Problem executing simple program on Thingy91
I recently acquired a Thingy91 board in order to make a hardware prototype. I already have experience developing with the nRF52840 so I took inspiration from my working project.
First I flashed the straight out "Hello World" sample from the v2.9.0 SDK to the nRF9160 using a J-Link external probe and the "west flash" command with success. I could launch the program and read "Hello World" from a serial terminal.
Then I tried to create a basic setup project by copying what worked on my nRF52840 project. These basic functionalities includes:
_ Versionning
_ Using sysbuild with MCUBOOT
_ Signing firmware with an ECDSA 256 key.
The project successfully built and flashed, but unfortunately, didn't execute. No output can be read from the serial terminal anymore, not even the early logs from the bootloader.
What's a bit worrisome is that I can't manage to get back to a state where things worked. When I try to flash the basic "Hello World" sample again, the program doesn't launch anymore (no output on the serial terminal).
Any idea what could be going on and how to fix this ? I tried switching to the most recent v3.0.1 SDK but with no success.
I'm adding the .tar.gz of the project.
thingy_minimal.tar.gz
Here is my build configuration:
And the output when I flash:
Flashing build_prod to 801051622
west flash -d /home/abourgaud/repos/haugenplus_official/user-node/application/build_prod --dev-id 801051622
-- west flash: rebuilding
[0/6] Performing build step for 'application'
ninja: no work to do.
[1/6] Performing build step for 'mcuboot'
[3/6] Completed 'application'
[5/6] No install step for 'mcuboot'
[6/6] Completed 'mcuboot'
WARNING: Specifying runner options for multiple domains is experimental.
If problems are experienced, please specify a single domain using '--domain <domain>'
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: /home/abourgaud/repos/haugenplus_official/user-node/application/build_prod/mcuboot/zephyr/zephyr.hex
[ ######               ]   0.000s | Erase file - Check image                               [ ####                 ]   0.000s | Check image validity - Initialize device info          [ ########             ]   0.000s | Check image validity - Check region 0 settings         [ ############         ]   0.000s | Check image validity - block 1 of 3                    [ ################     ]   0.007s | Check image validity - block 2 of 3                    [ #################### ]   0.028s | Check image validity - Finished                        [ #############        ]   0.000s | Erase file - Erasing                                   [ ######               ]   0.000s | Erasing non-volatile memory - block 1 of 2             [ #############        ]   0.553s | Erasing non-volatile memory - block 2 of 2             [ #################### ]   0.000s | Erasing non-volatile memory - Erase successful         [ #################### ]   1.291s | Erase file - Done erasing
[ ######               ]   0.000s | Program file - Checking image                          [ ####                 ]   0.000s | Check image validity - Initialize device info          [ ########             ]   0.000s | Check image validity - Check region 0 settings         [ ############         ]   0.963s | Check image validity - block 1 of 3                    [ ################     ]   0.361s | Check image validity - block 2 of 3                    [ #################### ]   0.004s | Check image validity - Finished                        [ #############        ]   0.000s | Program file - Programming                             [ ######               ]   0.000s | Programming image - block 1 of 2                       [ #############        ]   0.147s | Programming image - block 2 of 2                       [ #################### ]   0.000s | Programming image - Write successful                   [ #################### ]   0.330s | Program file - Done programming
[ ######               ]   0.000s | Verify file - Check image                              [ ####                 ]   0.000s | Check image validity - Initialize device info          [ ########             ]   0.000s | Check image validity - Check region 0 settings         [ ############         ]   1.224s | Check image validity - block 1 of 3                    [ ################     ]   0.459s | Check image validity - block 2 of 3                    [ #################### ]   0.004s | Check image validity - Finished                        [ #############        ]   0.000s | Verify file - Verifying                                [ ######               ]   0.000s | Verifying image - block 1 of 2                         [ #############        ]   0.144s | Verifying image - block 2 of 2                         [ #################### ]   0.000s | Verifying image - Verify successful                    [ #################### ]   0.304s | Verify file - Done verifying
-- runners.nrfjprog: Board with serial number 801051622 flashed successfully.
-- runners.nrfjprog: reset after flashing requested
-- runners.nrfjprog: Flashing file: /home/abourgaud/repos/haugenplus_official/user-node/application/build_prod/application/zephyr/zephyr.signed.hex
[ ######               ]   0.000s | Erase file - Check image                               [ #####                ]   0.000s | Check image validity - Initialize device info          [ ##########           ]   0.000s | Check image validity - Check region 0 settings         [ ###############      ]   0.000s | Check image validity - block 1 of 2                    [ #################### ]   0.028s | Check image validity - Finished                        [ #############        ]   0.000s | Erase file - Erasing                                   [ ##########           ]   0.000s | Erasing non-volatile memory - block 1 of 1             [ #################### ]   0.000s | Erasing non-volatile memory - Erase successful         [ #################### ]   1.510s | Erase file - Done erasing
[ ######               ]   0.000s | Program file - Checking image                          [ #####                ]   0.000s | Check image validity - Initialize device info          [ ##########           ]   0.000s | Check image validity - Check region 0 settings         [ ###############      ]   0.531s | Check image validity - block 1 of 2                    [ #################### ]   0.002s | Check image validity - Finished                        [ #############        ]   0.000s | Program file - Programming                             [ ##########           ]   0.000s | Programming image - block 1 of 1                       [ #################### ]   0.000s | Programming image - Write successful                   [ #################### ]   0.402s | Program file - Done programming
[ ######               ]   0.000s | Verify file - Check image                              [ #####                ]   0.000s | Check image validity - Initialize device info          [ ##########           ]   0.000s | Check image validity - Check region 0 settings         [ ###############      ]   0.685s | Check image validity - block 1 of 2                    [ #################### ]   0.002s | Check image validity - Finished                        [ #############        ]   0.000s | Verify file - Verifying                                [ ##########           ]   0.000s | Verifying image - block 1 of 1                         [ #################### ]   0.000s | Verifying image - Verify successful                    [ #################### ]   0.402s | Verify file - Done verifying
Applying system reset.
Run.
Thank you for your time,
AdBee
    Did you set CONFIG_THINGY91_STATIC_PARTITIONS_FACTORY=n along with CONFIG_THINGY91_NO_PREDEFINED_LAYOUT=y?
    I didn't indeed. Doing this seems to have troubleshot the problem, thank you.
    Running  west build -t partition_manager_report gets me:
    flash_primary (0x100000 - 1024kB):
    | 0x0: mcuboot (0xc000 - 48kB)                    |
    +---0xc000: mcuboot_primary (0x69000 - 420kB)-----+
    +---0xc000: tfm_secure (0xc000 - 48kB)------------+
    | 0xc000: mcuboot_pad (0x200 - 512B)              |
    +---0xc200: mcuboot_primary_app (0x68e00 - 419kB)-+
    | 0xc200: tfm (0xbe00 - 47kB)                     |
    | 0x18000: app (0x5d000 - 372kB)                  |
    +---0x18000: tfm_nonsecure (0x5b000 - 364kB)------+
    | 0x75000: mcuboot_secondary (0x69000 - 420kB)    |
    | 0xde000: user_partition (0x1e000 - 120kB)       |
    | 0xfc000: EMPTY_0 (0x2000 - 8kB)                 |
    +---0xfe000: nonsecure_storage (0x2000 - 8kB)-----+
    | 0xfe000: settings_storage (0x2000 - 8kB)        |
      otp (0x2f4 - 756B):
    | 0xff8108: otp (0x2f4 - 756B) |
      sram_primary (0x40000 - 256kB):
    +---0x20000000: mcuboot_sram (0x8000 - 32kB)-------+
    +---0x20000000: sram_secure (0x8000 - 32kB)--------+
    | 0x20000000: tfm_sram (0x8000 - 32kB)             |
    +---0x20008000: sram_nonsecure (0x38000 - 224kB)---+
    +---0x20008000: nrf_modem_lib_sram (0x4568 - 17kB)-+
    | 0x20008000: nrf_modem_lib_ctrl (0x4e8 - 1kB)     |
    | 0x200084e8: nrf_modem_lib_tx (0x2080 - 8kB)      |
    | 0x2000a568: nrf_modem_lib_rx (0x2000 - 8kB)      |
    | 0x2000c568: sram_primary (0x33a98 - 206kB)       |
    At heart, I took the default partitions and added a custom one for NVS that I called "user_partition". Since a scratch partition for MCUBOOT shouldn't be absolutely needed depending on the FOTA swap policy, I decided to remove it to make room for "user_partition".
    I'm now getting this error at runtime when trying to mount the NVS partition:
    [00:00:00.391,296] <err> os: ***** SECURE FAULT *****
    [00:00:00.397,033] <err> os:   Address: 0xe0ff8
    [00:00:00.402,313] <err> os:   Attribution unit violation
    [00:00:00.408,477] <err> os: r0/a1:  0x20011518  r1/a2:  0x000e0ff8  r2/a3:  0x000e1000
    [00:00:00.417,236] <err> os: r3/a4:  0x20011517 r12/ip:  0x0001cad5 r14/lr:  0x0001cb23
    [00:00:00.425,994] <err> os:  xpsr:  0x81000000
    [00:00:00.431,274] <err> os: Faulting instruction address (r15/pc): 0x0002de86
    [00:00:00.439,239] <err> os: >>> ZEPHYR FATAL ERROR 41: Unknown error on CPU 0
    [00:00:00.447,204] <err> os: Current thread: 0x2000d318 (unknown)
    [00:00:00.454,040] <err> os: Halting system
    which is pretty explicit about me violating the NS and/or trusted Firmware setup. Since I'm not very familiar with the concept, I am currently going through the documentation to see how I could fix this.
    Have a good day.
  • I solved my problem by moving my "user_partition" to the "nonsecure_storage" sector. My partition now looks like this:
    | 0x18000: app (0x50000 - 320kB)                  |
    | 0x68000: nvs_storage (0x6000 - 24kB)            |
    | 0xde000: EMPTY_0 (0x2000 - 8kB)                 |
    +---0xe0000: nonsecure_storage (0x20000 - 128kB)--+
    | 0xe0000: user_partition (0x1e000 - 120kB)       |
      otp (0x2f4 - 756B):
    I am still a bit confused about some partitions though, could you explain them to me ?
    First I'd like to know why there is a "nvs_storage" partition which appeared in the tfm_nonsecure sector. I didn't explicitly requested this, and this is not the partition that is being mounted on my system (it is "user_partition" which works fine).
    Secondly I'd like to know what the EMPTY_0 partition is for. This partition is set by default in the partitions.pm file so I kept it in my custom pm_static.yml file, but I'd like to why it's there.
    Here is my pm_static.yml file:
    app: {address: 0x18000, size: 0x5b000}
    mcuboot:
      address: 0x0
      placement:
        before: [mcuboot_primary]
    mcuboot_pad:
      address: 0xc000
      placement:
        align: {start: 0x1000}
        before: [mcuboot_primary_app]
    mcuboot_primary:
      address: 0xc000
      span: [tfm, mcuboot_pad, app]
    mcuboot_primary_app:
      address: 0xc200
      span: [app, tfm]
    mcuboot_secondary:
      address: 0x75000
      placement:
        after: [mcuboot_primary]
      share_size: [mcuboot_primary]
    EMPTY_0:
      address: 0xde000
    user_partition:
      address: 0xe0000
      placement:
        after: [EMPTY_0]
    settings_storage:
      address: 0xfe000
      placement:
        after: [user_partition]
    nonsecure_storage:
      address: 0xe0000
      span: [user_partition, settings_storage]
    tfm_secure:
      address: 0xc000
      span: [mcuboot_pad, tfm]
    tfm_nonsecure:
      address: 0x18000
      span: [app]
    tfm:
      address: 0xc200
    mcuboot_sram:
      address: 0x20000000
      end_address: 0x20008000
      orig_span: &id001
      - tfm_sram
      region: sram_primary
      span: *id001
    sram_secure:
      address: 0x20000000
      orig_span: &id004
      - tfm_sram
      span: *id004
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
    sram_nonsecure:
      address: 0x20008000
      end_address: 0x20040000
      orig_span: &id003
      - sram_primary
      - nrf_modem_lib_ctrl
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id003
    nrf_modem_lib_sram:
      address: 0x20008000
      end_address: 0x2000c568
      orig_span: &id002
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id002
    nrf_modem_lib_ctrl:
      address: 0x20008000
      end_address: 0x200084e8
      inside:
      - sram_nonsecure
      placement:
        after:
        - tfm_sram
        - start
    nrf_modem_lib_tx:
      address: 0x200084e8
      end_address: 0x2000a568
      inside:
      - sram_nonsecure
      placement:
        after:
    nrf_modem_lib_rx:
      address: 0x2000a568
      inside:
      - sram_nonsecure
      placement:
        after:
        - nrf_modem_lib_tx
    sram_primary:
      address: 0x2000c568
    Relevant prj.conf configurations:
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    Thank you,
    AdBee
  • Hello, sorry for the delayed answer.
    I think looking at the Partition manager documentation and Building and configuring TF-M should provide some information on the misc. partitions, as most of this is handled in the build system and the partition manager script.
    There is no good explanation on what does empty_0 mean in pm_static? But from our Nordic Semiconductor AI it states:
    In the context of Nordic Semiconductor's nRF Connect SDK and Partition Manager, an EMPTY_0 partition in a pm_static.yml file (or in the generated partition map) represents an unallocated or unused region of flash memory. These "EMPTY" partitions are automatically created by the Partition Manager to fill gaps between other defined partitions, often due to alignment requirements or reserved space.
    Key points about EMPTY_0:
    • It is a placeholder for unused flash space.
    • Its presence is often due to alignment constraints (e.g., partitions needing to start at specific boundaries).
    • You can rename EMPTY_0 to something more descriptive (like app_data) if you want to use that space for your own data storage.
    • If you want to ensure this region remains available and does not move due to future configuration changes, you should lock down your memory layout by using a static partition configuration (pm_static.yml) copied from your build's partitions.yml file.
    • The address and size of EMPTY_0 can be found programmatically using symbols defined in pm_config.h (included with #include <pm_config.h>).
    For example, as explained by a Nordic engineer:
    You can also change the 'EMPTY_0' name in your pm_static file to a more descriptive name, such as 'app_data'. The size and address of this partition can be found programmatically using the symbols defined in pm_config.h (included with #include <pm_config.h>)
    Write user data to NVM
    And from the official documentation:
    There can only be one unoccupied gap per region.
    Configuring static partitions
    In summary, EMPTY_0 is simply a label for unused flash space, and you are free to repurpose it as needed in your application.
