Help understanding RX / TX
I have this main code:
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/uart.h>
#include <string.h>
#define MSG_SIZE 32
K_MSGQ_DEFINE(uart_msgq, MSG_SIZE, 10, 4);
static char rx_buf[MSG_SIZE];
static int rx_buf_pos;
#define UART_DEVICE_NODE DT_NODELABEL(uart1)
static const struct device *const uart_dev = DEVICE_DT_GET(UART_DEVICE_NODE);
void serial_cb(const struct device *dev, void *user_data)
    uint8_t c;
    if (!uart_irq_update(uart_dev) || !uart_irq_rx_ready(uart_dev)) {
		printk("UART IRQ not ready\r\n");
		return;
	printk("reading datar\r\n");
    while (uart_fifo_read(uart_dev, &c, 1) == 1) {
		printk("RX: %c\n", c);
        if ((c == '\n' || c == '\r') && rx_buf_pos > 0) {
            rx_buf[rx_buf_pos] = '\0';
            k_msgq_put(&uart_msgq, &rx_buf, K_NO_WAIT);
            rx_buf_pos = 0;
        } else if (rx_buf_pos < (sizeof(rx_buf) - 1)) {
            rx_buf[rx_buf_pos++] = c;
void print_uart(char *buf)
    for (int i = 0; buf[i] != '\0'; i++) {
        uart_poll_out(uart_dev, buf[i]);
        k_busy_wait(100);
    printk("UART Echo Started\n");
    if (!device_is_ready(uart_dev)) {
        printk("UART device not ready\n");
        return 0;
    uart_irq_callback_user_data_set(uart_dev, serial_cb, NULL);
    uart_irq_rx_enable(uart_dev);
    print_uart("Hello from echo bot\r\n");
	printk("Hello sent\r\n");
	while(true) {
		print_uart("Echo: ");
		print_uart(" is one wild");
		print_uart("\r\n");
		//Sleep for a second
		k_sleep(K_SECONDS(1));
		printk("Sending data to TX\r\n");
    return 0;
With this overlay:
&uart1 {
    status = "okay";
    current-speed = <115200>;
    pinctrl-0 = <&uart1_default>;
    pinctrl-1 = <&uart1_sleep>;
&pinctrl {
    uart1_default: uart1_default {
        group1 {
            psels = <NRF_PSEL(UART_TX, 0, 9)>,
                    <NRF_PSEL(UART_RX, 0, 10)>;
    uart1_sleep: uart1_sleep {
        group1 {
            low-power-enable;
and this configuration:
CONFIG_SERIAL=y
CONFIG_UART_CONSOLE=n
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_LOG=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_PRINTK=y
I am using a nrf52840 dev board and have connected P0.06 and P0.08.
Why does it not trigger TX and write to JRTTLinkEXE the data sent in the main loop?
    P0.09 and P0.10 are NFC-pins, and require handling as such, by adding this to the overlay:
    &uicr {
    	nfct-pins-as-gpios;
    If you are using the nRF52840-DK, you will also need to adjust some resistors on the board itself:
    https://docs.nordicsemi.com/bundle/ug_nrf52840_dk/page/UG/dk/hw_nfc_if.html#d45e110
    Håkon
  • Hi.
    But this means it should work with P0.06 and P0.08, right?
    With this configuration:
    pinctrl {
    group1 {
    psels = <NRF_PSEL(UART_TX, 0, 6)>,
    <NRF_PSEL(UART_RX, 0, 8)>;
    group1 {
    low-power-enable;
    And it does not. What am I missing?
    If you still have issues, please try any unused GPIO pair. flip the kit over, and you can see which pins are already connected on the DK itself.
    Those pins are normally used for uart0. Is uart0 disabled in this case?
    Håkon
  • Hi.
    Thanks, changing pins solved my issues. Atleast partly, the pins I where using where busy doing other things on the board. And thanks for letting me know about the diagram on the back of the boards.
    I have a new setup, which is a bit strange.
    overlay:
    &uart1 {
        status = "okay";
        current-speed = <9600>;
    &pinctrl {
            group1 {
                psels = <NRF_PSEL(UART_TX, 1, 12)>,
                        <NRF_PSEL(UART_RX, 1, 11)>;
                bias-pull-up;
    main.c:
    #include <string.h>
    #define MSG_SIZE 32
    static volatile bool uart_tx_done = true;
        uint8_t c;
    		return;
    	printk("UART RX Ready\n");
                rx_buf_pos = 0;
            k_busy_wait(100);
    void send_uart_async(const char *msg)
        if (!uart_tx_done) {
            printk("UART busy, skipping TX\n");
            return;
        uart_tx_done = false;
        int ret = uart_tx(uart_dev, msg, strlen(msg), SYS_FOREVER_MS);
        if (ret != 0) {
            printk("uart_tx failed with error: %d\n", ret);
            uart_tx_done = true; // reset flag so we don't block forever
            return 0;
    	while(true) {
    		print_uart("Hello from nrf52\r\n");
        return 0;
    prj.conf:
    CONFIG_SERIAL=y
    CONFIG_UART_ASYNC_API=y
    CONFIG_CONSOLE=n
    CONFIG_LOG=y
    CONFIG_PRINTK=y
    However, now it seems like it is able to transmit and receive on the pins 11, 12.
    For some reason using uart1, im able to receive but not transmit.
    But my problem is, using uart0 with the following setup, im able to transmit but not receive, the complete oposite.
    &uart0 {
        status = "okay";
        pinctrl-0 = <&uart0_default>;
        pinctrl-1 = <&uart0_sleep>;
    &pinctrl {
        uart0_default: uart0_default {
            group1 {
                bias-pull-up;
    Any logical reason for that?
