Hi
Does the nrf-sw-pwm driver work on the nrf54l15. I am porting code form the nrf52840.
My output does not toggel, 0% and 100% does work but noting else.
Hi
I should have mentioned that this is with sdk version 2.9.1. Using timer 21 and port 0.4
Unfortunately, it is not a supported option for the nRF54L-series devices, as the node is deleted from the boards:
This is because the nrf54l has a GRTC, and not RTC peripheral.
I will make a feature request internally to support the nrf-sw-pwm driver.
Håkon
Hi
That is why I recreated the node with timer23 like this. The sw pwm does have support for using a timer.
pwm_sw0: pwm_sw0 {
compatible = "nordic,nrf-sw-pwm";
status = "okay";
generator = <&timer23>;
clock-prescaler = <0>;
#pwm-cells = <3>;
channel-gpios = <&gpio0 4 GPIO_ACTIVE_HIGH>;
I can confirm that this does not work, as the support is not present. The pin is not toggling as one would expect.
In ncs v3.0.0, this will even cause a compilation error due to missing hardware peripheral (RTC).
Unfortunately, this module needs several items before having support for nRF54L-series devices.
Håkon
