How does the device receive messages from the parent node when it goes into low power?
Hi, the nordic team
I am working on thread protocol using SDK version 2.9.1.
I use the SED device,My poll is 1000 ms. How can I receive messages from my parent node when my SED device goes into low power?
Here is my code to get into low power:
        if (IS_ENABLED(CONFIG_RAM_POWER_DOWN_LIBRARY)) {
		power_down_unused_ram();
        int err;
        k_timer_init(&led_timer, on_led_timer_expiry, on_led_timer_stop);
	k_timer_init(&provisioning_timer, on_provisioning_timer_expiry, NULL);
	k_work_queue_init(&coap_server_workq);
	k_work_queue_start(&coap_server_workq, coap_server_workq_stack_area,
					K_THREAD_STACK_SIZEOF(coap_server_workq_stack_area),
					COAP_SERVER_WORKQ_PRIORITY, NULL);
	k_work_init(&provisioning_work, activate_provisioning);
        if (IS_ENABLED(CONFIG_OPENTHREAD_MTD_SED)) {
		k_work_init(&poll_change_work,
                        into_low_power_sleeply);
        err = ot_coap_init(&deactivate_provisionig, &on_light_request);
        if (err) {
		LOG_ERR("Could not initialize OpenThread CoAP");
		goto end;
        err = dk_leds_init();
        if (err) {
                LOG_ERR("Cannot init LEDs (err: %d)", err);
                goto end;
        err = dk_buttons_init(button_pressed_callback);
        if (err)
                LOG_ERR("Cannot init buttons (err: %d)", err);
                goto end;
            // 点亮 LED1
        dk_set_led_on(OT_CONNECTION_LED);
        err = restore_network_data();
end:
        return 0;
 //改变poll时间,进入低功耗
static void into_low_power_sleeply(struct k_work *item)
        ARG_UNUSED(item);
        otError error;
	otLinkModeConfig mode;
	struct openthread_context *context = openthread_get_default_context();
	__ASSERT_NO_MSG(context != NULL);
	openthread_api_mutex_lock(context);
	mode = otThreadGetLinkMode(context->instance);
	mode.mRxOnWhenIdle = false;
	error = otThreadSetLinkMode(context->instance, mode);
        otLinkSetPollPeriod(context->instance, OT_POLL_PERIOD);
	openthread_api_mutex_unlock(context);
	if (error != OT_ERROR_NONE) {
		LOG_ERR("Failed to set MLE link mode configuration");
#if IS_ENABLED(CONFIG_PM_DEVICE)
	const struct device *cons = DEVICE_DT_GET(DT_CHOSEN(zephyr_console));
	if (!device_is_ready(cons)) {
		return;
        pm_device_action_run(cons, PM_DEVICE_ACTION_SUSPEND);
        dk_set_led_off(OT_CONNECTION_LED);
        dk_set_led_off(PROVISIONING_LED);
        dk_set_led_off(LIGHT_LED);
    Thank you for your reply,I will try.
    this is my config in prj.config:
    # Copyright (c) 2024 Nordic Semiconductor
    # Increase Settings storage size
    CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x8000
    # Enable OpenThread CoAP support API
    CONFIG_OPENTHREAD_COAP=y
    CONFIG_COAP=y
    CONFIG_COAP_UTILS=y
    CONFIG_OPENTHREAD_COAP_OBSERVE=y
    # Network sockets
    CONFIG_NET_SOCKETS=y
    CONFIG_POSIX_API=y
    CONFIG_NET_SOCKETS_POLL_MAX=4
    # Enable OpenThread features set
    CONFIG_NET_L2_OPENTHREAD=y
    # Generic networking options
    CONFIG_NETWORKING=y
    CONFIG_OPENTHREAD_JOINER=y
    CONFIG_LOG=y
    CONFIG_DK_LIBRARY=y
    # Power Manager
    CONFIG_PM_DEVICE=y
    CONFIG_OPENTHREAD_MTD=y
    CONFIG_OPENTHREAD_MTD_SED=y
    CONFIG_OPENTHREAD_POLL_PERIOD=5000
    CONFIG_RAM_POWER_DOWN_LIBRARY=y
    #SHA
    CONFIG_MBEDTLS_SHA1_C=n
