nRF54L15 protobuf error
Hello, I'm running an example of channel sounding using nRF54L15.
The build is fine, but the following error occurs during flash.
Python is using 3.12.4 version.
As you can see, we're using protobuf version 3.19.6 as well. (The same error occurred in 3.20.0 version)
But I keep getting protobuf errors, how do I fix it?
I solved this problem, but another problem occurred.
ModuleNotFoundError: No module named 'constants'
    Unfortunately, as shown in the image, I tried using the Build and Flash buttons in the nRF Connect SDK Toolchain v3.0.1, but the same error kept occurring.
    However, I was able to resolve the issue and successfully flash the device.
    I tried several methods:
    • Downloaded Python 3.10 and configured both the interpreter and system PATH to use it.
    • I downloaded nrfutil from www.nordicsemi.com/.../nrf-util, manually moved it to the folder C:\ncs\toolchains\0b393f9e1b\opt\bin\Scripts, and ran the command C:\ncs\toolchains\0b393f9e1b\opt\bin\Scripts\nrfutil.exe install device
  • According to google translate, this is what you wrote:
    Unfortunately, I tried using the Build and Flash buttons of the nRF Connect SDK Toolchain v3.0.1 as shown in the image, but I kept getting the same error.
    However, I was able to fix the issue and successfully run the flash.
    Download Python 3.10 and configure the interpreter and system PATH to use it.
    Download nrfutil from www.nordicsemi.com/.../nrf-util and manually place it and run the command nrfutil.exeC:\ncs\toolchains\0b393f9e1b\opt\bin\Scriptsnrfutil.exe install devic
    If you got it working, it is fine, I guess. But you may still run into other issues, if your toolchain is not being correctly set up when building your applications.
    Try building using this terminal and the command "west build -b <board_name> -d build_2"
    But if you have changed things inside the toolchain, I would recommend that you uninstall that toolchain and re-install it again. Building with the toolchain enabled should never try to access your "personal" python instance outside the toolchain.
    Edvin
    As you mentioned, I ran the following command:
    west build -b nrf54l15dk/nrf54l15/cpuapp -d C:\ncs\channel_sounding_ras_initiator\build
    CMake Error: CMake was unable to find a build program corresponding to "Ninja".  CMAKE_MAKE_PROGRAM is not set.  You probably need to select a different build
    tool.
    FATAL ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' -DWEST_PYTHON=C:/Users/SJIT/AppData/Local/Programs/Python/Python310/python.exe '-BC:\ncs\channel_sounding_ras_initiator\build' -GNinja -DBOARD=nrf54l15dk/nrf54l15/cpuapp '-SC:\ncs\v3.0.1\zephyr\share\sysbuild' '-DAPP_DIR:PATH=C:\ncs\channel_sounding_ras_initiator'
    However, I encountered an issue with Ninja,
    but I was able to resolve it by adding the following to the PATH:
    set PATH=C:\ncs\toolchains\0b393f9e1b\opt\bin;%PATH%
    and the build was successful.
    However, when I first tried to flash using this command:
    C:\ncs\v3.0.1>west flash -d C:\ncs\channel_sounding_ras_initiator\build
    an error occurred.
    At that time, after I moved the downloaded nrfutil.exe file into C:\ncs\toolchains\0b393f9e1b\opt\bin,
    the flashing worked correctly.
    Thank you for your respons
  • A new error has occurred.
    After my colleague installed a new (=nothing touched) toolchain and SDK version v3.0.1, they tried to run the build using the command
    west build -b nrf54l15dk/nrf54l15/cpuapp -d build
    but encountered the following error message:
    'west' is not recognized as an internal or external command, operable program, or batch file.
  • Where did he try to type this command? Try calling it in an "nRF Connect" terminal in VS Code, like I showed in my reply the 27th of May.
    BR,
    Edvin
