getaddrinfo error when porting "FOTA over Wi-Fi" exercise to nrf52840 + modem
I am trying to adapt lesson 9 (FOTA over Wi-Fi) exercise 7 of the DevAcademy nRF Connect SDK Intermediate course. I am trying to adapt it to work with nrf52840 connected to a simcom modem via UART. I managed to get it to boot but it fails at trying to resolve the DNS address.
See my changes here: https://github.com/olalonde/ncs-l9-e7/pull/1/files
It seems like the network connectivity goes up but when it is time of doing the dns request (getaddrinfo), the packet never makes it to the modem. If it did, we would see a CMUX log with some data after getaddrinfo is called, but it doesn't happen.
Full log: github.com/.../LOGS.txt
Relevant part:
[00:00:26.858,245] <inf> aws_iot_sample: Network connectivity established
[00:00:31.858,337] <inf> aws_iot_sample: Connecting to AWS IoT
[00:00:31.858,581] <dbg> mqtt_helper: broker_init: Resolving IP address for XXXX-ats.iot.us-east-2.amazonaws.com
[00:00:31.859,191] <dbg> net_l2_ppp: net_pkt_hexdump: send L2
[00:00:31.859,252] <dbg> net_l2_ppp: net_pkt_hexdump: 0x200314dc
                                     45 00 00 52 00 00 00 00  40 11 b9 69 64 7c 15 46 |E..R.... @..id|.F
                                     c8 58 7f 17 f3 b1 00 35  00 3e d5 aa 46 d9 01 00 |.X.....5 .>..F...
                                     00 01 00 00 00 00 00 00  08 78 78 78 78 2d 61 74 |........ .xxxx-at
                                     73 03 69 6f 74 09 75 73  2d 65 61 73 74 2d 32 09 |s.iot.us -east-2.
                                     61 6d 61 7a 6f 6e 61 77  73 03 63 6f 6d 00 00 01 |amazonaw s.com...
                                     00 01                                            |..
[00:00:36.959,472] <err> mqtt_helper: getaddrinfo() failed, error -11
[00:00:36.959,533] <dbg> mqtt_helper: mqtt_state_set: Skipping transition to the same state (MQTT_STATE_DISCONNECTED)
[00:00:36.959,564] <err> aws_iot: mqtt_helper_connect, error: 11
[00:00:36.959,564] <err> aws_iot_sample: aws_iot_connect, error: 11
I assume there is something wrong with my configuration?
I am new to Zephyr/embedded development but it's as if getaddrinfo was not communicating with the modem PPP driver at all?
I am able to successfully run the secure MQTT sample and cellular modem samples from Zephyr so I don't think it's an issue with the modem driver. I also tried increasing the DNS timeout but that doesn't help.
github.com/.../modem-port
  • I don't know if this helps but I tried setting the hostname to 8.8.8.8 to test and skip the DNS resolution and this is what it does:
    [00:00:28.145,690] <dbg> modem_cellular: modem_cellular_log_event: event registered
    [00:00:28.145,721] <dbg> modem_cellular: modem_cellular_log_event: event script success
    [00:00:29.259,094] <inf> aws_iot_sample: Connecting to AWS IoT
    [00:00:29.259,338] <dbg> mqtt_helper: broker_init: Resolving IP address for 8.8.8.8
    [00:00:29.259,490] <dbg> mqtt_helper: broker_init: IPv4 Address found 8.8.8.8 (AF_INET)
    [00:00:29.259,582] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_DISCONNECTED --> MQTT_STATE_TRANSPORT_CONNECTING
    [00:00:29.260,253] <dbg> net_mqtt_sock_tls: mqtt_client_tls_connect: (sysworkq): Created socket 2
    [00:00:29.261,138] <dbg> net_l2_ppp: net_pkt_hexdump: send L2
    [00:00:29.261,199] <dbg> net_l2_ppp: net_pkt_hexdump: 0x2003155c
                                         45 00 00 2c 00 00 00 00  40 06 94 19 0a 4c cc 57 |E..,.... @....L.W
                                         08 08 08 08 91 23 22 b3  03 42 91 6f 00 00 00 00 |.....#". .B.o....
                                         60 02 02 aa 66 41 00 00  02 04 05 b4             |`...fA.. ....
    [00:00:29.524,475] <dbg> net_l2_ppp: net_pkt_hexdump: send L2
    [00:00:29.524,536] <dbg> net_l2_ppp: net_pkt_hexdump: 0x2003159c
    [00:00:29.887,725] <wrn> net_tcp: net_pkt alloc failure
    [00:00:30.250,946] <wrn> net_tcp: net_pkt alloc failure
    [00:00:30.614,166] <wrn> net_tcp: net_pkt alloc failure
    [00:00:30.977,355] <wrn> net_tcp: net_pkt alloc failure
    [00:00:31.340,545] <wrn> net_tcp: net_pkt alloc failure
    [00:00:31.703,735] <wrn> net_tcp: net_pkt alloc failure
    [00:00:32.066,925] <wrn> net_tcp: net_pkt alloc failure
    [00:00:32.261,627] <err> mqtt_helper: mqtt_connect, error: -116
    [00:00:32.261,688] <dbg> mqtt_helper: mqtt_state_set: State transition: MQTT_STATE_TRANSPORT_CONNECTING --> MQTT_STATE_DISCONNECTED
    [00:00:32.261,688] <err> aws_iot: mqtt_helper_connect, error: -116
    [00:00:32.261,688] <err> aws_iot_sample: aws_iot_connect, error: -116
    [00:00:32.261,718] <err> aws_iot_sample: Fatal error! Rebooting the device.
    Also, I noticed in the build there are some warnings related to the MQTT helper library.
    https://github.com/olalonde/ncs-l9-e7/blob/modem-port/BUILD_LOGS.txt
    [378/459] Building C object modules/nrf/subsys/net/lib/mqtt_helper/CMakeFiles/..__nrf__subsys__net__lib__mqtt_helper.dir/mqtt_helper.c.obj
    In file included from /Users/redacted/code/alpha21/myproject/workspace/zephyr/include/zephyr/toolchain.h:50,
                     from /Users/redacted/code/alpha21/myproject/workspace/zephyr/include/zephyr/kernel_includes.h:23,
                     from /Users/redacted/code/alpha21/myproject/workspace/zephyr/include/zephyr/kernel.h:17,
                     from /Users/redacted/code/alpha21/myproject/workspace/zephyr/include/zephyr/net/socket.h:27,
                     from /Users/redacted/code/alpha21/myproject/workspace/nrf/subsys/net/lib/mqtt_helper/mqtt_helper.c:8:
    In function 'broker_init',
        inlined from 'client_connect' at /Users/redacted/code/alpha21/myproject/workspace/nrf/subsys/net/lib/mqtt_helper/mqtt_helper.c:457:8,
        inlined from 'mqtt_helper_connect' at /Users/redacted/code/alpha21/myproject/workspace/nrf/subsys/net/lib/mqtt_helper/mqtt_helper.c:598:8:
    /Users/redacted/code/alpha21/myproject/workspace/zephyr/include/zephyr/toolchain/gcc.h:157:18: warning: array subscript 'struct <anonymous>[0]' is partly outside array bounds of 'struct sockaddr_storage[1]' [-Warray-bounds]
      157 |         __p->__v = (v);                                                 \
    /Users/redacted/code/alpha21/myproject/workspace/zephyr/include/zephyr/net/net_ip.h:889:9: note: in expansion of macro 'UNALIGNED_PUT'
      889 |         UNALIGNED_PUT(UNALIGNED_GET(src), dest)
    /Users/redacted/code/alpha21/myproject/workspace/nrf/subsys/net/lib/mqtt_helper/mqtt_helper.c:408:25: note: in expansion of macro 'net_ipaddr_copy'
      408 |                         net_ipaddr_copy(&broker6->sin6_addr,
    /Users/redacted/code/alpha21/myproject/workspace/nrf/subsys/net/lib/mqtt_helper/mqtt_helper.c: In function 'mqtt_helper_connect':
    /Users/redacted/code/alpha21/myproject/workspace/nrf/subsys/net/lib/mqtt_helper/mqtt_helper.c:32:32: note: at offset 4 into object 'broker' of size 8
       32 | static struct sockaddr_storage broker;
    /Users/redacted/code/alpha21/myproject/workspace/nrf/subsys/net/lib/mqtt_helper/mqtt_helper.c:410:46: warning: array subscript 'struct sockaddr_in6[0]' is partly outside array bounds of 'struct sockaddr_storage[1]' [-Warray-bounds]
      410 |                         broker6->sin6_family = addr->ai_family;
    /Users/redacted/code/alpha21/myproject/workspace/nrf/subsys/net/lib/mqtt_helper/mqtt_helper.c:32:32: note: object 'broker' of size 8
    /Users/redacted/code/alpha21/myproject/workspace/nrf/subsys/net/lib/mqtt_helper/mqtt_helper.c:411:44: warning: array subscript 'struct sockaddr_in6[0]' is partly outside array bounds of 'struct sockaddr_storage[1]' [-Warray-bounds]
      411 |                         broker6->sin6_port = htons(CONFIG_MQTT_HELPER_PORT);
  • After some debugging, I think the issue might be related to the fact that src/main.c uses the system work queue to resolve the address but the modem ppp driver also uses the system work queue leading to a deadlock? It seems that `k_work_submit(&ppp->send_work);` in `modem_ppp_ppp_api_send()` from `modem_ppp.c` gets called but the work handler (`modem_ppp_send_handler`) never gets executed.
    edit: Yep, that was the issue. I modified main.c to use its own work queue instead of system queue and it fixed this problem.
