Moving nrf9161 app to sysbuild - help needed
I'd like to go for sysbuild with my nrf9161 based application but after some trials and errors, I am not able to find which images should be enabled in sysbuild.conf and what exactly should be done elsewhere.
Could you please help me (I am sorry, https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-8-sysbuild/  was not enough for my case :-/) ?
Here is my current non-sysbuild prj.conf (2.7.0), using TFM + modem:
# prj.conf
# Copyright (c) 2020 Nordic Semiconductor ASA
### wrk
### watchdog
CONFIG_WATCHDOG=y
CONFIG_WDT_LOG_LEVEL_INF=y # Or DBG for more verbose watchdog logs
### tune networking
CONFIG_NET_TCP_RETRY_COUNT=1
CONFIG_MQTT_KEEPALIVE=30
CONFIG_NET_TCP_ACK_TIMEOUT=100
### modem
CONFIG_AT_MONITOR=y
CONFIG_NRF_MODEM_LIB=y
# CONFIG_NRF_MODEM_LIB_ON_FAULT_RESET_MODEM=y
CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DBG=y
### LTE
CONFIG_LTE_NETWORK_MODE_LTE_M=y
CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT=n
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_PSM_REQ=n
CONFIG_LTE_EDRX_REQ=n
CONFIG_LTE_RAI_REQ=n
CONFIG_LTE_NETWORK_TIMEOUT=60
CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS=n
CONFIG_LTE_LOCK_BANDS=y
CONFIG_LTE_LOCK_BAND_MASK="10000000000000000000"
### (do not) reset on fatal error
CONFIG_RESET_ON_FATAL_ERROR=y
### debug optimizations (-Og)
CONFIG_DEBUG=y
CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_DEBUG_THREAD_INFO=y
CONFIG_NVS_LOG_LEVEL_DBG=y
## debug network timing
# CONFIG_NET_LOG=y
## debug MQTT timing (add both below)
# CONFIG_MQTT_LOG_LEVEL_DBG=y
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=3000
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
### coredump debug
# CONFIG_DEBUG_COREDUMP=y
# CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
### higher LOG buffer not to drop LOG messages
CONFIG_LOG_BUFFER_SIZE=2300
#CONFIG_LOG_MODE_DEFERRED=y
#CONFIG_LOG_PROCESS_THREAD=y
### debugging threads
CONFIG_THREAD_ANALYZER=n
CONFIG_THREAD_ANALYZER_AUTO=n
### trying to manage priorities
# CONFIG_SYSTEM_WORKQUEUE_PRIORITY=10
### Admin uart helpers
CONFIG_UART_2_NRF_HW_ASYNC=y
CONFIG_UART_2_NRF_HW_ASYNC_TIMER=1
### Networking
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NEWLIB_LIBC=y
CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=4096
CONFIG_NET_TCP=y
CONFIG_NET_IPV4=y
### Floating point support
CONFIG_CBPRINTF_FP_SUPPORT=y
#### logging
CONFIG_LOG_MODE_IMMEDIATE=n
CONFIG_LOG_RUNTIME_FILTERING=y
CONFIG_LOG=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=y
### CPU load
#CONFIG_CPU_LOAD=
#CONFIG_CPU_LOAD_LOG_PERIODIC=y
#CONFIG_CPU_LOAD_LOG_INTERVAL=1000
### SECURE TFM logging
### disabling logging of TF-M
# CONFIG_TFM_LOG_LEVEL_SILENCE=y
# try to increase MODEM library heap size:
# CONFIG_NRF_MODEM_LIB_HEAP_SIZE=4096
### forward TF-M secure logging to the same UART as application logging (comment the previous)
# CONFIG_TFM_SECURE_UART=y
# CONFIG_TFM_SECURE_UART_SHARE_INSTANCE=y
# CONFIG_TFM_SECURE_UART0=y
# CONFIG_TFM_PARTITION_LOG_LEVEL_DEBUG=y
# CONFIG_TFM_SPM_LOG_LEVEL_DEBUG=y
# Dump exception info. Must be combined with enabling log output.
# CONFIG_TFM_EXCEPTION_INFO_DUMP=y
# CONFIG_TFM_CRYPTO_KEY_DERIVATION_MODULE_ENABLED=y
### NVS
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_NVS=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_FLASH_MAP=y
CONFIG_REBOOT=y
# Enable snprintf float
### Possible solution for Fatal error:
# Don't use the minimal TF-M configuration as that doesn't support logging
CONFIG_TFM_PROFILE_TYPE_NOT_SET=y
### Memory
CONFIG_MAIN_STACK_SIZE=3000
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_ISR_STACK_SIZE=4096
### uart
CONFIG_UART_ASYNC_API=y
# ! the following must be done not to loosing RX characters: assigning timer 2 to RX processing:
CONFIG_UART_NRFX=y
CONFIG_UART_1_NRF_HW_ASYNC=y
CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
# dynamic uart configuration needed
CONFIG_UART_USE_RUNTIME_CONFIGURE=y
### MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_CLEAN_SESSION=y
### ADC
CONFIG_ADC=y
### I2C, IMU
CONFIG_I2C=y
CONFIG_I2C_CALLBACK=y
CONFIG_I2C_LOG_LEVEL_DBG=y
### others
CONFIG_CLOCK_CONTROL=y
CONFIG_AT_HOST_LIBRARY=y
Additionally, the full config is here:
# CONFIG_INPUT is not set
# CONFIG_WIFI is not set
# CONFIG_NET_L2_ETHERNET is not set
CONFIG_ADC_INIT_PRIORITY=50
# CONFIG_MIPI_DSI is not set
# CONFIG_MODEM is not set
# CONFIG_UART_INTERRUPT_DRIVEN is not set
CONFIG_NET_IPV6=y
# CONFIG_SPI is not set
CONFIG_BOARD="msdk1_nrf9161"
CONFIG_FLASH_LOAD_SIZE=0x35000
CONFIG_FLASH_LOAD_OFFSET=0x50000
CONFIG_I2C=y
CONFIG_SOC="nRF9161_LACA"
CONFIG_SOC_SERIES="nrf91"
CONFIG_NUM_IRQS=65
CONFIG_NRF_RTC_TIMER=y
CONFIG_LOG_DOMAIN_NAME=""
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
CONFIG_BUILD_OUTPUT_HEX=y
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
CONFIG_GPIO=y
# Devicetree Info
CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
CONFIG_DT_HAS_NORDIC_NRF91_FLASH_CONTROLLER_ENABLED=y
CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
CONFIG_DT_HAS_ZEPHYR_PSA_CRYPTO_RNG_ENABLED=y
# end of Devicetree Info
# Modules
# Available modules.
# nrf (C:/ncs/v2.7.0/nrf)
# CONFIG_MBOX is not set
CONFIG_NEWLIB_LIBC_NANO=y
CONFIG_NUM_METAIRQ_PRIORITIES=0
# CONFIG_INIT_STACKS is not set
CONFIG_NET_PKT_RX_COUNT=4
CONFIG_NET_PKT_TX_COUNT=4
# CONFIG_MBEDTLS_SSL_PROTO_DTLS is not set
# CONFIG_MBEDTLS_SSL_MAX_FRAGMENT_LENGTH is not set
# CONFIG_MBEDTLS_ENTROPY_C is not set
CONFIG_MBEDTLS_CIPHER_MODE_CBC=y
CONFIG_MBEDTLS_CIPHER_MODE_CTR=y
CONFIG_MBEDTLS_CIPHER_MODE_CFB=y
CONFIG_MBEDTLS_CIPHER_MODE_OFB=y
CONFIG_MBEDTLS_CHACHA20_C=y
CONFIG_MBEDTLS_POLY1305_C=y
CONFIG_MBEDTLS_CHACHAPOLY_C=y
CONFIG_MBEDTLS_DHM_C=y
# CONFIG_MBEDTLS_RSA_C is not set
CONFIG_MBEDTLS_SHA512_C=y
CONFIG_MBEDTLS_GCM_C=y
# CONFIG_MBEDTLS_CIPHER_MODE_XTS is not set
CONFIG_MBEDTLS_SSL_SRV_C=y
CONFIG_MBEDTLS_SSL_COOKIE_C=y
CONFIG_MBEDTLS_SSL_CLI_C=y
CONFIG_MBEDTLS_SSL_TLS_C=y
CONFIG_MBEDTLS_HEAP_SIZE=512
# CONFIG_NET_PKT_TXTIME is not set
# CONFIG_NET_PKT_TIMESTAMP is not set
CONFIG_MBEDTLS_PSA_KEY_SLOT_COUNT=32
CONFIG_IDLE_STACK_SIZE=320
CONFIG_MPSL_WORK_STACK_SIZE=1024
CONFIG_NET_RX_STACK_SIZE=1500
CONFIG_NET_TX_STACK_SIZE=1200
CONFIG_MBEDTLS_SHA1_C=y
CONFIG_MBEDTLS=y
# CONFIG_MBEDTLS_TLS_VERSION_1_2 is not set
CONFIG_MBEDTLS_MAC_SHA256_ENABLED=y
# CONFIG_MBEDTLS_CTR_DRBG_ENABLED is not set
CONFIG_MBEDTLS_MD_C=y
CONFIG_MBEDTLS_TLS_LIBRARY=y
CONFIG_MBEDTLS_X509_LIBRARY=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_ECP_C=y
# CONFIG_MBEDTLS_CTR_DRBG_C is not set
CONFIG_MBEDTLS_CMAC_C=y
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_PSA_CRYPTO_STORAGE_C=y
CONFIG_MBEDTLS_LEGACY_CRYPTO_C=y
CONFIG_TFM_CRYPTO_RNG_MODULE_ENABLED=y
CONFIG_TFM_PARTITION_CRYPTO=y
CONFIG_TFM_PARTITION_PLATFORM=y
# Nordic nRF Connect
CONFIG_ROM_START_OFFSET=0
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_GETOPT is not set
CONFIG_FLASH_BASE_ADDRESS=0x0
CONFIG_FLASH_SIZE=1024
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# Image build variants
# CONFIG_NCS_MCUBOOT_IN_BUILD is not set
# end of Image build variants
# Subsystems
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
# CONFIG_IS_SECURE_BOOTLOADER is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# CONFIG_SECURE_BOOT_STORAGE is not set
# end of Bootloader
# Bluetooth Low Energy
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# BLE over nRF RPC
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# CONFIG_DFU_MULTI_IMAGE is not set
# CONFIG_DFU_TARGET is not set
# end of DFU
# CONFIG_ESB is not set
# CONFIG_EMDS is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# CONFIG_PCD_APP is not set
CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
# CONFIG_PCD_NET is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# nRF Cloud
# Client ID (nRF Cloud Device ID)
CONFIG_NRF_CLOUD_CLIENT_ID_SRC_IMEI=y
# CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME is not set
CONFIG_NRF_CLOUD_CLIENT_ID_PREFIX="nrf-"
# end of Client ID (nRF Cloud Device ID)
# CONFIG_NRF_CLOUD_MQTT is not set
# CONFIG_NRF_CLOUD_FOTA is not set
CONFIG_FOTA_USE_NRF_CLOUD_SETTINGS_AREA=y
CONFIG_FOTA_DL_TIMEOUT_MIN=15
# CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
# CONFIG_NRF_CLOUD_REST is not set
# CONFIG_NRF_CLOUD_LOCATION_PARSE_ANCHORS is not set
# CONFIG_NRF_CLOUD_ALERT is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
# CONFIG_NRF_CLOUD_LOG_INCLUDE_LEVEL_0 is not set
CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
# CONFIG_NRF_CLOUD_COAP is not set
# Send shadow info sections on initial connect (MQTT/CoAP)
# end of Send shadow info sections on initial connect (MQTT/CoAP)
# CONFIG_NRF_CLOUD_GATEWAY is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
# CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_CLOUD_LOG_LEVEL=3
# end of nRF Cloud
# CONFIG_REST_CLIENT is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# CONFIG_WIFI_CREDENTIALS is not set
# CONFIG_WIFI_CREDENTIALS_STATIC is not set
# CONFIG_MQTT_HELPER is not set
# CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
# CONFIG_APP_EVENT_MANAGER is not set
# CONFIG_NRF_PROFILER is not set
# CONFIG_FW_INFO is not set
# Debug
# CONFIG_CPU_LOAD is not set
# CONFIG_ETB_TRACE is not set
# CONFIG_PPI_TRACE is not set
# end of Debug
# Multiprotocol service layer (MPSL)
# CONFIG_MPSL_FEM_ONLY is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
# CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_FEM_LOG_LEVEL=3
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# CONFIG_MPSL_LOG_LEVEL_OFF is not set
# CONFIG_MPSL_LOG_LEVEL_ERR is not set
# CONFIG_MPSL_LOG_LEVEL_WRN is not set
# CONFIG_MPSL_LOG_LEVEL_INF is not set
# CONFIG_MPSL_LOG_LEVEL_DBG is not set
CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
CONFIG_MPSL_LOG_LEVEL=3
# end of Multiprotocol service layer (MPSL)
# Partition Manager
CONFIG_PARTITION_MANAGER_ENABLED=y
CONFIG_FLASH_MAP_CUSTOM=y
CONFIG_SRAM_SIZE=128
CONFIG_SRAM_BASE_ADDRESS=0x20020000
# Zephyr subsystem configurations
CONFIG_PM_PARTITION_SIZE_NVS_STORAGE=0x6000
# end of Zephyr subsystem configurations
# NCS subsystem configurations
CONFIG_PM_SINGLE_IMAGE=y
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_PATH=""
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x40000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# Full Modem Firmware Update Management(FMFU)
# CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
# CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
CONFIG_MGMT_FMFU_LOG_LEVEL=3
# end of Full Modem Firmware Update Management(FMFU)
# SUIT-based Firmware Update Management
CONFIG_MGMT_SUITFU_TRIGGER_UPDATE_RESET_DELAY_MS=100
CONFIG_MGMT_SUITFU_AUTO_REGISTER_HANDLERS=y
CONFIG_MGMT_SUITFU_GRP_IMG=y
CONFIG_MGMT_SUITFU_IMAGE_NUMBER=0
# CONFIG_MGMT_SUITFU_GRP_SUIT is not set
# CONFIG_MGMT_SUITFU_LOG_LEVEL_OFF is not set
# CONFIG_MGMT_SUITFU_LOG_LEVEL_ERR is not set
# CONFIG_MGMT_SUITFU_LOG_LEVEL_WRN is not set
# CONFIG_MGMT_SUITFU_LOG_LEVEL_INF is not set
# CONFIG_MGMT_SUITFU_LOG_LEVEL_DBG is not set
CONFIG_MGMT_SUITFU_LOG_LEVEL_DEFAULT=y
CONFIG_MGMT_SUITFU_LOG_LEVEL=3
# end of SUIT-based Firmware Update Management
# CONFIG_CAF is not set
# Nordic IEEE 802.15.4
# end of Nordic IEEE 802.15.4
# CONFIG_DM_MODULE is not set
# nRF Security
CONFIG_NORDIC_SECURITY_BACKEND=y
CONFIG_NRF_SECURITY=y
CONFIG_MBEDTLS_CFG_FILE="nrf-config.h"
CONFIG_MBEDTLS_USER_CONFIG_FILE="nrf-config-user-empty.h"
CONFIG_MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-want-config.h"
CONFIG_MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-config.h"
CONFIG_GENERATE_MBEDTLS_CFG_FILE=y
CONFIG_MBEDTLS_X509_USE_C=y
# CONFIG_MBEDTLS_X509_CREATE_C is not set
CONFIG_MBEDTLS_X509_CHECK_KEY_USAGE=y
CONFIG_MBEDTLS_X509_CHECK_EXTENDED_KEY_USAGE=y
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
CONFIG_MBEDTLS_X509_CRT_PARSE_C=y
# CONFIG_MBEDTLS_X509_CSR_WRITE_C is not set
CONFIG_MBEDTLS_X509_REMOVE_INFO=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
CONFIG_MBEDTLS_SSL_ENCRYPT_THEN_MAC=y
CONFIG_MBEDTLS_SSL_EXTENDED_MASTER_SECRET=y
# CONFIG_MBEDTLS_DEBUG_C is not set
# CONFIG_MBEDTLS_MEMORY_DEBUG is not set
CONFIG_MBEDTLS_SSL_ALL_ALERT_MESSAGES=y
CONFIG_MBEDTLS_SSL_CONTEXT_SERIALIZATION=y
# CONFIG_MBEDTLS_SSL_DEBUG_ALL is not set
CONFIG_MBEDTLS_SSL_KEEP_PEER_CERTIFICATE=y
# CONFIG_MBEDTLS_SSL_RENEGOTIATION is not set
# CONFIG_MBEDTLS_SSL_SESSION_TICKETS is not set
# CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION is not set
# CONFIG_MBEDTLS_SSL_CACHE_C is not set
# CONFIG_MBEDTLS_SSL_TICKET_C is not set
CONFIG_MBEDTLS_SSL_EXPORT_KEYS=y
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=16380
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16380
CONFIG_MBEDTLS_SSL_CIPHERSUITES=""
# TLS/DTL Cipher Suites
CONFIG_MBEDTLS_HAS_CBC_CIPHERSUITE_REQUIREMENTS=y
CONFIG_MBEDTLS_HAS_GCM_CIPHERSUITE_REQUIREMENTS=y
CONFIG_MBEDTLS_HAS_CCM_CIPHERSUITE_REQUIREMENTS=y
CONFIG_MBEDTLS_HAS_CHACHAPOLY_CIPHERSUITE_REQUIREMENTS=y
CONFIG_MBEDTLS_HAS_CIPHER_MODE_CIPHERSUITE_REQUIREMENTS=y
CONFIG_MBEDTLS_HAS_ECDH_CIPHERSUITE_REQUIREMENTS=y
CONFIG_MBEDTLS_HAS_ECDSA_CIPHERSUITE_REQUIREMENTS=y
CONFIG_MBEDTLS_HAS_ECJPAKE_CIPHERSUITE_REQUIREMENTS=y
CONFIG_MBEDTLS_KEY_EXCHANGE_PSK_ENABLED=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED=y
# end of TLS/DTL Cipher Suites
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_MBEDTLS_PSA_CRYPTO_CLIENT=y
CONFIG_PSA_WANT_ALG_SHA_256=y
# PSA RNG support
CONFIG_PSA_WANT_GENERATE_RANDOM=y
CONFIG_PSA_WANT_ALG_CTR_DRBG=y
# CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
# end of PSA RNG support
# PSA key type support
CONFIG_PSA_HAS_KEY_SUPPORT=y
# CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
# CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
# CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
# CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
CONFIG_PSA_WANT_KEY_TYPE_AES=y
# CONFIG_PSA_WANT_KEY_TYPE_ARIA is not set
# CONFIG_PSA_WANT_KEY_TYPE_DES is not set
# CONFIG_PSA_WANT_KEY_TYPE_CAMELLIA is not set
# CONFIG_PSA_WANT_KEY_TYPE_SM4 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ARC4 is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR_GENERATE is not set
# CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_KEY_PAIR is not set
# CONFIG_PSA_WANT_KEY_TYPE_SPAKE2P_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_IMPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_EXPORT is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR_DERIVE is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_PUBLIC_KEY is not set
# CONFIG_PSA_WANT_KEY_TYPE_SRP_KEY_PAIR is not set
# end of PSA key type support
# PSA AEAD support
CONFIG_PSA_HAS_AEAD_SUPPORT=y
CONFIG_PSA_WANT_ALG_CCM=y
# CONFIG_PSA_WANT_ALG_GCM is not set
# CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
# end of PSA AEAD support
# PSA MAC support
CONFIG_PSA_HAS_MAC_SUPPORT=y
# CONFIG_PSA_WANT_ALG_CBC_MAC is not set
# CONFIG_PSA_WANT_ALG_CMAC is not set
CONFIG_PSA_WANT_ALG_HMAC=y
# end of PSA MAC support
# PSA Hash support
CONFIG_PSA_HAS_HASH_SUPPORT=y
# CONFIG_PSA_WANT_ALG_SHA_1 is not set
CONFIG_PSA_WANT_ALG_SHA_224=y
# CONFIG_PSA_WANT_ALG_SHA_384 is not set
# CONFIG_PSA_WANT_ALG_SHA_512 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_224 is not set
# CONFIG_PSA_WANT_ALG_SHA_512_256 is not set
# CONFIG_PSA_WANT_ALG_SHA3_224 is not set
# CONFIG_PSA_WANT_ALG_SHA3_256 is not set
# CONFIG_PSA_WANT_ALG_SHA3_384 is not set
# CONFIG_PSA_WANT_ALG_SHA3_512 is not set
# CONFIG_PSA_WANT_ALG_SM3 is not set
# CONFIG_PSA_WANT_ALG_SHAKE256_512 is not set
# CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
# CONFIG_PSA_WANT_ALG_MD2 is not set
# CONFIG_PSA_WANT_ALG_MD4 is not set
# CONFIG_PSA_WANT_ALG_MD5 is not set
# end of PSA Hash support
# PSA Cipher support
# CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
# CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
# CONFIG_PSA_WANT_ALG_CFB is not set
# CONFIG_PSA_WANT_ALG_CTR is not set
# CONFIG_PSA_WANT_ALG_OFB is not set
# CONFIG_PSA_WANT_ALG_XTS is not set
# CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
# CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
# end of PSA Cipher support
# PSA Key agreement support
# CONFIG_PSA_WANT_ALG_ECDH is not set
# CONFIG_PSA_WANT_ALG_FFDH is not set
# end of PSA Key agreement support
# PSA Key derivation support
CONFIG_PSA_HAS_KEY_DERIVATION=y
CONFIG_PSA_WANT_ALG_HKDF=y
# CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
# CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
# CONFIG_PSA_WANT_ALG_PBKDF2_HMAC is not set
# CONFIG_PSA_WANT_ALG_SP800_108_COUNTER_HMAC is not set
CONFIG_PSA_WANT_ALG_TLS12_PRF=y
CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS=y
# CONFIG_PSA_WANT_ALG_TLS12_ECJPAKE_TO_PMS is not set
# end of PSA Key derivation support
# PSA Asymmetric support
# CONFIG_PSA_WANT_ALG_ECDSA is not set
# CONFIG_PSA_WANT_ALG_ECDSA_ANY is not set
# CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
# Elliptic Curve type support
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_160 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_192 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_224 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_256 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_320 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_384 is not set
# CONFIG_PSA_WANT_ECC_BRAINPOOL_P_R1_512 is not set
# CONFIG_PSA_WANT_ECC_MONTGOMERY_255 is not set
# CONFIG_PSA_WANT_ECC_MONTGOMERY_448 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_255 is not set
# CONFIG_PSA_WANT_ECC_TWISTED_EDWARDS_448 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_192 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_K1_256 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_192 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_224 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_256 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_384 is not set
# CONFIG_PSA_WANT_ECC_SECP_R1_521 is not set
# CONFIG_PSA_WANT_ECC_SECP_R2_160 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_239 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_K1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_163 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_233 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_283 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_409 is not set
# CONFIG_PSA_WANT_ECC_SECT_R1_571 is not set
# CONFIG_PSA_WANT_ECC_SECT_R2_163 is not set
# CONFIG_PSA_WANT_ECC_FRP_V1_256 is not set
# end of Elliptic Curve type support
# CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
# CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN_RAW is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS is not set
# CONFIG_PSA_WANT_ALG_RSA_PSS_ANY_SALT is not set
# end of PSA Asymmetric support
# CONFIG_PSA_WANT_ALG_JPAKE is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_HMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_CMAC is not set
# CONFIG_PSA_WANT_ALG_SPAKE2P_MATTER is not set
# CONFIG_PSA_WANT_ALG_SRP_6 is not set
# CONFIG_PSA_WANT_ALG_SRP_PASSWORD_HASH is not set
# CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
# CONFIG_PSA_WANT_ALG_ED25519PH is not set
# CONFIG_PSA_WANT_ALG_ED448PH is not set
CONFIG_PSA_CORE_OBERON=y
# PSA Driver Support
CONFIG_MBEDTLS_PSA_CRYPTO_DRIVERS=y
CONFIG_PSA_CRYPTO_DRIVER_OBERON=y
# CONFIG_PSA_CRYPTO_DRIVER_CC3XX is not set
# Choose DRBG algorithm
CONFIG_PSA_USE_CTR_DRBG_DRIVER=y
# end of Choose DRBG algorithm
# CryptoCell PSA Driver Configuration
CONFIG_PSA_USE_CC3XX_CTR_DRBG_DRIVER=y
# end of CryptoCell PSA Driver Configuration
# CRACEN PSA Driver Configuration
# end of CRACEN PSA Driver Configuration
# AES key size configuration
CONFIG_PSA_WANT_AES_KEY_SIZE_128=y
CONFIG_PSA_WANT_AES_KEY_SIZE_192=y
CONFIG_PSA_WANT_AES_KEY_SIZE_256=y
# end of AES key size configuration
# RSA key size configuration
# CONFIG_PSA_WANT_RSA_KEY_SIZE_1024 is not set
# CONFIG_PSA_WANT_RSA_KEY_SIZE_1536 is not set
# CONFIG_PSA_WANT_RSA_KEY_SIZE_2048 is not set
# CONFIG_PSA_WANT_RSA_KEY_SIZE_3072 is not set
# CONFIG_PSA_WANT_RSA_KEY_SIZE_4096 is not set
# CONFIG_PSA_WANT_RSA_KEY_SIZE_6144 is not set
# CONFIG_PSA_WANT_RSA_KEY_SIZE_8192 is not set
CONFIG_PSA_MAX_RSA_KEY_BITS=0
# end of RSA key size configuration
CONFIG_PSA_ACCEL_GENERATE_RANDOM=y
CONFIG_PSA_NEED_CC3XX_CTR_DRBG_DRIVER=y
# CONFIG_CRACEN_LOG_LEVEL_OFF is not set
# CONFIG_CRACEN_LOG_LEVEL_ERR is not set
# CONFIG_CRACEN_LOG_LEVEL_WRN is not set
# CONFIG_CRACEN_LOG_LEVEL_INF is not set
# CONFIG_CRACEN_LOG_LEVEL_DBG is not set
CONFIG_CRACEN_LOG_LEVEL_DEFAULT=y
CONFIG_CRACEN_LOG_LEVEL=3
CONFIG_PSA_NEED_OBERON_CCM_AES=y
CONFIG_PSA_NEED_OBERON_AEAD_DRIVER=y
CONFIG_PSA_NEED_OBERON_SHA_224=y
CONFIG_PSA_NEED_OBERON_SHA_256=y
CONFIG_PSA_NEED_OBERON_HASH_DRIVER=y
CONFIG_PSA_NEED_OBERON_HMAC=y
CONFIG_PSA_NEED_OBERON_MAC_DRIVER=y
CONFIG_PSA_NEED_OBERON_HKDF=y
CONFIG_PSA_NEED_OBERON_TLS12_PRF=y
CONFIG_PSA_NEED_OBERON_TLS12_PSK_TO_MS=y
CONFIG_PSA_NEED_OBERON_KEY_DERIVATION_DRIVER=y
# PSA API support
# CONFIG_MBEDTLS_USE_PSA_CRYPTO is not set
# end of PSA API support
CONFIG_MBEDTLS_PLATFORM_MEMORY=y
CONFIG_MBEDTLS_PLATFORM_C=y
CONFIG_MBEDTLS_MEMORY_C=y
CONFIG_MBEDTLS_MEMORY_BUFFER_ALLOC_C=y
CONFIG_MBEDTLS_ENTROPY_HARDWARE_ALT=y
CONFIG_MBEDTLS_AES_SETKEY_ENC_ALT=y
CONFIG_MBEDTLS_AES_SETKEY_DEC_ALT=y
CONFIG_MBEDTLS_AES_ENCRYPT_ALT=y
CONFIG_MBEDTLS_AES_DECRYPT_ALT=y
CONFIG_MBEDTLS_CHACHA20_ALT=y
CONFIG_MBEDTLS_POLY1305_ALT=y
CONFIG_MBEDTLS_ECDH_GEN_PUBLIC_ALT=y
CONFIG_MBEDTLS_ECDH_COMPUTE_SHARED_ALT=y
CONFIG_MBEDTLS_ECDSA_GENKEY_ALT=y
CONFIG_MBEDTLS_ECDSA_SIGN_ALT=y
CONFIG_MBEDTLS_ECDSA_VERIFY_ALT=y
CONFIG_MBEDTLS_ECJPAKE_ALT=y
CONFIG_MBEDTLS_SHA1_ALT=y
CONFIG_MBEDTLS_SHA224_ALT=y
CONFIG_MBEDTLS_SHA256_ALT=y
CONFIG_MBEDTLS_ENTROPY_FORCE_SHA256=y
CONFIG_MBEDTLS_ENTROPY_MAX_SOURCES=1
CONFIG_MBEDTLS_NO_PLATFORM_ENTROPY=y
# CONFIG_NRF_SECURITY_ADVANCED is not set
CONFIG_OBERON_ONLY_PSA_ENABLED=y
CONFIG_OBERON_ONLY_ENABLED=y
# Legacy mbed TLS crypto APIs
CONFIG_MBEDTLS_MPI_WINDOW_SIZE=6
CONFIG_MBEDTLS_MPI_MAX_SIZE=256
# CONFIG_CC3XX_BACKEND is not set
CONFIG_OBERON_BACKEND=y
CONFIG_MBEDTLS_CTR_DRBG_USE_128_BIT_KEY=y
CONFIG_MBEDTLS_HMAC_DRBG_C=y
CONFIG_MBEDTLS_AES_C=y
# Cipher Selection
# CBC cipher padding modes
CONFIG_MBEDTLS_CIPHER_PADDING_PKCS7=y
CONFIG_MBEDTLS_CIPHER_PADDING_ONE_AND_ZEROS=y
CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS_AND_LEN=y
CONFIG_MBEDTLS_CIPHER_PADDING_ZEROS=y
# end of CBC cipher padding modes
# CONFIG_MBEDTLS_AES_ONLY_128_BIT_KEY_LENGTH is not set
# AEAD  - Authenticated Encryption with Associated Data
# end of AEAD  - Authenticated Encryption with Associated Data
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_ECDSA_C=y
CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=y
CONFIG_MBEDTLS_ECJPAKE_C=y
# ECC curves
# CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED is not set
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
# end of ECC curves
CONFIG_MBEDTLS_HKDF_C=y
# SHA - Secure Hash Algorithm
CONFIG_MBEDTLS_MD5_C=y
CONFIG_MBEDTLS_SHA224_C=y
CONFIG_MBEDTLS_SHA256_C=y
CONFIG_MBEDTLS_SHA384_C=y
# end of SHA - Secure Hash Algorithm
CONFIG_MBEDTLS_CIPHER_C=y
CONFIG_MBEDTLS_PK_C=y
CONFIG_MBEDTLS_PKCS5_C=y
# CONFIG_MBEDTLS_PK_WRITE_C is not set
CONFIG_MBEDTLS_PK_PARSE_C=y
CONFIG_MBEDTLS_PK_PARSE_EC_EXTENDED=y
# end of Legacy mbed TLS crypto APIs
# Zephyr legacy configurations
# CONFIG_MBEDTLS_DTLS is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_SOME_PSK_ENABLED is not set
# CONFIG_MBEDTLS_ECP_ALL_ENABLED is not set
# CONFIG_MBEDTLS_CIPHER_ALL_ENABLED is not set
# CONFIG_MBEDTLS_MAC_ALL_ENABLED is not set
# CONFIG_MBEDTLS_MAC_MD5_ENABLED is not set
# CONFIG_MBEDTLS_HMAC_DRBG_ENABLED is not set
# CONFIG_MBEDTLS_CIPHER is not set
# CONFIG_MBEDTLS_MD is not set
# CONFIG_MBEDTLS_ENTROPY_ENABLED is not set
# CONFIG_MBEDTLS_GENPRIME_ENABLED is not set
# end of Zephyr legacy configurations
CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
# end of nRF Security
# Audio Module
# CONFIG_AUDIO_MODULE_TEST is not set
CONFIG_AUDIO_MODULE_NAME_SIZE=20
# CONFIG_AUDIO_MODULE_LOG_LEVEL_OFF is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_ERR is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_WRN is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_INF is not set
# CONFIG_AUDIO_MODULE_LOG_LEVEL_DBG is not set
CONFIG_AUDIO_MODULE_LOG_LEVEL_DEFAULT=y
CONFIG_AUDIO_MODULE_LOG_LEVEL=3
# end of Audio Module
# CONFIG_UART_ASYNC_ADAPTER is not set
# SUIT provisioning
# CONFIG_SUIT_MPI_GENERATE is not set
# end of SUIT provisioning
# CONFIG_SUIT is not set
# CONFIG_MBEDTLS_ZEPHYR_ENTROPY is not set
# end of Subsystems
# CONFIG_WPA_SUPP is not set
CONFIG_NET_TCP_ISN_RFC6528=y
CONFIG_POSIX_MAX_FDS=4
CONFIG_NET_SOCKETS_POLL_MAX=3
# CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
# CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
# CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
# CONFIG_WFA_QT_LOG_LEVEL_INF is not set
# CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
CONFIG_WFA_QT_LOG_LEVEL=3
# CONFIG_WFA_QT_CONTROL_APP is not set
CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
CONFIG_WFA_QT_REBOOT_TIMEOUT_MS=1000
CONFIG_WFA_QT_DEFAULT_INTERFACE="nordic_wlan0"
CONFIG_WPAS_READY_TIMEOUT_MS=10000
# Libraries
# Binary libraries
# end of Binary libraries
# Memory configuration
CONFIG_NRF_MODEM_LIB_HEAP_SIZE=1024
CONFIG_NRF_MODEM_LIB_SHMEM_CTRL_SIZE=0x4e8
CONFIG_NRF_MODEM_LIB_SHMEM_TX_SIZE=8320
CONFIG_NRF_MODEM_LIB_SHMEM_RX_SIZE=8192
CONFIG_NRF_MODEM_LIB_SHMEM_TRACE_SIZE=0
CONFIG_NRF_MODEM_LIB_SENDMSG_BUF_SIZE=128
# CONFIG_NRF_MODEM_LIB_MEM_DIAG is not set
# end of Memory configuration
# CONFIG_NRF_MODEM_LIB_TRACE is not set
CONFIG_NRF_MODEM_LIB_ON_FAULT_DO_NOTHING=y
# CONFIG_NRF_MODEM_LIB_ON_FAULT_RESET_MODEM is not set
# CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC is not set
CONFIG_NRF_MODEM_LIB_CFUN_HOOKS=y
# CONFIG_NRF_MODEM_LIB_FAULT_STRERROR is not set
# Shell
# CONFIG_NRF_MODEM_LIB_SHELL_TRACE is not set
# end of Shell
CONFIG_NRF_MODEM_LIB_IPC_IRQ_PRIO=1
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_OFF is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_ERR is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_WRN is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_INF is not set
# CONFIG_NRF_MODEM_LIB_LOG_LEVEL_DEFAULT is not set
CONFIG_NRF_MODEM_LIB_LOG_LEVEL=4
# CONFIG_NRF_MODEM_LIB_LOG_FW_VERSION_UUID is not set
CONFIG_AT_MONITOR=y
CONFIG_AT_MONITOR_HEAP_SIZE=256
# CONFIG_AT_MONITOR_LOG_LEVEL_OFF is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_ERR is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_WRN is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_INF is not set
# CONFIG_AT_MONITOR_LOG_LEVEL_DBG is not set
CONFIG_AT_MONITOR_LOG_LEVEL_DEFAULT=y
CONFIG_AT_MONITOR_LOG_LEVEL=3
CONFIG_LTE_PLMN_SELECTION_OPTIMIZATION=y
# CONFIG_LTE_LOCK_PLMN is not set
# CONFIG_LTE_UNLOCK_PLMN is not set
# CONFIG_LTE_PSM_REQ is not set
CONFIG_LTE_PSM_REQ_FORMAT_STRING=y
# CONFIG_LTE_PSM_REQ_FORMAT_SECONDS is not set
CONFIG_LTE_PSM_REQ_RPTAU="00000011"
CONFIG_LTE_PSM_REQ_RAT="00100001"
CONFIG_LTE_PSM_REQ_RPTAU_SECONDS=1800
CONFIG_LTE_PSM_REQ_RAT_SECONDS=60
# CONFIG_LTE_PROPRIETARY_PSM_REQ is not set
# CONFIG_LTE_EDRX_REQ is not set
CONFIG_LTE_EDRX_REQ_VALUE_LTE_M="1001"
CONFIG_LTE_EDRX_REQ_VALUE_NBIOT="1001"
CONFIG_LTE_PTW_VALUE_LTE_M=""
CONFIG_LTE_PTW_VALUE_NBIOT=""
# CONFIG_LTE_NETWORK_MODE_DEFAULT is not set
# CONFIG_LTE_NETWORK_MODE_LTE_M_GPS is not set
# CONFIG_LTE_NETWORK_MODE_NBIOT is not set
# CONFIG_LTE_NETWORK_MODE_NBIOT_GPS is not set
# CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT is not set
# CONFIG_LTE_NETWORK_MODE_LTE_M_NBIOT_GPS is not set
CONFIG_LTE_MODE_PREFERENCE_AUTO=y
CONFIG_LTE_MODE_PREFERENCE_VALUE=0
# CONFIG_LTE_RAI_REQ is not set
# CONFIG_LTE_NETWORK_USE_FALLBACK is not set
# CONFIG_LTE_LC_TAU_PRE_WARNING_NOTIFICATIONS is not set
CONFIG_LTE_LC_TAU_PRE_WARNING_TIME_MS=5000
CONFIG_LTE_LC_TAU_PRE_WARNING_THRESHOLD_MS=1200000
CONFIG_LTE_NEIGHBOR_CELLS_MAX=10
# CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS is not set
CONFIG_LTE_LC_MODEM_SLEEP_PRE_WARNING_TIME_MS=5000
CONFIG_LTE_LC_MODEM_SLEEP_NOTIFICATIONS_THRESHOLD_MS=1200000
# CONFIG_LTE_LC_TRACE is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_WRN is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_INF is not set
# CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DEFAULT=y
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL=3
CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x8000
CONFIG_FPROTECT_BLOCK_SIZE=0x8000
# CONFIG_FPROTECT is not set
# CONFIG_AT_CMD_CUSTOM is not set
CONFIG_AT_HOST_UART_INIT_TIMEOUT=500
# CONFIG_NULL_TERMINATION is not set
CONFIG_CR_TERMINATION=y
# CONFIG_LF_TERMINATION is not set
# CONFIG_CR_LF_TERMINATION is not set
CONFIG_AT_HOST_TERMINATION=1
CONFIG_AT_HOST_CMD_MAX_LEN=4096
CONFIG_AT_HOST_THREAD_PRIO=10
CONFIG_AT_HOST_STACK_SIZE=1024
# CONFIG_AT_HOST_LOG_LEVEL_OFF is not set
# CONFIG_AT_HOST_LOG_LEVEL_ERR is not set
# CONFIG_AT_HOST_LOG_LEVEL_WRN is not set
# CONFIG_AT_HOST_LOG_LEVEL_INF is not set
# CONFIG_AT_HOST_LOG_LEVEL_DBG is not set
CONFIG_AT_HOST_LOG_LEVEL_DEFAULT=y
CONFIG_AT_HOST_LOG_LEVEL=3
# CONFIG_DK_LIBRARY is not set
CONFIG_AT_CMD_PARSER=y
# CONFIG_MODEM_BATTERY is not set
# CONFIG_MODEM_INFO is not set
# CONFIG_PDN is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_OFF is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_ERR is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_WRN is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_INF is not set
# CONFIG_FATAL_ERROR_LOG_LEVEL_DBG is not set
CONFIG_FATAL_ERROR_LOG_LEVEL_DEFAULT=y
CONFIG_FATAL_ERROR_LOG_LEVEL=3
# CONFIG_SMS is not set
# CONFIG_GCF_SMS is not set
# CONFIG_MODEM_KEY_MGMT is not set
# CONFIG_SUPL_CLIENT_LIB is not set
# CONFIG_DATE_TIME is not set
# CONFIG_HW_ID_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_SUPPORTED=y
CONFIG_HW_UNIQUE_KEY=y
CONFIG_HW_UNIQUE_KEY_RANDOM=y
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
# CONFIG_MODEM_JWT is not set
# CONFIG_MODEM_ATTEST_TOKEN is not set
# CONFIG_LOCATION is not set
# CONFIG_MODEM_ANTENNA is not set
# CONFIG_QOS is not set
# CONFIG_SFLOAT is not set
# CONFIG_CONTIN_ARRAY is not set
# CONFIG_PCM_MIX is not set
# CONFIG_TONE is not set
# CONFIG_PSCM is not set
# CONFIG_DATA_FIFO is not set
# CONFIG_FEM_AL_LIB is not set
# CONFIG_SAMPLE_RATE_CONVERTER is not set
CONFIG_NCS_BOOT_BANNER=y
CONFIG_NCS_NCS_BOOT_BANNER_STRING="nRF Connect SDK"
CONFIG_NCS_ZEPHYR_BOOT_BANNER_STRING="Zephyr OS"
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# CONFIG_NRF_SW_LPUART is not set
CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
CONFIG_NET_TC_TX_COUNT=0
CONFIG_NET_INTERFACE_NAME_LEN=8
# CONFIG_FLASH_RPC is not set
# end of Device Drivers
# External libraries
# end of External libraries
# Test
CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
# CONFIG_UNITY is not set
# Mocks
# CONFIG_MOCK_NRF_MODEM_AT is not set
# end of Mocks
# end of Test
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (C:/ncs/v2.7.0/nrf)
# mcuboot (C:/ncs/v2.7.0/bootloader/mcuboot)
# MCUboot
CONFIG_BOOT_SIGNATURE_KEY_FILE=""
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
# CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (C:/ncs/v2.7.0/bootloader/mcuboot)
# mbedtls (C:/ncs/v2.7.0/modules/crypto/mbedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
# PSA RNG support
# PSA AEAD support
# PSA MAC support
# PSA Hash support
# CONFIG_MBEDTLS_LIBRARY is not set
CONFIG_DISABLE_MBEDTLS_BUILTIN=y
# CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
# CONFIG_MBEDTLS_LOG_LEVEL_OFF is not set
# CONFIG_MBEDTLS_LOG_LEVEL_ERR is not set
# CONFIG_MBEDTLS_LOG_LEVEL_WRN is not set
# CONFIG_MBEDTLS_LOG_LEVEL_INF is not set
# CONFIG_MBEDTLS_LOG_LEVEL_DBG is not set
CONFIG_MBEDTLS_LOG_LEVEL_DEFAULT=y
CONFIG_MBEDTLS_LOG_LEVEL=3
# CONFIG_MBEDTLS_DEBUG is not set
CONFIG_MBEDTLS_INIT=y
# CONFIG_MBEDTLS_ZEROIZE_ALT is not set
CONFIG_APP_LINK_WITH_MBEDTLS=y
# end of mbedtls (C:/ncs/v2.7.0/modules/crypto/mbedtls)
# oberon-psa-crypto (C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
# end of oberon-psa-crypto (C:/ncs/v2.7.0/modules/crypto/oberon-psa-crypto)
# trusted-firmware-m (C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
CONFIG_TFM_BOARD="C:/ncs/v2.7.0/nrf/modules/trusted-firmware-m/tfm_boards/nrf9120"
CONFIG_TFM_ISOLATION_LEVEL=1
# CONFIG_TFM_DUMMY_PROVISIONING is not set
# CONFIG_TFM_REGRESSION_NS is not set
# CONFIG_TFM_LOG_LEVEL_SILENCE is not set
CONFIG_TFM_QCBOR_PATH="C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m/../qcbor"
CONFIG_TFM_PARTITION_PROTECTED_STORAGE=y
# CONFIG_TFM_ITS_ENCRYPTED is not set
# CONFIG_BOOTLOADER_MCUBOOT is not set
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
CONFIG_BUILD_WITH_TFM=y
CONFIG_TFM_KEY_FILE_S="C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072.pem"
CONFIG_TFM_KEY_FILE_NS="C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m/bl2/ext/mcuboot/root-RSA-3072_1.pem"
# CONFIG_TFM_PROFILE_TYPE_SMALL is not set
# CONFIG_TFM_PROFILE_TYPE_MEDIUM is not set
# CONFIG_TFM_PROFILE_TYPE_AROTLESS is not set
# CONFIG_TFM_PROFILE_TYPE_LARGE is not set
# CONFIG_TFM_CMAKE_BUILD_TYPE_RELEASE is not set
# CONFIG_TFM_CMAKE_BUILD_TYPE_RELWITHDEBINFO is not set
# CONFIG_TFM_CMAKE_BUILD_TYPE_MINSIZEREL is not set
CONFIG_TFM_CMAKE_BUILD_TYPE_DEBUG=y
# CONFIG_TFM_ITS_NUM_ASSETS_OVERRIDE is not set
CONFIG_TFM_ITS_NUM_ASSETS=10
# CONFIG_TFM_ITS_MAX_ASSET_SIZE_OVERRIDE is not set
CONFIG_TFM_ITS_MAX_ASSET_SIZE=512
CONFIG_TFM_PARTITION_PLATFORM_CUSTOM_REBOOT=y
CONFIG_TFM_BL2_NOT_SUPPORTED=y
CONFIG_TFM_IMAGE_VERSION_S="0.0.0+0"
CONFIG_TFM_IMAGE_VERSION_NS="0.0.0+0"
# CONFIG_TFM_USE_NS_APP is not set
# CONFIG_TFM_CONNECTION_BASED_SERVICE_API is not set
CONFIG_TFM_IPC=y
# CONFIG_TFM_SFN is not set
# CONFIG_TFM_REGRESSION_S is not set
# CONFIG_TFM_PSA_TEST_PROTECTED_STORAGE is not set
# CONFIG_TFM_PSA_TEST_INTERNAL_TRUSTED_STORAGE is not set
# CONFIG_TFM_PSA_TEST_STORAGE is not set
CONFIG_TFM_PSA_TEST_NONE=y
CONFIG_TFM_FLASH_MERGED_BINARY=y
# CONFIG_TFM_SPM_LOG_LEVEL_DEBUG is not set
CONFIG_TFM_SPM_LOG_LEVEL_INFO=y
# CONFIG_TFM_SPM_LOG_LEVEL_ERROR is not set
# CONFIG_TFM_SPM_LOG_LEVEL_SILENCE is not set
CONFIG_TFM_PARTITION_INTERNAL_TRUSTED_STORAGE=y
# CONFIG_TFM_PARTITION_FIRMWARE_UPDATE is not set
# CONFIG_TFM_PARTITION_LOG_LEVEL_DEBUG is not set
CONFIG_TFM_PARTITION_LOG_LEVEL_INFO=y
# CONFIG_TFM_PARTITION_LOG_LEVEL_ERROR is not set
# CONFIG_TFM_PARTITION_LOG_LEVEL_SILENCE is not set
CONFIG_TFM_CRYPTO_KEY_MODULE_ENABLED=y
CONFIG_TFM_CRYPTO_AEAD_MODULE_ENABLED=y
CONFIG_TFM_CRYPTO_MAC_MODULE_ENABLED=y
CONFIG_TFM_CRYPTO_HASH_MODULE_ENABLED=y
# Platform partition component configs
CONFIG_TFM_PLATFORM_SERVICE_INPUT_BUFFER_SIZE=64
CONFIG_TFM_PLATFORM_SERVICE_OUTPUT_BUFFER_SIZE=64
CONFIG_TFM_PLATFORM_SP_STACK_SIZE=0x500
# CONFIG_TFM_PLATFORM_NV_COUNTER_MODULE_DISABLED is not set
# end of Platform partition component configs
# Crypto component configs
# CONFIG_TFM_CRYPTO_SINGLE_PART_FUNCS_DISABLED is not set
CONFIG_TFM_CRYPTO_BUILTIN_KEYS=y
CONFIG_TFM_CRYPTO_ENGINE_BUF_SIZE=8320
CONFIG_TFM_CRYPTO_CONC_OPER_NUM=8
CONFIG_TFM_CRYPTO_IOVEC_BUFFER_SIZE=5120
CONFIG_TFM_CRYPTO_PARTITION_STACK_SIZE=0x2000
# end of Crypto component configs
# ITS component configs
CONFIG_TFM_ITS_CREATE_FLASH_LAYOUT=y
# CONFIG_TFM_ITS_RAM_FS is not set
CONFIG_TFM_ITS_VALIDATE_METADATA_FROM_FLASH=y
CONFIG_TFM_ITS_BUF_SIZE=512
CONFIG_TFM_ITS_STACK_SIZE=0x720
# end of ITS component configs
# PS component configs
CONFIG_TFM_PS_CREATE_FLASH_LAYOUT=y
# CONFIG_TFM_PS_RAM_FS is not set
CONFIG_TFM_PS_ROLLBACK_PROTECTION=y
CONFIG_TFM_PS_VALIDATE_METADATA_FROM_FLASH=y
CONFIG_TFM_PS_MAX_ASSET_SIZE=2048
CONFIG_TFM_PS_NUM_ASSETS=10
CONFIG_TFM_PS_STACK_SIZE=0x700
# end of PS component configs
# TF-M SPM component configs
CONFIG_TFM_CONN_HANDLE_MAX_NUM=8
# CONFIG_TFM_DOORBELL_API is not set
# end of TF-M SPM component configs
# TF-M memory regions
CONFIG_PM_PARTITION_SIZE_TFM_SRAM=0x16000
CONFIG_PM_PARTITION_SIZE_TFM=0x50000
CONFIG_PM_PARTITION_SIZE_TFM_PROTECTED_STORAGE=0x4000
CONFIG_PM_PARTITION_SIZE_TFM_INTERNAL_TRUSTED_STORAGE=0x2000
CONFIG_PM_PARTITION_SIZE_TFM_OTP_NV_COUNTERS=0x2000
CONFIG_PM_PARTITION_TFM_STORAGE=y
# end of TF-M memory regions
# Peripheral Secure mapping
# CONFIG_NRF_FPU_SECURE is not set
# CONFIG_NRF_REGULATORS_SECURE is not set
# CONFIG_NRF_CLOCK_SECURE is not set
# CONFIG_NRF_POWER_SECURE is not set
# CONFIG_NRF_SPIM0_SECURE is not set
# CONFIG_NRF_TWIM0_SECURE is not set
# CONFIG_NRF_UARTE0_SECURE is not set
# CONFIG_NRF_SPIM1_SECURE is not set
# CONFIG_NRF_TWIM1_SECURE is not set
CONFIG_NRF_UARTE1_SECURE=y
# CONFIG_NRF_SPIM2_SECURE is not set
# CONFIG_NRF_TWIM2_SECURE is not set
# CONFIG_NRF_UARTE2_SECURE is not set
# CONFIG_NRF_SPIM3_SECURE is not set
# CONFIG_NRF_TWIM3_SECURE is not set
# CONFIG_NRF_UARTE3_SECURE is not set
# CONFIG_NRF_SAADC_SECURE is not set
# CONFIG_NRF_TIMER0_SECURE is not set
# CONFIG_NRF_TIMER1_SECURE is not set
# CONFIG_NRF_TIMER2_SECURE is not set
# CONFIG_NRF_RTC0_SECURE is not set
# CONFIG_NRF_RTC1_SECURE is not set
# CONFIG_NRF_DPPI_SECURE is not set
# CONFIG_NRF_WDT0_SECURE is not set
# CONFIG_NRF_EGU0_SECURE is not set
# CONFIG_NRF_EGU1_SECURE is not set
# CONFIG_NRF_EGU2_SECURE is not set
# CONFIG_NRF_EGU3_SECURE is not set
# CONFIG_NRF_EGU4_SECURE is not set
# CONFIG_NRF_EGU5_SECURE is not set
# CONFIG_NRF_PWM0_SECURE is not set
# CONFIG_NRF_PWM1_SECURE is not set
# CONFIG_NRF_PWM2_SECURE is not set
# CONFIG_NRF_PWM3_SECURE is not set
# CONFIG_NRF_PDM_SECURE is not set
# CONFIG_NRF_I2S_SECURE is not set
# CONFIG_NRF_IPC_SECURE is not set
# CONFIG_NRF_NVMC_SECURE is not set
# CONFIG_NRF_GPIO0_SECURE is not set
# CONFIG_NRF_GPIOTE0_SECURE is not set
CONFIG_NRF_GPIO0_PIN_MASK_SECURE=0x00000000
CONFIG_NRF_DPPI_CHANNEL_MASK_SECURE=0x00000000
CONFIG_NRF_VMC_SECURE=y
# end of Peripheral Secure mapping
# CONFIG_TFM_PROFILE_TYPE_MINIMAL is not set
# CONFIG_TFM_SECURE_UART0 is not set
CONFIG_TFM_SECURE_UART1=y
CONFIG_TFM_EXPERIMENTAL=y
# CONFIG_TFM_HW_INIT_RESET_ON_BOOT is not set
# CONFIG_TFM_HALT_ON_CORE_PANIC is not set
CONFIG_TFM_ALLOW_NON_SECURE_RESET=y
CONFIG_TFM_ALLOW_NON_SECURE_FAULT_HANDLING=y
CONFIG_TFM_S_CODE_VECTOR_TABLE_SIZE=0x144
# CONFIG_TFM_NRF_PROVISIONING is not set
# CONFIG_TFM_PSA_FRAMEWORK_HAS_MM_IOVEC is not set
# end of trusted-firmware-m (C:/ncs/v2.7.0/modules/tee/tf-m/trusted-firmware-m)
CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
CONFIG_ZEPHYR_SOC_HWMV1_MODULE=y
# cjson (C:/ncs/v2.7.0/modules/lib/cjson)
# CONFIG_CJSON_LIB is not set
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (C:/ncs/v2.7.0/modules/lib/cjson)
# azure-sdk-for-c (C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
# CONFIG_AZURE_SDK is not set
CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
# end of azure-sdk-for-c (C:/ncs/v2.7.0/modules/lib/azure-sdk-for-c)
# cirrus-logic (C:/ncs/v2.7.0/modules/hal/cirrus-logic)
# CONFIG_HW_CODEC_CIRRUS_LOGIC is not set
CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
# end of cirrus-logic (C:/ncs/v2.7.0/modules/hal/cirrus-logic)
# openthread (C:/ncs/v2.7.0/modules/lib/openthread)
# CONFIG_OPENTHREAD is not set
CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
# end of openthread (C:/ncs/v2.7.0/modules/lib/openthread)
# suit-generator (C:/ncs/v2.7.0/modules/lib/suit-generator)
CONFIG_SUIT_ENVELOPE_TEMPLATE=""
CONFIG_SUIT_ENVELOPE_TARGET=""
CONFIG_SUIT_ENVELOPE_OUTPUT_ARTIFACT="merged.hex"
CONFIG_SUIT_ENVELOPE_OUTPUT_MPI_MERGE=y
# CONFIG_SUIT_LOCAL_ENVELOPE_GENERATE is not set
CONFIG_ZEPHYR_SUIT_GENERATOR_MODULE=y
# end of suit-generator (C:/ncs/v2.7.0/modules/lib/suit-generator)
# suit-processor (C:/ncs/v2.7.0/modules/lib/suit-processor)
# CONFIG_SUIT_PROCESSOR is not set
CONFIG_SUIT_PLATFORM_DRY_RUN_SUPPORT=y
CONFIG_ZEPHYR_SUIT_PROCESSOR_MODULE=y
# end of suit-processor (C:/ncs/v2.7.0/modules/lib/suit-processor)
# memfault-firmware-sdk (C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (C:/ncs/v2.7.0/modules/lib/memfault-firmware-sdk)
# coremark (C:/ncs/v2.7.0/modules/benchmark/coremark)
# CONFIG_COREMARK is not set
CONFIG_ZEPHYR_COREMARK_MODULE=y
# end of coremark (C:/ncs/v2.7.0/modules/benchmark/coremark)
# canopennode (C:/ncs/v2.7.0/modules/lib/canopennode)
CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
# end of canopennode (C:/ncs/v2.7.0/modules/lib/canopennode)
# chre (C:/ncs/v2.7.0/modules/lib/chre)
CONFIG_ZEPHYR_CHRE_MODULE=y
# CONFIG_CHRE is not set
# end of chre (C:/ncs/v2.7.0/modules/lib/chre)
# lz4 (C:/ncs/v2.7.0/modules/lib/lz4)
CONFIG_ZEPHYR_LZ4_MODULE=y
# CONFIG_LZ4 is not set
# end of lz4 (C:/ncs/v2.7.0/modules/lib/lz4)
# nanopb (C:/ncs/v2.7.0/modules/lib/nanopb)
CONFIG_ZEPHYR_NANOPB_MODULE=y
# CONFIG_NANOPB is not set
# end of nanopb (C:/ncs/v2.7.0/modules/lib/nanopb)
CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
# zscilib (C:/ncs/v2.7.0/modules/lib/zscilib)
# CONFIG_ZSL is not set
CONFIG_ZEPHYR_ZSCILIB_MODULE=y
# end of zscilib (C:/ncs/v2.7.0/modules/lib/zscilib)
# cmsis (C:/ncs/v2.7.0/modules/hal/cmsis)
CONFIG_ZEPHYR_CMSIS_MODULE=y
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_CMSIS_M_CHECK_DEVICE_DEFINES is not set
# end of cmsis (C:/ncs/v2.7.0/modules/hal/cmsis)
# cmsis-dsp (C:/ncs/v2.7.0/modules/lib/cmsis-dsp)
CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
# CONFIG_CMSIS_DSP is not set
# end of cmsis-dsp (C:/ncs/v2.7.0/modules/lib/cmsis-dsp)
# cmsis-nn (C:/ncs/v2.7.0/modules/lib/cmsis-nn)
CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
# CONFIG_CMSIS_NN is not set
# end of cmsis-nn (C:/ncs/v2.7.0/modules/lib/cmsis-nn)
# fatfs (C:/ncs/v2.7.0/modules/fs/fatfs)
CONFIG_ZEPHYR_FATFS_MODULE=y
# end of fatfs (C:/ncs/v2.7.0/modules/fs/fatfs)
# hal_nordic (C:/ncs/v2.7.0/modules/hal/nordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
CONFIG_HAS_NRFX=y
# nrfx drivers
# nrfx drivers logging
# CONFIG_NRFX_CLOCK_LOG is not set
# CONFIG_NRFX_DPPI_LOG is not set
# CONFIG_NRFX_GPIOTE_LOG is not set
# CONFIG_NRFX_IPC_LOG is not set
# CONFIG_NRFX_NVMC_LOG is not set
# CONFIG_NRFX_TIMER_LOG is not set
# CONFIG_NRFX_TWIM_LOG is not set
# CONFIG_NRFX_WDT_LOG is not set
# end of nrfx drivers logging
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
CONFIG_NRFX_DPPI=y
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
CONFIG_NRFX_GPIOTE1=y
# CONFIG_NRFX_I2S0 is not set
CONFIG_NRFX_IPC=y
CONFIG_NRFX_NVMC=y
# CONFIG_NRFX_PDM is not set
# CONFIG_NRFX_POWER is not set
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_PWM3 is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM2 is not set
# CONFIG_NRFX_SPIM3 is not set
# CONFIG_NRFX_SYSTICK is not set
CONFIG_NRFX_TIMER=y
# CONFIG_NRFX_TIMER0 is not set
CONFIG_NRFX_TIMER1=y
CONFIG_NRFX_TIMER2=y
CONFIG_NRFX_TWIM=y
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_TWIM1 is not set
# CONFIG_NRFX_TWIM2 is not set
CONFIG_NRFX_TWIM3=y
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_UARTE1 is not set
# CONFIG_NRFX_UARTE2 is not set
# CONFIG_NRFX_UARTE3 is not set
CONFIG_NRFX_WDT=y
CONFIG_NRFX_WDT0=y
# Peripheral Resource Sharing module
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of Peripheral Resource Sharing module
# end of hal_nordic (C:/ncs/v2.7.0/modules/hal/nordic)
# hal_st (C:/ncs/v2.7.0/modules/hal/st)
CONFIG_ZEPHYR_HAL_ST_MODULE=y
# end of hal_st (C:/ncs/v2.7.0/modules/hal/st)
CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
CONFIG_ZEPHYR_LIBMETAL_MODULE=y
# liblc3 (C:/ncs/v2.7.0/modules/lib/liblc3)
CONFIG_ZEPHYR_LIBLC3_MODULE=y
# end of liblc3 (C:/ncs/v2.7.0/modules/lib/liblc3)
# littlefs (C:/ncs/v2.7.0/modules/fs/littlefs)
CONFIG_ZEPHYR_LITTLEFS_MODULE=y
# end of littlefs (C:/ncs/v2.7.0/modules/fs/littlefs)
# loramac-node (C:/ncs/v2.7.0/modules/lib/loramac-node)
CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# end of loramac-node (C:/ncs/v2.7.0/modules/lib/loramac-node)
# lvgl (C:/ncs/v2.7.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_LVGL_MODULE=y
# end of lvgl (C:/ncs/v2.7.0/modules/lib/gui/lvgl)
CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
# picolibc (C:/ncs/v2.7.0/modules/lib/picolibc)
# CONFIG_PICOLIBC_MODULE is not set
CONFIG_ZEPHYR_PICOLIBC_MODULE=y
# end of picolibc (C:/ncs/v2.7.0/modules/lib/picolibc)
# segger (C:/ncs/v2.7.0/modules/debug/segger)
CONFIG_ZEPHYR_SEGGER_MODULE=y
CONFIG_HAS_SEGGER_RTT=y
CONFIG_SEGGER_RTT_CUSTOM_LOCKING=y
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
CONFIG_SEGGER_RTT_MODE=0
# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
CONFIG_SEGGER_RTT_SECTION_NONE=y
# CONFIG_SEGGER_RTT_SECTION_DTCM is not set
# CONFIG_SEGGER_RTT_SECTION_CCM is not set
# end of segger (C:/ncs/v2.7.0/modules/debug/segger)
CONFIG_ZEPHYR_TINYCRYPT_MODULE=y
# uoscore-uedhoc (C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
# end of uoscore-uedhoc (C:/ncs/v2.7.0/modules/lib/uoscore-uedhoc)
# zcbor (C:/ncs/v2.7.0/modules/lib/zcbor)
CONFIG_ZEPHYR_ZCBOR_MODULE=y
# CONFIG_ZCBOR is not set
# end of zcbor (C:/ncs/v2.7.0/modules/lib/zcbor)
# nrfxlib (C:/ncs/v2.7.0/nrfxlib)
# Nordic nrfxlib
# nrf_modem (Modem library)
CONFIG_NRF_MODEM=y
CONFIG_NRF_MODEM_LINK_BINARY_CELLULAR=y
# CONFIG_NRF_MODEM_LINK_BINARY_DECT_PHY is not set
# CONFIG_NRF_MODEM_LOG is not set
# end of nrf_modem (Modem library)
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# Crypto libraries for nRF5x SOCs.
CONFIG_HAS_HW_NRF_CC3XX=y
CONFIG_NRF_OBERON=y
# end of Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# CONFIG_NRF_DM is not set
# CONFIG_NRF_FUEL_GAUGE is not set
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (C:/ncs/v2.7.0/nrfxlib)
# connectedhomeip (C:/ncs/v2.7.0/modules/lib/matter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (C:/ncs/v2.7.0/modules/lib/matter)
# CONFIG_LIBMETAL is not set
# CONFIG_LVGL is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_HAS_MPFS_HAL is not set
# CONFIG_HAS_MEC5_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_HAS_TELINK_DRIVERS is not set
# CONFIG_TINYCRYPT is not set
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# CONFIG_WIFI_NM_WPA_SUPPLICANT is not set
# Unavailable modules, please install those via the project manifest.
# hal_gigadevice module not available.
# Trusted-firmware-a module not available.
# THRIFT module not available.
# CONFIG_ACPI is not set
# end of Modules
CONFIG_BOARD_REVISION="0.9.0"
CONFIG_BOARD_TARGET="[email protected]"
# CONFIG_NET_DRIVERS is not set
# CONFIG_BOARD_MSDK1_NRF9161 is not set
CONFIG_BOARD_MSDK1_NRF9161_NS=y
# Board Options
# end of Board Options
# CONFIG_SOC_SERIES_NRF51X is not set
# CONFIG_SOC_SERIES_NRF52X is not set
# CONFIG_SOC_SERIES_NRF53X is not set
CONFIG_SOC_SERIES_NRF91X=y
CONFIG_NRF_SPU_FLASH_REGION_ALIGNMENT=0x8000
CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
CONFIG_NRF_SPU_RAM_REGION_ALIGNMENT=0x2000
# Hardware Configuration
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NORDIC_NRF=y
CONFIG_SOC_FAMILY_NRF=y
CONFIG_HAS_HW_NRF_CC310=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_DPPIC=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIOTE1=y
CONFIG_HAS_HW_NRF_IPC=y
CONFIG_HAS_HW_NRF_KMU=y
CONFIG_HAS_HW_NRF_NVMC_PE=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_REGULATORS=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_TWIM3=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_UARTE1=y
CONFIG_HAS_HW_NRF_UARTE2=y
CONFIG_HAS_HW_NRF_VMC=y
CONFIG_HAS_HW_NRF_WDT0=y
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
CONFIG_SOC_NRF9120=y
# CONFIG_SOC_NRF9160_SICA is not set
CONFIG_SOC_NRF9161_LACA=y
# CONFIG_SOC_NRF9131_LACA is not set
# CONFIG_SOC_NRF9151_LACA is not set
CONFIG_NRF_SOC_SECURE_SUPPORTED=y
CONFIG_TFM_NRF_NS_STORAGE=y
CONFIG_NRF_APPROTECT_USE_UICR=y
# CONFIG_NRF_APPROTECT_LOCK is not set
# CONFIG_NRF_APPROTECT_USER_HANDLING is not set
# CONFIG_NRF_TRACE_PORT is not set
# CONFIG_SOC_LOG_LEVEL_OFF is not set
# CONFIG_SOC_LOG_LEVEL_ERR is not set
# CONFIG_SOC_LOG_LEVEL_WRN is not set
# CONFIG_SOC_LOG_LEVEL_INF is not set
# CONFIG_SOC_LOG_LEVEL_DBG is not set
CONFIG_SOC_LOG_LEVEL_DEFAULT=y
CONFIG_SOC_LOG_LEVEL=3
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
# ARM Options
CONFIG_ARCH="arm"
CONFIG_CPU_CORTEX=y
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
CONFIG_CPU_CORTEX_M=y
# CONFIG_ARM_ZIMAGE_HEADER is not set
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_FAULT_DUMP=2
CONFIG_BUILTIN_STACK_GUARD=y
CONFIG_ARM_STACK_PROTECTION=y
CONFIG_ARM_NONSECURE_FIRMWARE=y
CONFIG_ARM_NONSECURE_PREEMPTIBLE_SECURE_CALLS=y
CONFIG_ARM_STORE_EXC_RETURN=y
CONFIG_FP16=y
CONFIG_FP16_IEEE=y
# CONFIG_FP16_ALT is not set
CONFIG_CPU_CORTEX_M33=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_DCACHE_LINE_SIZE=32
CONFIG_ICACHE_LINE_SIZE=32
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_CPU_CORTEX_M_HAS_CMSE=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_MAINLINE=y
CONFIG_ARMV8_M_SE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
CONFIG_ARMV8_M_DSP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_GEN_ISR_TABLES=y
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
# CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
# CONFIG_TRAP_UNALIGNED_ACCESS is not set
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33/M55 options
CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
CONFIG_ARM_TRUSTZONE_M=y
# ARM TrustZone-M Options
# Non-secure firmware
# CONFIG_ARM_FIRMWARE_USES_SECURE_ENTRY_FUNCS is not set
# end of ARM TrustZone-M Options
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_STACK_GUARD is not set
# CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
CONFIG_CPU_HAS_ARM_MPU=y
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
CONFIG_CPU_HAS_NRF_IDAU=y
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_SEMIHOST is not set
# CONFIG_ARCH_LOG_LEVEL_OFF is not set
# CONFIG_ARCH_LOG_LEVEL_ERR is not set
# CONFIG_ARCH_LOG_LEVEL_WRN is not set
# CONFIG_ARCH_LOG_LEVEL_INF is not set
# CONFIG_ARCH_LOG_LEVEL_DBG is not set
CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
CONFIG_ARCH_LOG_LEVEL=3
CONFIG_LITTLE_ENDIAN=y
# CONFIG_TRUSTED_EXECUTION_SECURE is not set
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
CONFIG_HW_STACK_PROTECTION=y
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
CONFIG_ISR_TABLES_LOCAL_DECLARATION_SUPPORTED=y
# CONFIG_ISR_TABLES_LOCAL_DECLARATION is not set
# CONFIG_DYNAMIC_INTERRUPTS is not set
# CONFIG_SHARED_INTERRUPTS is not set
CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
# CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
CONFIG_GEN_IRQ_START_VECTOR=0
CONFIG_EXCEPTION_DEBUG=y
# CONFIG_EXTRA_EXCEPTION_INFO is not set
# CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_SUPPORTS_ROM_START=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
CONFIG_CPU_HAS_TEE=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
# CONFIG_MPU_LOG_LEVEL_OFF is not set
# CONFIG_MPU_LOG_LEVEL_ERR is not set
# CONFIG_MPU_LOG_LEVEL_WRN is not set
# CONFIG_MPU_LOG_LEVEL_INF is not set
# CONFIG_MPU_LOG_LEVEL_DBG is not set
CONFIG_MPU_LOG_LEVEL_DEFAULT=y
CONFIG_MPU_LOG_LEVEL=3
CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
CONFIG_MPU_GAP_FILLING=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# CONFIG_CODE_DATA_RELOCATION is not set
# DSP Options
# end of DSP Options
# Floating Point Options
# CONFIG_FPU is not set
# end of Floating Point Options
# Cache Options
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
# CONFIG_ARCH_CPU_IDLE_CUSTOM is not set
# General Kernel Options
# CONFIG_KERNEL_LOG_LEVEL_OFF is not set
# CONFIG_KERNEL_LOG_LEVEL_ERR is not set
# CONFIG_KERNEL_LOG_LEVEL_WRN is not set
# CONFIG_KERNEL_LOG_LEVEL_INF is not set
# CONFIG_KERNEL_LOG_LEVEL_DBG is not set
CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
CONFIG_KERNEL_LOG_LEVEL=3
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=-127
# CONFIG_SCHED_DEADLINE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
# CONFIG_DYNAMIC_THREAD is not set
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Misc Kernel related options
CONFIG_ERRNO=y
# end of Misc Kernel related options
# Kernel Debugging and Metrics
CONFIG_BOOT_DELAY=0
CONFIG_THREAD_MONITOR=y
CONFIG_THREAD_NAME=y
CONFIG_THREAD_MAX_NAME_LEN=32
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# CONFIG_OBJ_CORE is not set
# System Work Queue Options
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of System Work Queue Options
# Barrier Operations
CONFIG_BARRIER_OPERATIONS_ARCH=y
# end of Barrier Operations
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_TIMESLICE_PER_THREAD is not set
# end of Timer API Options
# Other Kernel Object Options
CONFIG_POLL=y
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
# CONFIG_EVENTS is not set
# CONFIG_PIPES is not set
CONFIG_KERNEL_MEM_POOL=y
# CONFIG_HEAP_MEM_POOL_IGNORE_MIN is not set
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
CONFIG_XIP=y
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# Memory Domains
CONFIG_ARCH_MEM_DOMAIN_SUPPORTS_ISOLATED_STACKS=y
CONFIG_MEM_DOMAIN_ISOLATED_STACKS=y
# end of Memory Domains
# SMP Options
CONFIG_MP_NUM_CPUS=1
CONFIG_MP_MAX_NUM_CPUS=1
# CONFIG_TICKET_SPINLOCKS is not set
# end of SMP Options
CONFIG_TICKLESS_KERNEL=y
CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
# CONFIG_THREAD_LOCAL_STORAGE is not set
# end of General Kernel Options
# Device Options
# CONFIG_DEVICE_DEPS is not set
# CONFIG_DEVICE_MUTABLE is not set
# end of Device Options
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Virtual Memory Support
# end of Virtual Memory Support
# Device Drivers
CONFIG_ADC=y
CONFIG_ADC_CONFIGURABLE_INPUTS=y
# CONFIG_ADC_ASYNC is not set
# CONFIG_ADC_LOG_LEVEL_OFF is not set
# CONFIG_ADC_LOG_LEVEL_ERR is not set
# CONFIG_ADC_LOG_LEVEL_WRN is not set
# CONFIG_ADC_LOG_LEVEL_INF is not set
# CONFIG_ADC_LOG_LEVEL_DBG is not set
CONFIG_ADC_LOG_LEVEL_DEFAULT=y
CONFIG_ADC_LOG_LEVEL=3
CONFIG_ADC_NRFX_SAADC=y
# CONFIG_AUDIO is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_BBRAM is not set
# CONFIG_CACHE is not set
# CONFIG_CAN is not set
# CONFIG_CHARGER is not set
CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
# CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
CONFIG_CONSOLE=y
CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
CONFIG_CONSOLE_HAS_DRIVER=y
# CONFIG_CONSOLE_HANDLER is not set
CONFIG_CONSOLE_INIT_PRIORITY=60
CONFIG_UART_CONSOLE=y
# CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
# CONFIG_UART_CONSOLE_MCUMGR is not set
# CONFIG_RAM_CONSOLE is not set
# CONFIG_RTT_CONSOLE is not set
# CONFIG_IPM_CONSOLE_SENDER is not set
# CONFIG_IPM_CONSOLE_RECEIVER is not set
# CONFIG_UART_MCUMGR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
# CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
CONFIG_UART_CONSOLE_LOG_LEVEL=3
# CONFIG_GSM_MUX is not set
# CONFIG_EFI_CONSOLE is not set
# CONFIG_COREDUMP_DEVICE is not set
# CONFIG_COUNTER is not set
# CONFIG_CRYPTO is not set
# CONFIG_DAC is not set
# CONFIG_DAI is not set
# CONFIG_DISK_DRIVERS is not set
# CONFIG_DISPLAY is not set
# CONFIG_DMA is not set
# CONFIG_EDAC is not set
# CONFIG_EEPROM is not set
CONFIG_ENTROPY_GENERATOR=y
# CONFIG_ENTROPY_LOG_LEVEL_OFF is not set
# CONFIG_ENTROPY_LOG_LEVEL_ERR is not set
# CONFIG_ENTROPY_LOG_LEVEL_WRN is not set
# CONFIG_ENTROPY_LOG_LEVEL_INF is not set
# CONFIG_ENTROPY_LOG_LEVEL_DBG is not set
CONFIG_ENTROPY_LOG_LEVEL_DEFAULT=y
CONFIG_ENTROPY_LOG_LEVEL=3
CONFIG_ENTROPY_INIT_PRIORITY=50
CONFIG_ENTROPY_PSA_CRYPTO_RNG=y
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_ESPI is not set
# CONFIG_ETH_DRIVER is not set
CONFIG_FLASH_HAS_DRIVER_ENABLED=y
CONFIG_FLASH_HAS_PAGE_LAYOUT=y
CONFIG_FLASH=y
# CONFIG_FLASH_LOG_LEVEL_OFF is not set
# CONFIG_FLASH_LOG_LEVEL_ERR is not set
# CONFIG_FLASH_LOG_LEVEL_WRN is not set
# CONFIG_FLASH_LOG_LEVEL_INF is not set
# CONFIG_FLASH_LOG_LEVEL_DBG is not set
CONFIG_FLASH_LOG_LEVEL_DEFAULT=y
CONFIG_FLASH_LOG_LEVEL=3
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_INIT_PRIORITY=50
CONFIG_SOC_FLASH_NRF=y
CONFIG_SOC_FLASH_NRF_RADIO_SYNC_NONE=y
# CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE is not set
# CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS is not set
# CONFIG_FPGA is not set
# CONFIG_FUEL_GAUGE is not set
# CONFIG_GNSS is not set
# CONFIG_GPIO_LOG_LEVEL_OFF is not set
# CONFIG_GPIO_LOG_LEVEL_ERR is not set
# CONFIG_GPIO_LOG_LEVEL_WRN is not set
# CONFIG_GPIO_LOG_LEVEL_INF is not set
# CONFIG_GPIO_LOG_LEVEL_DBG is not set
CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
CONFIG_GPIO_LOG_LEVEL=3
CONFIG_GPIO_INIT_PRIORITY=40
# CONFIG_GPIO_GET_DIRECTION is not set
# CONFIG_GPIO_GET_CONFIG is not set
# CONFIG_GPIO_HOGS is not set
# CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRFX_INTERRUPT=y
# CONFIG_HWINFO is not set
# CONFIG_HWSPINLOCK is not set
# CONFIG_I2C_DUMP_MESSAGES is not set
CONFIG_I2C_CALLBACK=y
# CONFIG_I2C_TARGET is not set
CONFIG_I2C_NRFX=y
CONFIG_I2C_NRFX_TWIM=y
CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
# CONFIG_I2C_AMBIQ_DMA is not set
CONFIG_I2C_DMA_TCB_BUFFER_SIZE=1024
CONFIG_I2C_INIT_PRIORITY=50
# CONFIG_I2C_LOG_LEVEL_OFF is not set
# CONFIG_I2C_LOG_LEVEL_ERR is not set
# CONFIG_I2C_LOG_LEVEL_WRN is not set
# CONFIG_I2C_LOG_LEVEL_INF is not set
CONFIG_I2C_LOG_LEVEL_DBG=y
# CONFIG_I2C_LOG_LEVEL_DEFAULT is not set
CONFIG_I2C_LOG_LEVEL=4
# CONFIG_I2S is not set
# CONFIG_I3C is not set
# CONFIG_IEEE802154 is not set
# Interrupt controller drivers
CONFIG_INTC_INIT_PRIORITY=40
# CONFIG_INTC_LOG_LEVEL_OFF is not set
# CONFIG_INTC_LOG_LEVEL_ERR is not set
# CONFIG_INTC_LOG_LEVEL_WRN is not set
# CONFIG_INTC_LOG_LEVEL_INF is not set
# CONFIG_INTC_LOG_LEVEL_DBG is not set
CONFIG_INTC_LOG_LEVEL_DEFAULT=y
CONFIG_INTC_LOG_LEVEL=3
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# CONFIG_INTC_ESP32 is not set
# end of Interrupt controller drivers
# CONFIG_IPM is not set
# CONFIG_KSCAN is not set
# CONFIG_LED is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LORA is not set
# CONFIG_MDIO is not set
# CONFIG_MEMC is not set
# CONFIG_MFD is not set
# CONFIG_MIPI_DBI is not set
# Miscellaneous Drivers
# CONFIG_TIMEAWARE_GPIO is not set
# end of Miscellaneous Drivers
# CONFIG_MM_DRV is not set
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_PECI is not set
CONFIG_PINCTRL=y
# CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
# CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
# CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
# CONFIG_PINCTRL_LOG_LEVEL_INF is not set
# CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
CONFIG_PINCTRL_LOG_LEVEL=3
CONFIG_PINCTRL_STORE_REG=y
# CONFIG_PINCTRL_DYNAMIC is not set
CONFIG_PINCTRL_NRF=y
# CONFIG_PM_CPU_OPS is not set
# CONFIG_POWER_DOMAIN is not set
# CONFIG_PS2 is not set
# CONFIG_PTP_CLOCK is not set
# CONFIG_PWM is not set
# CONFIG_REGULATOR is not set
# CONFIG_RESET is not set
# CONFIG_RETAINED_MEM is not set
# CONFIG_RTC is not set
# CONFIG_SDHC is not set
CONFIG_SERIAL=y
# Capabilities
CONFIG_SERIAL_HAS_DRIVER=y
CONFIG_SERIAL_SUPPORT_ASYNC=y
CONFIG_SERIAL_SUPPORT_INTERRUPT=y
CONFIG_SERIAL_INIT_PRIORITY=50
# CONFIG_UART_LOG_LEVEL_OFF is not set
# CONFIG_UART_LOG_LEVEL_ERR is not set
# CONFIG_UART_LOG_LEVEL_WRN is not set
# CONFIG_UART_LOG_LEVEL_INF is not set
# CONFIG_UART_LOG_LEVEL_DBG is not set
CONFIG_UART_LOG_LEVEL_DEFAULT=y
CONFIG_UART_LOG_LEVEL=3
CONFIG_UART_ASYNC_API=y
# CONFIG_UART_LINE_CTRL is not set
# CONFIG_UART_DRV_CMD is not set
# CONFIG_UART_WIDE_DATA is not set
# CONFIG_UART_PIPE is not set
# CONFIG_UART_ASYNC_RX_HELPER is not set
# Serial Drivers
CONFIG_UART_NRFX=y
CONFIG_UART_NRFX_UARTE=y
CONFIG_UART_NRFX_UARTE_LEGACY_SHIM=y
CONFIG_UART_ASYNC_TX_CACHE_SIZE=8
CONFIG_UART_0_ASYNC=y
CONFIG_UART_0_ENHANCED_POLL_OUT=y
# CONFIG_UART_0_NRF_PARITY_BIT is not set
CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
# CONFIG_UART_0_NRF_HW_ASYNC is not set
# CONFIG_UART_0_NRF_ASYNC_LOW_POWER is not set
CONFIG_UART_1_ASYNC=y
CONFIG_UART_1_ENHANCED_POLL_OUT=y
# CONFIG_UART_1_NRF_PARITY_BIT is not set
CONFIG_UART_1_NRF_TX_BUFFER_SIZE=32
CONFIG_UART_1_NRF_HW_ASYNC=y
# CONFIG_UART_1_NRF_ASYNC_LOW_POWER is not set
CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2
CONFIG_UART_2_ASYNC=y
CONFIG_UART_2_ENHANCED_POLL_OUT=y
# CONFIG_UART_2_NRF_PARITY_BIT is not set
CONFIG_UART_2_NRF_TX_BUFFER_SIZE=32
CONFIG_UART_2_NRF_HW_ASYNC=y
# CONFIG_UART_2_NRF_ASYNC_LOW_POWER is not set
CONFIG_UART_2_NRF_HW_ASYNC_TIMER=1
# CONFIG_SMBUS is not set
# CONFIG_SYSCON is not set
# Timer drivers
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
# CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
# end of Timer drivers
# CONFIG_USB_BC12 is not set
# CONFIG_UDC_DRIVER is not set
# CONFIG_UHC_DRIVER is not set
# CONFIG_UVB is not set
# CONFIG_USB_DEVICE_DRIVER is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_OFF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_ERR is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_WRN is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_INF is not set
# CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DBG is not set
CONFIG_NRF_USBD_COMMON_LOG_LEVEL_DEFAULT=y
CONFIG_NRF_USBD_COMMON_LOG_LEVEL=3
# CONFIG_USBC_TCPC_DRIVER is not set
# CONFIG_USBC_LOG_LEVEL_OFF is not set
# CONFIG_USBC_LOG_LEVEL_ERR is not set
# CONFIG_USBC_LOG_LEVEL_WRN is not set
# CONFIG_USBC_LOG_LEVEL_INF is not set
# CONFIG_USBC_LOG_LEVEL_DBG is not set
CONFIG_USBC_LOG_LEVEL_DEFAULT=y
CONFIG_USBC_LOG_LEVEL=3
# CONFIG_USBC_VBUS_DRIVER is not set
# CONFIG_USBC_PPC_DRIVER is not set
# CONFIG_VIDEO is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_W1 is not set
CONFIG_WATCHDOG=y
# CONFIG_WDT_DISABLE_AT_BOOT is not set
# CONFIG_WDT_LOG_LEVEL_OFF is not set
# CONFIG_WDT_LOG_LEVEL_ERR is not set
# CONFIG_WDT_LOG_LEVEL_WRN is not set
CONFIG_WDT_LOG_LEVEL_INF=y
# CONFIG_WDT_LOG_LEVEL_DBG is not set
# CONFIG_WDT_LOG_LEVEL_DEFAULT is not set
CONFIG_WDT_LOG_LEVEL=3
CONFIG_WDT_NRFX=y
CONFIG_NET_TCP_WORKQ_STACK_SIZE=1024
CONFIG_REQUIRES_FULL_LIBC=y
# CONFIG_REQUIRES_FLOAT_PRINTF is not set
CONFIG_FULL_LIBC_SUPPORTED=y
CONFIG_MINIMAL_LIBC_SUPPORTED=y
CONFIG_NEWLIB_LIBC_SUPPORTED=y
CONFIG_PICOLIBC_SUPPORTED=y
# C Library
# CONFIG_PICOLIBC is not set
CONFIG_NEWLIB_LIBC=y
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_COMMON_LIBC_ABORT=y
# CONFIG_COMMON_LIBC_MALLOC is not set
CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=4096
# CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
# CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
CONFIG_STDOUT_CONSOLE=y
CONFIG_NEED_LIBC_MEM_PARTITION=y
# end of C Library
# C++ Language Support
# CONFIG_CPP is not set
# Deprecated
# CONFIG_CPLUSPLUS is not set
# CONFIG_LIB_CPLUSPLUS is not set
# end of Deprecated
# end of C++ Language Support
CONFIG_CRC=y
# Additional libraries
# Hash Function Support
# CONFIG_SYS_HASH_FUNC32 is not set
# end of Hash Function Support
# Hashmap (Hash Table) Support
# CONFIG_SYS_HASH_MAP is not set
# end of Hashmap (Hash Table) Support
# Heap and Memory Allocation
# CONFIG_SYS_HEAP_VALIDATE is not set
# CONFIG_SYS_HEAP_STRESS is not set
# CONFIG_SYS_HEAP_INFO is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_SYS_HEAP_RUNTIME_STATS is not set
# CONFIG_SYS_HEAP_LISTENER is not set
# CONFIG_SYS_HEAP_SMALL_ONLY is not set
# CONFIG_SYS_HEAP_BIG_ONLY is not set
CONFIG_SYS_HEAP_AUTO=y
# CONFIG_MULTI_HEAP is not set
# CONFIG_SHARED_MULTI_HEAP is not set
# end of Heap and Memory Allocation
# Memory Blocks
# CONFIG_SYS_MEM_BLOCKS is not set
# end of Memory Blocks
# OS Support Library
CONFIG_FDTABLE=y
# CONFIG_PRINTK_SYNC is not set
CONFIG_MPSC_PBUF=y
# CONFIG_SPSC_PBUF is not set
# CONFIG_MPSC_CLEAR_ALLOCATED is not set
CONFIG_REBOOT=y
CONFIG_HAS_POWEROFF=y
# CONFIG_POWEROFF is not set
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
CONFIG_CBPRINTF_FP_SUPPORT=y
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_FP_ALWAYS_A is not set
CONFIG_CBPRINTF_N_SPECIFIER=y
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
# CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
CONFIG_CBPRINTF_CONVERT_CHECK_PTR=y
# end of OS Support Library
# POSIX API Support
# POSIX Options
# CONFIG_POSIX_API is not set
# CONFIG_POSIX_ASYNCHRONOUS_IO is not set
# CONFIG_POSIX_CLOCK is not set
# CONFIG_POSIX_CONFSTR is not set
# CONFIG_POSIX_ENV_LOG_LEVEL_OFF is not set
# CONFIG_POSIX_ENV_LOG_LEVEL_ERR is not set
# CONFIG_POSIX_ENV_LOG_LEVEL_WRN is not set
# CONFIG_POSIX_ENV_LOG_LEVEL_INF is not set
# CONFIG_POSIX_ENV_LOG_LEVEL_DBG is not set
CONFIG_POSIX_ENV_LOG_LEVEL_DEFAULT=y
CONFIG_POSIX_ENV_LOG_LEVEL=3
# CONFIG_EVENTFD is not set
# File descriptor table options
# end of File descriptor table options
# CONFIG_FNMATCH is not set
# CONFIG_GETENTROPY is not set
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_POSIX_NETWORKING is not set
# sem_t support
CONFIG_SEM_VALUE_MAX=32767
CONFIG_SEM_NAMELEN_MAX=16
# end of sem_t support
# Signal support
CONFIG_POSIX_RTSIG_MAX=0
# CONFIG_POSIX_SIGNAL is not set
# end of Signal support
# CONFIG_POSIX_PUTMSG is not set
# Sysconf support
# CONFIG_POSIX_SYSCONF is not set
CONFIG_POSIX_PAGE_SIZE_BITS=6
# end of Sysconf support
# CONFIG_POSIX_SYSLOG is not set
# CONFIG_TIMER is not set
# CONFIG_POSIX_UNAME is not set
# end of POSIX Options
# POSIX Shell Utilities
# end of POSIX Shell Utilities
# end of POSIX API Support
# CONFIG_OPENAMP_RSC_TABLE is not set
# CONFIG_SMF is not set
CONFIG_LIBGCC_RTLIB=y
# Utility Library
# CONFIG_JSON_LIBRARY is not set
# CONFIG_RING_BUFFER is not set
CONFIG_NOTIFY=y
# CONFIG_BASE64 is not set
CONFIG_ONOFF=y
# CONFIG_WINSTREAM is not set
# CONFIG_UTF8 is not set
# end of Utility Library
# end of Additional libraries
# Subsystems and OS Services
# CONFIG_BINDESC is not set
# CONFIG_BT is not set
# Controller Area Network (CAN) bus subsystem
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
CONFIG_DEBUG=y
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
CONFIG_EARLY_CONSOLE=y
# CONFIG_ASSERT is not set
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_ASSERT_TEST is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
CONFIG_DEBUG_THREAD_INFO=y
# CONFIG_DEBUG_COREDUMP is not set
# end of Debugging Options
# CONFIG_MIPI_STP_DECODER is not set
# CONFIG_DISK_ACCESS is not set
# CONFIG_DSP is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# CONFIG_FCB is not set
CONFIG_NVS=y
# CONFIG_NVS_LOOKUP_CACHE is not set
# CONFIG_NVS_DATA_CRC is not set
# CONFIG_NVS_LOG_LEVEL_OFF is not set
# CONFIG_NVS_LOG_LEVEL_ERR is not set
# CONFIG_NVS_LOG_LEVEL_WRN is not set
# CONFIG_NVS_LOG_LEVEL_INF is not set
CONFIG_NVS_LOG_LEVEL_DBG=y
# CONFIG_NVS_LOG_LEVEL_DEFAULT is not set
CONFIG_NVS_LOG_LEVEL=4
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# CONFIG_IPC_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LLEXT is not set
# Linkable loadable Extension Development Kit (EDK)
CONFIG_LLEXT_EDK_NAME="llext-edk"
# CONFIG_LLEXT_EDK_USERSPACE_ONLY is not set
# end of Linkable loadable Extension Development Kit (EDK)
# Logging
CONFIG_LOG=y
CONFIG_LOG_CORE_INIT_PRIORITY=0
CONFIG_LOG_MODE_DEFERRED=y
# CONFIG_LOG_MODE_IMMEDIATE is not set
# CONFIG_LOG_MODE_MINIMAL is not set
# CONFIG_LOG_FRONTEND is not set
# CONFIG_LOG_FRONTEND_OPT_API is not set
# CONFIG_LOG_CUSTOM_HEADER is not set
# CONFIG_LOG_MULTIDOMAIN is not set
# Logging levels filtering
CONFIG_LOG_RUNTIME_FILTERING=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# end of Logging levels filtering
# Processing
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_OVERFLOW=y
# CONFIG_LOG_BLOCK_IN_THREAD is not set
CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=2048
# CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
# CONFIG_LOG_TIMESTAMP_64BIT is not set
# CONFIG_LOG_SPEED is not set
# end of Processing
# Output Formatting
# Prepend non-hexdump log message with function name
# CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
# CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
# end of Prepend non-hexdump log message with function name
# CONFIG_LOG_MIPI_SYST_ENABLE is not set
# CONFIG_LOG_THREAD_ID_PREFIX is not set
# CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
CONFIG_LOG_BACKEND_SHOW_COLOR=y
# CONFIG_LOG_INFO_COLOR_GREEN is not set
CONFIG_LOG_TAG_MAX_LEN=0
CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
# CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
# CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
# end of Output Formatting
# Backends
# CONFIG_LOG_BACKEND_NET is not set
CONFIG_LOG_BACKEND_RTT=y
# CONFIG_LOG_BACKEND_RTT_MODE_DROP is not set
CONFIG_LOG_BACKEND_RTT_MODE_BLOCK=y
# CONFIG_LOG_BACKEND_RTT_MODE_OVERWRITE is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_RTT_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_RTT_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_RTT_OUTPUT_DEFAULT=0
CONFIG_LOG_BACKEND_RTT_OUTPUT_BUFFER_SIZE=16
CONFIG_LOG_BACKEND_RTT_RETRY_CNT=4
CONFIG_LOG_BACKEND_RTT_RETRY_DELAY_MS=5
CONFIG_LOG_BACKEND_RTT_BUFFER=0
CONFIG_LOG_BACKEND_UART=y
# CONFIG_LOG_BACKEND_UART_ASYNC is not set
CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1
CONFIG_LOG_BACKEND_UART_AUTOSTART=y
CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
# CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
# CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set
CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
# CONFIG_LOG_BACKEND_IPC_SERVICE is not set
# end of Backends
# Misc
CONFIG_LOG_DOMAIN_ID=0
CONFIG_LOG_USE_VLA=y
CONFIG_LOG_SIMPLE_MSG_OPTIMIZE=y
# CONFIG_LOG_ALWAYS_RUNTIME is not set
# CONFIG_LOG_FMT_SECTION is not set
# CONFIG_LOG_FMT_STRING_VALIDATE is not set
# CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
# CONFIG_LOG_MEM_UTILIZATION is not set
CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
# end of Misc
CONFIG_LOG_OUTPUT=y
# end of Logging
CONFIG_MEM_ATTR=y
# CONFIG_MEM_ATTR_HEAP is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# CONFIG_MODEM_MODULES is not set
# Networking
CONFIG_NET_BUF=y
# CONFIG_NET_BUF_LOG is not set
# CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
# CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
# CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
# CONFIG_NET_BUF_LOG_LEVEL_INF is not set
# CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
CONFIG_NET_BUF_LOG_LEVEL=3
# CONFIG_NET_BUF_POOL_USAGE is not set
CONFIG_NET_BUF_ALIGNMENT=0
CONFIG_NETWORKING=y
# CONFIG_NET_HOSTNAME_ENABLE is not set
# Link layer options
# CONFIG_NET_L2_DUMMY is not set
# CONFIG_NET_L2_VIRTUAL is not set
# CONFIG_NET_L2_PPP is not set
# CONFIG_NET_L2_IEEE802154 is not set
# CONFIG_NET_L2_OPENTHREAD is not set
# CONFIG_NET_L2_CUSTOM_IEEE802154 is not set
# CONFIG_NET_L2_CANBUS_RAW is not set
# CONFIG_NET_L2_WIFI_MGMT is not set
# CONFIG_NET_L2_WIFI_SHELL is not set
# CONFIG_NET_L2_PTP is not set
# end of Link layer options
# IP stack
CONFIG_NET_IP=y
# CONFIG_NET_NATIVE is not set
# CONFIG_NET_OFFLOAD is not set
CONFIG_NET_OFFLOADING_SUPPORT=y
CONFIG_NET_INIT_PRIO=90
CONFIG_NET_IP_DSCP_ECN=y
CONFIG_NET_IF_MAX_IPV6_COUNT=1
CONFIG_NET_IF_UNICAST_IPV6_ADDR_COUNT=2
CONFIG_NET_IF_MCAST_IPV6_ADDR_COUNT=3
CONFIG_NET_IF_IPV6_PREFIX_COUNT=2
CONFIG_NET_IPV4=y
CONFIG_NET_INITIAL_TTL=64
CONFIG_NET_INITIAL_MCAST_TTL=1
CONFIG_NET_IF_MAX_IPV4_COUNT=1
CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1
CONFIG_NET_IF_MCAST_IPV4_ADDR_COUNT=1
CONFIG_NET_IF_MCAST_IPV4_SOURCE_COUNT=1
# CONFIG_NET_ICMPV4_ACCEPT_BROADCAST is not set
# CONFIG_NET_IPV4_ACCEPT_ZERO_BROADCAST is not set
# CONFIG_NET_IPV4_IGMP is not set
# CONFIG_NET_IPV4_HDR_OPTIONS is not set
# CONFIG_NET_IPV4_FRAGMENT is not set
CONFIG_NET_IPV4_LOG_LEVEL=0
CONFIG_NET_ICMPV4_LOG_LEVEL=0
# CONFIG_NET_SHELL is not set
CONFIG_NET_TC_RX_COUNT=1
# CONFIG_NET_TC_SKIP_FOR_HIGH_PRIO is not set
CONFIG_NET_TC_THREAD_COOPERATIVE=y
# CONFIG_NET_TC_THREAD_PREEMPTIVE is not set
CONFIG_NET_TC_NUM_PRIORITIES=16
# CONFIG_NET_TC_THREAD_PRIO_CUSTOM is not set
CONFIG_NET_TC_MAPPING_STRICT=y
CONFIG_NET_TX_DEFAULT_PRIORITY=1
CONFIG_NET_RX_DEFAULT_PRIORITY=0
# CONFIG_NET_ALLOW_ANY_PRIORITY is not set
CONFIG_NET_IP_ADDR_CHECK=y
CONFIG_NET_MAX_ROUTERS=2
CONFIG_NET_TCP=y
CONFIG_NET_TCP_LOG_LEVEL=0
CONFIG_NET_TCP_WORKER_PRIO=2
CONFIG_NET_TCP_TIME_WAIT_DELAY=1500
CONFIG_NET_TCP_ACK_TIMEOUT=100
CONFIG_NET_TCP_INIT_RETRANSMISSION_TIMEOUT=200
CONFIG_NET_TCP_RANDOMIZED_RTO=y
CONFIG_NET_TCP_RETRY_COUNT=1
CONFIG_NET_TCP_MAX_SEND_WINDOW_SIZE=0
CONFIG_NET_TCP_MAX_RECV_WINDOW_SIZE=0
CONFIG_NET_TCP_RECV_QUEUE_TIMEOUT=2000
CONFIG_NET_TCP_PKT_ALLOC_TIMEOUT=100
CONFIG_NET_TCP_CHECKSUM=y
CONFIG_NET_TCP_FAST_RETRANSMIT=y
CONFIG_NET_TCP_CONGESTION_AVOIDANCE=y
# CONFIG_NET_TCP_KEEPALIVE is not set
CONFIG_NET_TCP_REJECT_CONN_WITH_RST=y
# CONFIG_NET_TEST_PROTOCOL is not set
CONFIG_NET_UDP=y
CONFIG_NET_UDP_CHECKSUM=y
CONFIG_NET_UDP_MISSING_CHECKSUM=y
CONFIG_NET_UDP_LOG_LEVEL=0
CONFIG_NET_MAX_CONN=8
CONFIG_NET_MAX_CONTEXTS=6
# CONFIG_NET_CONTEXT_NET_PKT_POOL is not set
CONFIG_NET_CONTEXT_SYNC_RECV=y
CONFIG_NET_CONTEXT_CHECK=y
# CONFIG_NET_CONTEXT_PRIORITY is not set
# CONFIG_NET_CONTEXT_TXTIME is not set
# CONFIG_NET_CONTEXT_RCVTIMEO is not set
# CONFIG_NET_CONTEXT_SNDTIMEO is not set
# CONFIG_NET_CONTEXT_RCVBUF is not set
# CONFIG_NET_CONTEXT_SNDBUF is not set
CONFIG_NET_CONTEXT_DSCP_ECN=y
CONFIG_NET_CONTEXT_REUSEADDR=y
CONFIG_NET_CONTEXT_REUSEPORT=y
# CONFIG_NET_CONTEXT_RECV_PKTINFO is not set
# CONFIG_NET_TEST is not set
CONFIG_NET_BUF_RX_COUNT=16
CONFIG_NET_BUF_TX_COUNT=16
CONFIG_NET_BUF_FIXED_DATA_SIZE=y
# CONFIG_NET_BUF_VARIABLE_DATA_SIZE is not set
CONFIG_NET_BUF_DATA_SIZE=128
CONFIG_NET_PKT_BUF_USER_DATA_SIZE=4
CONFIG_NET_DEFAULT_IF_FIRST=y
# CONFIG_NET_DEFAULT_IF_UP is not set
CONFIG_NET_INTERFACE_NAME=y
# CONFIG_NET_PROMISCUOUS_MODE is not set
# CONFIG_NET_DISABLE_ICMP_DESTINATION_UNREACHABLE is not set
# Stack usage
# end of Stack usage
# CONFIG_NET_MGMT is not set
# CONFIG_NET_STATISTICS is not set
# CONFIG_NET_LOG is not set
CONFIG_NET_PKT_LOG_LEVEL=0
# CONFIG_NET_DEBUG_NET_PKT_ALLOC is not set
CONFIG_NET_DEBUG_NET_PKT_EXTERNALS=0
# CONFIG_NET_DEBUG_NET_PKT_NON_FRAGILE_ACCESS is not set
CONFIG_NET_CORE_LOG_LEVEL=0
CONFIG_NET_IF_LOG_LEVEL=0
CONFIG_NET_TC_LOG_LEVEL=0
CONFIG_NET_UTILS_LOG_LEVEL=0
CONFIG_NET_CONTEXT_LOG_LEVEL=0
CONFIG_NET_CONN_LOG_LEVEL=0
CONFIG_NET_ROUTE_LOG_LEVEL=0
# end of IP stack
# Network Packet Filtering
# CONFIG_NET_PKT_FILTER is not set
# end of Network Packet Filtering
# Network Protocols
# CONFIG_COAP is not set
# CONFIG_DNS_SD is not set
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LOG_LEVEL=0
CONFIG_MQTT_KEEPALIVE=30
# CONFIG_MQTT_LIB_TLS is not set
# CONFIG_MQTT_LIB_WEBSOCKET is not set
# CONFIG_MQTT_LIB_CUSTOM_TRANSPORT is not set
CONFIG_MQTT_CLEAN_SESSION=y
# CONFIG_MQTT_SN_LIB is not set
# CONFIG_TFTP_LIB is not set
# CONFIG_HTTP_PARSER is not set
# CONFIG_HTTP_PARSER_URL is not set
# CONFIG_HTTP_CLIENT is not set
# CONFIG_HTTP_SERVER is not set
CONFIG_NET_HTTP_LOG_LEVEL=0
CONFIG_NET_HTTP_SERVER_LOG_LEVEL=0
# CONFIG_WEBSOCKET_CLIENT is not set
# CONFIG_LWM2M is not set
# CONFIG_SOCKS is not set
# CONFIG_SNTP is not set
# end of Network Protocols
# Network Libraries
CONFIG_NET_CONFIG_LOG_LEVEL=0
# CONFIG_NET_CONFIG_SETTINGS is not set
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_PRIORITY_DEFAULT=50
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_CONNECT_TIMEOUT=3000
CONFIG_NET_SOCKET_MAX_SEND_WAIT=10000
# CONFIG_NET_SOCKETS_SERVICE is not set
# CONFIG_NET_SOCKETS_SOCKOPT_TLS is not set
CONFIG_NET_SOCKETS_TLS_PRIORITY=45
CONFIG_NET_SOCKETS_TLS_SET_MAX_FRAGMENT_LENGTH=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS_OFFLOAD_PRIORITY=40
# CONFIG_NET_SOCKETS_OFFLOAD_DISPATCHER is not set
# CONFIG_NET_SOCKETS_PACKET is not set
# CONFIG_NET_SOCKETS_CAN is not set
# CONFIG_NET_SOCKETPAIR is not set
CONFIG_NET_SOCKETS_LOG_LEVEL=0
# CONFIG_TLS_CREDENTIALS is not set
# end of Network Libraries
# Network additional services
# CONFIG_NET_CAPTURE is not set
# CONFIG_NET_DHCPV4 is not set
# CONFIG_NET_DHCPV4_SERVER is not set
# CONFIG_NET_DHCPV6 is not set
CONFIG_NET_DHCPV6_DUID_MAX_LEN=22
# CONFIG_NET_TRICKLE is not set
# CONFIG_NET_ZPERF is not set
# end of Network additional services
# CONFIG_NET_CONNECTION_MANAGER is not set
# end of Networking
# Power Management
# CONFIG_PM_DEVICE is not set
# end of Power Management
# Portability
# end of Portability
# Random Number Generators
# CONFIG_TEST_RANDOM_GENERATOR is not set
CONFIG_TIMER_RANDOM_INITIAL_STATE=123456789
CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
# CONFIG_XOSHIRO_RANDOM_GENERATOR is not set
CONFIG_CSPRNG_ENABLED=y
CONFIG_HARDWARE_DEVICE_CS_GENERATOR=y
# CONFIG_CTR_DRBG_CSPRNG_GENERATOR is not set
# end of Random Number Generators
# CONFIG_RTIO is not set
# SD
# CONFIG_MMC_STACK is not set
# CONFIG_SDMMC_STACK is not set
# CONFIG_SDIO_STACK is not set
# end of SD
# CONFIG_SETTINGS is not set
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# Storage
CONFIG_FLASH_MAP=y
# CONFIG_FLASH_AREA_CHECK_INTEGRITY is not set
# CONFIG_FLASH_MAP_LABELS is not set
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_ZTRESS is not set
# CONFIG_TEST is not set
CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
# CONFIG_FORCE_COVERAGE is not set
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# CONFIG_USB_DEVICE_STACK is not set
# CONFIG_USB_DEVICE_STACK_NEXT is not set
# CONFIG_USB_HOST_STACK is not set
# CONFIG_USBC_STACK is not set
# CONFIG_ZBUS is not set
# CONFIG_MODULES is not set
# end of Subsystems and OS Services
CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_GNU_EXTENSIONS=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_USE_DT_CODE_PARTITION is not set
CONFIG_ROM_END_OFFSET=0
CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
CONFIG_LD_LINKER_TEMPLATE=y
# CONFIG_CMAKE_LINKER_GENERATOR is not set
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_KERNEL_ENTRY="__start"
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
# CONFIG_SRAM_VECTOR_TABLE is not set
CONFIG_SRAM_OFFSET=0
# Linker Sections
# CONFIG_LINKER_USE_BOOT_SECTION is not set
# CONFIG_LINKER_USE_PINNED_SECTION is not set
CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
CONFIG_LINKER_LAST_SECTION_ID=y
CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
CONFIG_LINKER_USE_RELAX=y
# end of Linker Sections
CONFIG_LINKER_ITERABLE_SUBALIGN=4
CONFIG_LINKER_DEVNULL_SUPPORT=y
# CONFIG_LINKER_DEVNULL_MEMORY is not set
# end of Linker Options
# Compiler Options
# CONFIG_STD_C90 is not set
CONFIG_STD_C99=y
# CONFIG_STD_C11 is not set
# CONFIG_STD_C17 is not set
# CONFIG_STD_C23 is not set
CONFIG_TOOLCHAIN_SUPPORTS_GNU_EXTENSIONS=y
# CONFIG_GNU_C_EXTENSIONS is not set
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_COMPILER_FREESTANDING is not set
# CONFIG_SIZE_OPTIMIZATIONS is not set
# CONFIG_SPEED_OPTIMIZATIONS is not set
CONFIG_DEBUG_OPTIMIZATIONS=y
# CONFIG_NO_OPTIMIZATIONS is not set
# CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
# CONFIG_COMPILER_SAVE_TEMPS is not set
CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
# CONFIG_FORTIFY_SOURCE_NONE is not set
CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
# CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
CONFIG_COMPILER_OPT=""
# CONFIG_MISRA_SANE is not set
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
# CONFIG_OUTPUT_SYMBOLS is not set
# CONFIG_OUTPUT_DISASSEMBLY is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_BUILD_OUTPUT_COMPRESS_DEBUG_SECTIONS is not set
# CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
# CONFIG_BUILD_ALIGN_LMA is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# CONFIG_BUILD_OUTPUT_META is not set
CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
CONFIG_CHECK_INIT_PRIORITIES=y
# CONFIG_EMIT_ALL_SYSCALLS is not set
# end of Build Options
CONFIG_DEPRECATED=y
CONFIG_WARN_DEPRECATED=y
CONFIG_EXPERIMENTAL=y
CONFIG_ENFORCE_ZEPHYR_STDINT=y
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_BOSSA is not set
# end of Boot Options
Thank you very much.
Martin
