Problem executing simple program on Thingy91
I recently acquired a Thingy91 board in order to make a hardware prototype. I already have experience developing with the nRF52840 so I took inspiration from my working project.
First I flashed the straight out "Hello World" sample from the v2.9.0 SDK to the nRF9160 using a J-Link external probe and the "west flash" command with success. I could launch the program and read "Hello World" from a serial terminal.
Then I tried to create a basic setup project by copying what worked on my nRF52840 project. These basic functionalities includes:
_ Versionning
_ Using sysbuild with MCUBOOT
_ Signing firmware with an ECDSA 256 key.
The project successfully built and flashed, but unfortunately, didn't execute. No output can be read from the serial terminal anymore, not even the early logs from the bootloader.
What's a bit worrisome is that I can't manage to get back to a state where things worked. When I try to flash the basic "Hello World" sample again, the program doesn't launch anymore (no output on the serial terminal).
Any idea what could be going on and how to fix this ? I tried switching to the most recent v3.0.1 SDK but with no success.
I'm adding the .tar.gz of the project.
thingy_minimal.tar.gz
Here is my build configuration:
And the output when I flash:
Flashing build_prod to 801051622
west flash -d /home/abourgaud/repos/haugenplus_official/user-node/application/build_prod --dev-id 801051622
-- west flash: rebuilding
[0/6] Performing build step for 'application'
ninja: no work to do.
[1/6] Performing build step for 'mcuboot'
[3/6] Completed 'application'
[5/6] No install step for 'mcuboot'
[6/6] Completed 'mcuboot'
WARNING: Specifying runner options for multiple domains is experimental.
If problems are experienced, please specify a single domain using '--domain <domain>'
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: /home/abourgaud/repos/haugenplus_official/user-node/application/build_prod/mcuboot/zephyr/zephyr.hex
[ ######               ]   0.000s | Erase file - Check image                               [ ####                 ]   0.000s | Check image validity - Initialize device info          [ ########             ]   0.000s | Check image validity - Check region 0 settings         [ ############         ]   0.000s | Check image validity - block 1 of 3                    [ ################     ]   0.007s | Check image validity - block 2 of 3                    [ #################### ]   0.028s | Check image validity - Finished                        [ #############        ]   0.000s | Erase file - Erasing                                   [ ######               ]   0.000s | Erasing non-volatile memory - block 1 of 2             [ #############        ]   0.553s | Erasing non-volatile memory - block 2 of 2             [ #################### ]   0.000s | Erasing non-volatile memory - Erase successful         [ #################### ]   1.291s | Erase file - Done erasing
[ ######               ]   0.000s | Program file - Checking image                          [ ####                 ]   0.000s | Check image validity - Initialize device info          [ ########             ]   0.000s | Check image validity - Check region 0 settings         [ ############         ]   0.963s | Check image validity - block 1 of 3                    [ ################     ]   0.361s | Check image validity - block 2 of 3                    [ #################### ]   0.004s | Check image validity - Finished                        [ #############        ]   0.000s | Program file - Programming                             [ ######               ]   0.000s | Programming image - block 1 of 2                       [ #############        ]   0.147s | Programming image - block 2 of 2                       [ #################### ]   0.000s | Programming image - Write successful                   [ #################### ]   0.330s | Program file - Done programming
[ ######               ]   0.000s | Verify file - Check image                              [ ####                 ]   0.000s | Check image validity - Initialize device info          [ ########             ]   0.000s | Check image validity - Check region 0 settings         [ ############         ]   1.224s | Check image validity - block 1 of 3                    [ ################     ]   0.459s | Check image validity - block 2 of 3                    [ #################### ]   0.004s | Check image validity - Finished                        [ #############        ]   0.000s | Verify file - Verifying                                [ ######               ]   0.000s | Verifying image - block 1 of 2                         [ #############        ]   0.144s | Verifying image - block 2 of 2                         [ #################### ]   0.000s | Verifying image - Verify successful                    [ #################### ]   0.304s | Verify file - Done verifying
-- runners.nrfjprog: Board with serial number 801051622 flashed successfully.
-- runners.nrfjprog: reset after flashing requested
-- runners.nrfjprog: Flashing file: /home/abourgaud/repos/haugenplus_official/user-node/application/build_prod/application/zephyr/zephyr.signed.hex
[ ######               ]   0.000s | Erase file - Check image                               [ #####                ]   0.000s | Check image validity - Initialize device info          [ ##########           ]   0.000s | Check image validity - Check region 0 settings         [ ###############      ]   0.000s | Check image validity - block 1 of 2                    [ #################### ]   0.028s | Check image validity - Finished                        [ #############        ]   0.000s | Erase file - Erasing                                   [ ##########           ]   0.000s | Erasing non-volatile memory - block 1 of 1             [ #################### ]   0.000s | Erasing non-volatile memory - Erase successful         [ #################### ]   1.510s | Erase file - Done erasing
[ ######               ]   0.000s | Program file - Checking image                          [ #####                ]   0.000s | Check image validity - Initialize device info          [ ##########           ]   0.000s | Check image validity - Check region 0 settings         [ ###############      ]   0.531s | Check image validity - block 1 of 2                    [ #################### ]   0.002s | Check image validity - Finished                        [ #############        ]   0.000s | Program file - Programming                             [ ##########           ]   0.000s | Programming image - block 1 of 1                       [ #################### ]   0.000s | Programming image - Write successful                   [ #################### ]   0.402s | Program file - Done programming
[ ######               ]   0.000s | Verify file - Check image                              [ #####                ]   0.000s | Check image validity - Initialize device info          [ ##########           ]   0.000s | Check image validity - Check region 0 settings         [ ###############      ]   0.685s | Check image validity - block 1 of 2                    [ #################### ]   0.002s | Check image validity - Finished                        [ #############        ]   0.000s | Verify file - Verifying                                [ ##########           ]   0.000s | Verifying image - block 1 of 1                         [ #################### ]   0.000s | Verifying image - Verify successful                    [ #################### ]   0.402s | Verify file - Done verifying
Applying system reset.
Run.
Thank you for your time,
AdBee
  • Any update ?
    EDIT: With regard to my last question, I found out that the nrfxlib library is already compiled in the packaged v2.9.0 SDK (as "west list" reveals). The correct way to import it is to call #include <nrf_model_at.h>. I would suggest updating this doc and this one which are misleading about it.
  • Hello, my apologies for the late reply.
    Yes, I see what you man, which can be somewhat confusing. The best way is often to look at our samples in our SDK, but of course the documentation should reflect the code base. I will report internally.
    AdBee said:
    I am trying to interact with the LTE-M/GNSS module by using AT-commands.
    Have you successfully been able to send AT commands programmatically?
    AdBee said:
    Does the existence of the later file means that pm_static files are not used by default, but only if configs such as CONFIG_THINGY91_STATIC_PARTITIONS_FACTORY are provided ?
    The build system should pick up on the file automatically. Have a look at Configuring static partitions in the partition manager. This is a KConfig symbol defined in nrf/boards/nordic/thingy91/Kconfig
    config THINGY91_STATIC_PARTITIONS_FACTORY
    	bool "Factory Thingy:91 partition layout"
    	help
    	   The default Thingy:91 partition layout used in the factory firmware. This ensures
    	   firmware updates are compatible with Thingy:91 when flashing firmware over USB or over
    	   the air.
    Øyvind
  • Yes, I see what you man, which can be somewhat confusing. The best way is often to look at our samples in our SDK, but of course the documentation should reflect the code base. I will report internally.
    I don't think there is a sample to demonstrate this functionnality, or at least I didn't find it.
    Yes with the nrf_modem_at_printf() function and the correct include it appears to work.
    The only remaining question I have is about the absence of early logs. I assume it is because the hook that redirects outputs from the nRF9160 to the nRF52840 serial is set after some delay rather than at program start. Correct ?
    Thank you for your support,
    AdBee
    I have been trying to implement a custom static partition following your leads, but with no success.
    First I ran west build -t partition_manager_report with the default thingy/nrf9160/ns board:
      flash_primary (0x100000 - 1024kB):
    | 0x0: mcuboot (0xc000 - 48kB)                    |
    +---0xc000: mcuboot_primary (0x69000 - 420kB)-----+
    +---0xc000: tfm_secure (0xc000 - 48kB)------------+
    | 0xc000: mcuboot_pad (0x200 - 512B)              |
    +---0xc200: mcuboot_primary_app (0x68e00 - 419kB)-+
    | 0xc200: tfm (0xbe00 - 47kB)                     |
    | 0x18000: app (0x5d000 - 372kB)                  |
    +---0x18000: tfm_nonsecure (0x5b000 - 364kB)------+
    | 0x75000: mcuboot_secondary (0x69000 - 420kB)    |
    | 0xde000: mcuboot_scratch (0x1e000 - 120kB)      |
    | 0xfc000: EMPTY_0 (0x2000 - 8kB)                 |
    +---0xfe000: nonsecure_storage (0x2000 - 8kB)-----+
    | 0xfe000: settings_storage (0x2000 - 8kB)        |
      otp (0x2f4 - 756B):
    | 0xff8108: otp (0x2f4 - 756B) |
      sram_primary (0x40000 - 256kB):
    +---0x20000000: mcuboot_sram (0x8000 - 32kB)-------+
    +---0x20000000: sram_secure (0x8000 - 32kB)--------+
    | 0x20000000: tfm_sram (0x8000 - 32kB)             |
    +---0x20008000: sram_nonsecure (0x38000 - 224kB)---+
    +---0x20008000: nrf_modem_lib_sram (0x4568 - 17kB)-+
    | 0x20008000: nrf_modem_lib_ctrl (0x4e8 - 1kB)     |
    | 0x200084e8: nrf_modem_lib_tx (0x2080 - 8kB)      |
    | 0x2000a568: nrf_modem_lib_rx (0x2000 - 8kB)      |
    | 0x2000c568: sram_primary (0x33a98 - 206kB)       |
    So far so good.
    Then  tried to put a custom pm_static.yml file in my project directory, and following your doc I put
    CONFIG_THINGY91_NO_PREDEFINED_LAYOUT=y
    in my prj.conf file.
    Running again west build -t partition_manager_report, I found the exact same result than previously, meaning that my pm_static.yml file was not taken into account.
    I tried to move
    to my sysbuild/mcuboot.conf file with no greater success.
    I also added
    SB_CONFIG_PARTITION_MANAGER=y
    to my sysbuild.conf file which didn't help.
    Lastly, I tried to switch the board from thingy91/nrf9160/ns to thingy91/nrf9160 but at this point the project didn't even compile (the <nrf_modem.h> library that I referenced for AT commands was not found)
    What am I supposed to do ?
    Ty,
    AdBee
  • Hello AdBee,
    My apologies for the late reply.
    No, there is no specific sample for this, but if you look at the samples that are using e.g. nrf_modem_at_printf() they will show the correct way to include the files.
    This is due to the build system and how CMakeLists.txt work in the background, removing parts of the path when found in a "include" folder. That said, the documentation for the AT commands should show how to use the AT commands.
    Did you set CONFIG_THINGY91_STATIC_PARTITIONS_FACTORY=n along with CONFIG_THINGY91_NO_PREDEFINED_LAYOUT=y?
    Could you share your pm_static file?
