Matter over Ethernet and Matter over Wi-Fi support
Hello DevZone,
Is it possible to support Matter over Ethernet and Matter over Wi-Fi at same time?
Since there are many Ethernet chips support in Zephyr.
Seems that the point is how to provision the device.
By the way, there is another question.
If there are some Wi-Fi APs with different SSID in one house, one LAN. Is it possible to provision a Matter device to a Wi-Fi AP that different to the Matter controller?
Jayant
  • Hi Jayant,
    It should be possible to implement Matter over Ethernet and Matter over Wi-Fi on the same device, but they can likely not run simultaneously. Also note that nRF Connect SDK does not support Matter over Ethernet so this needs to be implemented. It is possible to use some of the same code base as for Wi-Fi, but some modifications are needed. Here are some examples on needed modifications, but these are not all:
    In nRF Connect SDK, the Matter controller needs a direct link to the device which is provisioned. So if I understand your description correctly, what you describe is not possible.
    Maria
