I am facing the following error. I have referered light switch example and have included all the required configs in the prj_fota.conf file
CONFIG_NCS_SAMPLES_DEFAULTS=y
Thank you in advance
This is the error i am getting
c:/ncs/toolchains/b620d30767/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: modules/nrf/subsys/zigbee/lib/zigbee_fota/lib..__nrf__subsys__zigbee__lib__zigbee_fota.a(dfu_multi_target.c.obj): in function `dfu_multi_target_init_default':
C:/ncs/v2.9.1/nrf/subsys/zigbee/lib/zigbee_fota/src/dfu_multi_target.c:187: undefined reference to `dfu_target_mcuboot_set_buf'
The issue is resolved. The CONFIG_BOOTLOADER_MCUBOOT was not being defined globally. So added the command to enable it globally from CMakeLists.txt
Could you please let me know which Nordic chip you're working with? Also, is this a custom board or a development kit?
I assume you're using nRF Connect SDK version v2.9.1, please correct me if that’s not the case.
I’m not quite sure what you mean by prj_fota.config based on the Light Switch sample. Additionally, I don't see any configuration on your end that enables MCUboot. You likely need to include CONFIG_BOOTLOADER_MCUBOOT to enable the bootloader.
I’d also appreciate it if you could share the complete build log.
Abhijith
Hello Mariya,
I saw your message after I replied. I'm glad to hear that your issue has been resolved.
Kind Regards,
Abhijith
Thank you,
