONFIG_PROFILING is not set
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    CONFIG_CSPRNG_AVAILABLE=y
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SECURE_STORAGE is not set
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # CONFIG_MODULES is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_FLASH_LOAD_SIZE=0
    CONFIG_ROM_END_OFFSET=0
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_ITERABLE_SUBALIGN=4
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_STD_C90 is not set
    CONFIG_STD_C99=y
    # CONFIG_STD_C11 is not set
    # CONFIG_STD_C17 is not set
    # CONFIG_STD_C23 is not set
    CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
    # CONFIG_GNU_C_EXTENSIONS is not set
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    CONFIG_BUILD_GAP_FILL_PATTERN=0xFF
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
    # end of Compatibility
    with 'nrf54l15dk/nrf54l15/cpuapp/ns'
    # CONFIG_APP_USE_RETAINED_MEM is not set
    # CONFIG_GPIO_WAKEUP_ENABLE is not set
    CONFIG_GRTC_WAKEUP_ENABLE=y
    # CONFIG_LPCOMP_WAKEUP_ENABLE is not set
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    CONFIG_ROM_START_OFFSET=0
    CONFIG_BUILD_WITH_TFM=y
    CONFIG_TFM_FLASH_MERGED_BINARY=y
    CONFIG_NUM_IRQS=271
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=1000000
    CONFIG_FLASH_SIZE=1428
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_SOC_RESET_HOOK=y
    CONFIG_MAIN_STACK_SIZE=1024
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_CLOCK_CONTROL=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=31250
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_XIP=y
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    # CONFIG_SRAM_VECTOR_TABLE is not set
    CONFIG_CPU_HAS_ARM_MPU=y
    # CONFIG_COUNTER is not set
    # CONFIG_SHARED_INTERRUPTS is not set
    CONFIG_PM_DEVICE=y
    CONFIG_TICKLESS_KERNEL=y
    # CONFIG_FPU is not set
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    # CONFIG_USE_DT_CODE_PARTITION is not set
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    # CONFIG_CACHE_MANAGEMENT is not set
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_INIT_STACKS is not set
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_FLASH_LOAD_OFFSET=0
    # CONFIG_REGULATOR is not set
    CONFIG_PM_DEVICE_SYSTEM_MANAGED=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    # CONFIG_BUILD_OUTPUT_S19 is not set
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_MFD is not set
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    # CONFIG_SPI is not set
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    # CONFIG_MEMC is not set
    # CONFIG_CACHE is not set
    CONFIG_LOG=y
    CONFIG_CMSIS_CORE_HAS_SYSTEM_CORE_CLOCK=y
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_ROMSTART_RELOCATION_ROM is not set
    CONFIG_DCACHE_LINE_SIZE=32
    # CONFIG_RESET is not set
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    # CONFIG_NRF_RTC_TIMER is not set
    CONFIG_LOG_DOMAIN_NAME=""
    # CONFIG_ASSERT is not set
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_PM_DEVICE_POWER_DOMAIN=y
    # CONFIG_PM_DEVICE_RUNTIME is not set
    # CONFIG_UART_USE_RUNTIME_CONFIGURE is not set
    # CONFIG_SYSCON is not set
    CONFIG_SERIAL_INIT_PRIORITY=50
    # CONFIG_INTC_MTK_ADSP is not set
    # CONFIG_MTK_ADSP_TIMER is not set
    CONFIG_CONSOLE=y
    # CONFIG_WINSTREAM is not set
    CONFIG_COMMON_LIBC_MALLOC_ARENA_SIZE=-1
    CONFIG_SOC_TOOLCHAIN_NAME="amd_acp_6_0_adsp"
    CONFIG_GEN_SW_ISR_TABLE=y
    # CONFIG_REBOOT is not set
    CONFIG_GEN_IRQ_START_VECTOR=0
    CONFIG_SRAM_OFFSET=0
    # CONFIG_POWER_DOMAIN is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    # CONFIG_SCHED_CPU_MASK is not set
    # CONFIG_WATCHDOG is not set
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_CLOCK_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_JEDEC_SPI_NOR_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_BT_HCI_SDC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GRTC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_HFXO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IEEE802154_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_LFXO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PPIB_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RADIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TEMP_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF54L_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF5X_REGULATOR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_RRAM_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_PSA_CRYPTO_RNG_ENABLED=y
    # end of Devicetree Info
    # Modules
    # CONFIG_BUILD_ONLY_NO_BLOBS is not set
    # Available modules.
    # nrf (C:/ncs/v3.0.0/nrf)
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_LOG_BUFFER_SIZE=1024
    CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT=32
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    # CONFIG_ZMS is not set
    CONFIG_MBEDTLS=y
    # CONFIG_MBEDTLS_TLS_VERSION_1_2 is not set
    CONFIG_MBEDTLS_MAC_SHA256_ENABLED=y
    # CONFIG_MBEDTLS_CTR_DRBG_ENABLED is not set
    # CONFIG_MBEDTLS_MD_C is not set
    # CONFIG_MBEDTLS_TLS_LIBRARY is not set
    # CONFIG_MBEDTLS_X509_LIBRARY is not set
    # CONFIG_MBEDTLS_ENABLE_HEAP is not set
    CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C=y
    # CONFIG_MBEDTLS_LEGACY_CRYPTO_C is not set
    CONFIG_TFM_CRYPTO_RNG_MODULE_ENABLED=y
    CONFIG_TFM_PARTITION_CRYPTO=y
    CONFIG_TFM_PARTITION_PLATFORM=y
    # Nordic nRF Connect
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    # CONFIG_GETOPT is not set
    CONFIG_NRF_SECURITY_ENABLER=y
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # Subsystems
    # Bootloader
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x460
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7800
    # CONFIG_IS_SECURE_BOOTLOADER is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATION_STRUCT_HAS_HASH=y
    CONFIG_SB_VALIDATION_STRUCT_HAS_PUBLIC_KEY=y
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # CONFIG_SECURE_BOOT_STORAGE is not set
    # CONFIG_MCUBOOT_COMPRESSED_IMAGE_SUPPORT_ENABLED is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_ED25519 is not set
    # CONFIG_MCUBOOT_BOOTLOADER_SIGNATURE_TYPE_PURE is not set
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # BLE over nRF RPC
    CONFIG_HEAP_MEM_POOL_SIZE=0
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # CONFIG_NRF_CLOUD is not set
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_DOWNLOADER is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # CONFIG_OPENTHREAD_RPC is not set
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # CONFIG_NFC_RPC is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # Multiprotocol service layer (MPSL)
    # CONFIG_MPSL_FEM_ONLY is not set
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    CONFIG_MPSL_LOW_PRIO_IRQN=28
    CONFIG_MPSL_HFCLK_LATENCY=854
    CONFIG_MPSL_INIT_PRIORITY=40
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # CONFIG_MPSL_PIN_DEBUG is not set
    # end of Multiprotocol service layer (MPSL)
    # Partition Manager
    CONFIG_PARTITION_MANAGER_ENABLED=y
    CONFIG_FLASH_MAP_CUSTOM=y
    CONFIG_SRAM_SIZE=188
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    CONFIG_NRF_TRUSTZONE_FLASH_REGION_SIZE=0x1000
    CONFIG_NRF_TRUSTZONE_RAM_REGION_SIZE=0x1000
    # Zephyr subsystem configurations
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_PATH=""
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x2f000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # Full Modem Firmware Update Management(FMFU)
    # end of Full Modem Firmware Update Management(FMFU)
    # Additional MCUmgr configuration
    # Additional MCUmgr group configuration
    # Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr OS group management functionality
    # end of Additional MCUmgr group configuration
    # end of Additional MCUmgr configuration
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    CONFIG_NRF_SECURITY=y
    # Nordic-added meta types
    CONFIG_PSA_HAS_AEAD_SUPPORT=y
    CONFIG_PSA_HAS_CIPHER_SUPPORT=y
    CONFIG_PSA_HAS_HASH_SUPPORT=y
    CONFIG_PSA_HAS_KEY_DERIVATION=y
    CONFIG_PSA_HAS_KEY_SUPPORT=y
    CONFIG_PSA_HAS_MAC_SUPPORT=y
    # Nordic added alg types
    # CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
    # CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_HMAC is not set
    CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_CMAC=y
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    CONFIG_PSA_WANT_ALG_ECB_NO_PADDING=y
    # CONFIG_PSA_WANT_ALG_CHACHA20 is not set
    # CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
    # CONFIG_PSA_WANT_ALG_AES_KW is not set
    # CONFIG_PSA_WANT_ALG_AES_KWP is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE_PT is not set
    # CONFIG_PSA_WANT_ALG_WPA3_SAE is not set
    # Nordic added ECC curve types
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
    # CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
    # CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
    # CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
    # Nordic addded RNG configuration
    CONFIG_PSA_WANT_GENERATE_RANDOM=y
    # Nordic added key types
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_WPA3_SAE_PT is not set
    CONFIG_MBEDTLS_PSA_CRYPTO_BUILTIN_KEYS=y
    CONFIG_MBEDTLS_CFG_FILE="nrf-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-user-config.h"
    CONFIG_MBEDTLS_PSA_CRYPTO_C=y
    CONFIG_PSA_CORE_OBERON=y
    # CONFIG_PSA_CORE_LITE is not set
    # PSA Driver Support
    CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y
    CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y
    CONFIG_PSA_CRYPTO_DRIVER_CRACEN=y
    # Choose DRBG algorithm
    CONFIG_PSA_WANT_ALG_CTR_DRBG=y
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    CONFIG_PSA_USE_CTR_DRBG_DRIVER=y
    # end of Choose DRBG algorithm
    # CryptoCell PSA Driver Configuration
    # end of CryptoCell PSA Driver Configuration
    # CRACEN PSA Driver Configuration
    CONFIG_PSA_USE_CRACEN_CIPHER_DRIVER=y
    CONFIG_PSA_USE_CRACEN_AEAD_DRIVER=y
    CONFIG_PSA_USE_CRACEN_HASH_DRIVER=y
    CONFIG_PSA_USE_CRACEN_MAC_DRIVER=y
    CONFIG_PSA_USE_CRACEN_KEY_AGREEMENT_DRIVER=y
    CONFIG_PSA_USE_CRACEN_ASYMMETRIC_DRIVER=y
    CONFIG_PSA_USE_CRACEN_KEY_MANAGEMENT_DRIVER=y
    CONFIG_PSA_USE_CRACEN_KEY_DERIVATION_DRIVER=y
    CONFIG_PSA_USE_CRACEN_PAKE_DRIVER=y
    CONFIG_PSA_USE_CRACEN_ASYMMETRIC_SIGNATURE_DRIVER=y
    CONFIG_PSA_USE_CRACEN_CTR_DRBG_DRIVER=y
    # end of CRACEN PSA Driver Configuration
    # AES key size configuration
    CONFIG_PSA_WANT_AES_KEY_SIZE_128=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_192=y
    CONFIG_PSA_WANT_AES_KEY_SIZE_256=y
    # end of AES key size configuration
    # RSA key size configuration
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_2048 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set
    # CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set
    CONFIG_PSA_MAX_RSA_KEY_BITS=0
    # end of RSA key size configuration
    CONFIG_PSA_ACCEL_CHACHA20_POLY1305=y
    CONFIG_PSA_ACCEL_CMAC_AES_128=y
    CONFIG_PSA_ACCEL_CMAC_AES_192=y
    CONFIG_PSA_ACCEL_CMAC_AES_256=y
    CONFIG_PSA_ACCEL_ECB_NO_PADDING_AES_128=y
    CONFIG_PSA_ACCEL_ECB_NO_PADDING_AES_192=y
    CONFIG_PSA_ACCEL_ECB_NO_PADDING_AES_256=y
    CONFIG_PSA_ACCEL_GCM_AES_128=y
    CONFIG_PSA_ACCEL_GCM_AES_192=y
    CONFIG_PSA_ACCEL_GCM_AES_256=y
    CONFIG_PSA_ACCEL_GENERATE_RANDOM=y
    CONFIG_PSA_ACCEL_HKDF_SHA_224=y
    CONFIG_PSA_ACCEL_HKDF_SHA_256=y
    CONFIG_PSA_ACCEL_HMAC_SHA_224=y
    CONFIG_PSA_ACCEL_HMAC_SHA_256=y
    CONFIG_PSA_ACCEL_SHA_224=y
    CONFIG_PSA_ACCEL_SHA_256=y
    CONFIG_CRACEN_HW_PRESENT=y
    CONFIG_CRACEN_HW_VERSION_BASE=y
    # CONFIG_CRACEN_LOG_LEVEL_OFF is not set
    # CONFIG_CRACEN_LOG_LEVEL_ERR is not set
    # CONFIG_CRACEN_LOG_LEVEL_WRN is not set
    # CONFIG_CRACEN_LOG_LEVEL_INF is not set
    # CONFIG_CRACEN_LOG_LEVEL_DBG is not set
    CONFIG_CRACEN_LOG_LEVEL_DEFAULT=y
    CONFIG_CRACEN_LOG_LEVEL=3
    CONFIG_CRACEN_LOAD_MICROCODE=y
    CONFIG_CRACEN_LIB_KMU=y
    CONFIG_CRACEN_IKG_SEED_LOAD=y
    CONFIG_CRACEN_IKG_SEED_KMU_SLOT=183
    CONFIG_PSA_NEED_CRACEN_GCM_AES=y
    CONFIG_PSA_NEED_CRACEN_CHACHA20_POLY1305=y
    CONFIG_PSA_NEED_CRACEN_AEAD_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_ECB_NO_PADDING_AES=y
    CONFIG_PSA_NEED_CRACEN_CIPHER_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_SHA_224=y
    CONFIG_PSA_NEED_CRACEN_SHA_256=y
    CONFIG_PSA_NEED_CRACEN_HASH_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_KEY_MANAGEMENT_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_HMAC=y
    CONFIG_PSA_NEED_CRACEN_CMAC=y
    CONFIG_PSA_NEED_CRACEN_MAC_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_CTR_DRBG_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_HKDF=y
    CONFIG_PSA_NEED_CRACEN_SP800_108_COUNTER_CMAC=y
    CONFIG_PSA_NEED_CRACEN_KEY_DERIVATION_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_KMU_DRIVER=y
    CONFIG_PSA_NEED_CRACEN_KMU_ENCRYPTED_KEYS=y
    # PSA API support
    CONFIG_MBEDTLS_USE_PSA_CRYPTO=y
    # CONFIG_MBEDTLS_PSA_STATIC_KEY_SLOTS is not set
    CONFIG_PSA_ITS_ENCRYPTED=y
    # end of PSA API support
    CONFIG_MBEDTLS_PLATFORM_MEMORY=y
    CONFIG_MBEDTLS_PLATFORM_C=y
    CONFIG_MBEDTLS_MEMORY_C=y
    CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y
    CONFIG_MBEDTLS_THREADING_C=y
    CONFIG_MBEDTLS_BASE64_C=y
    CONFIG_MBEDTLS_OID_C=y
    CONFIG_MBEDTLS_ASN1_WRITE_C=y
    CONFIG_MBEDTLS_ASN1_PARSE_C=y
    CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y
    CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y
    CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1
    CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y
    # CONFIG_NRF_SECURITY_ADVANCED is not set
    # Legacy mbed TLS crypto APIs
    CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6
    CONFIG_MBEDTLS_MPI_MAX_SIZE=256
    # CONFIG_MBEDTLS_CIPHER_C is not set
    # CONFIG_MBEDTLS_PK_C is not set
    # CONFIG_MBEDTLS_PEM_PARSE_C is not set
    # CONFIG_MBEDTLS_PEM_WRITE_C is not set
    # end of Legacy mbed TLS crypto APIs
    # Zephyr legacy configurations
    # CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED is not set
    # CONFIG_MBEDTLS_ECP_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set
    # CONFIG_MBEDTLS_MAC_MD5_ENABLED is not set
    # CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set
    # CONFIG_MBEDTLS_CIPHER is not set
    # CONFIG_MBEDTLS_MD is not set
    # CONFIG_MBEDTLS_ENTROPY_ENABLED is not set
    # CONFIG_MBEDTLS_GENPRIME_ENABLED is not set
    # end of Zephyr legacy configurations
    CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
    # end of nRF Security
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEST is not set
    # Log levels
    # end of Log levels
    # end of Audio Modules
    # Audio Modules
    # CONFIG_AUDIO_MODULE_TEMPLATE is not set
    # CONFIG_UART_ASYNC_ADAPTER is not set
    # Logging over RPC
    # CONFIG_LOG_FORWARDER_RPC is not set
    # CONFIG_LOG_BACKEND_RPC is not set
    # end of Logging over RPC
    # CONFIG_SUIT is not set
    # CONFIG_NRF_COMPRESS is not set
    # MCUboot IDs (informative only, do not change)
    CONFIG_MCUBOOT_APPLICATION_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_NETWORK_CORE_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_WIFI_PATCHES_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_QSPI_XIP_IMAGE_NUMBER=-1
    CONFIG_MCUBOOT_MCUBOOT_IMAGE_NUMBER=-1
    # end of MCUboot IDs (informative only, do not change)
    # end of Subsystems
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=5200
    CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
    CONFIG_WFA_QT_DEFAULT_INTERFACE="wlan0"
    CONFIG_WPAS_READY_TIMEOUT_MS=10000
    # Libraries
    # CONFIG_APP_JWT is not set
    # Binary libraries
    # end of Binary libraries
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_FPROTECT_BLOCK_SIZE=0x1000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_AT_PARSER is not set
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    # CONFIG_SMS is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
    CONFIG_HW_UNIQUE_KEY=y
    CONFIG_HW_UNIQUE_KEY_RANDOM=y
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY is not set
    # CONFIG_PCM_MIX is not set
    # CONFIG_TONE is not set
    # CONFIG_PSCM is not set
    # CONFIG_DATA_FIFO is not set
    # CONFIG_FEM_AL_LIB is not set
    # CONFIG_SAMPLE_RATE_CONVERTER is not set
    CONFIG_NCS_BOOT_BANNER=y
    CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
    CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    # CONFIG_FLASH_RPC is not set
    CONFIG_SOC_FLASH_NRF_RADIO_SYNC_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_ETH_RTT is not set
    # CONFIG_SENSOR is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # CONFIG_MOCK_NRF_RPC is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (C:/ncs/v3.0.0/nrf)
    # hostap (C:/ncs/v3.0.0/modules/lib/hostap)
    # CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
    CONFIG_ZEPHYR_HOSTAP_MODULE=y
    # end of hostap (C:/ncs/v3.0.0/modules/lib/hostap)
    # mcuboot (C:/ncs/v3.0.0/bootloader/mcuboot)
    # MCUboot
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=16
    # CONFIG_USE_NRF53_MULTI_IMAGE_WITHOUT_UPGRADE_ONLY is not set
    # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (C:/ncs/v3.0.0/bootloader/mcuboot)
    # mbedtls (C:/ncs/v3.0.0/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_PSA_CRYPTO_CLIENT=y
    # CONFIG_PSA_CRYPTO_ENABLE_ALL is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    CONFIG_PSA_WANT_ALG_CMAC=y
    CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305=y
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    CONFIG_PSA_WANT_ALG_GCM=y
    CONFIG_PSA_WANT_ALG_HKDF=y
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    CONFIG_PSA_WANT_ALG_HMAC=y
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_PBKDF2_HMAC is not set
    # CONFIG_PSA_WANT_ALG_PBKDF2_AES_CMAC_PRF_128 is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    CONFIG_PSA_WANT_ALG_SHA_224=y
    CONFIG_PSA_WANT_ALG_SHA_256=y
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA3_512 is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # CONFIG_PSA_WANT_ALG_TLS12_PRF is not set
    # CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS is not set
    # CONFIG_PSA_WANT_ALG_TLS12_ECJPAKE_TO_PMS is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
    # CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
    # CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    CONFIG_PSA_WANT_KEY_TYPE_AES=y
    # CONFIG_PSA_WANT_KEY_TYPE_CHACHA20 is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_DERIVE is not set
    # CONFIG_MBEDTLS_LIBRARY is not set
    CONFIG_DISABLE_MBEDTLS_BUILTIN=y
    # CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_OFF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_ERR is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_WRN is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_INF is not set
    # CONFIG_MBEDTLS_LOG_LEVEL_DBG is not set
    CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT=y
    CONFIG_MBEDTLS_LOG_LEVEL=3
    # CONFIG_MBEDTLS_DEBUG is not set
    CONFIG_MBEDTLS_INIT=y
    # CONFIG_MBEDTLS_ZEROIZE_ALT is not set
    CONFIG_APP_LINK_WITH_MBEDTLS=y
    # end of mbedtls (C:/ncs/v3.0.0/modules/crypto/mbedtls)
    # oberon-psa-crypto (C:/ncs/v3.0.0/modules/crypto/oberon-psa-crypto)
    CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    # end of oberon-psa-crypto (C:/ncs/v3.0.0/modules/crypto/oberon-psa-crypto)
    # trusted-firmware-m (C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_TFM_BOARD="C:/ncs/v3.0.0/nrf/modules/trusted-firmware-m/tfm_boards/nrf54l15_cpuapp"
    # CONFIG_TFM_DUMMY_PROVISIONING is not set
    # CONFIG_TFM_REGRESSION_NS is not set
    # CONFIG_TFM_LOG_LEVEL_SILENCE is not set
    CONFIG_TFM_QCBOR_PATH="C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m/../qcbor"
    CONFIG_TFM_PARTITION_PROTECTED_STORAGE=y
    CONFIG_TFM_ITS_ENCRYPTED=y
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
    # CONFIG_TFM_PROFILE_TYPE_SMALL is not set
    # CONFIG_TFM_PROFILE_TYPE_MEDIUM is not set
    # CONFIG_TFM_PROFILE_TYPE_AROTLESS is not set
    # CONFIG_TFM_PROFILE_TYPE_LARGE is not set
    # CONFIG_TFM_CMAKE_BUILD_TYPE_RELEASE is not set
    # CONFIG_TFM_CMAKE_BUILD_TYPE_RELWITHDEBINFO is not set
    CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL=y
    # CONFIG_TFM_CMAKE_BUILD_TYPE_DEBUG is not set
    CONFIG_TFM_ISOLATION_LEVEL=1
    # CONFIG_TFM_ITS_NUM_ASSETS_OVERRIDE is not set
    CONFIG_TFM_ITS_NUM_ASSETS=10
    # CONFIG_TFM_ITS_MAX_ASSET_SIZE_OVERRIDE is not set
    CONFIG_TFM_ITS_MAX_ASSET_SIZE=512
    CONFIG_TFM_PARTITION_PLATFORM_CUSTOM_REBOOT=y
    CONFIG_TFM_BL2_NOT_SUPPORTED=y
    CONFIG_TFM_IMAGE_VERSION_S="0.0.0+0"
    CONFIG_TFM_IMAGE_VERSION_NS="0.0.0+0"
    # CONFIG_TFM_USE_NS_APP is not set
    # CONFIG_TFM_CONNECTION_BASED_SERVICE_API is not set
    CONFIG_TFM_IPC=y
    # CONFIG_TFM_SFN is not set
    # CONFIG_TFM_REGRESSION_S is not set
    # CONFIG_TFM_PSA_TEST_PROTECTED_STORAGE is not set
    # CONFIG_TFM_PSA_TEST_INTERNAL_TRUSTED_STORAGE is not set
    # CONFIG_TFM_PSA_TEST_STORAGE is not set
    CONFIG_TFM_PSA_TEST_NONE=y
    # CONFIG_TFM_SPM_LOG_LEVEL_DEBUG is not set
    CONFIG_TFM_SPM_LOG_LEVEL_INFO=y
    # CONFIG_TFM_SPM_LOG_LEVEL_ERROR is not set
    # CONFIG_TFM_SPM_LOG_LEVEL_SILENCE is not set
    CONFIG_TFM_EXCEPTION_INFO_DUMP=y
    CONFIG_TFM_PARTITION_INTERNAL_TRUSTED_STORAGE=y
    # CONFIG_TFM_PARTITION_FIRMWARE_UPDATE is not set
    # CONFIG_TFM_PARTITION_LOG_LEVEL_DEBUG is not set
    CONFIG_TFM_PARTITION_LOG_LEVEL_INFO=y
    # CONFIG_TFM_PARTITION_LOG_LEVEL_ERROR is not set
    # CONFIG_TFM_PARTITION_LOG_LEVEL_SILENCE is not set
    CONFIG_TFM_CRYPTO_KEY_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_AEAD_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_MAC_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_HASH_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_CIPHER_MODULE_ENABLED=y
    CONFIG_TFM_CRYPTO_KEY_DERIVATION_MODULE_ENABLED=y
    # Platform partition component configs
    CONFIG_TFM_PLATFORM_SERVICE_INPUT_BUFFER_SIZE=64
    CONFIG_TFM_PLATFORM_SERVICE_OUTPUT_BUFFER_SIZE=64
    CONFIG_TFM_PLATFORM_SP_STACK_SIZE=0x500
    # CONFIG_TFM_PLATFORM_NV_COUNTER_MODULE_DISABLED is not set
    # end of Platform partition component configs
    # Crypto component configs
    # CONFIG_TFM_CRYPTO_SINGLE_PART_FUNCS_DISABLED is not set
    CONFIG_TFM_CRYPTO_ENGINE_BUF_SIZE=8320
    CONFIG_TFM_CRYPTO_CONC_OPER_NUM=8
    CONFIG_TFM_CRYPTO_IOVEC_BUFFER_SIZE=5120
    CONFIG_TFM_CRYPTO_PARTITION_STACK_SIZE=0x2000
    # end of Crypto component configs
    # ITS component configs
    CONFIG_TFM_ITS_CREATE_FLASH_LAYOUT=y
    # CONFIG_TFM_ITS_RAM_FS is not set
    CONFIG_TFM_ITS_VALIDATE_METADATA_FROM_FLASH=y
    CONFIG_TFM_ITS_BUF_SIZE=2048
    CONFIG_TFM_ITS_STACK_SIZE=0x1000
    # end of ITS component configs
    # PS component configs
    CONFIG_TFM_PS_CREATE_FLASH_LAYOUT=y
    # CONFIG_TFM_PS_RAM_FS is not set
    CONFIG_TFM_PS_ROLLBACK_PROTECTION=y
    CONFIG_TFM_PS_VALIDATE_METADATA_FROM_FLASH=y
    CONFIG_TFM_PS_MAX_ASSET_SIZE=2048
    CONFIG_TFM_PS_NUM_ASSETS=10
    CONFIG_TFM_PS_STACK_SIZE=0x700
    # end of PS component configs
    # TF-M SPM component configs
    CONFIG_TFM_CONN_HANDLE_MAX_NUM=8
    # CONFIG_TFM_DOORBELL_API is not set
    # end of TF-M SPM component configs
    # TF-M memory regions
    CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0x13000
    CONFIG_PM_PARTITION_SIZE_TFM=0x40000
    CONFIG_PM_PARTITION_SIZE_TFM_PROTECTED_STORAGE=0x4000
    CONFIG_PM_PARTITION_SIZE_TFM_INTERNAL_TRUSTED_STORAGE=0x2000
    CONFIG_PM_PARTITION_SIZE_TFM_OTP_NV_COUNTERS=0x2000
    CONFIG_PM_PARTITION_TFM_STORAGE=y
    # end of TF-M memory regions
    # Peripheral Secure mapping
    # CONFIG_NRF_UARTE00_SECURE is not set
    # CONFIG_NRF_UARTE20_SECURE is not set
    # CONFIG_NRF_UARTE21_SECURE is not set
    # CONFIG_NRF_UARTE22_SECURE is not set
    CONFIG_NRF_UARTE30_SECURE=y
    # CONFIG_NRF_FPU_SECURE is not set
    # CONFIG_NRF_CLOCK_SECURE is not set
    # CONFIG_NRF_POWER_SECURE is not set
    # CONFIG_NRF_SPIM00_SECURE is not set
    # CONFIG_NRF_SPIM20_SECURE is not set
    # CONFIG_NRF_SPIM21_SECURE is not set
    # CONFIG_NRF_SPIM22_SECURE is not set
    # CONFIG_NRF_SPIM30_SECURE is not set
    # CONFIG_NRF_SAADC_SECURE is not set
    # CONFIG_NRF_TIMER00_SECURE is not set
    # CONFIG_NRF_TIMER10_SECURE is not set
    # CONFIG_NRF_TIMER20_SECURE is not set
    # CONFIG_NRF_TIMER21_SECURE is not set
    # CONFIG_NRF_TIMER22_SECURE is not set
    # CONFIG_NRF_TIMER23_SECURE is not set
    # CONFIG_NRF_TIMER24_SECURE is not set
    # CONFIG_NRF_DPPI_SECURE is not set
    # CONFIG_NRF_COMP_SECURE is not set
    # CONFIG_NRF_EGU10_SECURE is not set
    # CONFIG_NRF_EGU20_SECURE is not set
    # CONFIG_NRF_PWM20_SECURE is not set
    # CONFIG_NRF_PWM21_SECURE is not set
    # CONFIG_NRF_PWM22_SECURE is not set
    # CONFIG_NRF_PDM_SECURE is not set
    # CONFIG_NRF_I2S_SECURE is not set
    # CONFIG_NRF_NFCT_SECURE is not set
    # CONFIG_NRF_NVMC_SECURE is not set
    # CONFIG_NRF_GPIO0_SECURE is not set
    # CONFIG_NRF_GPIO1_SECURE is not set
    # CONFIG_NRF_GPIO2_SECURE is not set
    # CONFIG_NRF_GPIOTE0_SECURE is not set
    CONFIG_NRF_GPIO0_PIN_MASK_SECURE=0x00000003
    CONFIG_NRF_GPIO1_PIN_MASK_SECURE=0x00000000
    CONFIG_NRF_DPPI_CHANNEL_MASK_SECURE=0x00000000
    # end of Peripheral Secure mapping
    # CONFIG_TFM_PROFILE_TYPE_MINIMAL is not set
    CONFIG_TFM_CPU_FREQ_MHZ=128
    CONFIG_TFM_SECURE_UART=y
    # CONFIG_TFM_SECURE_UART_SHARE_INSTANCE is not set
    # CONFIG_TFM_SECURE_UART20 is not set
    CONFIG_TFM_SECURE_UART30=y
    CONFIG_TFM_EXPERIMENTAL=y
    # CONFIG_TFM_HW_INIT_RESET_ON_BOOT is not set
    CONFIG_TFM_HALT_ON_CORE_PANIC=y
    CONFIG_TFM_ALLOW_NON_SECURE_RESET=y
    CONFIG_TFM_ALLOW_NON_SECURE_FAULT_HANDLING=y
    CONFIG_TFM_S_CODE_VECTOR_TABLE_SIZE=0x47c
    # CONFIG_TFM_PSA_FRAMEWORK_HAS_MM_IOVEC is not set
    # end of trusted-firmware-m (C:/ncs/v3.0.0/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    # cjson (C:/ncs/v3.0.0/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (C:/ncs/v3.0.0/modules/lib/cjson)
    # azure-sdk-for-c (C:/ncs/v3.0.0/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (C:/ncs/v3.0.0/modules/lib/azure-sdk-for-c)
    # cirrus-logic (C:/ncs/v3.0.0/modules/hal/cirrus-logic)
    # CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (C:/ncs/v3.0.0/modules/hal/cirrus-logic)
    # openthread (C:/ncs/v3.0.0/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (C:/ncs/v3.0.0/modules/lib/openthread)
    # suit-generator (C:/ncs/v3.0.0/modules/lib/suit-generator)
    CONFIG_SUIT_ENVELOPE_TEMPLATE_FILENAME=""
    CONFIG_SUIT_ENVELOPE_TARGET=""
    CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
    # CONFIG_SUIT_RECOVERY is not set
    # CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
    # CONFIG_SUIT_DFU_CACHE_EXTRACT_IMAGE is not set
    # CONFIG_SUIT_ENVELOPE_TARGET_ENCRYPT is not set
    # CONFIG_SUIT_ENVELOPE_TARGET_SIGN is not set
    CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
    # end of suit-generator (C:/ncs/v3.0.0/modules/lib/suit-generator)
    # suit-processor (C:/ncs/v3.0.0/modules/lib/suit-processor)
    # CONFIG_SUIT_PROCESSOR is not set
    CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
    CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
    # end of suit-processor (C:/ncs/v3.0.0/modules/lib/suit-processor)
    # memfault-firmware-sdk (C:/ncs/v3.0.0/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (C:/ncs/v3.0.0/modules/lib/memfault-firmware-sdk)
    # coremark (C:/ncs/v3.0.0/modules/benchmark/coremark)
    # CONFIG_COREMARK is not set
    CONFIG_ZEPHYR_COREMARK_MODULE=y
    # end of coremark (C:/ncs/v3.0.0/modules/benchmark/coremark)
    # canopennode (C:/ncs/v3.0.0/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (C:/ncs/v3.0.0/modules/lib/canopennode)
    # chre (C:/ncs/v3.0.0/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (C:/ncs/v3.0.0/modules/lib/chre)
    # lz4 (C:/ncs/v3.0.0/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (C:/ncs/v3.0.0/modules/lib/lz4)
    # nanopb (C:/ncs/v3.0.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (C:/ncs/v3.0.0/modules/lib/nanopb)
    CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    # zscilib (C:/ncs/v3.0.0/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (C:/ncs/v3.0.0/modules/lib/zscilib)
    # cmsis (C:/ncs/v3.0.0/modules/hal/cmsis)
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
    # end of cmsis (C:/ncs/v3.0.0/modules/hal/cmsis)
    # cmsis-dsp (C:/ncs/v3.0.0/modules/lib/cmsis-dsp)
    CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    # CONFIG_CMSIS_DSP is not set
    # end of cmsis-dsp (C:/ncs/v3.0.0/modules/lib/cmsis-dsp)
    # cmsis-nn (C:/ncs/v3.0.0/modules/lib/cmsis-nn)
    CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    # CONFIG_CMSIS_NN is not set
    # end of cmsis-nn (C:/ncs/v3.0.0/modules/lib/cmsis-nn)
    # fatfs (C:/ncs/v3.0.0/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (C:/ncs/v3.0.0/modules/fs/fatfs)
    # hal_nordic (C:/ncs/v3.0.0/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_RADIO_DRIVER is not set
    # CONFIG_NRF_802154_SER_RADIO is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_GRTC_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK=y
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    # CONFIG_NRFX_DPPI00 is not set
    # CONFIG_NRFX_DPPI10 is not set
    # CONFIG_NRFX_DPPI20 is not set
    # CONFIG_NRFX_DPPI30 is not set
    # CONFIG_NRFX_EGU10 is not set
    # CONFIG_NRFX_EGU20 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_GPIOTE20=y
    CONFIG_NRFX_GPIOTE30=y
    # CONFIG_NRFX_GPPI is not set
    CONFIG_NRFX_GRTC=y
    # CONFIG_NRFX_I2S20 is not set
    # CONFIG_NRFX_LPCOMP is not set
    # CONFIG_NRFX_NFCT is not set
    # CONFIG_NRFX_PDM20 is not set
    # CONFIG_NRFX_PDM21 is not set
    # CONFIG_NRFX_POWER is not set
    # CONFIG_NRFX_PPIB00 is not set
    # CONFIG_NRFX_PPIB01 is not set
    # CONFIG_NRFX_PPIB10 is not set
    # CONFIG_NRFX_PPIB11 is not set
    # CONFIG_NRFX_PPIB20 is not set
    # CONFIG_NRFX_PPIB21 is not set
    # CONFIG_NRFX_PPIB22 is not set
    # CONFIG_NRFX_PPIB30 is not set
    # CONFIG_NRFX_PWM20 is not set
    # CONFIG_NRFX_PWM21 is not set
    # CONFIG_NRFX_PWM22 is not set
    # CONFIG_NRFX_QDEC20 is not set
    # CONFIG_NRFX_QDEC21 is not set
    # CONFIG_NRFX_RRAMC is not set
    # CONFIG_NRFX_SAADC is not set
    # CONFIG_NRFX_SPIM00 is not set
    # CONFIG_NRFX_SPIM20 is not set
    # CONFIG_NRFX_SPIM21 is not set
    # CONFIG_NRFX_SPIM22 is not set
    # CONFIG_NRFX_SPIM30 is not set
    # CONFIG_NRFX_SPIS00 is not set
    # CONFIG_NRFX_SPIS20 is not set
    # CONFIG_NRFX_SPIS21 is not set
    # CONFIG_NRFX_SPIS22 is not set
    # CONFIG_NRFX_SPIS30 is not set
    # CONFIG_NRFX_SYSTICK is not set
    # CONFIG_NRFX_TEMP is not set
    # CONFIG_NRFX_TIMER00 is not set
    # CONFIG_NRFX_TIMER10 is not set
    # CONFIG_NRFX_TIMER20 is not set
    # CONFIG_NRFX_TIMER21 is not set
    # CONFIG_NRFX_TIMER22 is not set
    # CONFIG_NRFX_TIMER23 is not set
    # CONFIG_NRFX_TIMER24 is not set
    # CONFIG_NRFX_TWIM20 is not set
    # CONFIG_NRFX_TWIM21 is not set
    # CONFIG_NRFX_TWIM22 is not set
    # CONFIG_NRFX_TWIM30 is not set
    # CONFIG_NRFX_TWIS20 is not set
    # CONFIG_NRFX_TWIS21 is not set
    # CONFIG_NRFX_TWIS22 is not set
    # CONFIG_NRFX_TWIS30 is not set
    # CONFIG_NRFX_UARTE00 is not set
    # CONFIG_NRFX_UARTE20 is not set
    # CONFIG_NRFX_UARTE21 is not set
    # CONFIG_NRFX_UARTE22 is not set
    # CONFIG_NRFX_UARTE30 is not set
    # CONFIG_NRFX_WDT31 is not set
    # Peripheral Resource Sharing module
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    # CONFIG_NRFX_PRS_BOX_2 is not set
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    CONFIG_NRFX_RESERVED_RESOURCES_HEADER="nrfx_config_reserved_resources_ncs.h"
    # end of hal_nordic (C:/ncs/v3.0.0/modules/hal/nordic)
    # hal_st (C:/ncs/v3.0.0/modules/hal/st)
    CONFIG_ZEPHYR_HAL_ST_MODULE=y
    # end of hal_st (C:/ncs/v3.0.0/modules/hal/st)
    # hal_tdk (C:/ncs/v3.0.0/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_TDK_MODULE=y
    # TDK drivers
    # CONFIG_TDK_HAL is not set
    # end of TDK drivers
    # end of hal_tdk (C:/ncs/v3.0.0/modules/hal/tdk)
    CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    # liblc3 (C:/ncs/v3.0.0/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # end of liblc3 (C:/ncs/v3.0.0/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    # littlefs (C:/ncs/v3.0.0/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (C:/ncs/v3.0.0/modules/fs/littlefs)
    # loramac-node (C:/ncs/v3.0.0/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (C:/ncs/v3.0.0/modules/lib/loramac-node)
    # lvgl (C:/ncs/v3.0.0/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (C:/ncs/v3.0.0/modules/lib/gui/lvgl)
    CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    # nrf_wifi (C:/ncs/v3.0.0/modules/lib/nrf_wifi)
    CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
    # CONFIG_NRF70_BUSLIB is not set
    # end of nrf_wifi (C:/ncs/v3.0.0/modules/lib/nrf_wifi)
    CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    # percepio (C:/ncs/v3.0.0/modules/debug/percepio)
    # Percepio Tracealyzer support can be enabled from the tracing subsystem
    # CONFIG_PERCEPIO_DFM is not set
    CONFIG_ZEPHYR_PERCEPIO_MODULE=y
    # end of percepio (C:/ncs/v3.0.0/modules/debug/percepio)
    # picolibc (C:/ncs/v3.0.0/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (C:/ncs/v3.0.0/modules/lib/picolibc)
    # segger (C:/ncs/v3.0.0/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
    CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
    CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
    CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
    CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
    CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
    CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
    # CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
    # CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
    CONFIG_SEGGER_RTT_MODE=0
    # CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
    # CONFIG_SEGGER_RTT_SECTION_NONE is not set
    # CONFIG_SEGGER_RTT_SECTION_DTCM is not set
    # CONFIG_SEGGER_RTT_SECTION_CCM is not set
    CONFIG_SEGGER_RTT_SECTION_CUSTOM=y
    # CONFIG_SEGGER_RTT_SECTION_CUSTOM_DTS_REGION is not set
    CONFIG_SEGGER_RTT_SECTION_CUSTOM_NAME=".rtt_buff_data"
    # CONFIG_SEGGER_RTT_INIT_MODE_ALWAYS is not set
    CONFIG_SEGGER_RTT_INIT_MODE_STRONG_CHECK=y
    # CONFIG_SEGGER_RTT_INIT_MODE_WEAK_CHECK is not set
    # end of segger (C:/ncs/v3.0.0/modules/debug/segger)
    CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
    # uoscore-uedhoc (C:/ncs/v3.0.0/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (C:/ncs/v3.0.0/modules/lib/uoscore-uedhoc)
    # zcbor (C:/ncs/v3.0.0/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # CONFIG_ZCBOR is not set
    # end of zcbor (C:/ncs/v3.0.0/modules/lib/zcbor)
    # nrfxlib (C:/ncs/v3.0.0/nrfxlib)
    # Nordic nrfxlib
    # nrf_modem (Modem library)
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # end of nrf_modem (Modem library)
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # CONFIG_MPSL is not set
    # Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_OBERON is not set
    # CONFIG_NRF_CC310_BL is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_NRF_DM is not set
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (C:/ncs/v3.0.0/nrfxlib)
    CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    # connectedhomeip (C:/ncs/v3.0.0/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (C:/ncs/v3.0.0/modules/lib/matter)
    # CONFIG_LIBMETAL is not set
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    # CONFIG_HAS_MEC5_HAL is not set
    # CONFIG_OPENAMP is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_TINYCRYPT is not set
    # CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD="nrf54l15dk"
    CONFIG_BOARD_REVISION=""
    CONFIG_BOARD_TARGET="nrf54l15dk/nrf54l15/cpuapp/ns"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF54L15DK=y
    CONFIG_BOARD_NRF54L15DK_NRF54L15_CPUAPP_NS=y
    CONFIG_BOARD_QUALIFIERS="nrf54l15/cpuapp/ns"
    # Board Options
    CONFIG_NRF_MPC_REGION_SIZE=0x1000
    # end of Board Options
    # Hardware Configuration
    CONFIG_SOC="nrf54l15"
    CONFIG_SOC_SERIES="nrf54l"
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_SOC_FAMILY_NORDIC_NRF=y
    CONFIG_SOC_SERIES_NRF54LX=y
    CONFIG_SOC_NRF54L15=y
    CONFIG_SOC_NRF54L15_CPUAPP=y
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIO2=y
    CONFIG_HAS_HW_NRF_GPIOTE20=y
    CONFIG_HAS_HW_NRF_GPIOTE30=y
    CONFIG_HAS_HW_NRF_GRTC=y
    CONFIG_HAS_HW_NRF_PWM20=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
    CONFIG_HAS_HW_NRF_RADIO_BLE_CODED=y
    CONFIG_HAS_HW_NRF_RADIO_CS=y
    CONFIG_HAS_HW_NRF_RADIO_DFE=y
    CONFIG_HAS_HW_NRF_RADIO_IEEE802154=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM00=y
    CONFIG_HAS_HW_NRF_TEMP=y
    CONFIG_HAS_HW_NRF_UARTE20=y
    CONFIG_HAS_NORDIC_RAM_CTRL=y
    # CONFIG_NRF_FORCE_RAM_ON_REBOOT is not set
    # CONFIG_NRF_SYS_EVENT is not set
    # CONFIG_SOC_NRF54H20_GPD is not set
    CONFIG_SOC_NRF54L_CPUAPP_COMMON=y
    CONFIG_SOC_NRF54LX_SKIP_CLOCK_CONFIG=y
    CONFIG_SOC_NRF54LX_DISABLE_FICR_TRIMCNF=y
    CONFIG_SOC_NRF54LX_SKIP_GLITCHDETECTOR_DISABLE=y
    # CONFIG_SOC_NRF_FORCE_CONSTLAT is not set
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    CONFIG_TFM_NRF_NS_STORAGE=y
    # CONFIG_NFCT_PINS_AS_GPIOS is not set
    CONFIG_NRF_APPROTECT_DISABLE=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_DISABLE=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    CONFIG_GPIO_INIT_PRIORITY=40
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF54LX=y
    CONFIG_ARCH="arm"
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_CPU_CORTEX=y
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_ALLOW_FLASH_WRITE is not set
    # ARM Options
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    # CONFIG_PLATFORM_SPECIFIC_INIT is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_ARM_NONSECURE_FIRMWARE=y
    CONFIG_ARM_NONSECURE_PREEMPTIBLE_SECURE_CALLS=y
    CONFIG_ARM_STORE_EXC_RETURN=y
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    CONFIG_ARM_TRUSTZONE_M=y
    # ARM TrustZone-M Options
    # Non-secure firmware
    # CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS is not set
    # end of ARM TrustZone-M Options
    # CONFIG_MPU_STACK_GUARD is not set
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    CONFIG_CPU_HAS_ARM_SAU=y
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # CONFIG_FRAME_POINTER is not set
    # Interrupt Configuration
    CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
    # CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_EXCEPTION_DEBUG=y
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_COREDUMP_THREADS=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_SUPPORTS_ROM_START=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_CPU_HAS_ICACHE=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # DSP Options
    # end of DSP Options
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    CONFIG_ICACHE=y
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_MAIN_THREAD_PRIORITY=0
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    # CONFIG_SCHED_DUMB is not set
    CONFIG_SCHED_SIMPLE=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_DUMB is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_SIMPLE=y
    # Misc Kernel related options
    CONFIG_LIBC_ERRNO=y
    CONFIG_ERRNO=y
    CONFIG_CURRENT_THREAD_USE_TLS=y
    # end of Misc Kernel related options
    # Kernel Debugging and Metrics
    CONFIG_BOOT_DELAY=0
    # CONFIG_BOOT_CLEAR_SCREEN is not set
    # CONFIG_THREAD_MONITOR is not set
    # CONFIG_THREAD_NAME is not set
    # CONFIG_THREAD_RUNTIME_STATS is not set
    # end of Kernel Debugging and Metrics
    # CONFIG_OBJ_CORE is not set
    # System Work Queue Options
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of System Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_POLL is not set
    # CONFIG_MEM_SLAB_POINTER_VALIDATE is not set
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    CONFIG_EVENTS=y
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
    # end of Other Kernel Object Options
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    # Security Options
    # end of Security Options
    # Memory Domains
    CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
    CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
    # end of Memory Domains
    # SMP Options
    # CONFIG_TICKET_SPINLOCKS is not set
    # end of SMP Options
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_SUPPORTS_STATIC_INIT_GNU=y
    # CONFIG_STATIC_INIT_GNU is not set
    # CONFIG_BOOTARGS is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # CONFIG_DEVICE_MUTABLE is not set
    # CONFIG_DEVICE_DT_METADATA is not set
    # end of Device Options
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_LIBC=35
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Virtual Memory Support
    # end of Virtual Memory Support
    # SoC and Board Hooks
    # CONFIG_SOC_PREP_HOOK is not set
    # CONFIG_SOC_EARLY_INIT_HOOK is not set
    # CONFIG_SOC_LATE_INIT_HOOK is not set
    # CONFIG_SOC_PER_CORE_INIT_HOOK is not set
    # CONFIG_BOARD_EARLY_INIT_HOOK is not set
    # CONFIG_BOARD_LATE_INIT_HOOK is not set
    # end of SoC and Board Hooks
    # Device Drivers
    # CONFIG_ADC is not set
    # CONFIG_AUDIO is not set
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_BBRAM is not set
    # CONFIG_FLASH is not set
    # CONFIG_CAN is not set
    # CONFIG_CHARGER is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    # CONFIG_CLOCK_CONTROL_RTS5912_SCCON is not set
    # CONFIG_COMPARATOR is not set
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    CONFIG_CONSOLE_INIT_PRIORITY=40
    # CONFIG_UART_CONSOLE is not set
    # CONFIG_RAM_CONSOLE is not set
    CONFIG_RTT_CONSOLE=y
    CONFIG_RTT_TX_RETRY_CNT=2
    CONFIG_RTT_TX_RETRY_DELAY_MS=2
    # CONFIG_RTT_TX_RETRY_IN_INTERRUPT is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_EFI_CONSOLE is not set
    CONFIG_WINSTREAM_CONSOLE_STATIC=y
    CONFIG_WINSTREAM_CONSOLE_STATIC_SIZE=32768
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVERS is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_DP_DRIVER is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    # CONFIG_ENTROPY_GENERATOR is not set
    # CONFIG_ESPI is not set
    # Firmware drivers
    # CONFIG_ARM_SCMI is not set
    # end of Firmware drivers
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GNSS is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    # CONFIG_GPIO_HOGS is not set
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_GPIO_RTS5912 is not set
    # CONFIG_HAPTICS is not set
    CONFIG_HWINFO=y
    # CONFIG_HWINFO_LOG_LEVEL_OFF is not set
    # CONFIG_HWINFO_LOG_LEVEL_ERR is not set
    # CONFIG_HWINFO_LOG_LEVEL_WRN is not set
    # CONFIG_HWINFO_LOG_LEVEL_INF is not set
    # CONFIG_HWINFO_LOG_LEVEL_DBG is not set
    CONFIG_HWINFO_LOG_LEVEL_DEFAULT=y
    CONFIG_HWINFO_LOG_LEVEL=3
    CONFIG_HWINFO_HAS_DRIVER=y
    CONFIG_HWINFO_NRF=y
    # CONFIG_HWSPINLOCK is not set
    # CONFIG_I2C is not set
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    # CONFIG_MBOX is not set
    # CONFIG_MDIO is not set
    # CONFIG_MIPI_DBI is not set
    # Miscellaneous Drivers
    # CONFIG_TIMEAWARE_GPIO is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_MSPI is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    CONFIG_PINCTRL=y
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PINCTRL_REALTEK_RTS5912 is not set
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    # CONFIG_PWM is not set
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    # CONFIG_UART_ASYNC_API is not set
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # CONFIG_UART_ASYNC_RX_HELPER is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
    # CONFIG_UART_20_NRF_PARITY_BIT is not set
    CONFIG_UART_20_NRF_TX_BUFFER_SIZE=32
    # CONFIG_UART_RTS5912 is not set
    # CONFIG_SMBUS is not set
    # CONFIG_STEPPER is not set
    # Timer drivers
    CONFIG_TIMER_HAS_64BIT_CYCLE_COUNTER=y
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_NRF_GRTC_TIMER=y
    # CONFIG_NRF_GRTC_TIMER_APP_DEFINED_INIT is not set
    CONFIG_NRF_GRTC_START_SYSCOUNTER=y
    CONFIG_NRF_GRTC_TIMER_CLOCK_MANAGEMENT=y
    CONFIG_NRF_GRTC_SYSCOUNTER_SLEEP_MINIMUM_LATENCY=1000
    CONFIG_NRF_GRTC_TIMER_AUTO_KEEP_ALIVE=y
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # CONFIG_REALTEK_RTS5912_RTMR is not set
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
    # CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_USBC_PPC_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_TEE is not set
    # CONFIG_REQUIRES_FULL_LIBC is not set
    # CONFIG_REQUIRES_FLOAT_PRINTF is not set
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    # CONFIG_MINIMAL_LIBC is not set
    CONFIG_PICOLIBC=y
    # CONFIG_NEWLIB_LIBC is not set
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_ASCTIME_R is not set
    # CONFIG_COMMON_LIBC_CTIME_R is not set
    CONFIG_COMMON_LIBC_MALLOC=y
    CONFIG_COMMON_LIBC_CALLOC=y
    CONFIG_COMMON_LIBC_REALLOCARRAY=y
    # CONFIG_COMMON_LIBC_REMOVE is not set
    # CONFIG_PICOLIBC_USE_MODULE is not set
    CONFIG_PICOLIBC_USE_TOOLCHAIN=y
    # CONFIG_PICOLIBC_IO_FLOAT is not set
    CONFIG_PICOLIBC_IO_LONG_LONG=y
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_NEED_LIBC_MEM_PARTITION=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # end of C++ Language Support
    CONFIG_CRC=y
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_STRESS is not set
    # CONFIG_SYS_HEAP_INFO is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    # CONFIG_MULTI_HEAP is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # end of Heap and Memory Allocation
    # Memory Blocks
    # CONFIG_SYS_MEM_BLOCKS is not set
    # end of Memory Blocks
    # CONFIG_NET_BUF is not set
    # OS Support Library
    # CONFIG_FDTABLE is not set
    CONFIG_ZVFS_OPEN_MAX=4
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_HAS_POWEROFF=y
    CONFIG_POWEROFF=y
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    # CONFIG_CBPRINTF_FP_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
    # CONFIG_ZVFS is not set
    # end of OS Support Library
    # POSIX API Support
    # POSIX Options
    # CONFIG_POSIX_API is not set
    CONFIG_POSIX_AEP_CHOICE_NONE=y
    # CONFIG_POSIX_AEP_CHOICE_BASE is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE51 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE52 is not set
    # CONFIG_POSIX_AEP_CHOICE_PSE53 is not set
    # CONFIG_POSIX_ASYNCHRONOUS_IO is not set
    # CONFIG_POSIX_BARRIERS is not set
    # CONFIG_POSIX_C_LANG_SUPPORT_R is not set
    # CONFIG_POSIX_C_LIB_EXT is not set
    # POSIX device I/O
    # CONFIG_POSIX_DEVICE_IO is not set
    CONFIG_POSIX_OPEN_MAX=4
    # end of POSIX device I/O
    # CONFIG_POSIX_FD_MGMT is not set
    # CONFIG_POSIX_FILE_SYSTEM_R is not set
    # CONFIG_POSIX_FILE_SYSTEM is not set
    # POSIX memory
    CONFIG_POSIX_PAGE_SIZE=0x40
    # CONFIG_POSIX_SHARED_MEMORY_OBJECTS is not set
    # CONFIG_POSIX_MAPPED_FILES is not set
    # CONFIG_POSIX_MEMORY_PROTECTION is not set
    # end of POSIX memory
    # CONFIG_POSIX_MESSAGE_PASSING is not set
    # CONFIG_POSIX_SINGLE_PROCESS is not set
    # CONFIG_POSIX_MULTI_PROCESS is not set
    # CONFIG_POSIX_THREADS is not set
    # CONFIG_POSIX_READER_WRITER_LOCKS is not set
    # POSIX scheduler options
    # CONFIG_POSIX_PRIORITY_SCHEDULING is not set
    # end of POSIX scheduler options
    # CONFIG_POSIX_SEMAPHORES is not set
    # POSIX signals
    # CONFIG_POSIX_REALTIME_SIGNALS is not set
    # CONFIG_POSIX_SIGNALS is not set
    # end of POSIX signals
    # CONFIG_POSIX_SPIN_LOCKS is not set
    # POSIX synchronized I/O
    # CONFIG_POSIX_FSYNC is not set
    # CONFIG_POSIX_SYNCHRONIZED_IO is not set
    # end of POSIX synchronized I/O
    # CONFIG_POSIX_TIMERS is not set
    # X/Open system interfaces
    # CONFIG_XOPEN_STREAMS is not set
    # CONFIG_XSI_SYSTEM_LOGGING is not set
    # CONFIG_XSI_THREADS_EXT is not set
    # end of X/Open system interfaces
    # Miscellaneous POSIX-related options
    # CONFIG_EVENTFD is not set
    # end of Miscellaneous POSIX-related options
    # Deprecated POSIX options
    CONFIG_EVENTFD_MAX=0
    # CONFIG_FNMATCH is not set
    CONFIG_MAX_PTHREAD_COUNT=0
    CONFIG_MAX_PTHREAD_KEY_COUNT=0
    CONFIG_MAX_TIMER_COUNT=0
    CONFIG_MSG_COUNT_MAX=0
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_POSIX_FS is not set
    CONFIG_POSIX_LIMITS_RTSIG_MAX=0
    CONFIG_POSIX_MAX_FDS=4
    CONFIG_POSIX_MAX_OPEN_FILES=4
    # CONFIG_POSIX_MQUEUE is not set
    # CONFIG_POSIX_PUTMSG is not set
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_POSIX_SYSCONF is not set
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_PTHREAD is not set
    # CONFIG_PTHREAD_BARRIER is not set
    # CONFIG_PTHREAD_COND is not set
    # CONFIG_PTHREAD_IPC is not set
    # CONFIG_PTHREAD_KEY is not set
    # CONFIG_PTHREAD_MUTEX is not set
    # CONFIG_PTHREAD_RWLOCK is not set
    # CONFIG_PTHREAD_SPINLOCK is not set
    # CONFIG_TIMER is not set
    CONFIG_TIMER_DELAYTIMER_MAX=0
    CONFIG_SEM_NAMELEN_MAX=0
    CONFIG_SEM_VALUE_MAX=0
    # end of Deprecated POSIX options
    CONFIG_TC_PROVIDES_POSIX_C_LANG_SUPPORT_R=y
    # end of POSIX Options
    # POSIX Shell Utilities
    # end of POSIX Shell Utilities
    # end of POSIX API Support
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_LIBGCC_RTLIB=y
    # Utility Library
    # CONFIG_JSON_LIBRARY is not set
    # CONFIG_RING_BUFFER is not set
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    CONFIG_ONOFF=y
    # CONFIG_UTF8 is not set
    # end of Utility Library
    # end of Additional libraries
    # Subsystems and OS Services
    # CONFIG_BINDESC is not set
    # CONFIG_BT is not set
    # Controller Area Network (CAN) bus subsystem
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # CONFIG_DAP is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    # CONFIG_DEBUG is not set
    # CONFIG_STACK_USAGE is not set
    # CONFIG_STACK_SENTINEL is not set
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    # CONFIG_DEBUG_INFO is not set
    # CONFIG_DEBUG_THREAD_INFO is not set
    # CONFIG_DEBUG_COREDUMP is not set
    # CONFIG_SYMTAB is not set
    # end of Debugging Options
    # CONFIG_MIPI_STP_DECODER is not set
    # CONFIG_CS_TRACE_DEFMT is not set
    # CONFIG_DISK_ACCESS is not set
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FILE_SYSTEM_LIB_LINK is not set
    # CONFIG_FILE_SYSTEM is not set
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    # CONFIG_IPC_SERVICE is not set
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # CONFIG_LLEXT is not set
    # Linkable loadable Extension Development Kit (EDK)
    CONFIG_LLEXT_EDK_NAME="llext-edk"
    # CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
    # end of Linkable loadable Extension Development Kit (EDK)
    # Logging
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_FRONTEND_OPT_API is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    # CONFIG_LOG_RUNTIME_FILTERING is not set
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    # CONFIG_LOG_DBG_COLOR_BLUE is not set
    CONFIG_LOG_TAG_MAX_LEN=0
    CONFIG_LOG_BACKEND_SUPPORTS_FORMAT_TIMESTAMP=y
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    CONFIG_LOG_OUTPUT_FORMAT_TIME_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    CONFIG_LOG_BACKEND_RTT=y
    # CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
    CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
    # CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
    CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
    CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
    CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
    CONFIG_LOG_BACKEND_RTT_BUFFER=0
    CONFIG_LOG_BACKEND_RTT_FORCE_PRINTK=y
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_USE_VLA=y
    CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_FMT_STRING_VALIDATE is not set
    # CONFIG_LOG_MEM_UTILIZATION is not set
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    CONFIG_MEM_ATTR=y
    # CONFIG_MEM_ATTR_HEAP is not set
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # CONFIG_PM_POLICY_LATENCY_STANDALONE is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_OFF is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_ERR is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_WRN is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_INF is not set
    # CONFIG_PM_DEVICE_LOG_LEVEL_DBG is not set
    CONFIG_PM_DEVICE_LOG_LEVEL_DEFAULT=y
    CONFIG_PM_DEVICE_LOG_LEVEL=3
    # end of Power Management
    # Portability
    # end of Portability
    # CONFIG_PROFILING is not set
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
    CONFIG_CSPRNG_AVAILABLE=y
    # end of Random Number Generators
    # CONFIG_RTIO is not set
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    # CONFIG_SETTINGS is not set
    # CONFIG_SHELL is not set
    # CONFIG_STATS is not set
    # Storage
    # CONFIG_STREAM_FLASH is not set
    # end of Storage
    # CONFIG_TASK_WDT is not set
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    # CONFIG_FORCE_COVERAGE is not set
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    # CONFIG_ZBUS is not set
    # CONFIG_MODULES is not set
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_17=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_FLASH_LOAD_SIZE=0
    CONFIG_ROM_END_OFFSET=0
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    CONFIG_LINKER_ITERABLE_SUBALIGN=4
    CONFIG_LINKER_DEVNULL_SUPPORT=y
    # CONFIG_LINKER_DEVNULL_MEMORY is not set
    # end of Linker Options
    # Compiler Options
    # CONFIG_STD_C90 is not set
    CONFIG_STD_C99=y
    # CONFIG_STD_C11 is not set
    # CONFIG_STD_C17 is not set
    # CONFIG_STD_C23 is not set
    CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
    # CONFIG_GNU_C_EXTENSIONS is not set
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    CONFIG_SIZE_OPTIMIZATIONS=y
    # CONFIG_SIZE_OPTIMIZATIONS_AGGRESSIVE is not set
    # CONFIG_SPEED_OPTIMIZATIONS is not set
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    CONFIG_BUILD_GAP_FILL_PATTERN=0xFF
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_HEX_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_WARN_DEPRECATED=y
    CONFIG_EXPERIMENTAL=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_LEGACY_GENERATED_INCLUDE_PATH=y
    # end of Compatibility
    If possible, would you tell me your .config and SDK version when you correctly built the systemoff application?
    Best regards.
  • The only modification you need to make to the SDK sample is to add CONFIG_GRTC_WAKEUP_ENABLE=y and CONFIG_GPIO_WAKEUP_ENABLE=n to the prj.conf. The reason you are not getting any log messages is that you have enabled logging over RTT instead of UART.
  • Hi.
    With ''nrf54l15dk/nrf54l15/cpuapp', I could see it works normally by using PPK2.
    But, I would like to make it with 'nrf54l15dk/nrf54l15/cpuapp/ns'.
    Why does not this example work ?
    It does not work with then /ns target because the app running in the non-secure processing environment does not have access to the REGULATORS and MEMCONF registers which both are used by sys_poweroff(). Any direct access made to these register from the app will lead to a fault exception.
    I'm not sure how we will expose this functionality to the app yet, but there is an open task internally to address this limitation.
  • Hi.
    I guess the difference between nrf54l15dk_nrf54l15_cpuapp and /ns is whether it has the .overlay file or not.
    Once, I succeeded in building with 'nrf54l15dk_nrf54l15_cpuapp/ns' after building 'nrf54l15dk_nrf54l15_cpuapp'.
    Then, I copied the content of prj.conf (below)
    CONFIG_PM_DEVICE=y
    CONFIG_GPIO=y
    CONFIG_CRC=y
    CONFIG_POWEROFF=y
    CONFIG_HWINFO=y
    and the content of CMakeLists.txt
    target_sources(app PRIVATE src/main.c)
    if(CONFIG_APP_USE_RETAINED_MEM)
      target_sources(app PRIVATE src/retained.c)
    endif()
    and retained.c/.h from systemoff sample.
    Then, I added the writing below in myapplication(nrf54l15dk_nrf54l15_cpuapp/ns).overlay.
    	cpuapp_sram@2002e000 {
    		compatible = "zephyr,memory-region", "mmio-sram";
    		reg = <0x2002e000 DT_SIZE_K(4)>;
    		zephyr,memory-region = "RetainedMem";
    		status = "okay";
    		retainedmem0: retainedmem {
    			compatible = "zephyr,retained-ram";
    			status = "okay";
    	aliases {
    		retainedmemdevice = &retainedmem0;
    &cpuapp_sram {
    	/* Shrink SRAM size to avoid overlap with retained memory region */
    	reg = <0x20000000 DT_SIZE_K(184)>;
    	ranges = <0x0 0x20000000 0x2e000>;
    I succeeded in building, but my application failed with the log when it entered SYSTEMOFF mode
    (when calling sys_poweroff() ).
    [00:00:41.625,824] <err> os: ***** BUS FAULT *****
    [00:00:41.625,843] <err> os:   Precise data bus error
    [00:00:41.625,847] <err> os:   BFAR Address: 0x0
    [00:00:41.625,857] <err> os: r0/a1:  0x00000000  r1/a2:  0x00000001  r2/a3:  0x00000000
    [00:00:41.625,863] <err> os: r3/a4:  0x400cf000 r12/ip:  0x00000000 r14/lr:  0x00064c79
    [00:00:41.625,867] <err> os:  xpsr:  0x41000000
    [00:00:41.625,875] <err> os: s[ 0]:  0x00000000  s[ 1]:  0x0006509b  s[ 2]:  0x20013830  s[ 3]:  0x00050b13
    [00:00:41.625,882] <err> os: s[ 4]:  0x20013cc0  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00050477
    [00:00:41.625,889] <err> os: s[ 8]:  0x20013100  s[ 9]:  0x00046401  s[10]:  0x00000004  s[11]:  0x00000000
    [00:00:41.625,897] <err> os: s[12]:  0x2001be44  s[13]:  0x00000000  s[14]:  0x00000020  s[15]:  0x00064fc5
    [00:00:41.625,911] <err> os: fpscr:  0x20013ce8
    [00:00:41.625,915] <err> os: Faulting instruction address (r15/pc): 0x0004ebda
    [00:00:41.625,934] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
    [00:00:41.625,951] <err> os: Current thread: 0x20013830 (main)
    [00:00:41.733,093] <err> os: Halting system
    Is it also the main cause of the difference board configuration?
    I'd like to investigate the cause and use the SYSTEMOFF and GRTC reset.
    Best regards.
