Cannot get ANT+ BPWR TX to work on S332 og S212 7.0.1 SDK 17.1.0
I am currently making an upgrade og a nRF51422 project that has both BLE. and ANT+ Cycling Power profiles and if I run the old project on an 51822 processor I can see BPWR broadcast packages just fine on my Samsung Galaxy S9+ with the ANT+ Plugin sampler app
Now I am trying to get one of the SDK 17.1.0 examples for ANT+ to work on my NRF52832
So I get the ant_bpwr_tx S212 project up and running with the S212 softdevice installed and try and see if I get any packages in my ANT+ Plugin Sampler app like before
But I do not find any devices when I scan in the app
I have tried :::
S212 V7.0.1 / S332 V7.0.1 both with DEMO licence and actual commercial license
Both own hardware board and the nRF52 DK board
I have tried both ant_bpwr_tx and ant_bsc_tx examples and alså both for D52 and for PCA10040
Does any body have an idea of what I do wrong?
Using Segger Embedded Studio 8.22 for MacOS
    I can see you are using a much newer release of SES than tested on release, ref release notes:
    https://docs.nordicsemi.com/bundle/sdk_nrf5_v17.1.0/page/index.html
    The following toolchains/devices have been used for testing and verification:
     - ARM: MDK-ARM version 5.25
     - GCC: GCC ARM Embedded 9.2020-q2.major
     - IAR: IAR Workbench 7.80.4
     - SES: SES 5.42a
    Make sure you have also programmed the softdevice first, and that you for instance see the log message from main():
    NRF_LOG_INFO("ANT+ Bicycle Power TX example started.");
    And that you have follow the text at top of main.c:
    /**@file
     * @defgroup ant_bpwr_sensor_main ANT Bicycle Power sensor example
     * @ingroup nrf_ant_bicycle_power
     * @brief Example of ANT Bicycle Power profile display.
     * Before compiling this example for NRF52, complete the following steps:
     * - Download the S212 SoftDevice from <a href="https://www.thisisant.com/developer/components/nrf52832" target="_blank">thisisant.com</a>.
     * - Extract the downloaded zip file and copy the S212 SoftDevice headers to <tt>\<InstallFolder\>/components/softdevice/s212/headers</tt>.
     * If you are using Keil packs, copy the files into a @c headers folder in your example folder.
     * - Make sure that @ref ANT_LICENSE_KEY in @c nrf_sdm.h is uncommented.
    Kenneth
  • Hi Kenneth and thank you for your message
    I have loaded the cpu with the correct Softdevice - and even put it into the "LOAD0" option og SES that ensures to program SD as well
    I also followed the instructions in the top of main.c
    In the debug log I seems to transmit in intervals of like 500ms
    The BT LE implementation is compiled with the same compiler and works just fine - also all the other BT exanples.
    Just not getting the ANT+ examples to work - (headache)
    Do you have an ANT+ simulator (using a USB dongle) and/or can you try to transmit/received between two DK's for comparison? Just to verify that it works as intended.
    By default the nRF5 SDK was used for S212 v6.1.1, but I can't see that should make difference here as long as you have used the right header files for S212 v7.0.1.
    Kenneth
  • Yes I am using the correct header files - because I changed folder in the project so it points to the S332 softdevice. But I have also tried using the S212 softdevice
    But still cannot see any ANT+ packages on my Samsung Galaxy S9+
    The old board with implementation for nRF51422 works just fine and I can see everything in the ANT+ Sampler app
  • My recommendation is to use the same toolchain version as when the nRF5 SDK was released.
    Also for testing do setup two DK's for testing first or use an ANT+ simulator with an ANT dongle connected to a PC.
    Kenneth
