Channel Sounding With Real Time Ranging Fails To Build
Hi, I have cloned the channel sounding with range requestor samples but every time I try to build it I encounter the error:
error: 'RAS_FEAT_REALTIME_RD' undeclared (first use in this function)
  176 |         if (!(ras_feature_bits & RAS_FEAT_REALTIME_RD))
In function 'main':
  593 |         const bool realtime_rd = ras_feature_bits & RAS_FEAT_REALTIME_RD;
warning: implicit declaration of function 'bt_ras_rreq_realtime_rd_subscribe'; did you mean 'bt_ras_rreq_rd_ready_subscribe'? [-Wimplicit-function-declaration]
  596 |                 err = bt_ras_rreq_realtime_rd_subscribe(connection,
[29/360] Building C object zephyr/subsys/bluetooth/host/CMakeFiles/subsys__bluetooth__host.dir/hci_core.c.obj
I have not changed the code or anything, but it just fails to build every time. Any help is appreciated.
Also I am trying to make multiple initiators connect to multiple reflectors, does anyone know if that is possible? Is the hardware powerful enough for that to happen? Because I have modified another sample without real time ranging but every time I try to start the two initiators one of them always says "Tried to parse empty step data", I am not sure if this is software or hardware or how to fix it. Thanks!
    Can you show your build command and provide complete build log?
    Which NCS version do you use?
    Which board do you use?
    Dejan
  • Hi Dejan, this is the complete build log below(I don't know why it did not let me insert the whole thing at once):
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: C:/ncs/toolchains/0b393f9e1b/opt/bin/python.exe (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v3.0.1/zephyr/.cache
    -- Board: nrf54l15dk, qualifiers: nrf54l15/cpuapp
    Parsing c:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/Kconfig.sysbuild
    Loaded configuration 'C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/_sysbuild/empty.conf'
    Merged configuration 'C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/_sysbuild/empty.conf'
    Configuration saved to 'C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/zephyr/.config'
    Kconfig header saved to 'C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/_sysbuild/autoconf.h'
       * Running CMake for channel_sounding_ras_initiator *
    -- Application: C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator
    -- CMake version: 3.21.0
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.1/zephyr)
    -- Found host-tools: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.17.0 (C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/0b393f9e1b/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v3.0.1/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp.dts
    -- Found devicetree overlay: boards/nrf54l15dk_nrf54l15_cpuapp.overlay
    -- Generated zephyr.dts: C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator/zephyr/zephyr.dts
    -- Generated pickled edt: C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator/zephyr/edt.pickle
    -- Generated devicetree_generated.h: C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator/zephyr/include/generated/zephyr/devicetree_generated.h
    -- Including generated dts.cmake file: C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator/zephyr/dts.cmake
    warning: Experimental symbol BT_CS_DE is enabled.
    warning: Experimental symbol BT_CHANNEL_SOUNDING is enabled.
    Parsing C:/ncs/v3.0.1/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v3.0.1/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp_defconfig'
    Merged configuration 'C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/prj.conf'
    Merged configuration 'C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator/zephyr/.config.sysbuild'
    Configuration saved to 'C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator/zephyr/.config'
    Kconfig header saved to 'C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    =========== Generating psa_crypto_config ===============
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Backup: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Backup: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Backup: CONFIG_MBEDTLS_THREADING: False
    Backup: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== Checkpoint: backup ===============
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_SPM: False
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_C: True
    Restore: CONFIG_MBEDTLS_PSA_CRYPTO_KEY_ID_ENCODES_OWNER: False
    Restore: CONFIG_MBEDTLS_PLATFORM_SETUP_TEARDOWN_ALT: False
    Restore: CONFIG_MBEDTLS_THREADING: False
    Restore: CONFIG_MBEDTLS_THREADING_ALT: True
    =========== End psa_crypto_config ===============
    =========== Generating psa_crypto_library_config ===============
    Backup: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Backup: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    Restore: CONFIG_MBEDTLS_USE_PSA_CRYPTO: True
    Restore: CONFIG_MBEDTLS_PLATFORM_PRINTF_ALT: False
    =========== End psa_crypto_library_config ===============
    CMake Warning at C:/ncs/v3.0.1/zephyr/CMakeLists.txt:2180 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator
    -- Configuring done
    -- Generating done
    [4/568] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.0.99 (C:/ncs/v3.0.1/zephyr), build: v4.0.99-ncs1-1
    [178/568] Building C object CMakeFiles/app.dir/src/main.c.obj
    FAILED: CMakeFiles/app.dir/src/main.c.obj
    C:\ncs\toolchains\0b393f9e1b\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DK_HEAP_MEM_POOL_SIZE=512 -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"nrf-psa-crypto-config.h\" -DMBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE=\"nrf-psa-crypto-user-config.h\" -DNRF54L15_XXAA -DNRF_APPLICATION -DNRF_CONFIG_CPU_FREQ_MHZ=128 -DPICOLIBC_DOUBLE_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v3.0.1/nrf/drivers/mpsl/clock_control -IC:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator/zephyr/include/generated/zephyr -IC:/ncs/v3.0.1/zephyr/include -IC:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator/zephyr/include/generated -IC:/ncs/v3.0.1/zephyr/soc/nordic -IC:/ncs/v3.0.1/zephyr/soc/nordic/nrf54l/. -IC:/ncs/v3.0.1/zephyr/soc/nordic/common/. -IC:/ncs/v3.0.1/zephyr/subsys/bluetooth -IC:/ncs/v3.0.1/nrf/include -IC:/ncs/v3.0.1/nrf/lib/multithreading_lock/. -IC:/ncs/v3.0.1/nrf/subsys/bluetooth/controller/. -IC:/ncs/v3.0.1/nrf/tests/include -IC:/ncs/v3.0.1/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v3.0.1/zephyr/modules/cmsis/. -IC:/ncs/v3.0.1/modules/lib/cmsis-dsp/Include -IC:/ncs/v3.0.1/nrf/modules/hal_nordic/. -IC:/ncs/v3.0.1/modules/hal/nordic/nrfx -IC:/ncs/v3.0.1/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v3.0.1/modules/hal/nordic/nrfx/mdk -IC:/ncs/v3.0.1/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v3.0.1/nrfxlib/softdevice_controller/include -IC:/ncs/v3.0.1/nrfxlib/mpsl/fem/common/include -IC:/ncs/v3.0.1/nrfxlib/mpsl/fem/nrf21540_gpio/include -IC:/ncs/v3.0.1/nrfxlib/mpsl/fem/nrf21540_gpio_spi/include -IC:/ncs/v3.0.1/nrfxlib/mpsl/fem/nrf2220/include -IC:/ncs/v3.0.1/nrfxlib/mpsl/fem/nrf2240/include -IC:/ncs/v3.0.1/nrfxlib/mpsl/fem/nrf22xx/include -IC:/ncs/v3.0.1/nrfxlib/mpsl/fem/simple_gpio/include -IC:/ncs/v3.0.1/nrfxlib/mpsl/fem/include -IC:/ncs/v3.0.1/nrfxlib/mpsl/fem/include/protocol -IC:/ncs/v3.0.1/nrfxlib/mpsl/include -IC:/ncs/v3.0.1/nrfxlib/mpsl/include/protocol -IC:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator/generated/library_nrf_security_psa -IC:/ncs/v3.0.1/nrf/subsys/nrf_security/include -IC:/ncs/v3.0.1/modules/crypto/oberon-psa-crypto/oberon/drivers -IC:/ncs/v3.0.1/nrf/subsys/nrf_security/src/threading/include -IC:/ncs/v3.0.1/nrf/subsys/nrf_security/src/utils -IC:/ncs/v3.0.1/nrf/subsys/nrf_security/src/drivers/cracen/common/include -IC:/ncs/v3.0.1/nrf/subsys/nrf_security/src/drivers/cracen/sxsymcrypt/include -IC:/ncs/v3.0.1/nrf/subsys/nrf_security/src/drivers/cracen/sxsymcrypt/src -IC:/ncs/v3.0.1/nrf/subsys/nrf_security/src/drivers/cracen/silexpk/target/baremetal_ba414e_with_ik -IC:/ncs/v3.0.1/nrf/subsys/nrf_security/src/drivers/cracen/silexpk/include -IC:/ncs/v3.0.1/nrf/subsys/nrf_security/src/drivers/cracen/sicrypto/include -IC:/ncs/v3.0.1/nrf/subsys/nrf_security/src/drivers/cracen/cracenpsa/include -IC:/ncs/v3.0.1/modules/crypto/oberon-psa-crypto/include -IC:/ncs/v3.0.1/modules/crypto/oberon-psa-crypto/library -IC:/ncs/v3.0.1/modules/crypto/mbedtls/library -IC:/ncs/v3.0.1/modules/crypto/mbedtls/include -IC:/ncs/v3.0.1/modules/crypto/mbedtls/include/library -isystem C:/ncs/v3.0.1/zephyr/lib/libc/common/include -fno-strict-aliasing -Os -imacros C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/build/channel_sounding_ras_initiator/zephyr/include/generated/zephyr/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -mtp=soft --sysroot=C:/ncs/toolchains/0b393f9e1b/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v3.0.1/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wdouble-promotion -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v3.0.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v3.0.1=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=picolibc.specs -std=c99 -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles\app.dir\src\main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/src/main.c
    C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/src/main.c: In function 'ranging_data_cb':
    C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/src/main.c:176:34: error: 'RAS_FEAT_REALTIME_RD' undeclared (first use in this function)
      176 |         if (!(ras_feature_bits & RAS_FEAT_REALTIME_RD)) {
    C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/src/main.c:176:34: note: each undeclared identifier is reported only once for each function it appears in
    C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/src/main.c: In function 'main':
    C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/src/main.c:593:53: error: 'RAS_FEAT_REALTIME_RD' undeclared (first use in this function)
    C:/sdk-nrf/samples/bluetooth/channel_sounding_ras_initiator/src/main.c:596:23: warning: implicit declaration of function 'bt_ras_rreq_realtime_rd_subscribe'; did you mean 'bt_ras_rreq_rd_ready_subscribe'? [-Wimplicit-function-declaration]
    [185/568] Building C object zephyr/CMakeFiles/zephyr.dir/lib/utils/bitarray.c.obj
    I am using 3.0.1 on the nrf54l15dk. I believe the issue is that it is not able to access the header file, even though the directory in the main.c file is correct and untouched.
    Do you use this channel sounding initiator sample located in nrf/samples/bluetooth/channel_sounding_ras_initiator?
    Can you try to build the same sample using NCS v3.0.0? Do you get the same error?
    Dejan
    I was able to build it after downloading all the zephyr dependencies, where as before I just cloned the repository from Github. Thank you so much.
    Thank you for the update.
    Dejan
